27 Nov 2013, 13:45
zhasha wrote:Are there CAPS LOCK alternatives? Am I blind?
Sight-test:
HONEY/STANDARD        |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD        |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD        |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE|R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE|R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE|R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS        |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS        |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS        |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS/RED    |R3U175 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED    |R3U175 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED    |R3U175S|WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESSISO/BASE|R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE|R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE|R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS125     |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125     |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS125     |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS150     |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150     |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS150     |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY           |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY           |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY           |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE   |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE   |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE   |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/FORTY           |R3U175 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIER        |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER        |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODIFIEREXTRA   |R3U175S|WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U175S|WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIEREXTRA   |R3U175S|WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MOD175          |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD175          |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD175          |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\diamond
HONEY/FUNMOD/BLACK    |R3U175 |WFK (White)|NN (Black) |CONTROL
HONEY/FUNMOD/BLACK    |R3U175S|WFK (White)|NN (Black) |CTRL
HONEY/FUNMOD/BLACK    |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNCTION/RED    |R3U175 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/RETURN175       |R3U175 |WFK (White)|GPA (Gray) |RETURN
HONEY/SHIFT175        |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT175/RED    |R3U175 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT175/BLACK  |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/LOTUS175        |R3U175 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS175S       |R3U175S|WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS175/RED    |R3U175 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS175S/RED   |R3U175S|WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS175/BLACK  |R3U175 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS175S/BLACK |R3U175S|WFK (White)|NN (Black) |\lotuswhiteblack
:cool:
27 Nov 2013, 13:48
Boom! Never doubt the bot.
7bit: you've added a bunch of things lately. Could I have another text dump of the whole Round 5 list please? (Add as a post attachment and you'll even spare people's mobile browsers. Not that I had any trouble either.)
27 Nov 2013, 13:53
Does not work.
SPH/REPAIR            |R3U275 |WV (White) |BFP (Blue) |SHIFT
SPH/REPAIR            |R3U225 |WV (White) |BFP (Blue) |SHIFT
SPH/REPAIR            |R3U225 |WV (White) |BFP (Blue) |RETURN
SPH/REPAIR            |R2U150 |WV (White) |BFP (Blue) |TAB
SPH/REPAIR            |R2U150 |WV (White) |BFP (Blue) |BACK\ \ SPACE
SPH/REPAIR            |R2UJRET|WFK (White)|GPA (Gray) |RETURN
SPH/REPAIR            |R1U200H|WV (White) |BFP (Blue) |BACK\ \ SPACE
SPH/SHIFT225          |R3U225 |WV (White) |BFP (Blue) |SHIFT
SPH/SHIFT275          |R3U275 |WV (White) |BFP (Blue) |SHIFT
SPH/RETURN225         |R3U225 |WV (White) |BFP (Blue) |RETURN
SPH/ISO/RETURN        |R2UJRET|WV (White) |BFP (Blue) |RETURN
SPH/TAB150            |R2U150 |WV (White) |BFP (Blue) |TAB
SPH/BACKSPACE150      |R2U150 |WV (White) |BFP (Blue) |BACK\ \ SPACE
SPH/BACKSPACE200      |R1U200H|WV (White) |BFP (Blue) |BACK\ \ SPACE
HONEY/STANDARD        |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD        |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD        |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD        |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARD        |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/STANDARD        |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STANDARD        |R3U200H|NN (Black) |WFK (White)|0
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|\dot
HONEY/STANDARD        |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/STANDARD        |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|Z
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|X
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|C
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|V
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|B
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|N
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|M
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/STANDARD        |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|1
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|2
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|3
HONEY/STANDARD        |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/STANDARD        |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|A
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|S
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|D
HONEY/STANDARD        |R3U100D|NN (Black) |WFK (White)|F
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|G
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|H
HONEY/STANDARD        |R3U100D|NN (Black) |WFK (White)|J
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|K
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|L
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/STANDARD        |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|4
HONEY/STANDARD        |R3U100D|NN (Black) |WFK (White)|5
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|6
HONEY/STANDARD        |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/STANDARD        |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|Q
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|W
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|E
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|R
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|T
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|Y
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|U
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|I
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|O
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|P
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/STANDARD        |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD        |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARD        |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STANDARD        |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|7
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|8
HONEY/STANDARD        |R2U100 |NN (Black) |WFK (White)|9
HONEY/STANDARD        |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/STANDARD        |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |/
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |STOP
HONEY/STANDARD        |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARD        |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/STANDARD        |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STANDARD        |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/STANDARD        |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/STANDARD        |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/STANDARD        |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARD        |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|F
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|J
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|5
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|0
HONEY/STANDARD        |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD        |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/STANDARD125     |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARD125     |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD125     |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD125     |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD125     |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STANDARD125     |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STANDARD125     |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STANDARD125     |R3U200H|NN (Black) |WFK (White)|0
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|\dot
HONEY/STANDARD125     |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STANDARD125     |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|Z
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|X
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|C
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|V
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|B
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|N
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|M
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/STANDARD125     |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD125     |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|1
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|2
HONEY/STANDARD125     |R4U100 |NN (Black) |WFK (White)|3
HONEY/STANDARD125     |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|A
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|S
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|D
HONEY/STANDARD125     |R3U100D|NN (Black) |WFK (White)|F
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|G
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|H
HONEY/STANDARD125     |R3U100D|NN (Black) |WFK (White)|J
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|K
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|L
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/STANDARD125     |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|4
HONEY/STANDARD125     |R3U100D|NN (Black) |WFK (White)|5
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|6
HONEY/STANDARD125     |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STANDARD125     |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|Q
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|W
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|E
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|R
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|T
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|Y
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|U
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|I
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|O
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|P
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/STANDARD125     |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD125     |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARD125     |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STANDARD125     |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|7
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|8
HONEY/STANDARD125     |R2U100 |NN (Black) |WFK (White)|9
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/STANDARD125     |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/STANDARD125     |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |/
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STANDARD125     |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STANDARD125     |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|F
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|J
HONEY/STANDARD125     |R3U100 |NN (Black) |WFK (White)|5
HONEY/STANDARDISO/BASE|R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE|R3U150 |WFK (White)|GPA (Gray) |META
HONEY/STANDARDISO/BASE|R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARDISO/BASE|R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARDISO/BASE|R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/STANDARDISO/BASE|R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STANDARDISO/BASE|R3U200H|NN (Black) |WFK (White)|0
HONEY/STANDARDISO/BASE|R3U100 |NN (Black) |WFK (White)|\dot
HONEY/STANDARDISO/BASE|R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/STANDARDISO/BASE|R4U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE|R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STANDARDISO/BASE|R4U100 |NN (Black) |WFK (White)|1
HONEY/STANDARDISO/BASE|R4U100 |NN (Black) |WFK (White)|2
HONEY/STANDARDISO/BASE|R4U100 |NN (Black) |WFK (White)|3
HONEY/STANDARDISO/BASE|R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/STANDARDISO/BASE|R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARDISO/BASE|R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/STANDARDISO/BASE|R3U100 |NN (Black) |WFK (White)|4
HONEY/STANDARDISO/BASE|R3U100D|NN (Black) |WFK (White)|5
HONEY/STANDARDISO/BASE|R3U100 |NN (Black) |WFK (White)|6
HONEY/STANDARDISO/BASE|R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/STANDARDISO/BASE|R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STANDARDISO/BASE|R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARDISO/BASE|R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STANDARDISO/BASE|R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STANDARDISO/BASE|R2U100 |NN (Black) |WFK (White)|7
HONEY/STANDARDISO/BASE|R2U100 |NN (Black) |WFK (White)|8
HONEY/STANDARDISO/BASE|R2U100 |NN (Black) |WFK (White)|9
HONEY/STANDARDISO/BASE|R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/STANDARDISO/BASE|R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |/
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |STOP
HONEY/STANDARDISO/BASE|R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARDISO/BASE|R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/STANDARDISO/BASE|R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STANDARDISO/BASE|R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/STANDARDISO/BASE|R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/STANDARDISO/BASE|R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |META
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARDISO/BASE|R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARDISO/BASE|R3U100 |NN (Black) |WFK (White)|5
HONEY/STANDARDISO/BASE|R3U100 |NN (Black) |WFK (White)|0
HONEY/STD125ISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STD125ISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STD125ISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STD125ISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STD125ISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/STD125ISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STD125ISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STD125ISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STD125ISO/BASE  |R3U200H|NN (Black) |WFK (White)|0
HONEY/STD125ISO/BASE  |R3U100 |NN (Black) |WFK (White)|\dot
HONEY/STD125ISO/BASE  |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STD125ISO/BASE  |R4U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STD125ISO/BASE  |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STD125ISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STD125ISO/BASE  |R4U100 |NN (Black) |WFK (White)|1
HONEY/STD125ISO/BASE  |R4U100 |NN (Black) |WFK (White)|2
HONEY/STD125ISO/BASE  |R4U100 |NN (Black) |WFK (White)|3
HONEY/STD125ISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STD125ISO/BASE  |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/STD125ISO/BASE  |R3U100 |NN (Black) |WFK (White)|4
HONEY/STD125ISO/BASE  |R3U100D|NN (Black) |WFK (White)|5
HONEY/STD125ISO/BASE  |R3U100 |NN (Black) |WFK (White)|6
HONEY/STD125ISO/BASE  |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STD125ISO/BASE  |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STD125ISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STD125ISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STD125ISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STD125ISO/BASE  |R2U100 |NN (Black) |WFK (White)|7
HONEY/STD125ISO/BASE  |R2U100 |NN (Black) |WFK (White)|8
HONEY/STD125ISO/BASE  |R2U100 |NN (Black) |WFK (White)|9
HONEY/STD125ISO/BASE  |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |/
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STD125ISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STD125ISO/BASE  |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STD125ISO/BASE  |R3U100 |NN (Black) |WFK (White)|5
HONEY/TENKLESS        |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS        |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS        |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS        |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS        |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/TENKLESS        |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESS        |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS        |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESS        |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|D
HONEY/TENKLESS        |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS        |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|L
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS        |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESS        |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS        |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS        |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS        |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS        |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESS        |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS        |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESS        |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS        |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS        |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESS        |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/TENKLESS        |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESS        |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS        |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS        |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|F
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|J
HONEY/TENKLESS        |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS        |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/TENKLESS/RED    |R3U150 |WFK (White)|RAS (Red)  |ALT
HONEY/TENKLESS/RED    |R3U150 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED    |R3U150 |WFK (White)|RAS (Red)  |SUPER
HONEY/TENKLESS/RED    |R3U150 |WFK (White)|RAS (Red)  |META
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TENKLESS/RED    |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/TENKLESS/RED    |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/TENKLESS/RED    |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TENKLESS/RED    |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/TENKLESS/RED    |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/TENKLESS/RED    |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/TENKLESS/RED    |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/TENKLESS/RED    |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/TENKLESS/RED    |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TENKLESS/RED    |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/TENKLESS/RED    |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TENKLESS/RED    |R2U150 |WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TENKLESS/RED    |R3U175S|WFK (White)|RAS (Red)  |CAPS,LOCK
HONEY/TENKLESS/RED    |R3U200H|WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |FN
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |MENU
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |WIN
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |OPTION
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |COMMAND
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TENKLESS/RED    |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |BACK,SPACE
HONEY/TENKLESS/RED    |R1U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |CTRL
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |META
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |SUPER
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |FN
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/TENKLESS/RED    |R3U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TENKLESSISO/BASE|R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE|R3U150 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESSISO/BASE|R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESSISO/BASE|R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESSISO/BASE|R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/TENKLESSISO/BASE|R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE|R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESSISO/BASE|R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESSISO/BASE|R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESSISO/BASE|R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESSISO/BASE|R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESSISO/BASE|R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESSISO/BASE|R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESSISO/BASE|R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESSISO/BASE|R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESSISO/BASE|R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESSISO/BASE|R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESSISO/BASE|R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/TENKLESSISO/BASE|R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESSISO/BASE|R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS125     |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS125     |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS125     |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS125     |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS125     |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESS125     |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESS125     |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESS125     |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS125     |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS125     |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125     |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESS125     |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|D
HONEY/TENKLESS125     |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS125     |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|L
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS125     |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESS125     |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS125     |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS125     |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS125     |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS125     |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESS125     |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS125     |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESS125     |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS125     |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS125     |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESS125     |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESS125     |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS125     |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|F
HONEY/TENKLESS125     |R3U100 |NN (Black) |WFK (White)|J
HONEY/TENKLESS150     |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150     |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS150     |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150     |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS150     |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESS150     |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS150     |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS150     |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESS150     |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|D
HONEY/TENKLESS150     |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS150     |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|L
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS150     |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESS150     |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS150     |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS150     |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS150     |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS150     |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESS150     |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS150     |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESS150     |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS150     |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS150     |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESS150     |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESS150     |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS150     |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS150     |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|F
HONEY/TENKLESS150     |R3U100 |NN (Black) |WFK (White)|J
HONEY/TKL             |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TKL             |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TKL             |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TKL             |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TKL             |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TKL             |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TKL             |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TKL             |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|X
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|C
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|V
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|B
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|N
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|M
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TKL             |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TKL             |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL             |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TKL             |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|A
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|S
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|D
HONEY/TKL             |R3U100D|NN (Black) |WFK (White)|F
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|G
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|H
HONEY/TKL             |R3U100D|NN (Black) |WFK (White)|J
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|K
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|L
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TKL             |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TKL             |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TKL             |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|W
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|E
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|R
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|T
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|U
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|I
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|O
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|P
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TKL             |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TKL             |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TKL             |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TKL             |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TKL             |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TKL             |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TKL             |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TKL             |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TKL/RED         |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TKL/RED         |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TKL/RED         |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TKL/RED         |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TKL/RED         |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/TKL/RED         |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/TKL/RED         |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TKL/RED         |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/TKL/RED         |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/TKL/RED         |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/TKL/RED         |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/TKL/RED         |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/TKL/RED         |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/TKL/RED         |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TKL/RED         |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/TKL/RED         |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TKL/RED         |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TKL/BLACK       |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKL/BLACK       |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKL/BLACK       |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKL/BLACK       |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKL/BLACK       |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKL/BLACK       |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKL/BLACK       |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKL/BLACK       |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/TKL/BLACK       |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/TKL/BLACK       |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BLACK       |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKL/BLACK       |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/TKL/BLACK       |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/TKL/BLACK       |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/TKL/BLACK       |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/TKL/BLACK       |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TKL/BLACK       |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/TKL/BLACK       |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/TKL/BLACK       |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TKL/BLACK       |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKL/BLACK       |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKL/BLACK       |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/TKL/BLACK       |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/TKL/BLACK       |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKL/BLACK       |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TKL/BASE        |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TKL/BASE        |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TKL/BASE        |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TKL/BASE        |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TKL/BASE        |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TKL/BASE        |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TKL/BASE        |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TKL/BASE        |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL/BASE        |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL/BASE        |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TKL/BASE        |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TKL/BASE        |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TKL/BASE        |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TKL/BASE        |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TKL/BASE        |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TKL/BASE        |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TKL/BASE        |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TKL/BASE        |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TKL/BASE/BLACK  |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKL/BASE/BLACK  |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKL/BASE/BLACK  |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKL/BASE/BLACK  |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKL/BASE/BLACK  |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKL/BASE/BLACK  |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKL/BASE/BLACK  |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKL/BASE/BLACK  |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BASE/BLACK  |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BASE/BLACK  |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKL/BASE/BLACK  |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKL/BASE/BLACK  |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TKL/BASE/BLACK  |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKL/BASE/BLACK  |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKL/BASE/BLACK  |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKL/BASE/BLACK  |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKL/BASE/BLACK  |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKL/BASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TKL/BASE/RED    |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TKL/BASE/RED    |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TKL/BASE/RED    |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TKL/BASE/RED    |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TKL/BASE/RED    |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TKL/BASE/RED    |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TKL/BASE/RED    |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TKL/BASE/RED    |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/BASE/RED    |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/BASE/RED    |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TKL/BASE/RED    |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TKL/BASE/RED    |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/TKL/BASE/RED    |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TKL/BASE/RED    |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TKL/BASE/RED    |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TKL/BASE/RED    |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TKL/BASE/RED    |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TKL/BASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TKLISOBASE      |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TKLISOBASE      |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TKLISOBASE      |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TKLISOBASE      |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TKLISOBASE      |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/TKLISOBASE      |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TKLISOBASE      |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TKLISOBASE      |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TKLISOBASE      |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKLISOBASE      |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKLISOBASE      |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TKLISOBASE      |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TKLISOBASE      |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/TKLISOBASE      |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TKLISOBASE      |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TKLISOBASE      |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TKLISOBASE      |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TKLISOBASE      |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TKLISOBASE      |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TKLISOBASE/RED  |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TKLISOBASE/RED  |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TKLISOBASE/RED  |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TKLISOBASE/RED  |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TKLISOBASE/RED  |R3U125 |WFK (White)|RAS (Red)  |ALT\ \ GR
HONEY/TKLISOBASE/RED  |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TKLISOBASE/RED  |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TKLISOBASE/RED  |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TKLISOBASE/RED  |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKLISOBASE/RED  |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKLISOBASE/RED  |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TKLISOBASE/RED  |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TKLISOBASE/RED  |R2UJRET|WFK (White)|RAS (Red)  |RETURN
HONEY/TKLISOBASE/RED  |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TKLISOBASE/RED  |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TKLISOBASE/RED  |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TKLISOBASE/RED  |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TKLISOBASE/RED  |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TKLISOBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TKLISOBASE/BLACK|R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKLISOBASE/BLACK|R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKLISOBASE/BLACK|R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKLISOBASE/BLACK|R3U125 |WFK (White)|NN (Black) |META
HONEY/TKLISOBASE/BLACK|R3U125 |WFK (White)|NN (Black) |ALT\ \ GR
HONEY/TKLISOBASE/BLACK|R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKLISOBASE/BLACK|R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKLISOBASE/BLACK|R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKLISOBASE/BLACK|R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/TKLISOBASE/BLACK|R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKLISOBASE/BLACK|R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKLISOBASE/BLACK|R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKLISOBASE/BLACK|R2UJRET|WFK (White)|NN (Black) |RETURN
HONEY/TKLISOBASE/BLACK|R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKLISOBASE/BLACK|R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKLISOBASE/BLACK|R2U100 |WFK (White)|NN (Black) |END
HONEY/TKLISOBASE/BLACK|R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKLISOBASE/BLACK|R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKLISOBASE/BLACK|R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |FUN
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/SIXTY           |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|Z
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|X
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|C
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|V
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|B
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|N
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|M
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/SIXTY           |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY           |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|A
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|S
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|D
HONEY/SIXTY           |R3U100D|NN (Black) |WFK (White)|F
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|G
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|H
HONEY/SIXTY           |R3U100D|NN (Black) |WFK (White)|J
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|K
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|L
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/SIXTY           |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/SIXTY           |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|Q
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|W
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|E
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|R
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|T
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|Y
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|U
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|I
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|O
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|P
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/SIXTY           |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/SIXTY           |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/SIXTY           |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/SIXTY           |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/SIXTY           |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/SIXTY           |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/SIXTY           |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/SIXTY           |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/SIXTY           |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTY           |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/SIXTY           |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/SIXTY           |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/SIXTY           |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY           |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY           |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY           |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|F
HONEY/SIXTY           |R3U100 |NN (Black) |WFK (White)|J
HONEY/SIXTY           |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTY           |R3U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |FUN
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/SIXTYISO/BASE   |R4U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE   |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE   |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTYISO/BASE   |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/SIXTYISO/BASE   |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/SIXTYISO/BASE   |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SIXTYISO/BASE   |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/SIXTYISO/BASE   |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/SIXTYISO/BASE   |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTYISO/BASE   |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/SIXTYISO/BASE   |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/SIXTYISO/BASE   |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/SIXTYISO/BASE   |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE   |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE   |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE   |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/SIXTYISO/BASE   |R3U100 |NN (Black) |WFK (White)|F
HONEY/SIXTYISO/BASE   |R3U100 |NN (Black) |WFK (White)|J
HONEY/SIXTYISO/BASE   |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/FORTY           |R3U125 |WFK (White)|GPA (Gray) |CTRL
HONEY/FORTY           |R3U100 |WFK (White)|GPA (Gray) |WIN
HONEY/FORTY           |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/FORTY           |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/FORTY           |R4U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|Z
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|X
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|C
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|V
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|B
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|N
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|M
HONEY/FORTY           |R4U100 |NN (Black) |WFK (White)|\cdot
HONEY/FORTY           |R4U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FORTY           |R4U100 |WFK (White)|GPA (Gray) |FN
HONEY/FORTY           |R3U125 |WFK (White)|GPA (Gray) |TAB
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|A
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|S
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|D
HONEY/FORTY           |R3U100D|NN (Black) |WFK (White)|F
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|G
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|H
HONEY/FORTY           |R3U100D|NN (Black) |WFK (White)|J
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|K
HONEY/FORTY           |R3U100 |NN (Black) |WFK (White)|L
HONEY/FORTY           |R3U175 |WFK (White)|GPA (Gray) |RETURN
HONEY/FORTY           |R2U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|Q
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|W
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|E
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|R
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|T
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|Y
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|U
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|I
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|O
HONEY/FORTY           |R2U100 |NN (Black) |WFK (White)|P
HONEY/FORTY           |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/ERGO            |R1U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGO            |R1U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ERGO/R3         |R3U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGO/R3         |R3U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|Z
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|X
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|C
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|V
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|B
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|N
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|M
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/ALPHA           |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|A
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|S
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|D
HONEY/ALPHA           |R3U100D|NN (Black) |WFK (White)|F
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|G
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|H
HONEY/ALPHA           |R3U100D|NN (Black) |WFK (White)|J
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|K
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|L
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|F
HONEY/ALPHA           |R3U100 |NN (Black) |WFK (White)|J
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|Q
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|W
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|E
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|R
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|T
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|Y
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|U
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|I
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|O
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|P
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/ALPHA           |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/ALPHA           |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/ALPHA           |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/ALPHA/RED       |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/ALPHA/RED       |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/ALPHA/RED       |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/ALPHA/RED       |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/ALPHA/RED       |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/ALPHA/RED       |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/ALPHA/RED       |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|Z
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|X
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|C
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|V
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|B
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|N
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|M
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/ALPHAUK         |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|A
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|S
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|D
HONEY/ALPHAUK         |R3U100D|NN (Black) |WFK (White)|F
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|G
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|H
HONEY/ALPHAUK         |R3U100D|NN (Black) |WFK (White)|J
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|K
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|L
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|\at,\quote
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|\tilde,\#
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|F
HONEY/ALPHAUK         |R3U100 |NN (Black) |WFK (White)|J
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|Q
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|W
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|E
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|R
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|T
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|Y
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|U
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|I
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|O
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|P
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/ALPHAUK         |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\neg,\backprime,\splitvert
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/ALPHAUK         |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/ALPHAUK/RED     |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/ALPHAUK/RED     |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/ALPHAUK/RED     |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |\at,\quote
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |\tilde,\#
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/ALPHAUK/RED     |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/ALPHAUK/RED     |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\neg,\backprime,\splitvert
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\doublequote,2
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\pound,3
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/ALPHAUK/RED     |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|Z
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|X
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|C
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|V
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|B
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|N
HONEY/ALPHAINT        |R4U100 |NN (Black) |WFK (White)|M
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|A
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|S
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|D
HONEY/ALPHAINT        |R3U100D|NN (Black) |WFK (White)|F
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|G
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|H
HONEY/ALPHAINT        |R3U100D|NN (Black) |WFK (White)|J
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|K
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|L
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|F
HONEY/ALPHAINT        |R3U100 |NN (Black) |WFK (White)|J
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|Q
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|W
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|E
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|R
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|T
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|Y
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|U
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|I
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|O
HONEY/ALPHAINT        |R2U100 |NN (Black) |WFK (White)|P
HONEY/ALPHAINT        |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/ALPHAINT        |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/ALPHAINT        |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/ALPHAINT/RED    |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/ALPHAINT/RED    |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/ALPHAINT/RED    |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/ALPHAINT/RED    |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/ALPHAINT/RED    |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/ALPHAINT/RED    |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/ALPHAINT/RED    |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/ALPHAINT/RED    |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\vert
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\backslash
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|Y
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/INTER           |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\"A
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\O
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\AE
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\prime,\#
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\c{c},\`o,\at
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|o,\`a,\#
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\sect,\`u
HONEY/INTER           |R3U100 |NN (Black) |WFK (White)|\wedge,\tilde
HONEY/INTER           |R2U100 |NN (Black) |WFK (White)|\"U
HONEY/INTER           |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/INTER           |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/INTER           |R2U100 |NN (Black) |WFK (White)|\'e,\`e,\openbra
HONEY/INTER           |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\closebra
HONEY/INTER           |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\tilde
HONEY/INTER           |R2U150 |NN (Black) |WFK (White)|\ast,\quote
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\slash,7
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\openparen,8
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\closeparen,9
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\equal,0
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\backprime,\prime
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\backprime,\backslash,\prime
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\backprime,\vert,\prime
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\powertwo
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\S,3,\powerthree
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|?,\ss,\backslash
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|?,\plus,\backslash
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|?,\textquotesingle
HONEY/INTER           |R1U100 |WFK (White)|GPA (Gray) |\circ,\wedge
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\circ,\wedge
HONEY/INTER           |R1U100 |WFK (White)|GPA (Gray) |\onehalf,\sect
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\onehalf,\sect
HONEY/INTER           |R1U100 |WFK (White)|GPA (Gray) |\sect,\onehalf
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\sect,\onehalf
HONEY/INTER           |R1U100 |WFK (White)|GPA (Gray) |\sect,\vert
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\sect,\vert
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\wedge,\`i
HONEY/INTER           |R1U100 |NN (Black) |WFK (White)|\prime,\hash
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt,\vert
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt,\backslash
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |Y
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |\semicolon,\comma
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |\colon,\period
HONEY/INTER/RED       |R4U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/INTER/RED       |R3U100 |WFK (White)|RAS (Red)  |\"O
HONEY/INTER/RED       |R3U100 |WFK (White)|RAS (Red)  |\O
HONEY/INTER/RED       |R3U100 |WFK (White)|RAS (Red)  |\"A
HONEY/INTER/RED       |R3U100 |WFK (White)|RAS (Red)  |\AE
HONEY/INTER/RED       |R3U100 |WFK (White)|RAS (Red)  |\ast,\quote
HONEY/INTER/RED       |R3U100 |WFK (White)|RAS (Red)  |\prime,\#
HONEY/INTER/RED       |R2U100 |WFK (White)|RAS (Red)  |\"U
HONEY/INTER/RED       |R2U100 |WFK (White)|RAS (Red)  |\swedA
HONEY/INTER/RED       |R2U100 |WFK (White)|RAS (Red)  |\wedge,\dieresis,\sim
HONEY/INTER/RED       |R2U100 |WFK (White)|RAS (Red)  |\ast,\plus,\tilde
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\doublequote,2,\at
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\doublequote,2,\powertwo
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\#,3,\pound
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\S,3,\powerthree
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\textcurrency,4,\$
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\&,6
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\slash,7,\opencur
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\openparen,8,\openbra
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\closeparen,9,\closebra
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\equal,0,\closecur
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\onehalf,\sect
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\sect,\onehalf
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\sect,\vert
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\circ,\wedge
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |?,\plus,\backslash
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |?,\ss,\backslash
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\backprime,\prime
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\backprime,\vert,\prime
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\backprime,\backslash,\prime
HONEY/INTER/RED       |R1U100 |WFK (White)|RAS (Red)  |\prime,\#
HONEY/DE              |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\vert
HONEY/DE              |R4U100 |NN (Black) |WFK (White)|Y
HONEY/DE              |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/DE              |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/DE              |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/DE              |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/DE              |R3U100 |NN (Black) |WFK (White)|\"A
HONEY/DE              |R3U100 |NN (Black) |WFK (White)|\prime,\#
HONEY/DE              |R2U100 |NN (Black) |WFK (White)|\"U
HONEY/DE              |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\tilde
HONEY/DE              |R1U100 |WFK (White)|GPA (Gray) |\circ,\wedge
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\circ,\wedge
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\powertwo
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\S,3,\powerthree
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|?,\ss,\backslash
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\backprime,\prime
HONEY/DE              |R1U100 |NN (Black) |WFK (White)|\prime,\#
HONEY/DK              |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\backslash
HONEY/DK              |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/DK              |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/DK              |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/DK              |R3U100 |NN (Black) |WFK (White)|\AE
HONEY/DK              |R3U100 |NN (Black) |WFK (White)|\O
HONEY/DK              |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/DK              |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/DK              |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/DK              |R1U100 |WFK (White)|GPA (Gray) |\sect,\onehalf
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\sect,\onehalf
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|?,\plus
HONEY/DK              |R1U100 |NN (Black) |WFK (White)|\backprime,\vert,\prime
HONEY/NO              |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/NO              |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/NO              |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/NO              |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/NO              |R3U100 |NN (Black) |WFK (White)|\AE
HONEY/NO              |R3U100 |NN (Black) |WFK (White)|\O
HONEY/NO              |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/NO              |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/NO              |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/NO              |R1U100 |WFK (White)|GPA (Gray) |\sect,\vert
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\sect,\vert
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|?,\plus
HONEY/NO              |R1U100 |NN (Black) |WFK (White)|\backprime,\backslash,\prime
HONEY/SE              |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\vert
HONEY/SE              |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/SE              |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/SE              |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/SE              |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/SE              |R3U100 |NN (Black) |WFK (White)|\"A
HONEY/SE              |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/SE              |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/SE              |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/SE              |R1U100 |WFK (White)|GPA (Gray) |\onehalf,\sect
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\onehalf,\sect
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|?,\plus,\backslash
HONEY/SE              |R1U100 |NN (Black) |WFK (White)|\backprime,\prime
HONEY/IT              |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/IT              |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/IT              |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/IT              |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/IT              |R3U100 |NN (Black) |WFK (White)|\c{c},\`o,\at
HONEY/IT              |R3U100 |NN (Black) |WFK (White)|o,\`a,\#
HONEY/IT              |R3U100 |NN (Black) |WFK (White)|\sect,\`u
HONEY/IT              |R2U100 |NN (Black) |WFK (White)|\'e,\`e,\openbra
HONEY/IT              |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\closebra
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\slash,7
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\openparen,8
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\closeparen,9
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\equal,0
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|?,\textquotesingle
HONEY/IT              |R1U100 |NN (Black) |WFK (White)|\wedge,\`i
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|W
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|?,\comma
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|\period,\semicolon
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|\slash,\colon
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|\sect,!
HONEY/FR              |R4U100 |NN (Black) |WFK (White)|\mu,\ast
HONEY/FR              |R3U100 |NN (Black) |WFK (White)|Q
HONEY/FR              |R3U100 |NN (Black) |WFK (White)|M
HONEY/FR              |R3U100 |NN (Black) |WFK (White)|\%,\`U
HONEY/FR              |R3U100 |NN (Black) |WFK (White)|\mu,\ast
HONEY/FR              |R2U100 |NN (Black) |WFK (White)|A
HONEY/FR              |R2U100 |NN (Black) |WFK (White)|\dieresis,\wedge
HONEY/FR              |R2U100 |NN (Black) |WFK (White)|\pounds,\$,\textcurrency
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|\ph,\powertwo
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|1,\&
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|2,\'e,\tilde
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|3,\doublequote,\hash
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|4,\quote,\opencur
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|5,\openparen,\openbra
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|6,\minus,\splitvert
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|7,\`e,\backprime
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|8,\underscore,\backslash
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|9,\ccedile,\wedge
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|0,\gravea,\at
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|\circ,\closeparen,\closebra
HONEY/FR              |R1U100 |NN (Black) |WFK (White)|\plus,\equal,\closecur
HONEY/UK              |R4U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/UK              |R3U100 |NN (Black) |WFK (White)|\at,\quote
HONEY/UK              |R3U100 |NN (Black) |WFK (White)|\tilde,\#
HONEY/UK              |R1U100 |NN (Black) |WFK (White)|\neg,\backprime,\splitvert
HONEY/UK              |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/UK              |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/UK/RED          |R4U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/UK/RED          |R3U100 |WFK (White)|RAS (Red)  |\at,\quote
HONEY/UK/RED          |R3U100 |WFK (White)|RAS (Red)  |\tilde,\#
HONEY/UK/RED          |R1U100 |WFK (White)|RAS (Red)  |\neg,\backprime,\splitvert
HONEY/UK/RED          |R1U100 |WFK (White)|RAS (Red)  |\doublequote,2
HONEY/UK/RED          |R1U100 |WFK (White)|RAS (Red)  |\pound,3
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|\^E
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|\`A
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|Y
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|K
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|?,\prime
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|Q
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|G
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|H
HONEY/BEPO            |R4U100 |NN (Black) |WFK (White)|F
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|U
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|I
HONEY/BEPO            |R3U100D|NN (Black) |WFK (White)|E
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|C
HONEY/BEPO            |R3U100D|NN (Black) |WFK (White)|T
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|R
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|N
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|M
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|\Ccedile
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|E
HONEY/BEPO            |R3U100 |NN (Black) |WFK (White)|T
HONEY/BEPO            |R2U150 |NN (Black) |WFK (White)|\bepoccedile,\ph
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|B
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|\'E
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|\`E
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|!,\wedge
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|V
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|D
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|L
HONEY/BEPO            |R2U100 |NN (Black) |WFK (White)|J
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|\hash,\$
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|1,\doublequote
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|2,\ll
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|3,\gg
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|4,\openparen
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|5,\closeparen
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|6,\at
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|7,\plus
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|8,\minus
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|9,\slash
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|0,\ast
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|\circ,\equal
HONEY/BEPO            |R1U100 |NN (Black) |WFK (White)|\backprime,\mod
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|\^E
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|\`A
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|Y
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|X
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|K
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|?,\prime
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|Q
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|G
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|H
HONEY/BEPOALPHA       |R4U100 |NN (Black) |WFK (White)|F
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|A
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|U
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|I
HONEY/BEPOALPHA       |R3U100D|NN (Black) |WFK (White)|E
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|C
HONEY/BEPOALPHA       |R3U100D|NN (Black) |WFK (White)|T
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|S
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|R
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|N
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|M
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|\Ccedile
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|E
HONEY/BEPOALPHA       |R3U100 |NN (Black) |WFK (White)|T
HONEY/BEPOALPHA       |R2U150 |NN (Black) |WFK (White)|\bepoccedile,\ph
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|B
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|\'E
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|P
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|O
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|\`E
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|!,\wedge
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|V
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|D
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|L
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|J
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|Z
HONEY/BEPOALPHA       |R2U100 |NN (Black) |WFK (White)|W
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|\hash,\$
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|1,\doublequote
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|2,\ll
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|3,\gg
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|4,\openparen
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|5,\closeparen
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|6,\at
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|7,\plus
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|8,\minus
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|9,\slash
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|0,\ast
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|\circ,\equal
HONEY/BEPOALPHA       |R1U100 |NN (Black) |WFK (White)|\backprime,\mod
HONEY/COLEMAK         |R4U100 |NN (Black) |WFK (White)|K
HONEY/COLEMAK         |R3U100 |NN (Black) |WFK (White)|R
HONEY/COLEMAK         |R3U100D|NN (Black) |WFK (White)|T
HONEY/COLEMAK         |R3U100D|NN (Black) |WFK (White)|N
HONEY/COLEMAK         |R3U100 |NN (Black) |WFK (White)|E
HONEY/COLEMAK         |R3U100 |NN (Black) |WFK (White)|I
HONEY/COLEMAK         |R3U100 |NN (Black) |WFK (White)|O
HONEY/COLEMAK         |R3U100 |NN (Black) |WFK (White)|T
HONEY/COLEMAK         |R3U100 |NN (Black) |WFK (White)|N
HONEY/COLEMAK         |R2U100 |NN (Black) |WFK (White)|F
HONEY/COLEMAK         |R2U100 |NN (Black) |WFK (White)|G
HONEY/COLEMAK         |R2U100 |NN (Black) |WFK (White)|J
HONEY/COLEMAK         |R2U100 |NN (Black) |WFK (White)|L
HONEY/COLEMAK         |R2U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/DVORAK          |R4U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/DVORAK          |R4U100 |NN (Black) |WFK (White)|Q
HONEY/DVORAK          |R4U100 |NN (Black) |WFK (White)|J
HONEY/DVORAK          |R4U100 |NN (Black) |WFK (White)|K
HONEY/DVORAK          |R4U100 |NN (Black) |WFK (White)|W
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|O
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|E
HONEY/DVORAK          |R3U100D|NN (Black) |WFK (White)|U
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|I
HONEY/DVORAK          |R3U100D|NN (Black) |WFK (White)|H
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|T
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|N
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|U
HONEY/DVORAK          |R3U100 |NN (Black) |WFK (White)|H
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|F
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|G
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|C
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|L
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|?,\slash
HONEY/DVORAK          |R2U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/DVORAK          |R1U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/DVORAK          |R1U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/ISO             |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/ISO             |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/ISO             |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/ISO             |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/ISO/RED         |R3U125 |WFK (White)|RAS (Red)  |ALT\ \ GR
HONEY/ISO/RED         |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/ISO/RED         |R2UJRET|WFK (White)|RAS (Red)  |RETURN
HONEY/ISO/RED         |R3U150 |WFK (White)|RAS (Red)  |ALT\ \ GRAPH
HONEY/ISO/BLACK       |R3U125 |WFK (White)|NN (Black) |ALT\ \ GR
HONEY/ISO/BLACK       |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/ISO/BLACK       |R2UJRET|WFK (White)|NN (Black) |RETURN
HONEY/ISO/BLACK       |R3U150 |WFK (White)|NN (Black) |ALT\ \ GRAPH
HONEY/MODIFIER        |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIER        |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIER        |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MODIFIER        |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER        |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODIFIER        |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER        |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER        |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIER        |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/MODIFIER        |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/MODIFIER        |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/MODIFIER        |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/MODIFIER        |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/MODIFIER        |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER        |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/MODIFIER        |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIER        |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/MODIFIER        |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIER        |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/MODIFIER        |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODIFIEREXTRA   |R3U175 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODIFIEREXTRA   |R3U175S|WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U175S|WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIEREXTRA   |R3U175S|WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |TOP
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |FRONT
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |COMMAND
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |OPTION
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |WIN
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |MENU
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |SHIFT\ \ LOCK
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MODIFIEREXTRA   |R3U150 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |TAB
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/MODIFIEREXTRA   |R3U125 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |FUN
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |CMD
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |OPT
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |WIN
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |MENU
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |SHIFT,LOCK
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |MODE,LOCK
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |ALT,LOCK
HONEY/MODIFIEREXTRA   |R3U100 |WFK (White)|GPA (Gray) |TTY,LOCK
HONEY/FUN125          |R3U125 |WFK (White)|GPA (Gray) |FUN
HONEY/FUN125/RED      |R3U125 |WFK (White)|RAS (Red)  |FUN
HONEY/FUN125/BLACK    |R3U125 |WFK (White)|NN (Black) |FUN
HONEY/WINDOWS125      |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/WINDOWS125      |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/WINDOWS125/RED  |R3U125 |WFK (White)|RAS (Red)  |WIN
HONEY/WINDOWS125/RED  |R3U125 |WFK (White)|RAS (Red)  |MENU
HONEY/WINDOWS125/BLACK|R3U125 |WFK (White)|NN (Black) |WIN
HONEY/WINDOWS125/BLACK|R3U125 |WFK (White)|NN (Black) |MENU
HONEY/WINDOWS150      |R3U150 |WFK (White)|GPA (Gray) |WIN
HONEY/WINDOWS150      |R3U150 |WFK (White)|GPA (Gray) |MENU
HONEY/APPLE125        |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/APPLE125        |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/APPLE125/RED    |R3U125 |WFK (White)|RAS (Red)  |OPTION
HONEY/APPLE125/RED    |R3U125 |WFK (White)|RAS (Red)  |COMMAND
HONEY/APPLE125/BLACK  |R3U125 |WFK (White)|NN (Black) |OPTION
HONEY/APPLE125/BLACK  |R3U125 |WFK (White)|NN (Black) |COMMAND
HONEY/APPLE150        |R3U150 |WFK (White)|GPA (Gray) |OPTION
HONEY/APPLE150        |R3U150 |WFK (White)|GPA (Gray) |COMMAND
HONEY/APPLE150/RED    |R3U150 |WFK (White)|RAS (Red)  |OPTION
HONEY/APPLE150/RED    |R3U150 |WFK (White)|RAS (Red)  |COMMAND
HONEY/APPLE150/BLACK  |R3U150 |WFK (White)|NN (Black) |OPTION
HONEY/APPLE150/BLACK  |R3U150 |WFK (White)|NN (Black) |COMMAND
HONEY/MOD100          |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/MOD100          |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/MOD100          |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/MOD100          |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MOD100          |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/MOD100          |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/MOD125          |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MOD150          |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD150          |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/MOD150          |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/MOD150          |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/MOD150          |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/MOD150          |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD150          |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/MOD150          |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MOD150/RED      |R3U150 |WFK (White)|RAS (Red)  |CONTROL
HONEY/MOD150/RED      |R3U150 |WFK (White)|RAS (Red)  |SUPER
HONEY/MOD150/RED      |R3U150 |WFK (White)|RAS (Red)  |META
HONEY/MOD150/RED      |R3U150 |WFK (White)|RAS (Red)  |ALT
HONEY/MOD150/RED      |R3U150 |WFK (White)|RAS (Red)  |ALT\ \ GRAPH
HONEY/MOD150/RED      |R3U150 |WFK (White)|RAS (Red)  |SHIFT
HONEY/MOD150/RED      |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/MOD150/RED      |R2U150 |WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/MOD150/BLACK    |R3U150 |WFK (White)|NN (Black) |CONTROL
HONEY/MOD150/BLACK    |R3U150 |WFK (White)|NN (Black) |SUPER
HONEY/MOD150/BLACK    |R3U150 |WFK (White)|NN (Black) |META
HONEY/MOD150/BLACK    |R3U150 |WFK (White)|NN (Black) |ALT
HONEY/MOD150/BLACK    |R3U150 |WFK (White)|NN (Black) |ALT\ \ GRAPH
HONEY/MOD150/BLACK    |R3U150 |WFK (White)|NN (Black) |SHIFT
HONEY/MOD150/BLACK    |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/MOD150/BLACK    |R2U150 |WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/MOD175          |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD175          |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MOD175          |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD175          |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MOD175          |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD200          |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD200          |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/MOD200          |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD200          |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MOD200          |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |FUN
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |CMD
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |OPT
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |WIN
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |MENU
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |SHIFT,LOCK
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |MODE,LOCK
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |ALT,LOCK
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |TTY,LOCK
HONEY/MODEXTRA100     |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |TAB
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |ENTER
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/MODEXTRA125     |R3U125 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |TOP
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |FRONT
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |SHIFT\ \ LOCK
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MODEXTRA150     |R3U150 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODEXTRA150     |R2U150 |WFK (White)|GPA (Gray) |DELETE
HONEY/MODEXTRA150     |R1U150 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODEXTRA175     |R3U175 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODEXTRA175     |R3U175S|WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODSYM100       |R3U100 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM100       |R3U100 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM100       |R3U100 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM100       |R3U100 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM100       |R2U100 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM100       |R2U100 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM100       |R2U100 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM100       |R2U100 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM125       |R3U125 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM125       |R3U125 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM125       |R3U125 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM125       |R3U125 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM150       |R3U150 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM150       |R3U150 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM150       |R3U150 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM150       |R3U150 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM150       |R2U150 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM150       |R2U150 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM150       |R2U150 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM150       |R2U150 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM175       |R3U175 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM175       |R2U175 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM175       |R2U175 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM175       |R2U175 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM175       |R2U175 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM200       |R3U200H|WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM200       |R3U200H|WFK (White)|GPA (Gray) |\square
HONEY/MODSYM200       |R3U200H|WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM200       |R3U200H|WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM200       |R2U200H|WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM200       |R2U200H|WFK (White)|GPA (Gray) |\square
HONEY/MODSYM200       |R2U200H|WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM200       |R2U200H|WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM200POS    |R3U200P|WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM200POS    |R3U200P|WFK (White)|GPA (Gray) |\square
HONEY/MODSYM200POS    |R3U200P|WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM200POS    |R3U200P|WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM200POS    |R1U200P|WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM200POS    |R1U200P|WFK (White)|GPA (Gray) |\square
HONEY/MODSYM200POS    |R1U200P|WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM200POS    |R1U200P|WFK (White)|GPA (Gray) |\diamond
HONEY/WASD/RED        |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/WASD/RED        |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/WASD/RED        |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/WASD/RED        |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/CURSORBASE      |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/CURSORBASE      |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/CURSORBASE      |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/CURSORBASE      |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/CURSORBASE      |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/CURSORBASE      |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/CURSORBASE      |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/CURSORBASE      |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/CURSORBASE      |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |\leftarrow
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |\downarrow
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |\rightarrow
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSORS         |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSORS         |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSORS         |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSORS         |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSORS         |R3U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSORS         |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSORS         |R2U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSORS         |R2U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSORS         |R2U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSORS         |R2U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R24      |R2U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R24      |R2U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R24      |R2U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R24      |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R24      |R4U100 |WFK (White)|GPA (Gray) |\rightarrow
HONEY/CURSOR/R24      |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R24      |R4U100 |WFK (White)|GPA (Gray) |\leftarrow
HONEY/CURSOR/R3       |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R3       |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R3       |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R3       |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R3       |R3U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R34      |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R34      |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R34      |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R34      |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R34      |R3U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R34      |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |\leftarrow
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |\downarrow
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |\rightarrow
HONEY/CURSOR/R4       |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSORBASE/RED  |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/CURSORBASE/RED  |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/CURSORBASE/RED  |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/CURSORBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/CURSORBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/CURSORBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/CURSORBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/CURSORBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/CURSORBASE/RED  |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |\leftarrow
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |\downarrow
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |\rightarrow
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSORS/RED     |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSORS/RED     |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSORS/RED     |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSORS/RED     |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSORS/RED     |R3U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSORS/RED     |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSORS/RED     |R2U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSORS/RED     |R2U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSORS/RED     |R2U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSORS/RED     |R2U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R24/RED  |R2U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R24/RED  |R2U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R24/RED  |R2U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R24/RED  |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R24/RED  |R4U100 |WFK (White)|RAS (Red)  |\rightarrow
HONEY/CURSOR/R24/RED  |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R24/RED  |R4U100 |WFK (White)|RAS (Red)  |\leftarrow
HONEY/CURSOR/R3/RED   |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R3/RED   |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R3/RED   |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R3/RED   |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R3/RED   |R3U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R34/RED  |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R34/RED  |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R34/RED  |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R34/RED  |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R34/RED  |R3U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R34/RED  |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |\leftarrow
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |\downarrow
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |\rightarrow
HONEY/CURSOR/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSORBASE/BLACK|R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/CURSORBASE/BLACK|R2U100 |WFK (White)|NN (Black) |END
HONEY/CURSORBASE/BLACK|R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/CURSORBASE/BLACK|R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/CURSORBASE/BLACK|R1U100 |WFK (White)|NN (Black) |HOME
HONEY/CURSORBASE/BLACK|R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/CURSORBASE/BLACK|R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/CURSORBASE/BLACK|R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/CURSORBASE/BLACK|R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |\leftarrow
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |\downarrow
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |\rightarrow
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSORS/BLACK   |R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSORS/BLACK   |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSORS/BLACK   |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSORS/BLACK   |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSORS/BLACK   |R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSORS/BLACK   |R3U100 |WFK (White)|NN (Black) |UP
HONEY/CURSORS/BLACK   |R2U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSORS/BLACK   |R2U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSORS/BLACK   |R2U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSORS/BLACK   |R2U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R24/BLACK|R2U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R24/BLACK|R2U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R24/BLACK|R2U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R24/BLACK|R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R24/BLACK|R4U100 |WFK (White)|NN (Black) |\rightarrow
HONEY/CURSOR/R24/BLACK|R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R24/BLACK|R4U100 |WFK (White)|NN (Black) |\leftarrow
HONEY/CURSOR/R3/BLACK |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R3/BLACK |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R3/BLACK |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R3/BLACK |R3U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R3/BLACK |R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R34/BLACK|R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R34/BLACK|R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R34/BLACK|R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R34/BLACK|R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R34/BLACK|R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R34/BLACK|R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |\leftarrow
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |\downarrow
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |\rightarrow
HONEY/CURSOR/R4/BLACK |R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/NUMPAD          |R3U200H|NN (Black) |WFK (White)|0
HONEY/NUMPAD          |R3U100 |NN (Black) |WFK (White)|\dot
HONEY/NUMPAD          |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMPAD          |R3U100 |NN (Black) |WFK (White)|0
HONEY/NUMPAD          |R3U100 |NN (Black) |WFK (White)|00
HONEY/NUMPAD          |R4U100 |NN (Black) |WFK (White)|1
HONEY/NUMPAD          |R4U100 |NN (Black) |WFK (White)|2
HONEY/NUMPAD          |R4U100 |NN (Black) |WFK (White)|3
HONEY/NUMPAD          |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMPAD          |R3U100 |NN (Black) |WFK (White)|4
HONEY/NUMPAD          |R3U100D|NN (Black) |WFK (White)|5
HONEY/NUMPAD          |R3U100 |NN (Black) |WFK (White)|6
HONEY/NUMPAD          |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMPAD          |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMPAD          |R3U100 |NN (Black) |WFK (White)|5
HONEY/NUMPAD          |R2U100 |NN (Black) |WFK (White)|7
HONEY/NUMPAD          |R2U100 |NN (Black) |WFK (White)|8
HONEY/NUMPAD          |R2U100 |NN (Black) |WFK (White)|9
HONEY/NUMPAD          |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMPAD          |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMPAD          |R1U100 |WFK (White)|GPA (Gray) |/
HONEY/NUMPAD          |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMPAD          |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMPAD          |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMPAD/GREY     |R3U200H|WFK (White)|GPA (Gray) |0
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |\dot
HONEY/NUMPAD/GREY     |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |0
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |00
HONEY/NUMPAD/GREY     |R4U100 |WFK (White)|GPA (Gray) |1
HONEY/NUMPAD/GREY     |R4U100 |WFK (White)|GPA (Gray) |2
HONEY/NUMPAD/GREY     |R4U100 |WFK (White)|GPA (Gray) |3
HONEY/NUMPAD/GREY     |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |4
HONEY/NUMPAD/GREY     |R3U100D|WFK (White)|GPA (Gray) |5
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |6
HONEY/NUMPAD/GREY     |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMPAD/GREY     |R3U100 |WFK (White)|GPA (Gray) |5
HONEY/NUMPAD/GREY     |R2U100 |WFK (White)|GPA (Gray) |7
HONEY/NUMPAD/GREY     |R2U100 |WFK (White)|GPA (Gray) |8
HONEY/NUMPAD/GREY     |R2U100 |WFK (White)|GPA (Gray) |9
HONEY/NUMPAD/GREY     |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMPAD/GREY     |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMPAD/GREY     |R1U100 |WFK (White)|GPA (Gray) |/
HONEY/NUMPAD/GREY     |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMPAD/GREY     |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMPAD/GREY     |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMPAD/RED      |R3U200H|WFK (White)|RAS (Red)  |0
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |\dot
HONEY/NUMPAD/RED      |R3U200V|WFK (White)|RAS (Red)  |ENTER
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |0
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |00
HONEY/NUMPAD/RED      |R4U100 |WFK (White)|RAS (Red)  |1
HONEY/NUMPAD/RED      |R4U100 |WFK (White)|RAS (Red)  |2
HONEY/NUMPAD/RED      |R4U100 |WFK (White)|RAS (Red)  |3
HONEY/NUMPAD/RED      |R4U100 |WFK (White)|RAS (Red)  |\equal
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |4
HONEY/NUMPAD/RED      |R3U100D|WFK (White)|RAS (Red)  |5
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |6
HONEY/NUMPAD/RED      |R3U200V|WFK (White)|RAS (Red)  |\fontkey{\plus}
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |\&
HONEY/NUMPAD/RED      |R3U100 |WFK (White)|RAS (Red)  |5
HONEY/NUMPAD/RED      |R2U100 |WFK (White)|RAS (Red)  |7
HONEY/NUMPAD/RED      |R2U100 |WFK (White)|RAS (Red)  |8
HONEY/NUMPAD/RED      |R2U100 |WFK (White)|RAS (Red)  |9
HONEY/NUMPAD/RED      |R2U100 |WFK (White)|RAS (Red)  |\plus
HONEY/NUMPAD/RED      |R1U100 |WFK (White)|RAS (Red)  |NUM,LOCK
HONEY/NUMPAD/RED      |R1U100 |WFK (White)|RAS (Red)  |/
HONEY/NUMPAD/RED      |R1U100 |WFK (White)|RAS (Red)  |\sixast
HONEY/NUMPAD/RED      |R1U100 |WFK (White)|RAS (Red)  |\minus
HONEY/NUMPAD/RED      |R1U100 |WFK (White)|RAS (Red)  |\tilde
HONEY/NUMPAD/BLACK    |R3U200H|WFK (White)|NN (Black) |0
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |\dot
HONEY/NUMPAD/BLACK    |R3U200V|WFK (White)|NN (Black) |ENTER
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |0
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |00
HONEY/NUMPAD/BLACK    |R4U100 |WFK (White)|NN (Black) |1
HONEY/NUMPAD/BLACK    |R4U100 |WFK (White)|NN (Black) |2
HONEY/NUMPAD/BLACK    |R4U100 |WFK (White)|NN (Black) |3
HONEY/NUMPAD/BLACK    |R4U100 |WFK (White)|NN (Black) |\equal
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |4
HONEY/NUMPAD/BLACK    |R3U100D|WFK (White)|NN (Black) |5
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |6
HONEY/NUMPAD/BLACK    |R3U200V|WFK (White)|NN (Black) |\fontkey{\plus}
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |\&
HONEY/NUMPAD/BLACK    |R3U100 |WFK (White)|NN (Black) |5
HONEY/NUMPAD/BLACK    |R2U100 |WFK (White)|NN (Black) |7
HONEY/NUMPAD/BLACK    |R2U100 |WFK (White)|NN (Black) |8
HONEY/NUMPAD/BLACK    |R2U100 |WFK (White)|NN (Black) |9
HONEY/NUMPAD/BLACK    |R2U100 |WFK (White)|NN (Black) |\plus
HONEY/NUMPAD/BLACK    |R1U100 |WFK (White)|NN (Black) |NUM,LOCK
HONEY/NUMPAD/BLACK    |R1U100 |WFK (White)|NN (Black) |/
HONEY/NUMPAD/BLACK    |R1U100 |WFK (White)|NN (Black) |\sixast
HONEY/NUMPAD/BLACK    |R1U100 |WFK (White)|NN (Black) |\minus
HONEY/NUMPAD/BLACK    |R1U100 |WFK (White)|NN (Black) |\tilde
HONEY/NUMERIC         |R3U200H|NN (Black) |WFK (White)|0
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|\dot
HONEY/NUMERIC         |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|0
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|00
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|\ccomma
HONEY/NUMERIC         |R4U100 |NN (Black) |WFK (White)|1
HONEY/NUMERIC         |R4U100 |NN (Black) |WFK (White)|2
HONEY/NUMERIC         |R4U100 |NN (Black) |WFK (White)|3
HONEY/NUMERIC         |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|4
HONEY/NUMERIC         |R3U100D|NN (Black) |WFK (White)|5
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|6
HONEY/NUMERIC         |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMERIC         |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMERIC         |R3U100 |NN (Black) |WFK (White)|5
HONEY/NUMERIC         |R2U100 |NN (Black) |WFK (White)|7
HONEY/NUMERIC         |R2U100 |NN (Black) |WFK (White)|8
HONEY/NUMERIC         |R2U100 |NN (Black) |WFK (White)|9
HONEY/NUMERIC         |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\backslash
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\pound
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\euro
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\yen
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\colon
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\eightast
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\at
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\#
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\$
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\%
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\wedge
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\lt
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\gt
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\openparen
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\closeparen
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\opencur
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\closecur
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\openbra
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\closebra
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |?
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |!
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\underscore
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\vert
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\prime
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\backprime
HONEY/NUMERIC         |R1U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMERIC/GREY    |R3U200H|WFK (White)|GPA (Gray) |0
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |\dot
HONEY/NUMERIC/GREY    |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |0
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |00
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |\ccomma
HONEY/NUMERIC/GREY    |R4U100 |WFK (White)|GPA (Gray) |1
HONEY/NUMERIC/GREY    |R4U100 |WFK (White)|GPA (Gray) |2
HONEY/NUMERIC/GREY    |R4U100 |WFK (White)|GPA (Gray) |3
HONEY/NUMERIC/GREY    |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |4
HONEY/NUMERIC/GREY    |R3U100D|WFK (White)|GPA (Gray) |5
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |6
HONEY/NUMERIC/GREY    |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMERIC/GREY    |R3U100 |WFK (White)|GPA (Gray) |5
HONEY/NUMERIC/GREY    |R2U100 |WFK (White)|GPA (Gray) |7
HONEY/NUMERIC/GREY    |R2U100 |WFK (White)|GPA (Gray) |8
HONEY/NUMERIC/GREY    |R2U100 |WFK (White)|GPA (Gray) |9
HONEY/NUMERIC/GREY    |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\backslash
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\pound
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\euro
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\yen
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\colon
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\eightast
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\at
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\#
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\$
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\%
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\wedge
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\lt
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\gt
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\openparen
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\closeparen
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\opencur
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\closecur
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\openbra
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\closebra
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |?
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |!
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\underscore
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\vert
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\prime
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\backprime
HONEY/NUMERIC/GREY    |R1U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMERIC/BLACK   |R3U200H|WFK (White)|NN (Black) |0
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |\dot
HONEY/NUMERIC/BLACK   |R3U200V|WFK (White)|NN (Black) |ENTER
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |0
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |00
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |\ccomma
HONEY/NUMERIC/BLACK   |R4U100 |WFK (White)|NN (Black) |1
HONEY/NUMERIC/BLACK   |R4U100 |WFK (White)|NN (Black) |2
HONEY/NUMERIC/BLACK   |R4U100 |WFK (White)|NN (Black) |3
HONEY/NUMERIC/BLACK   |R4U100 |WFK (White)|NN (Black) |\equal
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |4
HONEY/NUMERIC/BLACK   |R3U100D|WFK (White)|NN (Black) |5
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |6
HONEY/NUMERIC/BLACK   |R3U200V|WFK (White)|NN (Black) |\fontkey{\plus}
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |\&
HONEY/NUMERIC/BLACK   |R3U100 |WFK (White)|NN (Black) |5
HONEY/NUMERIC/BLACK   |R2U100 |WFK (White)|NN (Black) |7
HONEY/NUMERIC/BLACK   |R2U100 |WFK (White)|NN (Black) |8
HONEY/NUMERIC/BLACK   |R2U100 |WFK (White)|NN (Black) |9
HONEY/NUMERIC/BLACK   |R2U100 |WFK (White)|NN (Black) |\plus
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |NUM,LOCK
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\slash
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\sixast
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\minus
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\backslash
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\pound
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\euro
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\yen
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\colon
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\tilde
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\eightast
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\at
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\#
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\$
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\%
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\wedge
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\lt
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\gt
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\openparen
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\closeparen
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\opencur
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\closecur
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\openbra
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\closebra
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |?
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |!
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\underscore
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\vert
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\prime
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\backprime
HONEY/NUMERIC/BLACK   |R1U100 |WFK (White)|NN (Black) |\&
HONEY/NUMERIC/RED     |R3U200H|WFK (White)|RAS (Red)  |0
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |\dot
HONEY/NUMERIC/RED     |R3U200V|WFK (White)|RAS (Red)  |ENTER
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |0
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |00
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |\ccomma
HONEY/NUMERIC/RED     |R4U100 |WFK (White)|RAS (Red)  |1
HONEY/NUMERIC/RED     |R4U100 |WFK (White)|RAS (Red)  |2
HONEY/NUMERIC/RED     |R4U100 |WFK (White)|RAS (Red)  |3
HONEY/NUMERIC/RED     |R4U100 |WFK (White)|RAS (Red)  |\equal
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |4
HONEY/NUMERIC/RED     |R3U100D|WFK (White)|RAS (Red)  |5
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |6
HONEY/NUMERIC/RED     |R3U200V|WFK (White)|RAS (Red)  |\fontkey{\plus}
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |\&
HONEY/NUMERIC/RED     |R3U100 |WFK (White)|RAS (Red)  |5
HONEY/NUMERIC/RED     |R2U100 |WFK (White)|RAS (Red)  |7
HONEY/NUMERIC/RED     |R2U100 |WFK (White)|RAS (Red)  |8
HONEY/NUMERIC/RED     |R2U100 |WFK (White)|RAS (Red)  |9
HONEY/NUMERIC/RED     |R2U100 |WFK (White)|RAS (Red)  |\plus
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |NUM,LOCK
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\slash
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\sixast
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\minus
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\backslash
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\pound
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\euro
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\yen
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\colon
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\tilde
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\eightast
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\at
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\#
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\$
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\%
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\wedge
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\lt
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\gt
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\openparen
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\closeparen
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\opencur
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\closecur
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\openbra
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\closebra
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |?
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |!
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\underscore
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\vert
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\prime
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\backprime
HONEY/NUMERIC/RED     |R1U100 |WFK (White)|RAS (Red)  |\&
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |CTRL
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |WIN
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |MENU
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |COMMAND
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |OPTION
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK    |R3U125 |WFK (White)|NN (Black) |RETURN
HONEY/FUNMOD/BLACK    |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK    |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/FUNMOD/BLACK    |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK    |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/FUNMOD/BLACK    |R3U175S|WFK (White)|NN (Black) |CAPS,LOCK
HONEY/FUNMOD/BLACK    |R3U175 |WFK (White)|NN (Black) |CONTROL
HONEY/FUNMOD/BLACK    |R3U175S|WFK (White)|NN (Black) |CTRL
HONEY/FUNMOD/BLACK    |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK    |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/FUNMOD/BLACK    |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/FUNMOD/BLACK    |R3U100 |WFK (White)|NN (Black) |UP
HONEY/FUNMOD/BLACK    |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/FUNMOD/BLACK    |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/FUNMOD/BLACK    |R2U150 |WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/FUNMOD/BLACK    |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/FUNMOD/BLACK    |R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |COPY
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |RELOAD
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |CALC
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |COMP
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |TERM
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |MAIL
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |WEB
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |VOLUME,UP
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |VOLUME,DOWN
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |OPEN
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |ZOOM,IN
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |ZOOM,OUT
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |PLAY
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |REWIND
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |FORWD
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |PREV
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |EJECT
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |MUTE
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |RECORD
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |FF
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |RESET
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |LAYER 2
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |DEBUG
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |CLEAN
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |BUILD
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |ANY,KEY
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |STOP,RUN
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |7BIT,MODE
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |PANIC
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |HELP
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |DT
HONEY/FUNCTION/R1     |R1U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/FUNCTION/R2     |R2U100 |WFK (White)|GPA (Gray) |TAB
HONEY/FUNCTION/R2     |R2U100 |WFK (White)|GPA (Gray) |BTAB
HONEY/FUNCTION/R2     |R2U100 |WFK (White)|GPA (Gray) |BS
HONEY/FUNCTION/R2     |R2U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION/R2     |R2U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |ZOOM,IN
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |ZOOM,OUT
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |VOLUME,UP
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |VOLUME,DOWN
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |MUTE
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |PLAY
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |REWIND
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |FORWD
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |PREV
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |RELOAD
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |EJECT
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |RECORD
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |CALC
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |COMP
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |MAIL
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |TERM
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |LAYER 2
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |DEBUG
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |CLEAN
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |BUILD
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |PANIC
HONEY/FUNCTION/R3     |R3U100 |WFK (White)|GPA (Gray) |ANY,KEY
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |ALT
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |FN
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION/R4     |R4U100 |WFK (White)|GPA (Gray) |RETURN
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |CUT
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |PASTE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |MARK
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |SELECT
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |UNDO
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |REDO
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |PRIOR
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |NEXT
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |RETURN
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |LINE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |ENTER
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |BS
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |CR
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |LF
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |FF
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |PAGE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |EOF
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |TAB
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |BTAB
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |RESET
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |WRITE,BUFFER
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |OVER,STRIKE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |SHIFT,WORD
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |COM-,POSE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |STOP,RUN
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |7 BIT,MODE
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |REVERT
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |HELP
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |TURBO
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |POWER
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |DT
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |FIND
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |OPEN
HONEY/FUNCTION7       |R3U100 |WFK (White)|GPA (Gray) |PROPS
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |RETURN
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |RUN
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |7 BIT,MODE
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |FIRE
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |STOP,RUN
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |ANY,KEY
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |PANIC
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |TURBO
HONEY/FUNCTION/RED    |R3U100 |WFK (White)|RAS (Red)  |DT
HONEY/FUNCTION/RED    |R3U175 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/RED    |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/FUNCTION/RED    |R3U225 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/RED    |R2U150 |WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/FUNCTION/RED    |R2U150 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/RED    |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/FUNCTION/RED    |R2U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/FUNCTION/RED    |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/FUNCTION/RED    |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/FUNCTION/RED    |R1U100 |WFK (White)|RAS (Red)  |BACK,SPACE
HONEY/FUNCTION/RED    |R1U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/FUNCTION/RED    |R1U100 |WFK (White)|RAS (Red)  |EJECT
HONEY/FUNCTION/RED    |R1U150 |WFK (White)|RAS (Red)  |CLEAR,RESET
HONEY/FUNCTION/RED    |R1U150 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |MAIL
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |TERM
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |CALC
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |COMP
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |POWER
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |RECORD
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |WEB
HONEY/FUNCTION/R1/RED |R1U100 |WFK (White)|RAS (Red)  |STOP,RUN
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/F1TOF12         |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F1
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F2
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F3
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F4
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F5
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F6
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F7
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F8
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F9
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F10
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F11
HONEY/F1TOF12/WHITE   |R1U100 |NN (Black) |WFK (White)|F12
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/F1TOF12/RED     |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F1
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F2
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F3
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F4
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F5
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F6
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F7
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F8
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F9
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F10
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F11
HONEY/F1TOF12/BLACK   |R1U100 |WFK (White)|NN (Black) |F12
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F13
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F14
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F15
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F16
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F17
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F18
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F19
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F20
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F21
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F22
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F23
HONEY/F13TOF24        |R1U100 |WFK (White)|GPA (Gray) |F24
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F13
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F14
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F15
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F16
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F17
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F18
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F19
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F20
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F21
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F22
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F23
HONEY/F13TOF24/WHITE  |R1U100 |NN (Black) |WFK (White)|F24
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F13
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F14
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F15
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F16
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F17
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F18
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F19
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F20
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F21
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F22
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F23
HONEY/F1TOF24         |R1U100 |WFK (White)|GPA (Gray) |F24
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F1
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F2
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F3
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F4
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F5
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F6
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F7
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F8
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F9
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F10
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F11
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F12
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F13
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F14
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F15
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F16
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F17
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F18
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F19
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F20
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F21
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F22
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F23
HONEY/F1TOF24/WHITE   |R1U100 |NN (Black) |WFK (White)|F24
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |SELECT
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |LOCAL
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |COMPLETE
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |PASTE
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |SWITCH\ \ LAYER
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |NUM\ \ LOCK
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |OVER,STRIKE
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |QUOTE
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |WRITE\ \ BUFFER
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |REFRESH
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |HELP
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |\square
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |\circle
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |\triangle
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |\diamond
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |SYSTEM
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |STATUS
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |NETWORK
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |ESCAPE
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |ABORT
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |SUSPEND
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |BREAK
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |RESUME
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |CLEAR,INPUT
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |CLEAR,SCREEN
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |HOLD,OUTPUT
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |STOP,OUTPUT
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |MACRO
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |FUNCTION
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |TERMINAL
HONEY/POS             |R3U200P|WFK (White)|GPA (Gray) |CALL
HONEY/JRET            |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/JRET/RED        |R2UJRET|WFK (White)|RAS (Red)  |RETURN
HONEY/JRET/BLACK      |R2UJRET|WFK (White)|NN (Black) |RETURN
HONEY/RETURN175       |R3U175 |WFK (White)|GPA (Gray) |RETURN
HONEY/RETURN225/RED   |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/SHIFT100        |R3U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT125        |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT150        |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT175        |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT200        |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT225        |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT275        |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT100/R4     |R4U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT150/R4     |R4U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT175/R4     |R4U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT200/R4     |R4U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT100/RED    |R3U100 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT125/RED    |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT150/RED    |R3U150 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT175/RED    |R3U175 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT200/RED    |R3U200H|WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT225/RED    |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT275/RED    |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT100/R4/RED |R4U100 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT150/R4/RED |R4U150 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT175/R4/RED |R4U175 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT200/R4/RED |R4U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT100/BLACK  |R3U100 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT125/BLACK  |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT150/BLACK  |R3U150 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT175/BLACK  |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT200/BLACK  |R3U200H|WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT225/BLACK  |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT275/BLACK  |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/COMMA           |R3U100 |NN (Black) |WFK (White)|\ccomma
HONEY/COMMA/GREY      |R3U100 |WFK (White)|GPA (Gray) |\ccomma
HONEY/COMMA/RED       |R3U100 |WFK (White)|RAS (Red)  |\ccomma
HONEY/GTLT            |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/GTLT/RED        |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt
HONEY/FJ              |R3U100 |NN (Black) |WFK (White)|F
HONEY/FJ              |R3U100 |NN (Black) |WFK (White)|J
HONEY/FJ/RED          |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/FJ/RED          |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/TILDEBPRIME/GREY|R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/VERTBSL/R1      |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R2      |R2U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R3      |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R4      |R4U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R1/RED  |R1U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL/R2/RED  |R2U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL/R3/RED  |R3U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL/R4/RED  |R4U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL150      |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL150/GREY |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/VERTBSL150/RED  |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL150/BLACK|R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/ASTQUOTE150     |R2U150 |NN (Black) |WFK (White)|\ast,\quote
HONEY/ASTQUOTE150/GREY|R2U150 |WFK (White)|GPA (Gray) |\ast,\quote
HONEY/ASTQUOTE150/RED |R2U150 |WFK (White)|RAS (Red)  |\ast,\quote
HONEY/REDESCAPE/R1    |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/REDESCAPE/R2    |R2U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/REDESCAPE/R3    |R3U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SPACE100        |R3U100 |NN (Black) |WFK (White)|SPACE
HONEY/SPACE100/GREY   |R3U100 |WFK (White)|GPA (Gray) |SPACE
HONEY/SPACE100/RED    |R3U100 |WFK (White)|RAS (Red)  |SPACE
HONEY/SPACE100/BLACK  |R3U100 |WFK (White)|NN (Black) |SPACE
HONEY/SPACE150        |R2U150 |NN (Black) |WFK (White)|SPACE
HONEY/SPACE150/GREY   |R2U150 |WFK (White)|GPA (Gray) |SPACE
HONEY/SPACE150/RED    |R3U150 |WFK (White)|RAS (Red)  |SPACE
HONEY/SPACE150/BLACK  |R2U150 |WFK (White)|NN (Black) |SPACE
HONEY/ERGOKEY         |R3U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGOKEY         |R3U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/KBDRUNNER       |R1U100 |WFK (White)|GPA (Gray) |\kbdrunnergrey
HONEY/KBDRUNNER/WHITE |R2U100 |NN (Black) |WFK (White)|\kbdrunnerwhite
HONEY/KBDRUNNER/RED   |R1U100 |WFK (White)|RAS (Red)  |\kbdrunnerred
HONEY/KBDRUNNER/RED/R2|R2U100 |WFK (White)|RAS (Red)  |\kbdrunnerred
HONEY/KBDRUNNER/RED/R3|R3U100 |WFK (White)|RAS (Red)  |\kbdrunnerred
HONEY/KBDRUNNER/BLACK |R1U100 |WFK (White)|NN (Black) |\kbdrunnerblack
HONEY/LOTUSESC        |R1U100 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUSESC/RED    |R1U100 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUSESC/BLACK  |R1U100 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS100        |R3U100 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS125        |R3U125 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS150        |R3U150 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS175        |R3U175 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS175S       |R3U175S|WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS225        |R3U225 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS275        |R3U275 |WFK (White)|GPA (Gray) |\lotuswhitegrey
HONEY/LOTUS100/RED    |R3U100 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS125/RED    |R3U125 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS150/RED    |R3U150 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS175/RED    |R3U175 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS175S/RED   |R3U175S|WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS225/RED    |R3U225 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS275/RED    |R3U275 |WFK (White)|RAS (Red)  |\lotuswhitered
HONEY/LOTUS100/BLACK  |R3U100 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS125/BLACK  |R3U125 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS150/BLACK  |R3U150 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS175/BLACK  |R3U175 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS175S/BLACK |R3U175S|WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS225/BLACK  |R3U225 |WFK (White)|NN (Black) |\lotuswhiteblack
HONEY/LOTUS275/BLACK  |R3U275 |WFK (White)|NN (Black) |\lotuswhiteblack
:shock:
When I ever upload this to the wiki, Daniel Beardsmore will kill me!
:roll:
27 Nov 2013, 14:01
Cheers.
(Works fine on my ridiculously old iPod touch. Quicker than the images, that's for sure.)
-[°_°]-
27 Nov 2013, 14:05
is the wiki updated with all the recent changes?
27 Nov 2013, 14:09
No, I need to be at home to do that.
Ichigo87
27 Nov 2013, 15:11
Could you tell us where we are with language kits?
I am still not sure if i want to take financial risk and buy 5 full kits for French Azerty (approx 500€) and try to sell them after the group buy or if i just buy enough FR kit to reach the 8 orders target to keep the price low. It's stupid to have only FR kit that you cannot use on a board but at least i loose only 100€.
27 Nov 2013, 15:15
HONEY/DE              |  7| 22|   16|USD|DE language kit
HONEY/DK              |  2| 21|   16|USD|DK language kit
HONEY/NO              |  2| 21|   16|USD|NO language kit
HONEY/SE              |  8| 21|   16|USD|SE language kit
HONEY/IT              |  4| 19|   19|USD|IT language kit
HONEY/FR              |  9| 27|   21|USD|FR language kit
HONEY/UK              |  4|  6|    6|USD|UK language kit
HONEY/UK/RED          |   |  6|    6|USD|UK language kit
HONEY/BEPO            |   | 44|   35|USD|BEPO language kit
HONEY/BEPOALPHA       |  3| 51|   39|USD|BEPOALPHA language kit
HONEY/COLEMAK         |  3| 14|   12|USD|COLEMAK language kit
HONEY/DVORAK          |   | 26|   24|USD|DVORAK language kit
beltet
27 Nov 2013, 15:54
I got a new invoice from the not. EDIT: bot, of course...
Is it because you change some of the prices?
Or us it because my payment aren't registered?
I don't think any of my kits are one that changed but just want to be certain.
And I saw now that you separated one function kit.
If I now add a kit, will I get a invoice with the sum that I owe or on the total sum? Read that you don't want small payments atm but when is the last payment day?
I just want to be certain that I pay the correct amount and that the payment get registered.
Sincerely
27 Nov 2013, 16:08
I would say, 14 days after the deadline should be OK.
I send out the invoices from time to time to reming people who do not follow the thread each day about updates etc. Also, some people already paid so they got a new invoice stating their payment.
DeskNDL82
27 Nov 2013, 17:05
7bit:
if dealine of payment is 14days after deadline of order. I think you are better to change this line inside involve "Amount to be paid within 7 days via PayPal (no gift!)"
metalliqaz
27 Nov 2013, 17:16
I paid my invoice in full a while ago and got another invoice for more money...
27 Nov 2013, 17:19
DeskNDL82 wrote:7bit:
There is no harm in getting all the money together in a short time as possible.
metalliqaz wrote:I paid my invoice in full a while ago and got another invoice for more money...
Thanks!
:evilgeek:
metalliqaz
27 Nov 2013, 17:24
I don't think you understand. I didn't order anything new. Just more money for the same invoice.
27 Nov 2013, 17:28
@metalliqaz:
You paid 3 days after the Cherry MX 30th anniversary rebate expired (18 November, instead of 14th as originally intended).
:roll:
@Incognito:
Topres are not well documented.
The main problem might be the space bar, because of the position of the stabilisers.
metalliqaz
27 Nov 2013, 17:28
The Realforce uses a 6x spacebar, and there isn't an option for that in this GB
metalliqaz
27 Nov 2013, 17:35
Everything else is standard ANSI size except the bottom row
1.5x - 1x - 1.5x - 6x - 1.5x - 1x - 1x - 1.5x
27 Nov 2013, 17:38
Strange choice. Perhaps Topre doesn't have a 1.25 unit mold for the bottom row…
zhasha
27 Nov 2013, 19:17
7bit wrote:
zhasha wrote:Are there CAPS LOCK alternatives? Am I blind?
Sight-test:
[snip]
:cool:
Neat! Maybe we could have something more PANICky than this? Although I think I might just stick with this layout if I can get it in Alps ;-)
27 Nov 2013, 19:21
The Alps converter will be available really soon.
zhasha
27 Nov 2013, 19:29
facetsesame
Mad Dasher
27 Nov 2013, 20:49
Ok then, function key rows:
The "approved" legends:
ABORT, ANY, ATTN, BEL, BREAK, CLOSE, DELAY, DUCK, ENA/DIS, ERASE, EXEC, F0 [F zero], FAIL, GET, HALT, HEX, HONEY, HOLD, IF, ‽ [Interrobang], IPL, ISO, JUMP, KEY, LEVEL, LOC, LIGHT, LIST, LOOK, MAGIC, MEDIA, NO, PASS, PFx, POST, POWER, QUERY, QUIT, RAND, ROLL, SEND, SOUND, SRC, SUM, TEST, TIME, WORK, YES
Opinions:
Muirium wrote:Interrobang, Fail, (Rick) Roll, Honey … some fine choices there. Quit making me want more keys!
Belfong wrote:There is a BEL????
I can't resist THAT!!! It's my nick!!!
and for beltet too!
Ichigo87 wrote:Hello, could we have a DELETE or DEL in 1 unit row 1?
Done!
So what to add?
[interrobang] - row 4 for alignment with /?, or row 1 against 1!
FAIL - this was thought of as half a pair with PASS - how about row 2 as a delete replacement?
ROLL - a play on the German scroll lock and the frequent 7bit rolls - row 1 (and/or 2)?
HONEY - row 1 or 3
BEL - for its ASCII purpose this would be row 3
ALPS - late addition for zhasha ;) - row 4?
Unmentioned legends I'm bringing back:
ABORT, HALT, POWER; ATTN, BREAK, RAND, F0 [F zero]; ANY, DUCK, TEST all look like row 1 keys to me, any of these would be much appreciated! :)
PFx [programmable function] keys were mentioned before, is there any interest? I potentially could use a column of them numbered 1 to 5 for rows 1-5 on the rightmost column on a MX 8200...
27 Nov 2013, 20:54
Zhasha will buy at least 60 ALPS! To put on his MX…
But if we're going down the brand name route, we need this one first:
http://wecanbeaoriginal.com/blog/2011/0 ... umble-bee/
27 Nov 2013, 21:01
Let's call it HONEY/FACETSESAME:
How many will you and others order?
facetsesame
Mad Dasher
27 Nov 2013, 21:22
7bit wrote:Let's call it HONEY/FACETSESAME:
:shock: wow ok, considering existing pricing and MOQ, and the following kit of 16 keys:
10 Row 1 keys: ABORT, ANY, ATTN, BREAK, DUCK, F0 [BBC micro style F zero key!], HALT, POWER, RAND, TEST
2 Row 2 keys : FAIL, ROLL
2 Row 3 keys: BEL, HONEY
2 Row 4 keys: ALPS, [interrobang]
I would order 5 sets.
27 Nov 2013, 21:24
Sounds quite tasty actually.
facetsesame
Mad Dasher
27 Nov 2013, 21:42
So, six sets already?
27 Nov 2013, 22:09
I give it a try ...
:shock:
facetsesame
Mad Dasher
27 Nov 2013, 22:25
:o Thanks, ordered!
27 Nov 2013, 22:34
I call it HONEY/FUNCTION2 but you can also order it as HONEY/FACETSESAME:
Image :o
