home made key pullers
keyboardlover
15 Mar 2011, 15:29
Lol, nice Lego guy!
amleth
15 Mar 2011, 15:39
It is just a sign of appreciation to the official Lego guy for changing his small photo.
Evil_Spork
15 Mar 2011, 19:37
Wow I think I need to mangle some paperclips when I get home!
lucidlts
16 Mar 2011, 06:03
uh... i dont think i want to get myself a lego crowbar just for pulling keycap.
stunned by the 2nd pic though.
False_Dmitry_II
18 Mar 2011, 20:47
I just use a PCI slot cover. It works great.
nanu
27 Mar 2011, 03:04
I was inspired by a binder clip and made a new unit-sized puller since my brass one fell apart after disuse :lol:
small paperclips + steel strapping
I might try making a variant with a hinge for bigger keys.
JBert
27 Mar 2011, 21:29
I use a bit of string and a popsicle stick for those larger keys.
Here's how to make your own key-pulling rig:
  • Make an overhand loop knot into the rope.
  • Pull one of the free stands through the loop and put the two free strands together again.
  • You should now have 2 loops. Put one loop e.g. on the left side of the spacebar and push it down using the popsicle stick. Carefully pull it to the right to move it under the spacebar until it hits the left stabilizer.
  • Do the same for the right side.
  • Carefully adjust both loops to be of equal length, then pull the free strands upwards. Make sure to use the other hand to press the keyboard down and keep the spacebar from flying away.
