- Khers
- Main keyboard: LZ CLSh
- DT Pro Member: 0087
Maybe, but I'd say that the fact that it's a hopelessly scarce Norwegian layout increases its price a bit over the more common HAMPO and HAMDE 5ks. I might be overestimating its influence however, and I might be outright wrong. And it does seem to be in rather good nick, maybe not BNIB, but still.
- photekq
- Cherry Picker
300EUR is typical price for a Portuguese/DE MX5000 BNIB.
- photekq
- Cherry Picker
- photekq
- Cherry Picker
Hard to gauge that one. It's the 1985 model, right? I've seen very few of them, and typically when it comes to M's the older ones fetch higher prices. 1985 is about as old as you'll get, and of course the fact that it's an industrial (and a square black label one at that) will bump the price up quite significantly.
I'm not great when it comes to M's so I'll let someone else appraise it, but expect a high price!
Out of curiosity : Are you looking to buy or looking to sell?
- Chyros
1985 or 1985. They're very rare. The black metal badge is really kickass.photekq wrote: Hard to gauge that one. It's the 1985 model, right? I've seen very few of them, and typically when it comes to M's the older ones fetch higher prices. 1985 is about as old as you'll get, and of course the fact that it's an industrial (and a square black label one at that) will bump the price up quite significantly.
Mine is undated but the controller is from 1984, it's one of the Mandolin models, probably from 1985; it appears to be a very early production model fitted with prototype parts including an EEPROM (?) chip. That one was estimated at £300 or more iirc. After I put out my video tour of it I've had a considerable amount of offers for it xD . I suspect you'll have no trouble shifting it at all!
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
- scottc
What?! For a full-size industrial M?! I am shocked... I would've guessed maybe 50% of that.
- alh84001
- v.001
- Main keyboard: unsaver
- Main mouse: logitech m305 / apple trackpad
- Favorite switch: BS
I'm not a native english speaker so something might have been lost in translation
. I meant powerful in a way that it is much more impressive, it makes a much more powerful impression.
- Karandach
- Main keyboard: FC660C Silenced/Heavy-6 | IBM SSK
- Main mouse: Logitech G403 | MX Master 3
- Favorite switch: Topre | Beam Spring | Buckling spring
- seebart
- ramnes
- ПБТ НАВСЕГДА
- Main keyboard: KMAC LE
- Main mouse: Zowie AM
I really doubt anyone would pay 400-500€ for that industrial model M, even with that nice badge. I'd say around 300€, but then I don't really follow IBM market those days.
I'd say somewhere between 120 and 140$, more if you have the box, less if caps show some signs of use.
~100$
Looks in very good condition, is it NIB?
- seebart
It is not NIB and I do not have the case and yes the caps do have shine.
- seebart
- alh84001
- v.001
It would be crazy to take notes I agree
, but to note what each key does in different programs, OSs, whatnot, it makes perfect sense, especially in a professional environment where multiple people use the same station.
- seebart
Shortcuts etc. sure.
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
Those label flaps are pretty common on older boards, AEK/AEK II is a good example.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
Give a good look, on the right side you'll see there's a thumb index for the 10 programmable layers of the PF pad, so you can note what is actually programmed on each PF key for each layer (for example: layer 4, PF3 key: "print date").
And sorry seebart, no clue what they can be worth at the moment.
- Wingpad
- Main keyboard: Industrialized Model M/Orange ALPS Dell AT101W
- Main mouse: Logitech G502-RGB
- Favorite switch: Capacitive Buckling Springs
- DT Pro Member: 0162
I am hoping to sell a custom USB-Modded Black Dell AT101W with Matias Quiet Clicks. I built this board with new stabilizers, switches and ABS keycaps with the intent to use it as a daily driver but I ended up finding out that the switches are too light for me. The caps lock and spacebar are dyed original caps and the original green indicator lights were swapped for blue LEDs. Here is a link to an album with some pictures. I would like to sell it for $120 but what do you guys think, would that be fair?
- scottc
I think that's honestly a pretty fair price considering the condition and restoration work you put in. Looks really nice. If you have a build log you should post it in the workshop.
- fohat
- Elder Messenger
- DT Pro Member: 0158
3 questions:
Is the case painted black? Does that account for no logo and beige lock light sticker?
How did you do the USB conversion?
How did you dye the spacebar and CapsLock? ABS does not usually take dye very well.
- Wingpad
Yes, although I used vinyl dye so it preserved a lot of the original texture. Also, to be fair I think the beige lock light sticker helps to offset what would otherwise be a massive chunk of black plastic.
It is an embedded PS/2 to USB converter, but it is a nice one.
Much to my surprise, I tested the vinyl dye I used on the rest of the case and it worked marvelously on some of my extra keys. Rather than leaving the capslock and spacebar beige (since the keycaps in the BonW set did not work on this board), I decided to spray/dye them as well. So far it appears to have worked rather well and they are smooth (in texture).
Thanks! I wish I had one but sadly I don't. I thought I took pictures along the way but wasn't able to find them
- fohat
- Elder Messenger
When you say "vinyl dye" are you talking about a film-forming product something like the middle can?
Otherwise, most water-based dyes seem to require activation temperatures too high for ABS to tolerate.
The USB converter is a good idea. Is the original cable coiled up inside the case?
- F-122-X02-paint-etc-002.jpg (231.14 KiB) Viewed 6933 times
