IDENTIFY THE KEYBOARD thread
Looks like it could be some slider over dome/membrane switch. Those are never any good, or at all interesting in other ways, to my knowledge.
Though I must admit Terry has me schooled on Space Invaders!
- Touch_It
- Main keyboard: Unicomp Classic USB 103 key (work) IBM F 4704 107
- Main mouse: Logitech g502 Proteus Core
- Favorite switch: Buckling spring (yet to try Beam Spring)
Doesn't look like stackpole at all to me. Like previously said, likely slider over membrane.
- Main keyboard: Model M, dodoo dome keyboard,CherryMX numeric pad
- Main mouse: logitech Master,M705 and 3 Logitech mice
- Favorite switch: ff
Except the "Micro switch dome with slider" switch keyboard, this slider over dome is fascinating to type. It better than much more semi-mechanical keyboard, especially the "(Linear)Grey shell black slider with orange dome". I think it could better than model m if I can make it work and test on PC !
- stratokaster
- Main keyboard: Filco Minila Air
- Main mouse: Contour Unimouse WL / Apple Magic Trackpad 2
- Favorite switch: Alps SKCM Green
There are many rather nice "slider over dome" keyboards. For example, NMB slider with dome switches are very good for a rubber dome. BTW, Topre is also technically "slider over dome"terrycherry wrote:Except the "Micro switch dome with slider" switch keyboard, this slider over dome is fascinating to type. It better than much more semi-mechanical keyboard, especially the "(Linear)Grey shell black slider with orange dome". I think it could better than model m if I can make it work and test on PC !
The top slider look like KPT switch Blue (rectangular slider) but the top was branded AE7.
And the bottom shell seems like the KPT-like switch but the base was differed the KPT switch and KPT-like switch.
I don't get any idea. Is the blue switch came with yellow KPT-like switches keyboard?
You should assemble this strange switch to see what difference it has.
Please share the keyboard with that unknown rectangular blue switch.
Is the yellow one better than the blue?
- stratokaster
Aha! I know this keyboard, it was made by Key Mouse Enterprises (KME). AFAIK, they are still making keyboards of the nastiest possible kind.
Those switches are definitely not genuine Alps. The keycaps must be fairly thick doubleshots.
BTW, there were also rubber dome boards using the same case and the same FCC ID. Those come with Cherry MX-compatible doubleshots. I have one set of such caps with pad-printed red Cyrillic legends.
- gogusrl
- Main keyboard: Cherry G80-1851
- Main mouse: Logitech G9x
- Favorite switch: linear stuff
The keycaps are regular thin alps mount doubleshots but the switches are exquisite. I need someone to hook me with a single blue alps so I have a something to compare them to.
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
So nice, the blue one is more like the KPT-like switch inside!
Could you take out the two metal leaves and make two spring together to compare of them.
I think this blue switch should be the another one variant of KPT-like switch.
Many KPT-like switches have the numbering "AB" on the base shell and this blue variant marked "AB" on the base shell too. It should be the same family. Maybe this is the later variant of "KPT-like switch" family.
- gogusrl
oh man, they're a pain in the ass to desolder because the pins are bent and then soldered. so 1 move turns into 3 moves (heat it, straighten it up, heat it again & suck it all up). I'll get back to you when it's done
It hard to desolder when the pins were bent.
1. Put the knife on the bent
2. Keeping heat the solder until the knife lift up the pin.(be careful the gun)
- DT Pro Member: 0167
- gogusrl
I'm using this : http://yihua-soldering.com/product-1-2- ... -en/147658
and this : http://www.aliexpress.com/item/Prokits- ... 19850.html
I'm using the ProsKit pump but the another model.
- stratokaster
This keyboard looks vaguely familiar, but I can't quite put my finger on it. Probably something Taiwanese and Alps-like
- Main keyboard: Filco SSK
- Main mouse: Roccat Kone XTD
- Favorite switch: MX Blue
Found a Clevy Keyboard at a local market, a really weird keyboard with huge keys. Can someone help me identify the switches? It haves a really nice clicky sound
Here are some pictures, and info on the keyboard
http://clevy.com/products/clevy-keyboard
I can take some better picture tomorrow if needed
- IMG_0035.JPG (257.62 KiB) Viewed 6993 times
- IMG_0033.JPG (290.48 KiB) Viewed 6993 times
- Chyros
Generally you have to open up Alps clones to properly identify them, but in the meantime I'm going to guess Alps type T5 clone (they look very much like my own clicky T5s).
- Main keyboard: Unicomp PC 122
Hi there, keyboard novice here. Looking for help to identify a keyboard:
I found the perfect keyboard for me, but unfortunately it was in a pc pool of our university and I didn't note down the model. However I think, it might have been distinctive enough to be identifiable:
The layout was rather casual, i.e. not "large" like a model M
The keys were distinctively "high", like the keys on this board, but even higher:
http://deskthority.net/photos-f62/ibm-m ... 12048.html
It also featured integrated LEDs on the numlock and scroll lock keys , like these:
http://deskthority.net/wiki/File:Key_Tronic_101.jpg
iirc, the brandname was hewlett packard, but I guess, that doesn't say too much....
Any help is grately appreciated!!
- ramnes
- ПБТ НАВСЕГДА
- Main keyboard: KMAC LE
- Main mouse: Zowie AM
the "hewlett packard"-brand was the least significant bit from my description .... ^^
To sum it up:
To sum it up:
- "normal" form factor (i.e. NOT large like a model M)
- rather high keys, like here: http://deskthority.net/photos-f62/ibm-m ... 12048.html
- integrated status-LEDs on numlock and scroll lock
- stratokaster
Rubberdome with integrated LEDs? Must be Fujitsu-made.
