Yeah that would be the find...I've never seen one though.
What Are Your IBM Model F Preferences? (XT vs AT vs 122...)
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
- Main keyboard: Unicomp Spacesaver M
- Main mouse: CST trackball
I also sort of feel like the XT is under-appreciated as compared with the more exotic Model F variants. I mean... The XT is super heavy duty, it's not too huge (the combined nav and number keys are pretty efficient), and the eccentric layout is not as hard to deal with as it may first appear. And as you noted, they aren't hard to find.
I've got to say, however, that the new reproduction F77 looks pretty close to my ideal keyboard layout. In fact, I'd say the Ultra Compact F77 with the aluminum case is about as modern as keyboard design gets.
- depletedvespene
- Main mouse: Logitech G700s
- DT Pro Member: 0224
I have to disagree. When it first came out, the XT's layout's right third reeked of poor design. I was a teenager and I found it pretty bad, so much that I still remember how much of an improvement the "enhanced keyboard"'s layout was. So, why use the XT layout when the much better "normal" one is around? (besides the key feel itself, that is)
IMHO, YMMV, of course.
- DT Pro Member: 0190
Looks like a 3277 with only the 60% block.Wouldn't be too hard to make one since the caps already exist. Just cut the plate and modify Emdude's capsense PCB to only have that section and you'd be good to go. Just needs a custom case
- Main keyboard: IBM Model F122 XT Beamspring 3727
That's basically recreating the entire beamspring less the switch.orihalcon wrote:Looks like a 3277 with only the 60% block.Wouldn't be too hard to make one since the caps already exist. Just cut the plate and modify Emdude's capsense PCB to only have that section and you'd be good to go. Just needs a custom case
- depletedvespene
- Mr.Nobody
- Main keyboard: IBM Model M/F
- Main mouse: Lenovo Big Red Dot
There is a problem with AT layout; the backspace and Esc are adjacent, for several times, I hit the Esc key by accident and lost a whole page of text I'd keyed in, which's exasperating. Now, I've got Esc and Sys Req key swopped.
That's the thing with IBMs for me, they are never quite perfect and yet they are the best I have found.
I have an XT at home and model M at work.
The XT has a hideous layout but a very compact form factor and that retro look that I just love, clicky feel and force is absolutely spot on for me, here's a photo of mine: keyboards-f2/ibm-xt-almost-ended-my-game-t17664.html
The AT is bigger than the XT, making me wonder, well, I might just use a model M and spare me all the spacebar modding. In general there's something about the AT form factor that just doesn't appeal to me.
122 battleship, I could never have such a beast occupy the whole desk.
Model M, I find it a bit too stiff, like other members have reported as well, I like it, hate the numpad and the 90s look of its case, but in general for now is the best I could find on a budget.
Definitely an F77 would be the end game.
right now my soft modded(sharpkey + auto hotkey) f AT, but i do want to see what I can do with the XT and auto hotkey too! when i get my f122 it'll probably be my main, if i like it even half as much as my gf does her unicomp model m 122.
also the hhkb layout on the f77 from elipse thats coming may be enough to usurp the 122 for me
- Main keyboard: Modded IBM Model F AT
- Main mouse: Mionix Naos 8200
- Favorite switch: Capacitive Buckling Springs
I like the IBM Model F AT the best as it is much more compact and and has normal key sizing plus can be easily modified to a modern layout all that needs to be done is some custom key remapping and new keycaps or some relegendable keycaps. I know some really like the a dedicated nav cluster but for me using the num pad is no issue. Below is my modernised IBM Model F AT I use as my daily driver. The layout I have set gives me F11 F12 and all the media keys the image looks blurry in the attachment but it is actually not just do open the and it is perfectly clear. This image was posted in a different thread but thought it would be more appropriate here.
- IMG_20190603_110954.jpg (186.09 KiB) Viewed 9630 times
- Darkshado
- DT Pro Member: 0237
Lately it's been the F AT for me too, since it has the closest layout to a standard TKL once modded.
Wow that's quite the keycap set you got there also nice ISO mod have not seen more than one other ISO AT. I also like the TKL layout you have but I could never get used to having half my f keys on one side and the rest on the other side also I saw you got a model m space bar installed my I ask how hard that mod was to do. Either way looks great well done.Darkshado wrote: 04 Jun 2019, 07:05 Lately it's been the F AT for me too, since it has the closest layout to a standard TKL once modded.
- Darkshado
Thanks! The alphas, arrows, and weird legends came from an Impressa (a.k.a. Wheelwriter) typewriter; num row, homing keys, guillemets, accents, symbols, Enter and function keys are from the Unicomp set I originally ordered for this board.Fkazim wrote: 04 Jun 2019, 15:31 Wow that's quite the keycap set you got there also nice ISO mod have not seen more than one other ISO AT. I also like the TKL layout you have but I could never get used to having half my f keys on one side and the rest on the other side also I saw you got a model m space bar installed my I ask how hard that mod was to do. Either way looks great well done.
For your information: I set the upper-leftmost key to Super/Windows and the lower-rightmost one to Menu. The blanks do nothing for the moment. This effectively gives me all the keys from a TKL layout with no layering required.
I don't completely touch type the F-keys so their displacement isn't as big a deal as I thought at first, though I still reach for the top of the board on occasion and likely will keep doing so since this is one of many boards I use regularly.
For the space bar, take a look at my earlier write-up in this thread. Those pads send Set 3 codes, by the way. I trimmed the Alt caps I had, but in retrospect 1.25u caps with proper legends from Unicomp would probably look better.
- Main mouse: Logitech TrackMan Marble
- Favorite switch: IBM Model F BS
My first computer was an IBM PC 5150, meaning the Model F XT was my first keyboard. I've had countless keyboards since, including a number of rubber-dome mushboards, and a mixture of IBM, Lexmark, and Unicomp M's.
A couple of years ago, I nabbed a Model F XT and a Hagstrom converter (which IMO isn't terribly good), which is my daily driver in my office. My daily driver, connected to my laptop, is a black Unicomp custom classic, that has the Ctrl and Caps Lock keys swapped from the factory, and no Windows keys.
Both are nice boards, but the Unicomp feels sloppy and mushy compared to the Model F, and goes "thock" instead of "chit". Of course you all know these characteristics. Model F wins for me on both typing feel and layout, though I really want an F122--I use TN3270/TN5250 applications regularly, and the extra keys would be nice.
This, of course, is discounting my perpetual pining for a 5251 beamspring... but that's a bit rich for my blood.
- vometia
- irritant
- Main keyboard: Durrr-God with fancy keycaps
- Main mouse: Roccat Malarky
- Favorite switch: Avocent Thingy
- DT Pro Member: 0184
I'm sure I've mentioned elsewhere about gaming on an M, which I only stopped as it tended to keep my other half awake. I found it perfectly amenable other than that, but I also speak as someone who is not especially adept at combat, nor reaction times, and who definitely sucks at any measure of dexterity like Mirror's Edge. But as not-especially-leet as I am, as a regular gamer and modder I'm more than happy to game on an M, or an MX Blue, or a Matias, or... well, as long as it's a decent keyboard, IMHO. NKRO and hair-trigger switches aren't a necessity for me and when it comes to switch pressure and what-not, the bad console port is likely to be a factor way before any self-respecting keyboard.
I game on my IBM Model F AT and it is absolutely fine no rollover issues its nice and clicky good key placement, normal key sizing once modified to an ANSI or in my case an ISO layout. Seriously if you like light clicky switches you can't really beat a Model F.
- fohat
- Elder Messenger
- DT Pro Member: 0158
Remember that Soarer originally embarked on his converter project in order to get NKRO over USB so that he could game on an F AT.
I game on a F-XT - works just fine! And in the heat of the moment its quite enjoyable to angrily smash-repeat a key after dying
I love and hate the Model F's so much - reason: there isn't a perfect one. For me it would be the F-77 with Function row on top and some fold-out feet. (i.e. cursors, nav cluster, and the 1 unit keys between alt/ctrl. I'm a programmer so I definitely have use for a 'windows' type key there.)
I would like to try an AT (can't find any!), but I just love the iron heft of the XT - not sure if I would like full plastic on the AT.
The other, bigger types.. I would like to be able to reach my mouse..
(although, I still want to try the F107, so much METALLLL - hey Chyros, don't you wanna start doing tours of your house man?
wanna touch it allllllll..)
Anyways, I managed to get the XT to be 'normal' by messing with the numpad + making ALT into CTRL and the key next to left shift into ALT + CTRL into windows key.
- Chyros
Yeah my favourite is the F107, it's SO GOOOOD xD .caiko wrote: 03 Jul 2019, 18:32 I game on a F-XT - works just fine! And in the heat of the moment its quite enjoyable to angrily smash-repeat a key after dying
The other, bigger types.. I would like to be able to reach my mouse..(although, I still want to try the F107, so much METALLLL - hey Chyros, don't you wanna start doing tours of your house man?
Anyways, I managed to get the XT to be 'normal' by messing with the numpad + making ALT into CTRL and the key next to left shift into ALT + CTRL into windows key.Spoiler:
Chyros wrote: 03 Jul 2019, 20:26Yeah my favourite is the F107, it's SO GOOOOD xD .caiko wrote: 03 Jul 2019, 18:32 I game on a F-XT - works just fine! And in the heat of the moment its quite enjoyable to angrily smash-repeat a key after dying
Easier to rob a bank than to find one of those now!
- Chyros
Imagine how hard it was to rob a bank when those were still around!caiko wrote: 03 Jul 2019, 21:02Chyros wrote: 03 Jul 2019, 20:26Yeah my favourite is the F107, it's SO GOOOOD xD .caiko wrote: 03 Jul 2019, 18:32 I game on a F-XT - works just fine! And in the heat of the moment its quite enjoyable to angrily smash-repeat a key after dying
Anyways, I managed to get the XT to be 'normal' by messing with the numpad + making ALT into CTRL and the key next to left shift into ALT + CTRL into windows key.Spoiler:![]()
- fohat
- Elder Messenger
The AT still has the 2 internal of the 3 steel plates and probably weighs about the same as an XT.
Oh don't get me wrong, if I find one I'll get it - EU is a pain in the ass though. g'damn backwater
I think the AT is a little lighter but to be honest the plastic on the AT is far superior to the plastic used on the XT heres why.
1) The AT plastic is the same plastic used on the Model M (PVC) as this is the case the plastic is much more flexible meaning the AT is much less likely to get cracked and almost impossible to get faded over time.
2) The AT uses PVC plastic that is not painted meaning there is no chance of any paint flaking off or wearing off like it can on XT as that uses painted plastic which dirt really sinks into.
3) This one everyone may not agree with but the Plastic on the AT in my experience is easier to clean than the painted plastic on the Model F XT.
The only disadvantage to the AT's construction is that the bottom case is not made of metal and instead uses plastic with locking tabs along the bottom and screws along the top. Anyways that's just my findings and opinion.
- Wazrach
- Main mouse: Razer Viper 8KHz/ Viper Mini
I disagree. I've had about 9 XTs and two ATs. The XT's plastic is much thicker and feels a lot tougher. It sounds dense when knocking on it. The AT and F122 seem to use the same kind of plastic, which is a lot thinner and more susceptible to cracks. I think they used slightly different types of plastic, as one AT shower streaking after cleaning with isopropanol, whereas the other one didn't. Of course, the cases are still prone to scratches and wear - simply scrubbing the case with a scourer was enough to wear away the paint.Fkazim wrote: 04 Jul 2019, 00:50I think the AT is a little lighter but to be honest the plastic on the AT is far superior to the plastic used on the XT heres why.
It's very obvious that IBM were pinching pennies with the AT Model F, compared to the XT. The F122 is of course much heavier, but the case is still thin and brittle.
The AT uses the same plastic as the Model M it is thinner but not brittle, very flexible and less likely to crack. Where as the XT uses a thicker denser but more brittle plastic which is more likely to crack. Also it is painted meaning once the paint flakes off or wears off you are left with a yellow coloured plastic underneath.Wazrach wrote: 04 Jul 2019, 13:25I disagree. I've had about 9 XTs and two ATs. The XT's plastic is much thicker and feels a lot tougher. It sounds dense when knocking on it. The AT and F122 seem to use the same kind of plastic, which is a lot thinner and more susceptible to cracks. I think they used slightly different types of plastic, as one AT shower streaking after cleaning with isopropanol, whereas the other one didn't. Of course, the cases are still prone to scratches and wear - simply scrubbing the case with a scourer was enough to wear away the paint.Fkazim wrote: 04 Jul 2019, 00:50I think the AT is a little lighter but to be honest the plastic on the AT is far superior to the plastic used on the XT heres why.fohat wrote: 03 Jul 2019, 23:50
My AT is made from the exact same plastic as my Model M's 1st gen's and 2nd gen's plastic for sure. Also the plastic on my F122 is the same painted plastic as on my XT
So this is how all the keyboards are in my experience
IBM Model M- Thin flexible PVC Plastic
IBM Model F AT- Thin Flexible PVC Plastic
IBM Model F XT- Thick Dense Painted Brittle Plastic
IBM Model F122- Thick Dense Painted Brittle Plastic
Attached below is an example how the Thick dense painted brittle plastic can crack. The keyboard in the picture 1 is an F122 and the keyboard in picture 2 is an XT. The whole seperation between the F keys and the Alpha numeric keys
- IBM Model F122 cracked.jpg (226.62 KiB) Viewed 9025 times
- IBM Model F XT cracked.PNG (59.5 KiB) Viewed 9026 times
