DSA Retro Set (SHIPPED!)
Gilgam
12 Feb 2013, 12:10
matt3o wrote:The FR set alone would be around $13 in the first tier, but please note the there might be molds that SP don't have. That would be $45 for each new key. (I'm going to ask)
Also... aren't number and symbols inverted?
SP already did a FR kit (several indeed) but there were errors... one iunder the mu and there were 4 { for the altgr characters instead of 2 [ and 2 {
12 Feb 2013, 12:13
Yes, but the molds are not for DSA, but for DCS and SA family.
-[°_°]-
12 Feb 2013, 12:15
I'll take care of them doing it right :) Unfortunately molds are per family and as far as I can tell they have very few molds in DSA
Edit: whops, 7bit's first :)
Jesterfox
12 Feb 2013, 12:18
Nice Set. But I have some questions about a space bar, because the keyboard (NEO) I would use this set on is really wired at this point. 6.25 Units should be right but the mountpoints are not like Filco.
Picture: http://www.computerbase.de/forum/attach ... 1358884203
Top is a cap that fits on a Filco, bottom is a universal space from SP and the middle one is from the NEO. The stabs uses the middle stems on the sides and the same stem as the Filco in the middle.
Am I right that the 6.25 unit space offered here is the same as the bottom one on the pic? Is there any chance to get a space that would fit on the NEO or whould the 6 unit DSA fit? (with some space to the neighbour keys)
-[°_°]-
12 Feb 2013, 12:32
The DCS spacebar is the standard SP universal. Regarding the 6 unit DSA, can you measure the distance of the outer stems you need from the center one?
huttala
12 Feb 2013, 12:42
7bit wrote:Yes, but the molds are not for DSA, but for DCS and SA family.
It's been almost a month now since I paid you for the TIpro board, and you have still not sent it and keep ignoring my PM's. What's up with that? I'm getting kind of pissed by this now... Thought you were a good salesman. Do I really have to go public and spam threads just to get a response from you ?
maxmalkav
dye hard
12 Feb 2013, 14:45
pasph wrote:And here it is the silly italian set, please ask to SP
I've counted 12 keys in common with Spanish layout, 13 if we don't pay attention to "@", for which you need Alt Gr + 2 to write with Spanish layout :)
BimboBB
12 Feb 2013, 15:08
Maybe it might be useful to ask again for an entire Euro-Kit and an additional France Kit (they have quite much unique legends, so might be better to have them on their own). I just had look over 7bit's euro-kit and took out a few keys which had:
1. nearly the same legends (just different on third/fourth legend)
2. were included because of different rows (problem doesnt exist here)
3. already included in extra key kit (maybe still possible to swap them into a euro-pack)
Not sure, if i overlooked something.
CeeSA
12 Feb 2013, 15:15
very nice group buy!
The order form is very well done.
For common keyboards we should make a reference with keycap size in the wiki like this:
http://www.wasdkeyboards.com/keycap-compatibility
With it, I would be able to make an order without someone else ;) Maybe some other guys would be happy too?
-[°_°]-
12 Feb 2013, 15:20
I believe a pan-European kit might end up costing some bucks more than the standard ALPHA (plus the custom keys)
BimboBB
12 Feb 2013, 15:31
Was just an idea. Not sure what is more useful, either one euro-kit or several different language packs. :?
-[°_°]-
12 Feb 2013, 15:40
personally I'd prefer 1 kit to rule them all, so we could include languages that wouldn't meet the MOQ
Gilgam
12 Feb 2013, 15:51
Oups didn't knew that...
a Pan euro maybe nice (what a symbol ! :mrgreen: ) but many will buy FR keys useles for them, and if the price is higher than separate language sets...
It's time to get an unified layout...
12 Feb 2013, 16:08
Gilgam wrote:...
I'm afraid this unified layout will be mainly a mixture of SE and DE layout, still far away from FR layout.
BimboBB wrote:Not sure, if i overlooked something.
You can throw out evrything which is in the UK/7BIT kit (Extra kit), which is already included!
I'm so lucky, that my plain 7bit-ASCII-language kit made it.
pasph
12 Feb 2013, 16:33
There's 6 different keys, in fact for lysol gb i'm fine with ES
pasph
12 Feb 2013, 16:40
Hmmm...koreans like the plum mods?
Or are the vendors?
tlt
12 Feb 2013, 16:50
How are you making those set mockups?
-[°_°]-
12 Feb 2013, 16:59
7bit wrote: I'm so lucky, that my plain 7bit-ASCII-language kit made it.
who knows... I might still remove them (muahahahah)
pasph wrote:Hmmm...koreans like the plum mods?
Or are the vendors?
one vendor joined the GB
tlt wrote:How are you making those set mockups?
Inkscape
12 Feb 2013, 17:06
matt3o wrote:who knows... I might still remove them (muahahahah) ...
:cry: <---- 7bit when matt3o removed certain keys from the Extra kit.
-[°_°]-
12 Feb 2013, 17:19
I need to know if you want 1 pan-European set or N smaller kits (one per language).
What languages do we need? We talked about: FR, DE, IT, ES, UK, anything else?
Ascaii
The Beard
12 Feb 2013, 17:22
SE, but that is one language I would recommend lumping with DE, since they are incredibly similar. Unless im mistaken, it would add only 3 keys to combine the two.
-[°_°]-
12 Feb 2013, 17:26
mmh so we could merge similar languages.
IT+ES
DE+SE
FR
UK+7bit :P
BimboBB
12 Feb 2013, 17:34
Think I did. A few keys from dirge, seems to be not original UK. At least they are not in the euro-kit.
@matt3o
I support whatever is more useful with regards to MOQ and legend fee distribution.
rindorbrot
12 Feb 2013, 17:34
if DE happens, I'd probably be in for a set.
kvad
12 Feb 2013, 17:38
... and NO (as in Norway) - combined in one pack with other languages sounds fine. I'd guess the volume would partly offset the cost of extra keys.
dirge
12 Feb 2013, 17:39
Only UK key I think that's not in the UK/7Bit pack is [¬`¦] so that could be added in or we could just order in with whatever other pack its in. :)
Glad to see prices have come down loads. :)
-[°_°]-
12 Feb 2013, 17:43
dirge wrote:Glad to see prices have come down loads. :)
sad people don't like the full coffee variant... and they are already asking for plum mods and blank oh and white on blue of course.
-[°_°]-
12 Feb 2013, 18:00
Signature Plastics confirmed pricing for KIT 11
Bullveyr
12 Feb 2013, 18:02
matt3o wrote: sad people don't like the full coffee variant...
Yea but as long as we hit the 50 tier I'm fine with that.
Now where did I put my ID so I can add plum. :D
gmjhowe
12 Feb 2013, 18:10
I was holding out for the full coffee variant, really like the idea of coffee with a couple of green keys.
Though if it hits 50, that would be a step in the right direction.
