Round 4 / packing (99.8%) / shipping (99.7%)
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
It costs also my time to set that extra kit up.off wrote:So what would that make the price if I wouldn't cancel my function kits?
$10.
Still $12 for the RETRO variant.
- 7bit
There is no NOIR/TERMINL kit. The closest match is a NOIR/STANDARD which contains more keys that usual Standard kits:silv wrote:How much would a Noir Terminal Kit + ISO DE be?
Please tell me if there is anything missing for your terminal keyboard (like G80-2551 or G80-2100)!
(If you take NOIR/STANDARDDE it comes with J-shape return key and all that.)
- silv
- Favorite switch: MX Blues
Okay, i took a look.
I send a message to 7bit_r4 with:
NOIR/STANDARDDE
GAMER
SPACE
EMAIL e-mail@address
to get the Noir Standard DE Kit, Noir Gamer Kit and Noir Space Bar fitting for G80-2551? Would the Space Bar fit on a Qpad MK-XX, too, or is that a different width?
NOIR/STANDARDDE
GAMER
SPACE
- 7bit
You needsilv wrote:Okay, i took a look.
NOIR/STANDARDDE
GAMER
SPACE
NOIR/SPACEOLD
Qpad MK-XX: you have got to meaure yourself. I do not own that keyboard.
There is no NOIR/GAMER kit.
- 7bit
Does not exist.silv wrote:That is sad, but understandable. What about the NOIR/RGBY Kit?7bit wrote:There is no NOIR/GAMER kit.
Maybe next time there will be some add-on stuff.
- 7bit
If there is more interest in extra NOIR key caps for terminal keyboards (there are so many naked G80-2551 around!) I might put some extra stuff together.
- Zehkul
- Main keyboard: Filco Majestouch
- Main mouse: CM Spawn
- Favorite switch: Mother-Buckling-Springs!
The QPAD issue has already been brought up. Same as Blackwidow, etc. Apparently the SP universial spacebar FITS, it’s just .25 too long so that the 1.5 modifiers next to it don’t fit any more.
- 7bit
That's very interesting!Zehkul wrote:The QPAD issue has already been brought up. Same as Blackwidow, etc. Apparently the SP universial spacebar FITS, it’s just .25 too long so that the 1.5 modifiers next to it don’t fit any more.
So the space bar is too long 0.125 units left and right and therefore 1.25 units modifiers would fit!
- 7bit
Not at all!!!Zehkul wrote:Yeah, but Frankenstein ish on the other side, I guess. Haven’t seen a photo yet, that guy lost the cable to his cam. (._.) He said it wasn’t really easy to put on though.
The gap between the keys will help with orientation on the keyboard!
Also, if they are not genuine Cherry keys, SP keys are always an improvement!
- 7bit
Still the exact space bar measures are needed for this one:
Razor_BlankWindow
Razor_BlankWindow
- 7bit
The universal space bar has 6 mounts! I doubt they are all used by the Black Widow!Zehkul wrote:Of course, but correct spacebars are better.
You can measure the SP universial spacebar.![]()
Or give me some tips how to do accurate measurements without accurate equipment.
- universal_space.png (16.99 KiB) Viewed 5233 times
- Zehkul
About 49mm might not be accurate enough to for new molds, but it is for seeing that 40mm isn’t really the way to go.
But Costar ish stabilizers are rather forgiving (more so than Cherry ones, obviously), I doubt 50mm is right. It should be closer to 49mm, and the 47-48mm of SPACENEW aren’t right either, so another universial spacebar isn’t really possible, I think. Or because of Costar stabs it could work again here, too? Mhhh…
- 7bit
I don't have the universal space bar yet, so I can't take any measures. SP will make the spherical space bar with the same munts as the on for cylindricals.Zehkul wrote:About 49mm might not be accurate enough to for new molds, but it is for seeing that 40mm isn’t really the way to go.
- off
nope.
Might wanna make that functionmusic, people will understand pronto
And really, please make it in gamercolour! (round3/functionmusic/orange) or another variant on the default r3/retro scheme that still fits in yet is different.
Let us know when&how it's live..
!oh, and please include a 12th 'relevant' key in there, like 'select/open/lock/dt/stoprun or anykey', so nobody ends up with a signature plastic row interrupted by one cherry!
- 7bit
OK,off wrote:nope.
RETRO/MUSIC
ROUND3/MUSIC/ORANGE
plus OPEN?
plus TITLE?
plus MUSIC?
- off
Wicked!7bit wrote:RETRO/MUSIC
ROUND3/MUSIC/ORANGE
plus OPEN?
plus TITLE?
plus MUSIC?
Erm, I would love 'play' to be 'play pause' (with pause on the next line) but that might just be me..
As 12th key you're willing to do a new legend I see?
Ooh otherwise, 'Find' or 'Props' would be good (from terminal, but row1), would that incur extra costs?
And here is a toughy- is there any way in which you could get SP to make sure all keycaps have posts that are the same length from the inside top of the key (like, post+cross or just post; but all at the same length would make sure felt dampers and o-rings work consistently proper)??
@newphantomlogokey *ffffffffffffffffftakemymoney*
- 7bit
No, kits will cost $12.off wrote:Wicked!7bit wrote:RETRO/MUSIC
ROUND3/MUSIC/ORANGE
plus OPEN?
plus TITLE?
plus MUSIC?
Please notice that there are FF and REW as well as Forwrd and Rewind, so maybe you want other keys instead. Just make up you mind and tell me what you want.
But don't take too much time, I don't want to delay anything!
