Cherry Corp PBTs?
sixty
Gasbag Guru
16 Mar 2011, 22:30
manfaux wrote:
sixty wrote:The new ones are PBT also, but they are much thinner. Its pretty hard to find the old ones without pulling a keycap. The first safe indicator is that it uses the Bi-Color scheme (meaning F5,6,7,8, etc... are a different shade of grey and not all white). Other than that you will have to gamble. I've seen thin ones start appearing as early as 97.
wow, thanks for all these info guys,
I confirmed with a couple of Chinese cherry collectors, they seem to agree that if you have one with scooped F/J, it's most likely thick PBTs!
Yep. I've only seen one exception to that rule.. which was a Compaq 1800 which had thick F and J caps, and the rest thin :D
manfaux
16 Mar 2011, 22:41
I was also told, the last 3 figures of the Serial Number signifies the manufacture date of that particular keyboard,
This reads E18,which means it was made in year E, week 18, Cherry used A for 1988, so E would be 1992.
RiGS
16 Mar 2011, 23:02
I do not have any experience with cherry PBTs, however the Topre PBTs are very slippery, and uncomfortable for gaming.
The filmsy ABS caps on the Steelseries have a much better grip.
amleth
17 Mar 2011, 05:15
manfaux wrote: If you are only talking about Cherrys, easy, Cherry uses POM on black keys(non double shots) and PBT for white/grey keys,
Thank you for nice explanation.
Science is nothing else but an explanation. It says YOU prove it.
Religion is nothing else but an explanation. It says Do Not prove it, Shut up and belive it.
I hope your explanation belongs to former.
IanM
17 Mar 2011, 05:22
RiGS wrote:Topre PBTs are very slippery, and uncomfortable for gaming.
Pro gaming tip: wear Marigolds so that your fingers never slip! Guaranteed to improve your scores...
sixty
Gasbag Guru
17 Mar 2011, 08:02
Gloves and USB gold contacts! I'm going to be the next WCG champion for any game!
RiGS
17 Mar 2011, 14:39
That's creepy.
amleth
17 Mar 2011, 14:55
Dirty Six and ScarFaced Three
OLD ?
NEW ? Sorry.. Dunno..
It is mine. Dunno details.
thanks, Scarface
thanks, Scarface
07 G80-3000HAV.jpg (98.86 KiB) Viewed 10294 times
thanks, Scarface
thanks, Scarface
08 TG3 Black.jpg (98.76 KiB) Viewed 10294 times
thanks, Scarface
thanks, Scarface
09 Cherry Mini _ China.jpg (54.57 KiB) Viewed 10294 times
ripster
17 Mar 2011, 17:23
The one that looks like a Penis with three balls has always been my fav.
sixty
Gasbag Guru
17 Mar 2011, 17:37
Looking at the pictures I would say all of them are what I would consider "new type", going only by the logo. The exception is 07 and 09, those are old style.
amleth
17 Mar 2011, 21:27
Just add 2 more potos.
thanks scarface
thanks scarface
10 Scarface .jpg (178.95 KiB) Viewed 10265 times
thanks kbdholic
thanks kbdholic
11 kbdholic Blue img_5363.jpg (85.04 KiB) Viewed 10265 times
keyboardlover
17 Mar 2011, 21:29
For the blue photo, which is old and which is new?
amleth
17 Mar 2011, 21:34
i got my idea.
but, there are too much gurus and worshippers out there already.
my only chant for my goddess is PROVE IT.
so, nothing to say anymore.
amleth
17 Mar 2011, 21:36
keyboardlover wrote:For the blue photo, which is old and which is new?
The owner of the poto does not know and one guru who made comment too.
Both of them agreed with LET US DO FEEL IT (i guess).
amleth
17 Mar 2011, 21:40
For your reference.
http://www.kbdmania.net/xe/1412188
keyboardlover
17 Mar 2011, 21:41
I'm going to get some blues soon which I believe are old. Will post a photo when I do.
sixty
Gasbag Guru
17 Mar 2011, 21:46
I never felt a difference on Blues. Old or new, same feeling to me.
Clear difference on black switches though!
amleth
17 Mar 2011, 21:49
http://www.kbdmania.net/xe/1636590
This one have clear datum, but poto is not.
He says, it is New In Box.
thanks kbdholic
thanks kbdholic
kbdholic img.jpg (84.35 KiB) Viewed 10254 times
EDIT --> 1996. but, it is not clear though (i mean OLD or NEW generation)..
amleth
17 Mar 2011, 22:02
sixty wrote:I never felt a difference on Blues. Old or new, same feeling to me.
That is the last and the most important part of this discussion.
If you do not feel it.
Sorry, you are out.
So, what ? Am I a (stupid) dummy ?
Weird... All this discussion have started from the Blue slider (As far as i know).
17 Mar 2011, 22:38
Can you next take on the Cherry stabilizers?
amleth
17 Mar 2011, 23:37
webwit wrote:Can you next take on the Cherry stabilizers?
First of all i am not a collector at all. You are the one. Right ?
Nothing much to say about stabilizers (especially for Cherry ones).
Personally, i hate that.
It feels like be hit by 4*4 inch square wooden bar (directly into your skull center line).
It has own damping device (toe nail) though, it ruins the feelings. So, everybody cut it out. Right ?
Wyse stabilizers are almost the same situations (i mean, a head-on collision feelings/noise).
Because, it also hits bottoms (PCB) as in the Cherry ones. Nails? guess it have.
Majestouch-type. Yes, i prefer to it. Little bit of greasing, it is just perfect.
Several delicate inconsistency are found between brands though, it is ok. They are the boss.
Maje the 2nd (or the Linear or the Red ? whatever), they still have it.
keyboardlover
17 Mar 2011, 23:41
amleth wrote: It feels like be hit by 4*4 inch square wooden bar (directly into your skull center line).
Ouch! Whatever keyboard you're describing, I don't want it!
17 Mar 2011, 23:42
Seems we agree.
amleth
18 Mar 2011, 00:40
Many of Cherry lovers have problem with their stabilizers.
So did i.
Wire-side has a hook (bigger hole) and non-wired has some kind of snapping shape (smaller hole).
So, when you dismantle the keytops (i mean NOT stabilizers itself), you must have do hook-side first. If you fail, you find yourself in an annoyance situation. You have to stop harvesting cherries. You have to plant it first. If you are more unluckier, you could break the hooks (i mean possibly). For beginners it feels like more than that. Really. I clearly remember, the only words in my head was just f*** four times. Sure, there is a plating rules too. You must plant a hook first... not that much happy..
Use my Crowbar. It can handle your lovely Cherry stabilizers 110% safetly. Promise !!!
http://deskthority.net/viewtopic.php?f=2&t=347
ripster
18 Mar 2011, 00:59
The Definitive Guide on The InterToobs For Pulling Nasty Cherry Stabilizers.
http://geekhack.org/showwiki.php?title=Island:12649
amleth
18 Mar 2011, 01:16
ripster wrote:The Definitive Guide on The InterToobs For Pulling Nasty Cherry Stabilizers.
You have had almost everything about keyboard.
Nice post. Thanks.
Don't Reinvent The Wheels.
amleth
18 Mar 2011, 01:19
On second thought.
You have reinvented the wheels very nicely.
You only got conventional weapons. ^^..
i got my own idea, originality.
( Reinvention reminds me of a Galápagos-minded copycat guru group. Who have very strict memberships, have raised their voices loudest to demand originality for 40% size boards AND tenkeyless boards).
ripster
18 Mar 2011, 04:08
I like originality too.
Let me guess, you're on one of those Asian Forums where they call putting in multi colored keys original.
keyboardlover
18 Mar 2011, 04:11
Best part of that guide: The photo of my hand. =)
lucidlts
18 Mar 2011, 18:27
wow ~ the damage on Topre is sure painful D:
