KBC Poker aka "KBC 60%" aka "KBC 40%"
pzlate
06 Mar 2011, 05:34
Damn, that's pretty small.
sixty
Gasbag Guru
06 Mar 2011, 07:00
It's not about the size! It is about how you use it!
sixty
Gasbag Guru
06 Mar 2011, 07:36
Btw, I think the aluminum case will be an addon, not a separate poker mode. I'll ask to confirm.
celery
06 Mar 2011, 09:39
Does it fit over the existing case or something? Or is it screwdriver party time?
sixty
Gasbag Guru
06 Mar 2011, 09:42
The Poker case is virtually diassembled in 5 seconds, since its just the pcb screwed on top of a plastic plate with three screws. I assume you just replace the plastic case with the aluminum one.
celery
06 Mar 2011, 11:26
Too late, I'm already imagining a matroyshka keyboard with each shell fancier and more expensive than the last.
db_Iodine
06 Mar 2011, 12:00
A Poker with an aluminum case would be pretty cool.
ranm
06 Mar 2011, 19:35
db_Iodine wrote:A Poker with an aluminum case would be pretty cool.
... but expensive ? =/
Would be awesome though. Black keys with a Macbook-ish shade of aluminium =)
BababooeyHTJ
06 Mar 2011, 20:20
I'm thinking on getting in on the mass order from Geekhack for the Poker mostly just to try out red cherries. I just don't know about the ABS caps in the GH order and I have my doubts about the layout. I'm thinking that I would rather wait for the roumored Leopard with reds.
calavera
06 Mar 2011, 20:52
BababooeyHTJ wrote:I'm thinking on getting in on the mass order from Geekhack for the Poker mostly just to try out red cherries. I just don't know about the ABS caps in the GH order and I have my doubts about the layout. I'm thinking that I would rather wait for the roumored Leopard with reds.
Leopard? Leopold? Two very different things :mrgreen:
db_Iodine
06 Mar 2011, 22:08
A red leopard would be scary as hell.
BababooeyHTJ
06 Mar 2011, 22:33
Yeah, I'm not fond of the Poker layout but I do really want to try cherry reds.
sixty
Gasbag Guru
06 Mar 2011, 22:40
Layout is fine once you give it some time to grow on you. I love it by now.
duq
07 Mar 2011, 00:05
How much do you think that case would be sixty? It looks so damn nice....
sixty
Gasbag Guru
07 Mar 2011, 00:24
duq wrote:How much do you think that case would be sixty? It looks so damn nice....
I'm not sure. I sent an email to my KBC guy, I'll keep this topic updated once he gets back to me.
oyecomova
07 Mar 2011, 02:45
Is it going to be that nice raw aluminum or possibly anodized?
07 Mar 2011, 03:10
He only mailed some pictures. Also a tenkeyless case..
Nask
07 Mar 2011, 04:17
webwit wrote:He only mailed some pictures. Also a tenkeyless case..
Ah ! Need =]
07 Mar 2011, 04:30
calavera
07 Mar 2011, 05:14
wow um...can I have it? lol
Nask
07 Mar 2011, 05:20
Hum, it sounds that the KBC Poker will have a lot of options and as I can see there is a good one.
Zykos
07 Mar 2011, 06:29
A question about the Poker. Is this nKey, if it is, is it nkey over usb like the choc mini or is only through ps/2
British
07 Mar 2011, 10:26
sixty wrote:Layout is fine once you give it some time to grow on you. I love it by now.
It's probably much easier when you can actually touch-type... :?
07 Mar 2011, 13:50
The alu cases will be expensive though.
db_Iodine
07 Mar 2011, 13:58
Zykos wrote:A question about the Poker. Is this nKey, if it is, is it nkey over usb like the choc mini or is only through ps/2
I think it's 6kro over USB.
sixty
Gasbag Guru
07 Mar 2011, 17:32
Yes, 6kro over USB, apparently nkey over PS2, but I did not try it.
pita
07 Mar 2011, 21:28
I actually like the idea of wood case from KBTalking better..
Shazb0t
07 Mar 2011, 22:16
sixty wrote:Yes, 6kro over USB, apparently nkey over PS2, but I did not try it.
If it wasn't nkey over ps2 that would be very stange.
sixty
Gasbag Guru
08 Mar 2011, 00:26
Koeitje
08 Mar 2011, 00:55
Can somebody check this, I might buy one but I kinda need nkro.
