GMK / Cherry doubleshot modifier packs (complete?)
Halverson
16 Feb 2013, 22:49
pasph wrote:
guilleguillaume wrote:Sherryton announcing what probably could be Dolch sets
We should reject Dolch and go directly with the safest choice:
:mrgreen:
It is the Cover Photo of his Facebook page...
http://www.facebook.com/photo.php?fbid= ... permPage=1
That is true...however that may just because its bright and attention grabbing. He mentioned two sets this coming week, and only said grey, grey and more grey.
pasph
16 Feb 2013, 23:29
Maybe it will be the next pre-order?
How can you be sure it won't popup next month?
This is the problem.
IvanIvanovich
16 Feb 2013, 23:33
Exactly it is the problem. Maybe it would help if I stopped posting the results of the IC voting?
pasph
17 Feb 2013, 00:09
a dolch set for backlit kb?
Jmneuv
17 Feb 2013, 00:30
oh wow that key is intriguing
shiverrr
17 Feb 2013, 00:36
Have you had any communication with Sherryton? Perhaps he is not so unreasonable after all?
IvanIvanovich
17 Feb 2013, 00:59
Yes, and absolutely nothing useful came out of it.
rodtang
17 Feb 2013, 02:16
Profiteers have no place in any community.
BimboBB
18 Feb 2013, 15:12
How about adding beige/white modifiers to the "purple mod"-GB? As far as I can see there are only full sets offered sofar and people maybe still interested in just replacing their moogle-kits. At least i am. :)
IvanIvanovich
18 Feb 2013, 17:41
No, but maybe I will run some classic patch kit right after while we keep working on what we are doing with full set situation. I don't want to have more than one at a time as I fear it will be too hard to meet each moq if there are choices.
guilleguillaume
19 Feb 2013, 02:34
dirge wrote:Yes but the volume of colours would make it expensive!
Also the yellow isn't quite the right shade, hang on I've got a pic to demonstrate.
I guess you would be able to get your desired set...
sherryton on GH wrote: What about the one dirge posted? I think it was a black on yellow colored set. It was just the F row though.
How are we going to proceed with this situation?
Every time we are looking to go trough a colour choice he is planning to make an order. What I think is that GMK just has a VIP slot production for Sherryton so everytime he needs something they put his order in first line of production.
If this is happening we would not be able to finish any Group Buy and we will be unable to reach any MOQ for any set.
Soarer
19 Feb 2013, 05:46
Fine. Let him spend all his money and have lots of stock. Or whatever. The situation will stabilise.
IvanIvanovich
19 Feb 2013, 07:49
Yes, just need more patience. In the mean time we can do patch kits for hard to find language and specialty keys and so on. I really don't think have to worry about those things being rushed out by any vendor so it should be safe for us to organize and complete with less problem.
pasph
22 Feb 2013, 16:08
sherryton has announced Skidata set
guilleguillaume
22 Feb 2013, 16:45
Sherryton @ GH wrote:I want to thank everyone for consistently checking on my vendor forum. It's really fun just seeing a bunch of people here at all times.
For this reason, I'll announce one of the sets. The set is also known as Ski Data (I altered the colors slightly since the original orange was not available), but I imagine it more as the Geek Hack set. If you are using the default theme, then it looks exactly just like the GEEK HACK keys at the top. Theme can be found here, http://geekhack.org/index.php?action=theme;sa=pick
We have to hand organize these as well as all the other sets we had so far. I will not release them until they are 100% packaged since there is only a limited of these.
I made this order a long time ago, and I hope you guys understand that I did not copy anything. Expect them in a week.
Ski Data appeared in November when alles4pc! sold them in Ebay so this means he made the order in November- December.
Another set kicked out of the GB.
IvanIvanovich
22 Feb 2013, 17:40
I think maybe we can just shift direction. I put in a quote request for EURO pack with all the unique keys from most of the major language layouts. I was thinking of just doing those and modifier patch kits and maybe a few special keys for fun. Maybe start off with the black/white or white/black since it is most common sets. For the rest of the keys people can just source more plentiful US or DE set and add the patch kit to get what they want.
What do you think?
dirge
22 Feb 2013, 17:48
Think its a good idea, but new is always nicer. Mixing with a second hand set may not match perfectly, yellowing etc.
Also if we're talking about getting the most out of older sets, get the bottom row sorted with some 1unit window and menu keys? Maybe in cherry red? Would look nice on black or white/beige. Also in the correct A! profile :) that bottom row needs some height!
Grond
22 Feb 2013, 17:56
What I'd like:
- moogle kit in white on black;
- Ins/del/pag up/down cluster in white on black;
- rgb kit + red esc.
phinix
22 Feb 2013, 18:53
How about standard cherry moogle kits? Grey in particular:-)
pasph
22 Feb 2013, 19:01
Ok for euro kit + moogle kit
zulios
22 Feb 2013, 19:29
Will you include FR in the EURO kit ?
Gilgam
22 Feb 2013, 21:53
I think it is, or we may call the european court for discrimination :-)
Broadmonkey
Fancy Rank
23 Feb 2013, 00:11
I think a full base set with support for x amount of languages would be better. Then we could pair it with the modifier set that we are about to run a GB for. When I write base set I mean all the alpha keys and number row plus a spacebar.
The idea is that we will switch between modifier GB and base set GB. Avoiding making full sets yet still making them. only problem is it would require double the work, most Americans wouldn't be joining in on the base sets and you wouldn't necessarily be getting a matching set.
If we were to proceed with a full set GB, we should go with something not produced/seen before (from Cherry).
TA set would be preferable since there hasn't been a full set, isn't as hyped as Dolche, is much more subtle than DolchSKI and nobody has it, making it easier to reach MOQ.
Handarbeit is interesting, but tbh we can do better that that! it need some rework!
Jmneuv
23 Feb 2013, 02:00
Again no pictures nothing hands-on, people just shouldn't be so easily pushed off the track.
pasph
23 Feb 2013, 02:04
Jmneuv wrote:Again no pictures nothing hands-on, people just shouldn't be so easily pushed off the track.
The Sherry Syndrome
IvanIvanovich
05 Mar 2013, 19:54
Modifiers buy will start very soon. We need an EU partner(s) quite badly.
EU partner will have big responsibility so do not volunteer if you won't have plenty of time. Responsibility will be to receive the entire shipment initially from GMK, remove keys, sort pack and mail all European orders, then forward the remaining keys in bulk to me in USA. Additionally, you may also be needed to receive total payments from order payment collection and forward the payment to GMK via bank transfer.
I would really like to get someone on this so all you EU guys can avoid the double shipping back from USA and re-import taxes. It will be a lot of work, so if at all possible maybe a few people that live close to each other could do it together.
If you are able and willing to help with this please get in touch with me.
mintberryminuscrunch
07 Mar 2013, 07:15
pasph wrote:sherryton has announced Skidata set
You know, we could do a competitive GB :twisted:
vorn
07 Mar 2013, 08:31
"Orange Dolch will release on Monday. PBT Dye Sublimation RGB with Esc will release this week. Dolch will release in another 2-3+ weeks."
rindorbrot
07 Mar 2013, 13:27
... that kinda sucks but was to be expected.
Alltough the dolski is a bit surprising to me that he copied that as well...
IvanIvanovich
07 Mar 2013, 18:43
The other thing, is I am surprised how many people are willing to pay the high prices. Our 32 key modifiers kit will be cheaper than the 6 key RGB. We could do full set with more comprehensive, more key sizes for additional physical layout more board compatibility, additional languages for the same price or less. But too many people are impatient and won't wait for the groupbuy so running the same things is not a good idea.
We need good support for this modifiers buy, so even if you are not incredibly wild for the colors I hope some will come out and buy sets anyway if it's in trouble to reach the moq. If this is not a success nothing further will be attempted by me.
