dirge
20 Feb 2012, 10:46
kbdfr wrote:Wait 1 day 5 hours and you'll know.
Was thinking of bidding, however it's above my impulse purchase price now and wanted further information from the forum.
Trent
21 Feb 2012, 02:23
A used Focus 2001, no super keys, AT adapter?
Icarium
21 Feb 2012, 11:51
How much are the following worth:
MX-11800
I'm guessing somewhere around 35 Euro or $45
Apple Extended Keyboard 2
No idea...
dirge
21 Feb 2012, 16:38
dirge wrote:What is a uk iso model m worth?
http://www.ebay.co.uk/itm/220952114088? ... 97.c0.m619
It was worth a hundred quid, so vintage model m / uk iso worth nearly as much as a unicomp!
Magna224
21 Feb 2012, 18:05
Trent wrote:A used Focus 2001, no super keys, AT adapter?
They often sell for $20-40 USD depending on how clean the board is and if it has simplified or complicated ALPS.
Mrinterface
22 Feb 2012, 10:56
New unused Avant Prime programmable clicky white alps keyboard.
Mrinterface
22 Feb 2012, 11:08
Mint unused Siig Minitouch clicky white alps.
It's this one : http://5k177.com/more/?p=4 Comes with bag but without key puller and without extra keys.
BiNiaRiS
27 Feb 2012, 11:34
Mrinterface wrote:Mint unused Siig Minitouch clicky white alps.
I had a few of those NIB. I think I sold them for $60 shipped but the EU market might be a bit higher.
Trent
27 Feb 2012, 18:46
I have a FK-8000, working calculator and all.
I haven't seen any on eBay and the like, I've seen the FK-2000's go for big bucks (~$60 and above) on wBay but never the 8000 version.
See: http://deskthority.net/viewtopic.php?f=8&t=2027
Tarkoon
03 Mar 2012, 12:33
I got a Cherry G80-1000HFD/09 (MX blue with MX green space) in really good condition!
What do you think is it worth?
Icarium
03 Mar 2012, 12:36
We need a money oracle. Nobody answers in this thread anymore. :/
mintberryminuscrunch
03 Mar 2012, 12:59
Icarium wrote:We need a money oracle. Nobody answers in this thread anymore. :/
Depends on the question. Often there isn't enough information or prices aren't stable.
Tarkoon wrote:I got a Cherry G80-1000HFD/09 (MX blue with MX green space) in really good condition!
50ish with nkro...
Kukuschi
03 Mar 2012, 16:38
Erm well, this one is not directly a keyboard but ... ^^
It is a german IBM 169 c (german Selectric III afaik) in near mint condition . (Optical mint, one of the lights does not work but i have spare. The express backspace key does notwork but it did a few days ago, so a cleaning should fix this (i will replace the light and clean it until i figured out how to open it (i have no idea :oops: ) ... want to get rid of the foam inside, too. There must be a trick.)
The motor runs smooth and sooooo even and quiet and the typeface is outstanding.
It has both, velocity control dial and dead key dissconnect. (!!!!!! ^^)
All the accessories are there and in mint condition: Page end indicator, sound hood etc.
I am not sure if i will hold it (it is dream, but i seldom use it) or will try to sell it. I am not sure what price i can charge ... anybody any idea?
P.S.: Sorry for my poor english.
glossywhite
04 Mar 2012, 16:20
Dell AT102W (Black ALPS): How much is it worth in £?
Good condition (was stripped down and cleaned) but space bar slightly shiny. Any idea of the value in pounds sterling?
Thanks.
Ascaii
The Beard
04 Mar 2012, 16:31
Ive seen them go for anywhere from 5 to 35. Cleaned and tested should net you at least 25 pounds.
glossywhite
04 Mar 2012, 16:39
Ascaii wrote:Ive seen them go for anywhere from 5 to 35. Cleaned and tested should net you at least 25 pounds.
Thank you :)
dirge
05 Mar 2012, 10:37
http://www.ccworld.co.uk/index.php?main ... ts_id=1744
Anyone know anything about these boards?
Ascaii
The Beard
05 Mar 2012, 10:41
keytronic says it all...I am fairly certain it has foam+foil switches.
sixty
Gasbag Guru
05 Mar 2012, 10:41
dirge wrote:http://www.ccworld.co.uk/index.php?main ... ts_id=1744
Keytronic. Looking at the age it is probably a foam and foil board. If you are lucky the keys MIGHT be MX compatible, but no guarantees.
rodtang
05 Mar 2012, 11:36
Aren't those the reversed mx style stems?
Ascaii
The Beard
05 Mar 2012, 12:05
I have seen a board with mx compatible caps, the keys were close to sp caps.
lightsout
05 Mar 2012, 20:12
Is there any value in a dolch pac keyboard with no caps? The one with blue switches? Thinking about buying one but I have no use for the board.
Also what's a set of dolch doubleshots worth?
Ascaii
The Beard
05 Mar 2012, 20:57
The boards have 1800 layout and can be converted to pc use, so yes...they have use. Worth 20€ or so, possibly less depending on condition. Dolch keys are one area where I will not wager a guess...some crazy people have too much money and drive up the prices.
lightsout
05 Mar 2012, 21:02
OK thanks. I'm considering a board for $110 and would like to recoup some of the cost. But I have a feeling the board without keys will be a hard sell.
Ascaii
The Beard
05 Mar 2012, 21:08
If the switches are in good condition you can sell them seperately...for about 0.30-0.50 per switch. The switch group buy has pushed the prices of used switches + donor boards down a bit.
Kisakuku
05 Mar 2012, 21:08
lightsout
05 Mar 2012, 21:51
Thanks ascaii and no that's not the board. It's local not on ebay.
dirge
07 Mar 2012, 13:16
https://skydrive.live.com/redir.aspx?ci ... qnhzK184JQ
This ended up as a £1 winning bid on eBay for me, anyone know what it is and if I overpaid lol. It doesn't feel very nice to type on.
07 Mar 2012, 13:21
1gbp for alps compatible caps, seems fine
Ascaii
The Beard
07 Mar 2012, 13:54
looks like a membrane contact board that uses springs instead of domes for tactility...think of it as a cost cutting version that allowed companies to use up old stock of alps keys. Would you mind opening up the board? I am interested what is hiding under that stem.
Return to “Marketplace Help”
