14 Feb 2014, 12:05
Flintfish wrote:Just found this thread/forum so sorry for any noob questions. I tried skimming through the 100+ page thread but I couldn't find all my answers
Understandable!
Flintfish wrote:I assume it's still OK to submit a brand new order? (I'm wondering since payments are due before 2013-12-31)
Yes, you're still in time. Just. Those earlier deadlines were extended when Signature Plastics delayed production. Lucky for you!
Flintfish wrote:Except for the white modifiers which seems to be undecided are all kits on the Wiki page being produced? Especially the Swedish (SE) language kit is somewhat critical for me...
I believe so. Once upon a time, there were even more kits, and 7bit killed off everything with too low an order count on one of his deadlines. But the extension has let new stuff creep back in again. Including the white mods. Certainly, the language kits are good.
Flintfish wrote:I have a Filco numpad to go with my tenkeyless board and to make it perfect I could use row1 grey Tab and "=" keys. I assume it's too late to add those keys to somewhere? Not sure there would be general interest in it either.
Like this?
Checking against my spreadsheet of all the caps in all the kits (which you can find in a .pdf attachment at the end of this post) I see you're right on both counts. The only single unit = keys are row 3 (in HONEY/NUMERIC7/WHITE and HONEY/NUMERIC7/GREY) and single unit TAB is row 2 exclusive (in HONEY/FUNCTION7A and HONEY/FUNCTION/R2).
Anyone else here got a Filco numpad they want to Round 5? (I don't.) To make a new kit for it, 7bit only needs add those two variant keys.
Flintfish wrote:Are there any other special fitting consideration I should take into account?
Not that spring to mind. You've done a good close job finding those exceptions. So long as you realise how tall these caps are, and how chaotic these planning phases can be, I'd say you're a noob no more! Welcome to the cap club.
Anyway, for everyone with similar questions, here's my list. It was last updated before 7bit added a few more odds and ends (like the Swiss flag keys) but should be correct for the serious stuff. It is colour coded, and organised by legend, and unit size:
Round 5 Master List.pdf
(1.37 MiB) Downloaded 222 times
Flintfish
14 Feb 2014, 16:49
Muirium wrote: Like this?
That's the one! I plan to buy the HONEY/FUNCTION/R1 so worst case I can use something from there or blanks on the numpad.
Muirium wrote: Not that spring to mind. You've done a good close job finding those exceptions. So long as you realise how tall these caps are, and how chaotic these planning phases can be, I'd say you're a noob no more! Welcome to the cap club.
Well. I compared the data sheets on SPs homepage and it looks like the SA are ~5mm taller then the regular DCS caps. (Since you have the real thing - is that a good estimate?) Not perfect from an ergonomic standpoint but should work decently well. I plan to use this set at home anyway and really long typing session should be fairly rare.
Thanks for a thorough and quick reply btw. Always apreciated.
Yslen
14 Feb 2014, 17:36
Muirium wrote:Anyway, for everyone with similar questions, here's my list. It was last updated before 7bit added a few more odds and ends (like the Swiss flag keys) but should be correct for the serious stuff. It is colour coded, and organised by legend, and unit size:
I can't get that PDF to open :(
14 Feb 2014, 18:11
Hmm. It's one frickin' huge long page (there's several thousand discrete caps in this GB) and I see now that Google Docs doesn't like it either. But my old G4 iMac shows it fine with Preview, too. If I export (from Numbers where I made it) to an Excel file, all the colours get stripped. I went beyond Excel's limits, apparently. To be fair, I did colour code everything by key size, row, and colour. I like my data glance-friendly. If you want it without colours, and want to use Excel, tell me.
Flintfish wrote: Well. I compared the data sheets on SPs homepage and it looks like the SA are ~5mm taller then the regular DCS caps. (Since you have the real thing - is that a good estimate?) Not perfect from an ergonomic standpoint but should work decently well. I plan to use this set at home anyway and really long typing session should be fairly rare.
You're welcome.
Here's my SA profile caps compared to some of the original Honeywells this GB is modelled after:
Those guys are crazy thick, crazy tall, and crazy heavy. All in a good way!
I find typing on SA profile to be just as easy, fatigue and accuracy wise, as DCS. With one exception: since these are sphericals, I enjoy it more. Love that cup feel, compared to the cylindrical troughs of DCS.
Perhaps it helps to have a low keyboard, I guess. I never raise the feet on mine anyway. The extra height of caps doesn't seem to bother me. Maybe if you use yours propped up at an angle, it would.
15 Feb 2014, 12:39
After a long wait it can be viewed with gv. Seriously, a text file is much more practical:
SPH/REPAIR              |R3U275 |WV (White) |BFP (Blue) |SHIFT
SPH/REPAIR              |R3U225 |WV (White) |BFP (Blue) |SHIFT
SPH/REPAIR              |R3U225 |WV (White) |BFP (Blue) |RETURN
SPH/REPAIR              |R2U150 |WV (White) |BFP (Blue) |TAB
SPH/REPAIR              |R2U150 |WV (White) |BFP (Blue) |BACK\ \ SPACE
SPH/REPAIR              |R2UJRET|WV (White) |BFP (Blue) |RETURN
SPH/REPAIR              |R1U200H|WV (White) |BFP (Blue) |BACK\ \ SPACE
SPH/SHIFT225            |R3U225 |WV (White) |BFP (Blue) |SHIFT
SPH/SHIFT275            |R3U275 |WV (White) |BFP (Blue) |SHIFT
SPH/RETURN225           |R3U225 |WV (White) |BFP (Blue) |RETURN
SPH/ISO/RETURN          |R2UJRET|WV (White) |BFP (Blue) |RETURN
SPH/TAB150              |R2U150 |WV (White) |BFP (Blue) |TAB
SPH/BACKSPACE150        |R2U150 |WV (White) |BFP (Blue) |BACK\ \ SPACE
SPH/BACKSPACE200        |R1U200H|WV (White) |BFP (Blue) |BACK\ \ SPACE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |F11
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |F12
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |HOME
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |EOF
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |PRIOR
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |NEXT
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |SHIFT,LOCK
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |HYPER
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |SPACE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\circle
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |DELETE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |0
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\cdot
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |F9
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |F10
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |ALT,LOCK
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |TTY,LOCK
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |END
HONEY/HYPER7            |R4U150 |WFK (White)|GPA (Gray) |SYMBOL
HONEY/HYPER7            |R4U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|Z
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|X
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|C
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|V
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|B
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|N
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|M
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/HYPER7            |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |1
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |2
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |3
HONEY/HYPER7            |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |F7
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |F8
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |SELECT
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |DEBUG
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |MODE
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |TOP
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|A
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|S
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|D
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|F
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|G
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|H
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|J
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|K
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|L
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\backprime,\semicolon
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |RETURN
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |LINE
HONEY/HYPER7            |R3U150 |WFK (White)|GPA (Gray) |PAGE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |4
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |5
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |6
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |F5
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |F6
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |MARK
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |UNDO
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |PASTE
HONEY/HYPER7            |R2U150 |WFK (White)|GPA (Gray) |CUT
HONEY/HYPER7            |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|Q
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|W
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|E
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|R
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|T
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|Y
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|U
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|I
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|O
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|P
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/HYPER7            |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/HYPER7            |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/HYPER7            |R2U150 |WFK (White)|GPA (Gray) |CLEAR
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |7
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |8
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |9
HONEY/HYPER7            |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |FIND
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |WRITE
HONEY/HYPER7            |R1U150 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\pm,\doublequote
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\tilde,\colon
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\lt,\openparen
HONEY/HYPER7            |R1U100 |NN (Black) |WFK (White)|\gt,\closeparen
HONEY/HYPER7            |R1U150 |WFK (White)|GPA (Gray) |UNDO
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |\eightast
HONEY/HYPER7            |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |F2
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |CLOSE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |OPEN
HONEY/HYPER7            |R3U200P|WFK (White)|GPA (Gray) |ESCAPE
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|?
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|!
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\at
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\pound
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\euro
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\yen
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\backprime\backprime
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\prime\prime
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\underscore
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\lt
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\gt
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\vert
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\opencur
HONEY/HYPER7            |R3U100 |NN (Black) |WFK (White)|\closecur
HONEY/HYPER7            |R3U200P|WFK (White)|GPA (Gray) |COMPLETE
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\wedge
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\%
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\#
HONEY/HYPER7            |R3U100 |WFK (White)|GPA (Gray) |\$
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |LOCAL
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |NETWORK
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |SYSTEM
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |REFRESH
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |BUFFERS
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |\square
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |\circle
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |\triangle
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |\diamond
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |REPEAT
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |TRANSMIT
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |STATUS
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |SUSPEND
HONEY/HYPER7            |R2U200P|WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |HELP
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |MACRO
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |TERMINAL
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |QUOTE
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |OVER,STRIKE
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |CLEAR,INPUT
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |CLEAR,SCREEN
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |HOLD,OUTPUT
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |STOP,OUTPUT
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |ABORT
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |BREAK
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |RESUME
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |CALL
HONEY/HYPER7            |R1U200P|WFK (White)|GPA (Gray) |RESET
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STANDARD          |R3U200H|NN (Black) |WFK (White)|0
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/STANDARD          |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/STANDARD          |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|Z
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|X
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|C
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|V
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|B
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|N
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|M
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/STANDARD          |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|1
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|2
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|3
HONEY/STANDARD          |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/STANDARD          |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|A
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|S
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|D
HONEY/STANDARD          |R3U100D|NN (Black) |WFK (White)|F
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|G
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|H
HONEY/STANDARD          |R3U100D|NN (Black) |WFK (White)|J
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|K
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|L
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/STANDARD          |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|4
HONEY/STANDARD          |R3U100D|NN (Black) |WFK (White)|5
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|6
HONEY/STANDARD          |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/STANDARD          |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|Q
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|W
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|E
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|R
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|T
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|Y
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|U
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|I
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|O
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|P
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/STANDARD          |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD          |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARD          |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STANDARD          |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|7
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|8
HONEY/STANDARD          |R2U100 |NN (Black) |WFK (White)|9
HONEY/STANDARD          |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/STANDARD          |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |STOP
HONEY/STANDARD          |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARD          |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/STANDARD          |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARD          |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD          |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD          |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD          |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STANDARD          |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/STANDARD          |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/STANDARD          |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/STANDARD          |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARD          |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|F
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|J
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|5
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|0
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|00
HONEY/STANDARD          |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD          |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/STANDARD/BLACK    |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/STANDARD/BLACK    |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/STANDARD/BLACK    |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/STANDARD/BLACK    |R3U125 |WFK (White)|NN (Black) |FUN
HONEY/STANDARD/BLACK    |R3U125 |WFK (White)|NN (Black) |META
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/STANDARD/BLACK    |R3U200H|WFK (White)|NN (Black) |0
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |\cdot
HONEY/STANDARD/BLACK    |R3U200V|WFK (White)|NN (Black) |ENTER
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |0
HONEY/STANDARD/BLACK    |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |Z
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |X
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |C
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |V
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |B
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |N
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |M
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |\lt,\comma
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |\gt,\period
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |?,\slash
HONEY/STANDARD/BLACK    |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |UP
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |1
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |2
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |3
HONEY/STANDARD/BLACK    |R4U100 |WFK (White)|NN (Black) |\equal
HONEY/STANDARD/BLACK    |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |A
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |S
HONEY/STANDARD/BLACK    |R3U100D|WFK (White)|NN (Black) |F
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |G
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |H
HONEY/STANDARD/BLACK    |R3U100D|WFK (White)|NN (Black) |J
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |K
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |\colon,\semicolon
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |\doublequote,\prime
HONEY/STANDARD/BLACK    |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |4
HONEY/STANDARD/BLACK    |R3U100D|WFK (White)|NN (Black) |5
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |6
HONEY/STANDARD/BLACK    |R3U200V|WFK (White)|NN (Black) |\fontkey{\plus}
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |\&
HONEY/STANDARD/BLACK    |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |Q
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |W
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |E
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |R
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |T
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |Y
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |U
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |I
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |O
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |P
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |\opencur,\openbra
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |\closecur,\closebra
HONEY/STANDARD/BLACK    |R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |END
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |7
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |8
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |9
HONEY/STANDARD/BLACK    |R2U100 |WFK (White)|NN (Black) |\plus
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\tilde,\backprime
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |!,1
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\at,2
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\#,3
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\$,4
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\%,5
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\wedge,6
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\&,7
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\ast,8
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\openparen,9
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\closeparen,0
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\longunderscore,\minus
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\plus,\equal
HONEY/STANDARD/BLACK    |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |NUM,LOCK
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\slash
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\sixast
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\minus
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F1
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F2
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F3
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F4
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F5
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F6
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F7
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F8
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F9
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F10
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F11
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |F12
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/STANDARD/BLACK    |R1U100 |WFK (White)|NN (Black) |BACK,SPACE
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |CONTROL
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |SUPER
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |META
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |ALT
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |ALT\ \ GRAPH
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |SHIFT
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |FUNCTION
HONEY/STANDARD/BLACK    |R3U150 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |F
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |J
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |5
HONEY/STANDARD/BLACK    |R3U100 |WFK (White)|NN (Black) |00
HONEY/STANDARD/BLACK    |R2U150 |WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/STANDARD/BLACK    |R3U175S|WFK (White)|NN (Black) |CAPS,LOCK
HONEY/STANDARD/BLACK    |R3U175 |WFK (White)|NN (Black) |CONTROL
HONEY/STANDARD/BLACK    |R3U175S|WFK (White)|NN (Black) |CONTROL
HONEY/STANDARD/BLACK    |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/STANDARD125       |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARD125       |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARD125       |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARD125       |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STANDARD125       |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STANDARD125       |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STANDARD125       |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STANDARD125       |R3U200H|NN (Black) |WFK (White)|0
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/STANDARD125       |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STANDARD125       |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|Z
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|X
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|C
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|V
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|B
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|N
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|M
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/STANDARD125       |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARD125       |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|1
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|2
HONEY/STANDARD125       |R4U100 |NN (Black) |WFK (White)|3
HONEY/STANDARD125       |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|A
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|S
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|D
HONEY/STANDARD125       |R3U100D|NN (Black) |WFK (White)|F
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|G
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|H
HONEY/STANDARD125       |R3U100D|NN (Black) |WFK (White)|J
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|K
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|L
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/STANDARD125       |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|4
HONEY/STANDARD125       |R3U100D|NN (Black) |WFK (White)|5
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|6
HONEY/STANDARD125       |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STANDARD125       |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|Q
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|W
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|E
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|R
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|T
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|Y
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|U
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|I
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|O
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|P
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/STANDARD125       |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/STANDARD125       |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARD125       |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STANDARD125       |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|7
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|8
HONEY/STANDARD125       |R2U100 |NN (Black) |WFK (White)|9
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/STANDARD125       |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/STANDARD125       |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STANDARD125       |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STANDARD125       |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|F
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|J
HONEY/STANDARD125       |R3U100 |NN (Black) |WFK (White)|5
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STANDARDISO/BASE  |R3U200H|NN (Black) |WFK (White)|0
HONEY/STANDARDISO/BASE  |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/STANDARDISO/BASE  |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE  |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STANDARDISO/BASE  |R4U100 |NN (Black) |WFK (White)|1
HONEY/STANDARDISO/BASE  |R4U100 |NN (Black) |WFK (White)|2
HONEY/STANDARDISO/BASE  |R4U100 |NN (Black) |WFK (White)|3
HONEY/STANDARDISO/BASE  |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/STANDARDISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARDISO/BASE  |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/STANDARDISO/BASE  |R3U100 |NN (Black) |WFK (White)|4
HONEY/STANDARDISO/BASE  |R3U100D|NN (Black) |WFK (White)|5
HONEY/STANDARDISO/BASE  |R3U100 |NN (Black) |WFK (White)|6
HONEY/STANDARDISO/BASE  |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/STANDARDISO/BASE  |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STANDARDISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARDISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STANDARDISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STANDARDISO/BASE  |R2U100 |NN (Black) |WFK (White)|7
HONEY/STANDARDISO/BASE  |R2U100 |NN (Black) |WFK (White)|8
HONEY/STANDARDISO/BASE  |R2U100 |NN (Black) |WFK (White)|9
HONEY/STANDARDISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/STANDARDISO/BASE  |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |STOP
HONEY/STANDARDISO/BASE  |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STANDARDISO/BASE  |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/STANDARDISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STANDARDISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE  |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE  |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STANDARDISO/BASE  |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/STANDARDISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/STANDARDISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/STANDARDISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STANDARDISO/BASE  |R3U100 |NN (Black) |WFK (White)|5
HONEY/STANDARDISO/BASE  |R3U100 |NN (Black) |WFK (White)|0
HONEY/STD125ISO/BASE    |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/STD125ISO/BASE    |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/STD125ISO/BASE    |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/STD125ISO/BASE    |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/STD125ISO/BASE    |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/STD125ISO/BASE    |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/STD125ISO/BASE    |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/STD125ISO/BASE    |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/STD125ISO/BASE    |R3U200H|NN (Black) |WFK (White)|0
HONEY/STD125ISO/BASE    |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/STD125ISO/BASE    |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/STD125ISO/BASE    |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STD125ISO/BASE    |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/STD125ISO/BASE    |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/STD125ISO/BASE    |R4U100 |NN (Black) |WFK (White)|1
HONEY/STD125ISO/BASE    |R4U100 |NN (Black) |WFK (White)|2
HONEY/STD125ISO/BASE    |R4U100 |NN (Black) |WFK (White)|3
HONEY/STD125ISO/BASE    |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/STD125ISO/BASE    |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/STD125ISO/BASE    |R3U100 |NN (Black) |WFK (White)|4
HONEY/STD125ISO/BASE    |R3U100D|NN (Black) |WFK (White)|5
HONEY/STD125ISO/BASE    |R3U100 |NN (Black) |WFK (White)|6
HONEY/STD125ISO/BASE    |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/STD125ISO/BASE    |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/STD125ISO/BASE    |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/STD125ISO/BASE    |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/STD125ISO/BASE    |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/STD125ISO/BASE    |R2U100 |NN (Black) |WFK (White)|7
HONEY/STD125ISO/BASE    |R2U100 |NN (Black) |WFK (White)|8
HONEY/STD125ISO/BASE    |R2U100 |NN (Black) |WFK (White)|9
HONEY/STD125ISO/BASE    |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/STD125ISO/BASE    |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/STD125ISO/BASE    |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/STD125ISO/BASE    |R3U100 |NN (Black) |WFK (White)|5
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|CONTROL
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|META
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|SUPER
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|ALT
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|ALT\ \ GRAPH
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|FUNCTION
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|SHIFT
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/STD/BASE/WHITE    |R3U200H|NN (Black) |WFK (White)|0
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/STD/BASE/WHITE    |R3U200V|NN (Black) |WFK (White)|ENTER
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|0
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|00
HONEY/STD/BASE/WHITE    |R3U225 |NN (Black) |WFK (White)|SHIFT
HONEY/STD/BASE/WHITE    |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|UP
HONEY/STD/BASE/WHITE    |R4U100 |NN (Black) |WFK (White)|1
HONEY/STD/BASE/WHITE    |R4U100 |NN (Black) |WFK (White)|2
HONEY/STD/BASE/WHITE    |R4U100 |NN (Black) |WFK (White)|3
HONEY/STD/BASE/WHITE    |R4U100 |NN (Black) |WFK (White)|\equal
HONEY/STD/BASE/WHITE    |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/STD/BASE/WHITE    |R3U225 |NN (Black) |WFK (White)|RETURN
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|4
HONEY/STD/BASE/WHITE    |R3U100D|NN (Black) |WFK (White)|5
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|6
HONEY/STD/BASE/WHITE    |R3U200V|NN (Black) |WFK (White)|\fontkey{\plus}
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|\&
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|5
HONEY/STD/BASE/WHITE    |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|END
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|7
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|8
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|9
HONEY/STD/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|\plus
HONEY/STD/BASE/WHITE    |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|NUM,LOCK
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|\slash
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|\sixast
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|\minus
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|\tilde
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F1
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F2
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F3
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F4
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F5
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F6
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F7
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F8
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F9
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F10
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F11
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F12
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/STD/BASE/WHITE    |R2U150 |NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|HYPER
HONEY/STD/BASE/WHITE    |R3U175 |NN (Black) |WFK (White)|SHIFT
HONEY/STD/BASE/WHITE    |R3U175 |NN (Black) |WFK (White)|CONTROL
HONEY/STD/BASE/WHITE    |R3U175S|NN (Black) |WFK (White)|CONTROL
HONEY/STD/BASE/WHITE    |R3U175S|NN (Black) |WFK (White)|CAPS,LOCK
HONEY/STD/BASE/WHITE    |R3U200H|NN (Black) |WFK (White)|SHIFT
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|FN
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|MENU
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|WIN
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|OPTION
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|COMMAND
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|META
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|ALT\ \ GR
HONEY/STD/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|SHIFT
HONEY/STD/BASE/WHITE    |R3U150 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/STD/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|BACK,SPACE
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|CTRL
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|META
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|SUPER
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|DELETE
HONEY/STD/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|FN
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|CONTROL
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|META
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|SUPER
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|ALT
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|ALT\ \ GRAPH
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|FUNCTION
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|SHIFT
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/STDISO/BASE/WHITE |R3U200H|NN (Black) |WFK (White)|0
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/STDISO/BASE/WHITE |R3U200V|NN (Black) |WFK (White)|ENTER
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|0
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|00
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|SHIFT
HONEY/STDISO/BASE/WHITE |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|UP
HONEY/STDISO/BASE/WHITE |R4U100 |NN (Black) |WFK (White)|1
HONEY/STDISO/BASE/WHITE |R4U100 |NN (Black) |WFK (White)|2
HONEY/STDISO/BASE/WHITE |R4U100 |NN (Black) |WFK (White)|3
HONEY/STDISO/BASE/WHITE |R4U100 |NN (Black) |WFK (White)|\equal
HONEY/STDISO/BASE/WHITE |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/STDISO/BASE/WHITE |R2UJRET|NN (Black) |WFK (White)|RETURN
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|4
HONEY/STDISO/BASE/WHITE |R3U100D|NN (Black) |WFK (White)|5
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|6
HONEY/STDISO/BASE/WHITE |R3U200V|NN (Black) |WFK (White)|\fontkey{\plus}
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|\&
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|5
HONEY/STDISO/BASE/WHITE |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|END
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|7
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|8
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|9
HONEY/STDISO/BASE/WHITE |R2U100 |NN (Black) |WFK (White)|\plus
HONEY/STDISO/BASE/WHITE |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|NUM,LOCK
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|\slash
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|\sixast
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|\minus
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|\tilde
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F1
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F2
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F3
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F4
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F5
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F6
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F7
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F8
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F9
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F10
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F11
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|F12
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/STDISO/BASE/WHITE |R2U150 |NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|HYPER
HONEY/STDISO/BASE/WHITE |R3U175 |NN (Black) |WFK (White)|SHIFT
HONEY/STDISO/BASE/WHITE |R3U175 |NN (Black) |WFK (White)|CONTROL
HONEY/STDISO/BASE/WHITE |R3U175S|NN (Black) |WFK (White)|CONTROL
HONEY/STDISO/BASE/WHITE |R3U175S|NN (Black) |WFK (White)|CAPS,LOCK
HONEY/STDISO/BASE/WHITE |R3U200H|NN (Black) |WFK (White)|SHIFT
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|FN
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|MENU
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|WIN
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|OPTION
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|COMMAND
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|META
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/STDISO/BASE/WHITE |R3U125 |NN (Black) |WFK (White)|ALT\ \ GR
HONEY/STDISO/BASE/WHITE |R3U150 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/STDISO/BASE/WHITE |R1U100 |NN (Black) |WFK (White)|BACK,SPACE
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|CTRL
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|META
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|SUPER
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|DELETE
HONEY/STDISO/BASE/WHITE |R3U100 |NN (Black) |WFK (White)|FN
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESS          |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS          |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESS          |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|D
HONEY/TENKLESS          |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS          |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|L
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS          |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESS          |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS          |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS          |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS          |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS          |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESS          |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS          |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESS          |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS          |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS          |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS          |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS          |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS          |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESS          |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/TENKLESS          |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS          |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESS          |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS          |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS          |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|F
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|J
HONEY/TENKLESS          |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS          |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|CONTROL
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|META
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|SUPER
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|ALT
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|ALT\ \ GRAPH
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|FUNCTION
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/TENKLESS/WHITE    |R3U225 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS/WHITE    |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|UP
HONEY/TENKLESS/WHITE    |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS/WHITE    |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS/WHITE    |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS/WHITE    |R3U225 |NN (Black) |WFK (White)|RETURN
HONEY/TENKLESS/WHITE    |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS/WHITE    |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|END
HONEY/TENKLESS/WHITE    |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS/WHITE    |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F1
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F2
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F3
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F4
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F5
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F6
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F7
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F8
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F9
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F10
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F11
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|F12
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/TENKLESS/WHITE    |R2U150 |NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TENKLESS/WHITE    |R3U175 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKLESS/WHITE    |R3U175 |NN (Black) |WFK (White)|CONTROL
HONEY/TENKLESS/WHITE    |R3U175S|NN (Black) |WFK (White)|CONTROL
HONEY/TENKLESS/WHITE    |R3U175S|NN (Black) |WFK (White)|CAPS,LOCK
HONEY/TENKLESS/WHITE    |R3U200H|NN (Black) |WFK (White)|SHIFT
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|FN
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|MENU
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|WIN
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|OPTION
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|COMMAND
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|META
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|ALT\ \ GR
HONEY/TENKLESS/WHITE    |R3U125 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKLESS/WHITE    |R3U150 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|BACK,SPACE
HONEY/TENKLESS/WHITE    |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|CTRL
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|META
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|SUPER
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|DELETE
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|FN
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|J
HONEY/TENKLESS/WHITE    |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS/WHITE    |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |ALT
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |SUPER
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |META
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |FUNCTION
HONEY/TENKLESS/RED      |R3U150 |WFK (White)|RAS (Red)  |ALT\ \ GRAPH
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TENKLESS/RED      |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/TENKLESS/RED      |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/TENKLESS/RED      |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TENKLESS/RED      |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/TENKLESS/RED      |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/TENKLESS/RED      |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/TENKLESS/RED      |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/TENKLESS/RED      |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/TENKLESS/RED      |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TENKLESS/RED      |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/TENKLESS/RED      |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TENKLESS/RED      |R2U150 |WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TENKLESS/RED      |R3U175 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED      |R3U175 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED      |R3U175S|WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED      |R3U175S|WFK (White)|RAS (Red)  |CAPS,LOCK
HONEY/TENKLESS/RED      |R3U200H|WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |FN
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |MENU
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |WIN
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |OPTION
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |COMMAND
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |ALT\ \ GR
HONEY/TENKLESS/RED      |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |BACK,SPACE
HONEY/TENKLESS/RED      |R1U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |CTRL
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |META
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |SUPER
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |FN
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/TENKLESS/RED      |R3U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |CONTROL
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |META
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |SUPER
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |ALT
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |ALT\ \ GRAPH
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |FUNCTION
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |SHIFT
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TENKLESS/GRAPHITE |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |Z
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |X
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |C
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |V
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |B
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |N
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |M
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |\lt,\comma
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |\gt,\period
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |?,\slash
HONEY/TENKLESS/GRAPHITE |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TENKLESS/GRAPHITE |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |A
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |S
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |D
HONEY/TENKLESS/GRAPHITE |R3U100D|WFK (White)|GPA (Gray) |F
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |G
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |H
HONEY/TENKLESS/GRAPHITE |R3U100D|WFK (White)|GPA (Gray) |J
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |K
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |L
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |\colon,\semicolon
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |\doublequote,\prime
HONEY/TENKLESS/GRAPHITE |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TENKLESS/GRAPHITE |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |Q
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |W
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |E
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |R
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |T
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |Y
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |U
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |I
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |O
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |P
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |\opencur,\openbra
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|GPA (Gray) |\closecur,\closebra
HONEY/TENKLESS/GRAPHITE |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|NN (Black) |END
HONEY/TENKLESS/GRAPHITE |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |!,1
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\at,2
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\#,3
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\$,4
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\%,5
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\wedge,6
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\&,7
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\ast,8
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\openparen,9
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\closeparen,0
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\longunderscore,\minus
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\plus,\equal
HONEY/TENKLESS/GRAPHITE |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TENKLESS/GRAPHITE |R2U150 |WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TENKLESS/GRAPHITE |R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/TENKLESS/GRAPHITE |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/TENKLESS/GRAPHITE |R3U175 |WFK (White)|NN (Black) |CONTROL
HONEY/TENKLESS/GRAPHITE |R3U175S|WFK (White)|NN (Black) |CONTROL
HONEY/TENKLESS/GRAPHITE |R3U175S|WFK (White)|NN (Black) |CAPS,LOCK
HONEY/TENKLESS/GRAPHITE |R3U200H|WFK (White)|NN (Black) |SHIFT
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |FN
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |MENU
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |WIN
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |OPTION
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |COMMAND
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |META
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |ALT\ \ GR
HONEY/TENKLESS/GRAPHITE |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/TENKLESS/GRAPHITE |R3U150 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |BACK,SPACE
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|NN (Black) |\tilde,\backprime
HONEY/TENKLESS/GRAPHITE |R1U100 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |CTRL
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |META
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |SUPER
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |DELETE
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|NN (Black) |FN
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |F
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |J
HONEY/TENKLESS/GRAPHITE |R3U100 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS/GRAPHITE |R4U100 |WFK (White)|GPA (Gray) |\gt,\lt
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE  |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESSISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESSISO/BASE  |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESSISO/BASE  |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESSISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESSISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESSISO/BASE  |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESSISO/BASE  |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESSISO/BASE  |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESSISO/BASE  |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESSISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE  |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE  |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE  |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESSISO/BASE  |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESSISO/BASE  |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/TENKLESSISO/BASE  |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESSISO/BASE  |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|CONTROL
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|META
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|SUPER
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|ALT
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|ALT\ \ GRAPH
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|FUNCTION
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKISOBASE/WHITE |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|UP
HONEY/TENKISOBASE/WHITE |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TENKISOBASE/WHITE |R2UJRET|NN (Black) |WFK (White)|RETURN
HONEY/TENKISOBASE/WHITE |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/TENKISOBASE/WHITE |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/TENKISOBASE/WHITE |R2U100 |NN (Black) |WFK (White)|END
HONEY/TENKISOBASE/WHITE |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/TENKISOBASE/WHITE |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F1
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F2
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F3
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F4
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F5
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F6
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F7
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F8
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F9
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F10
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F11
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|F12
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/TENKISOBASE/WHITE |R2U150 |NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TENKISOBASE/WHITE |R3U150 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TENKISOBASE/WHITE |R3U175 |NN (Black) |WFK (White)|SHIFT
HONEY/TENKISOBASE/WHITE |R3U175 |NN (Black) |WFK (White)|CONTROL
HONEY/TENKISOBASE/WHITE |R3U175S|NN (Black) |WFK (White)|CONTROL
HONEY/TENKISOBASE/WHITE |R3U175S|NN (Black) |WFK (White)|CAPS,LOCK
HONEY/TENKISOBASE/WHITE |R3U200H|NN (Black) |WFK (White)|SHIFT
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|FN
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|MENU
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|WIN
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|OPTION
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|COMMAND
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|META
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/TENKISOBASE/WHITE |R3U125 |NN (Black) |WFK (White)|ALT\ \ GR
HONEY/TENKISOBASE/WHITE |R1U100 |NN (Black) |WFK (White)|BACK,SPACE
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|CTRL
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|META
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|SUPER
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|DELETE
HONEY/TENKISOBASE/WHITE |R3U100 |NN (Black) |WFK (White)|FN
HONEY/TENKLESS125       |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS125       |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS125       |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS125       |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS125       |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESS125       |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESS125       |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESS125       |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS125       |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS125       |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125       |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESS125       |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|D
HONEY/TENKLESS125       |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS125       |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|L
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS125       |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESS125       |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS125       |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS125       |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS125       |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS125       |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESS125       |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS125       |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESS125       |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS125       |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS125       |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125       |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS125       |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS125       |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESS125       |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESS125       |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS125       |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS125       |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|F
HONEY/TENKLESS125       |R3U100 |NN (Black) |WFK (White)|J
HONEY/TENKLESS150       |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150       |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS150       |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS150       |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150       |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/TENKLESS150       |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TENKLESS150       |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|X
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|C
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|V
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|B
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|N
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|M
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TENKLESS150       |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TENKLESS150       |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TENKLESS150       |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|A
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|S
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|D
HONEY/TENKLESS150       |R3U100D|NN (Black) |WFK (White)|F
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|G
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|H
HONEY/TENKLESS150       |R3U100D|NN (Black) |WFK (White)|J
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|K
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|L
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TENKLESS150       |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TENKLESS150       |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|W
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|E
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|R
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|T
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|U
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|I
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|O
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|P
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TENKLESS150       |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TENKLESS150       |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS150       |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS150       |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TENKLESS150       |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TENKLESS150       |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TENKLESS150       |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TENKLESS150       |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TENKLESS150       |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150       |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS150       |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/TENKLESS150       |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/TENKLESS150       |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/TENKLESS150       |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TENKLESS150       |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TENKLESS150       |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|F
HONEY/TENKLESS150       |R3U100 |NN (Black) |WFK (White)|J
HONEY/TKL               |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TKL               |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TKL               |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TKL               |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TKL               |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TKL               |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TKL               |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TKL               |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|X
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|C
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|V
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|B
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|N
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|M
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TKL               |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TKL               |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL               |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TKL               |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|A
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|S
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|D
HONEY/TKL               |R3U100D|NN (Black) |WFK (White)|F
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|G
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|H
HONEY/TKL               |R3U100D|NN (Black) |WFK (White)|J
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|K
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|L
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TKL               |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TKL               |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TKL               |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|W
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|E
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|R
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|T
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|U
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|I
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|O
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|P
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TKL               |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TKL               |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TKL               |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TKL               |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TKL               |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TKL               |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TKL               |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TKL               |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TKL/WHITE         |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/TKL/WHITE         |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/TKL/WHITE         |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/TKL/WHITE         |R3U125 |NN (Black) |WFK (White)|META
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/TKL/WHITE         |R3U225 |NN (Black) |WFK (White)|SHIFT
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|Z
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|X
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|C
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|V
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|B
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|N
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|M
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/TKL/WHITE         |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/TKL/WHITE         |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|UP
HONEY/TKL/WHITE         |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|A
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|S
HONEY/TKL/WHITE         |R3U100D|NN (Black) |WFK (White)|F
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|G
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|H
HONEY/TKL/WHITE         |R3U100D|NN (Black) |WFK (White)|J
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|K
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/TKL/WHITE         |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/TKL/WHITE         |R3U225 |NN (Black) |WFK (White)|RETURN
HONEY/TKL/WHITE         |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|Q
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|W
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|E
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|R
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|T
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|Y
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|U
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|I
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|O
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|P
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/TKL/WHITE         |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|END
HONEY/TKL/WHITE         |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/TKL/WHITE         |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F1
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F2
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F3
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F4
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F5
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F6
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F7
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F8
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F9
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F10
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F11
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|F12
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/TKL/WHITE         |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/TKL/RED           |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TKL/RED           |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TKL/RED           |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TKL/RED           |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TKL/RED           |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/TKL/RED           |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/TKL/RED           |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TKL/RED           |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/TKL/RED           |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/TKL/RED           |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/TKL/RED           |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/TKL/RED           |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/TKL/RED           |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/TKL/RED           |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TKL/RED           |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/TKL/RED           |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TKL/RED           |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TKL/BLACK         |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKL/BLACK         |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKL/BLACK         |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKL/BLACK         |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKL/BLACK         |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |Z
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |X
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |C
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |V
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |B
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |N
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |M
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |\lt,\comma
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |\gt,\period
HONEY/TKL/BLACK         |R4U100 |WFK (White)|NN (Black) |?,\slash
HONEY/TKL/BLACK         |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKL/BLACK         |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |A
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |S
HONEY/TKL/BLACK         |R3U100D|WFK (White)|NN (Black) |F
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |G
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |H
HONEY/TKL/BLACK         |R3U100D|WFK (White)|NN (Black) |J
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |K
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |\colon,\semicolon
HONEY/TKL/BLACK         |R3U100 |WFK (White)|NN (Black) |\doublequote,\prime
HONEY/TKL/BLACK         |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TKL/BLACK         |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |Q
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |W
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |E
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |R
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |T
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |Y
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |U
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |I
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |O
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |P
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |\opencur,\openbra
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |\closecur,\closebra
HONEY/TKL/BLACK         |R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKL/BLACK         |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\tilde,\backprime
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |!,1
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\at,2
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\#,3
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\$,4
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\%,5
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\wedge,6
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\&,7
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\ast,8
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\openparen,9
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\closeparen,0
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\longunderscore,\minus
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |\plus,\equal
HONEY/TKL/BLACK         |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKL/BLACK         |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TKL/GRAPHITE      |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKL/GRAPHITE      |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKL/GRAPHITE      |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKL/GRAPHITE      |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKL/GRAPHITE      |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |Z
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |X
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |C
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |V
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |B
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |N
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |M
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |\lt,\comma
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |\gt,\period
HONEY/TKL/GRAPHITE      |R4U100 |WFK (White)|GPA (Gray) |?,\slash
HONEY/TKL/GRAPHITE      |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKL/GRAPHITE      |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |A
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |S
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |D
HONEY/TKL/GRAPHITE      |R3U100D|WFK (White)|GPA (Gray) |F
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |G
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |H
HONEY/TKL/GRAPHITE      |R3U100D|WFK (White)|GPA (Gray) |J
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |K
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |L
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |\colon,\semicolon
HONEY/TKL/GRAPHITE      |R3U100 |WFK (White)|GPA (Gray) |\doublequote,\prime
HONEY/TKL/GRAPHITE      |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TKL/GRAPHITE      |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |Q
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |W
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |E
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |R
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |T
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |Y
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |U
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |I
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |O
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |P
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |\opencur,\openbra
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|GPA (Gray) |\closecur,\closebra
HONEY/TKL/GRAPHITE      |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKL/GRAPHITE      |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |!,1
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\at,2
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\#,3
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\$,4
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\%,5
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\wedge,6
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\&,7
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\ast,8
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\openparen,9
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\closeparen,0
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\longunderscore,\minus
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|GPA (Gray) |\plus,\equal
HONEY/TKL/GRAPHITE      |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKL/GRAPHITE      |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TKL/BLACKRED      |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKL/BLACKRED      |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKL/BLACKRED      |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKL/BLACKRED      |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKL/BLACKRED      |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/TKL/BLACKRED      |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/TKL/BLACKRED      |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKL/BLACKRED      |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/TKL/BLACKRED      |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/TKL/BLACKRED      |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/TKL/BLACKRED      |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/TKL/BLACKRED      |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TKL/BLACKRED      |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/TKL/BLACKRED      |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKL/BLACKRED      |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/TKL/BLACKRED      |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKL/BLACKRED      |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TKL/BASE          |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TKL/BASE          |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TKL/BASE          |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TKL/BASE          |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TKL/BASE          |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TKL/BASE          |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TKL/BASE          |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TKL/BASE          |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL/BASE          |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKL/BASE          |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TKL/BASE          |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TKL/BASE          |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/TKL/BASE          |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TKL/BASE          |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TKL/BASE          |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TKL/BASE          |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TKL/BASE          |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TKL/BASE          |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TKL/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/TKL/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/TKL/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/TKL/BASE/WHITE    |R3U125 |NN (Black) |WFK (White)|META
HONEY/TKL/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/TKL/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/TKL/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/TKL/BASE/WHITE    |R3U225 |NN (Black) |WFK (White)|SHIFT
HONEY/TKL/BASE/WHITE    |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/TKL/BASE/WHITE    |R3U100 |NN (Black) |WFK (White)|UP
HONEY/TKL/BASE/WHITE    |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TKL/BASE/WHITE    |R3U225 |NN (Black) |WFK (White)|RETURN
HONEY/TKL/BASE/WHITE    |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/TKL/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/TKL/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|END
HONEY/TKL/BASE/WHITE    |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/TKL/BASE/WHITE    |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F1
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F2
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F3
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F4
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F5
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F6
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F7
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F8
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F9
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F10
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F11
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|F12
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/TKL/BASE/WHITE    |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/TKL/BASE/BLACK    |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKL/BASE/BLACK    |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKL/BASE/BLACK    |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKL/BASE/BLACK    |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKL/BASE/BLACK    |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKL/BASE/BLACK    |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKL/BASE/BLACK    |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKL/BASE/BLACK    |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BASE/BLACK    |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKL/BASE/BLACK    |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKL/BASE/BLACK    |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKL/BASE/BLACK    |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/TKL/BASE/BLACK    |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKL/BASE/BLACK    |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKL/BASE/BLACK    |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKL/BASE/BLACK    |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKL/BASE/BLACK    |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKL/BASE/BLACK    |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/TKL/BASE/RED      |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TKL/BASE/RED      |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TKL/BASE/RED      |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TKL/BASE/RED      |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TKL/BASE/RED      |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TKL/BASE/RED      |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TKL/BASE/RED      |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TKL/BASE/RED      |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/BASE/RED      |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKL/BASE/RED      |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TKL/BASE/RED      |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TKL/BASE/RED      |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/TKL/BASE/RED      |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TKL/BASE/RED      |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TKL/BASE/RED      |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TKL/BASE/RED      |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TKL/BASE/RED      |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TKL/BASE/RED      |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TKLISOBASE        |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/TKLISOBASE        |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/TKLISOBASE        |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/TKLISOBASE        |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/TKLISOBASE        |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/TKLISOBASE        |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/TKLISOBASE        |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/TKLISOBASE        |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/TKLISOBASE        |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKLISOBASE        |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/TKLISOBASE        |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/TKLISOBASE        |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/TKLISOBASE        |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/TKLISOBASE        |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/TKLISOBASE        |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/TKLISOBASE        |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/TKLISOBASE        |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/TKLISOBASE        |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/TKLISOBASE        |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/TKLISOBASE/WHITE  |R3U125 |NN (Black) |WFK (White)|ALT
HONEY/TKLISOBASE/WHITE  |R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/TKLISOBASE/WHITE  |R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/TKLISOBASE/WHITE  |R3U125 |NN (Black) |WFK (White)|META
HONEY/TKLISOBASE/WHITE  |R3U125 |NN (Black) |WFK (White)|ALT\ \ GR
HONEY/TKLISOBASE/WHITE  |R3U100 |NN (Black) |WFK (White)|LEFT
HONEY/TKLISOBASE/WHITE  |R3U100 |NN (Black) |WFK (White)|DOWN
HONEY/TKLISOBASE/WHITE  |R3U100 |NN (Black) |WFK (White)|RIGHT
HONEY/TKLISOBASE/WHITE  |R3U125 |NN (Black) |WFK (White)|SHIFT
HONEY/TKLISOBASE/WHITE  |R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/TKLISOBASE/WHITE  |R3U100 |NN (Black) |WFK (White)|UP
HONEY/TKLISOBASE/WHITE  |R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/TKLISOBASE/WHITE  |R2UJRET|NN (Black) |WFK (White)|RETURN
HONEY/TKLISOBASE/WHITE  |R2U150 |NN (Black) |WFK (White)|TAB
HONEY/TKLISOBASE/WHITE  |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/TKLISOBASE/WHITE  |R2U100 |NN (Black) |WFK (White)|END
HONEY/TKLISOBASE/WHITE  |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/TKLISOBASE/WHITE  |R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F1
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F2
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F3
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F4
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F5
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F6
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F7
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F8
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F9
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F10
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F11
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|F12
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/TKLISOBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/TKLISOBASE/RED    |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/TKLISOBASE/RED    |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/TKLISOBASE/RED    |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/TKLISOBASE/RED    |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/TKLISOBASE/RED    |R3U125 |WFK (White)|RAS (Red)  |ALT\ \ GR
HONEY/TKLISOBASE/RED    |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/TKLISOBASE/RED    |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/TKLISOBASE/RED    |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/TKLISOBASE/RED    |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKLISOBASE/RED    |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/TKLISOBASE/RED    |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/TKLISOBASE/RED    |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/TKLISOBASE/RED    |R2UJRET|WFK (White)|RAS (Red)  |RETURN
HONEY/TKLISOBASE/RED    |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/TKLISOBASE/RED    |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/TKLISOBASE/RED    |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/TKLISOBASE/RED    |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/TKLISOBASE/RED    |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/TKLISOBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/TKLISOBASE/BLACK  |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/TKLISOBASE/BLACK  |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/TKLISOBASE/BLACK  |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/TKLISOBASE/BLACK  |R3U125 |WFK (White)|NN (Black) |META
HONEY/TKLISOBASE/BLACK  |R3U125 |WFK (White)|NN (Black) |ALT\ \ GR
HONEY/TKLISOBASE/BLACK  |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/TKLISOBASE/BLACK  |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/TKLISOBASE/BLACK  |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/TKLISOBASE/BLACK  |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/TKLISOBASE/BLACK  |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/TKLISOBASE/BLACK  |R3U100 |WFK (White)|NN (Black) |UP
HONEY/TKLISOBASE/BLACK  |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/TKLISOBASE/BLACK  |R2UJRET|WFK (White)|NN (Black) |RETURN
HONEY/TKLISOBASE/BLACK  |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/TKLISOBASE/BLACK  |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/TKLISOBASE/BLACK  |R2U100 |WFK (White)|NN (Black) |END
HONEY/TKLISOBASE/BLACK  |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/TKLISOBASE/BLACK  |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F1
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F2
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F3
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F4
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F5
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F6
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F7
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F8
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F9
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F10
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F11
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |F12
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/TKLISOBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |FUN
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/SIXTY             |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|Z
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|X
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|C
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|V
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|B
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|N
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|M
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/SIXTY             |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY             |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|A
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|S
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|D
HONEY/SIXTY             |R3U100D|NN (Black) |WFK (White)|F
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|G
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|H
HONEY/SIXTY             |R3U100D|NN (Black) |WFK (White)|J
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|K
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|L
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/SIXTY             |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/SIXTY             |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|Q
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|W
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|E
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|R
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|T
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|Y
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|U
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|I
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|O
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|P
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/SIXTY             |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/SIXTY             |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/SIXTY             |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/SIXTY             |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/SIXTY             |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/SIXTY             |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/SIXTY             |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/SIXTY             |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTY             |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/SIXTY             |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY             |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/SIXTY             |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/SIXTY             |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/SIXTY             |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY             |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY             |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY             |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|F
HONEY/SIXTY             |R3U100 |NN (Black) |WFK (White)|J
HONEY/SIXTY             |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTY             |R3U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |FUN
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE     |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE     |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTYISO/BASE     |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/SIXTYISO/BASE     |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/SIXTYISO/BASE     |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SIXTYISO/BASE     |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/SIXTYISO/BASE     |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/SIXTYISO/BASE     |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/SIXTYISO/BASE     |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTYISO/BASE     |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/SIXTYISO/BASE     |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE     |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/SIXTYISO/BASE     |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/SIXTYISO/BASE     |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTYISO/BASE     |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE     |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTYISO/BASE     |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/SIXTYISO/BASE     |R3U100 |NN (Black) |WFK (White)|F
HONEY/SIXTYISO/BASE     |R3U100 |NN (Black) |WFK (White)|J
HONEY/SIXTYISO/BASE     |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTY125BASE      |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/SIXTY125BASE      |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/SIXTY125BASE      |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/SIXTY125BASE      |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/SIXTY125BASE      |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY125BASE      |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SIXTY125BASE      |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/SIXTY125BASE      |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/SIXTY125BASE      |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/SIXTY125BASE      |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/SIXTY125BASE      |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SIXTY125BASE      |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/SIXTY125BASE      |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/SIXTY125BASE/WHITE|R3U125 |NN (Black) |WFK (White)|ALT
HONEY/SIXTY125BASE/WHITE|R3U125 |NN (Black) |WFK (White)|SUPER
HONEY/SIXTY125BASE/WHITE|R3U125 |NN (Black) |WFK (White)|CONTROL
HONEY/SIXTY125BASE/WHITE|R3U125 |NN (Black) |WFK (White)|META
HONEY/SIXTY125BASE/WHITE|R3U225 |NN (Black) |WFK (White)|SHIFT
HONEY/SIXTY125BASE/WHITE|R3U275 |NN (Black) |WFK (White)|SHIFT
HONEY/SIXTY125BASE/WHITE|R3U175 |NN (Black) |WFK (White)|CAPS\ \ LOCK
HONEY/SIXTY125BASE/WHITE|R3U225 |NN (Black) |WFK (White)|RETURN
HONEY/SIXTY125BASE/WHITE|R2U150 |NN (Black) |WFK (White)|TAB
HONEY/SIXTY125BASE/WHITE|R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/SIXTY125BASE/WHITE|R1U100 |NN (Black) |WFK (White)|ESCAPE
HONEY/SIXTY125BASE/WHITE|R1U200H|NN (Black) |WFK (White)|BACK\ \ SPACE
HONEY/SIXTY125BASE/RED  |R3U125 |WFK (White)|RAS (Red)  |ALT
HONEY/SIXTY125BASE/RED  |R3U125 |WFK (White)|RAS (Red)  |SUPER
HONEY/SIXTY125BASE/RED  |R3U125 |WFK (White)|RAS (Red)  |CONTROL
HONEY/SIXTY125BASE/RED  |R3U125 |WFK (White)|RAS (Red)  |META
HONEY/SIXTY125BASE/RED  |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SIXTY125BASE/RED  |R3U275 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SIXTY125BASE/RED  |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/SIXTY125BASE/RED  |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/SIXTY125BASE/RED  |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/SIXTY125BASE/RED  |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/SIXTY125BASE/RED  |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/SIXTY125BASE/RED  |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/SIXTY125BASE/BLACK|R3U125 |WFK (White)|NN (Black) |ALT
HONEY/SIXTY125BASE/BLACK|R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/SIXTY125BASE/BLACK|R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/SIXTY125BASE/BLACK|R3U125 |WFK (White)|NN (Black) |META
HONEY/SIXTY125BASE/BLACK|R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/SIXTY125BASE/BLACK|R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/SIXTY125BASE/BLACK|R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/SIXTY125BASE/BLACK|R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/SIXTY125BASE/BLACK|R2U150 |WFK (White)|NN (Black) |TAB
HONEY/SIXTY125BASE/BLACK|R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/SIXTY125BASE/BLACK|R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/SIXTY125BASE/BLACK|R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/FORTY             |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/FORTY             |R3U100 |WFK (White)|GPA (Gray) |WIN
HONEY/FORTY             |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/FORTY             |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/FORTY             |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|Z
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|X
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|C
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|V
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|B
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|N
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|M
HONEY/FORTY             |R4U100 |NN (Black) |WFK (White)|\cdot
HONEY/FORTY             |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FORTY             |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/FORTY             |R3U125 |WFK (White)|GPA (Gray) |TAB
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|A
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|S
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|D
HONEY/FORTY             |R3U100D|NN (Black) |WFK (White)|F
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|G
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|H
HONEY/FORTY             |R3U100D|NN (Black) |WFK (White)|J
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|K
HONEY/FORTY             |R3U100 |NN (Black) |WFK (White)|L
HONEY/FORTY             |R3U175 |WFK (White)|GPA (Gray) |RETURN
HONEY/FORTY             |R2U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|Q
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|W
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|E
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|R
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|T
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|Y
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|U
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|I
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|O
HONEY/FORTY             |R2U100 |NN (Black) |WFK (White)|P
HONEY/FORTY             |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/HHKB              |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/HHKB              |R3U150 |WFK (White)|GPA (Gray) |\diamond
HONEY/HHKB              |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|Z
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|X
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|C
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|V
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|B
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|N
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|M
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/HHKB              |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/HHKB              |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/HHKB              |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/HHKB              |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|A
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|S
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|D
HONEY/HHKB              |R3U100D|NN (Black) |WFK (White)|F
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|G
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|H
HONEY/HHKB              |R3U100D|NN (Black) |WFK (White)|J
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|K
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|L
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/HHKB              |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/HHKB              |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|Q
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|W
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|E
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|R
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|T
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|Y
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|U
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|I
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|O
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|P
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/HHKB              |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/HHKB              |R2U150 |WFK (White)|GPA (Gray) |DELETE
HONEY/HHKB              |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/HHKB              |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/HHKB              |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|F
HONEY/HHKB              |R3U100 |NN (Black) |WFK (White)|J
HONEY/HHKB              |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/HHKB/BASE         |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/HHKB/BASE         |R3U150 |WFK (White)|GPA (Gray) |\diamond
HONEY/HHKB/BASE         |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/HHKB/BASE         |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/HHKB/BASE         |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/HHKB/BASE         |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/HHKB/BASE         |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/HHKB/BASE         |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/HHKB/BASE         |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/HHKB/BASE         |R2U150 |WFK (White)|GPA (Gray) |DELETE
HONEY/HHKB/BASE         |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/HHKB/BASE         |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/HHKB/BASE         |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/ERGO              |R1U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGO              |R1U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ERGO/R3           |R3U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGO/R3           |R3U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|Z
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|X
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|C
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|V
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|B
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|N
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|M
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/ALPHA             |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|A
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|S
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|D
HONEY/ALPHA             |R3U100D|NN (Black) |WFK (White)|F
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|G
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|H
HONEY/ALPHA             |R3U100D|NN (Black) |WFK (White)|J
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|K
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|L
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|F
HONEY/ALPHA             |R3U100 |NN (Black) |WFK (White)|J
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|Q
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|W
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|E
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|R
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|T
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|Y
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|U
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|I
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|O
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|P
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/ALPHA             |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/ALPHA             |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\tilde,\backprime
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\at,2
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\#,3
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/ALPHA             |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |\gt,\lt
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |Z
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |X
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |C
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |V
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |B
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |N
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |M
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |\lt,\comma
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |\gt,\period
HONEY/ALPHA/GREY        |R4U100 |WFK (White)|GPA (Gray) |?,\slash
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |A
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |S
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |D
HONEY/ALPHA/GREY        |R3U100D|WFK (White)|GPA (Gray) |F
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |G
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |H
HONEY/ALPHA/GREY        |R3U100D|WFK (White)|GPA (Gray) |J
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |K
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |L
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |\colon,\semicolon
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |\doublequote,\prime
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |F
HONEY/ALPHA/GREY        |R3U100 |WFK (White)|GPA (Gray) |J
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |Q
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |W
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |E
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |R
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |T
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |Y
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |U
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |I
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |O
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |P
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |\opencur,\openbra
HONEY/ALPHA/GREY        |R2U100 |WFK (White)|GPA (Gray) |\closecur,\closebra
HONEY/ALPHA/GREY        |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |!,1
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\at,2
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\#,3
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\$,4
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\%,5
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\wedge,6
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\&,7
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\ast,8
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\openparen,9
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\closeparen,0
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\longunderscore,\minus
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\plus,\equal
HONEY/ALPHA/GREY        |R1U100 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |\lt,\comma
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |\gt,\period
HONEY/ALPHA/RED         |R4U100 |WFK (White)|RAS (Red)  |?,\slash
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/ALPHA/RED         |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/ALPHA/RED         |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |\colon,\semicolon
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |\doublequote,\prime
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/ALPHA/RED         |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |\opencur,\openbra
HONEY/ALPHA/RED         |R2U100 |WFK (White)|RAS (Red)  |\closecur,\closebra
HONEY/ALPHA/RED         |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\at,2
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\#,3
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\wedge,6
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\&,7
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\ast,8
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\openparen,9
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\closeparen,0
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/ALPHA/RED         |R1U100 |WFK (White)|RAS (Red)  |\plus,\equal
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |\gt,\lt
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |Z
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |X
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |C
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |V
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |B
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |N
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |M
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |\lt,\comma
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |\gt,\period
HONEY/ALPHA/BLACK       |R4U100 |WFK (White)|NN (Black) |?,\slash
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |A
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |S
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |D
HONEY/ALPHA/BLACK       |R3U100D|WFK (White)|NN (Black) |F
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |G
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |H
HONEY/ALPHA/BLACK       |R3U100D|WFK (White)|NN (Black) |J
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |K
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |L
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |\colon,\semicolon
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |\doublequote,\prime
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |F
HONEY/ALPHA/BLACK       |R3U100 |WFK (White)|NN (Black) |J
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |Q
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |W
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |E
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |R
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |T
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |Y
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |U
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |I
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |O
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |P
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |\opencur,\openbra
HONEY/ALPHA/BLACK       |R2U100 |WFK (White)|NN (Black) |\closecur,\closebra
HONEY/ALPHA/BLACK       |R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\tilde,\backprime
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |!,1
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\at,2
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\#,3
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\$,4
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\%,5
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\wedge,6
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\&,7
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\ast,8
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\openparen,9
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\closeparen,0
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\longunderscore,\minus
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\plus,\equal
HONEY/ALPHA/BLACK       |R1U100 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|Z
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|X
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|C
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|V
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|B
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|N
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|M
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/ALPHAUK           |R4U100 |NN (Black) |WFK (White)|?,\slash
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|A
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|S
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|D
HONEY/ALPHAUK           |R3U100D|NN (Black) |WFK (White)|F
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|G
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|H
HONEY/ALPHAUK           |R3U100D|NN (Black) |WFK (White)|J
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|K
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|L
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|\at,\quote
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|\tilde,\#
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|F
HONEY/ALPHAUK           |R3U100 |NN (Black) |WFK (White)|J
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|Q
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|W
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|E
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|R
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|T
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|Y
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|U
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|I
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|O
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|P
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/ALPHAUK           |R2U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\neg,\backprime,\splitvert
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\wedge,6
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\&,7
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\ast,8
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\openparen,9
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\closeparen,0
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/ALPHAUK           |R1U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |Z
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |X
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |C
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |V
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |B
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |N
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |M
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |\lt,\comma
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |\gt,\period
HONEY/ALPHAUK/BLACK     |R4U100 |WFK (White)|NN (Black) |?,\slash
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |A
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |S
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |D
HONEY/ALPHAUK/BLACK     |R3U100D|WFK (White)|NN (Black) |F
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |G
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |H
HONEY/ALPHAUK/BLACK     |R3U100D|WFK (White)|NN (Black) |J
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |K
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |L
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |\colon,\semicolon
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |\at,\quote
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |\tilde,\#
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |F
HONEY/ALPHAUK/BLACK     |R3U100 |WFK (White)|NN (Black) |J
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |Q
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |W
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |E
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |R
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |T
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |Y
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |U
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |I
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |O
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |P
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |\opencur,\openbra
HONEY/ALPHAUK/BLACK     |R2U100 |WFK (White)|NN (Black) |\closecur,\closebra
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\neg,\backprime,\splitvert
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |!,1
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\doublequote,2
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\pound,3
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\$,4
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\%,5
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\wedge,6
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\&,7
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\ast,8
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\openparen,9
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\closeparen,0
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\longunderscore,\minus
HONEY/ALPHAUK/BLACK     |R1U100 |WFK (White)|NN (Black) |\plus,\equal
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|Z
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|X
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|C
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|V
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|B
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|N
HONEY/ALPHAINT          |R4U100 |NN (Black) |WFK (White)|M
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|A
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|S
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|D
HONEY/ALPHAINT          |R3U100D|NN (Black) |WFK (White)|F
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|G
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|H
HONEY/ALPHAINT          |R3U100D|NN (Black) |WFK (White)|J
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|K
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|L
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|F
HONEY/ALPHAINT          |R3U100 |NN (Black) |WFK (White)|J
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|Q
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|W
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|E
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|R
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|T
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|Y
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|U
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|I
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|O
HONEY/ALPHAINT          |R2U100 |NN (Black) |WFK (White)|P
HONEY/ALPHAINT          |R1U100 |NN (Black) |WFK (White)|!,1
HONEY/ALPHAINT          |R1U100 |NN (Black) |WFK (White)|\$,4
HONEY/ALPHAINT          |R1U100 |NN (Black) |WFK (White)|\%,5
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |Z
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |X
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |C
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |V
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |N
HONEY/ALPHAINT/RED      |R4U100 |WFK (White)|RAS (Red)  |M
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/ALPHAINT/RED      |R3U100D|WFK (White)|RAS (Red)  |F
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/ALPHAINT/RED      |R3U100D|WFK (White)|RAS (Red)  |J
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |K
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |L
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/ALPHAINT/RED      |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |Q
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |E
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |R
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |T
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |Y
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |U
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |I
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |O
HONEY/ALPHAINT/RED      |R2U100 |WFK (White)|RAS (Red)  |P
HONEY/ALPHAINT/RED      |R1U100 |WFK (White)|RAS (Red)  |!,1
HONEY/ALPHAINT/RED      |R1U100 |WFK (White)|RAS (Red)  |\$,4
HONEY/ALPHAINT/RED      |R1U100 |WFK (White)|RAS (Red)  |\%,5
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |Z
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |X
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |C
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |V
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |B
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |N
HONEY/ALPHAINT/BLACK    |R4U100 |WFK (White)|NN (Black) |M
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |A
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |S
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |D
HONEY/ALPHAINT/BLACK    |R3U100D|WFK (White)|NN (Black) |F
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |G
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |H
HONEY/ALPHAINT/BLACK    |R3U100D|WFK (White)|NN (Black) |J
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |K
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |L
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |F
HONEY/ALPHAINT/BLACK    |R3U100 |WFK (White)|NN (Black) |J
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |Q
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |W
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |E
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |R
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |T
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |Y
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |U
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |I
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |O
HONEY/ALPHAINT/BLACK    |R2U100 |WFK (White)|NN (Black) |P
HONEY/ALPHAINT/BLACK    |R1U100 |WFK (White)|NN (Black) |!,1
HONEY/ALPHAINT/BLACK    |R1U100 |WFK (White)|NN (Black) |\$,4
HONEY/ALPHAINT/BLACK    |R1U100 |WFK (White)|NN (Black) |\%,5
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\vert
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\backslash
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|Y
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/INTER             |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\"A
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\O
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\AE
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\prime,\#
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\c{c},\`o,\at
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|o,\`a,\#
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\sect,\`u
HONEY/INTER             |R3U100 |NN (Black) |WFK (White)|\wedge,\tilde
HONEY/INTER             |R2U100 |NN (Black) |WFK (White)|\"U
HONEY/INTER             |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/INTER             |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/INTER             |R2U100 |NN (Black) |WFK (White)|\'e,\`e,\openbra
HONEY/INTER             |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\closebra
HONEY/INTER             |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\tilde
HONEY/INTER             |R2U150 |NN (Black) |WFK (White)|\ast,\quote
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\slash,7
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\openparen,8
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\closeparen,9
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\equal,0
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\backprime,\prime
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\backprime,\backslash,\prime
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\backprime,\vert,\prime
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\powertwo
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\S,3,\powerthree
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|?,\ss,\backslash
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|?,\plus,\backslash
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|?,\textquotesingle
HONEY/INTER             |R1U100 |WFK (White)|GPA (Gray) |\circ,\wedge
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\circ,\wedge
HONEY/INTER             |R1U100 |WFK (White)|GPA (Gray) |\onehalf,\sect
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\onehalf,\sect
HONEY/INTER             |R1U100 |WFK (White)|GPA (Gray) |\sect,\onehalf
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\sect,\onehalf
HONEY/INTER             |R1U100 |WFK (White)|GPA (Gray) |\sect,\vert
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\sect,\vert
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\wedge,\`i
HONEY/INTER             |R1U100 |NN (Black) |WFK (White)|\prime,\hash
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt,\vert
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt,\backslash
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |Y
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |\semicolon,\comma
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |\colon,\period
HONEY/INTER/RED         |R4U100 |WFK (White)|RAS (Red)  |\longunderscore,\minus
HONEY/INTER/RED         |R3U100 |WFK (White)|RAS (Red)  |\"O
HONEY/INTER/RED         |R3U100 |WFK (White)|RAS (Red)  |\O
HONEY/INTER/RED         |R3U100 |WFK (White)|RAS (Red)  |\"A
HONEY/INTER/RED         |R3U100 |WFK (White)|RAS (Red)  |\AE
HONEY/INTER/RED         |R3U100 |WFK (White)|RAS (Red)  |\ast,\quote
HONEY/INTER/RED         |R3U100 |WFK (White)|RAS (Red)  |\prime,\#
HONEY/INTER/RED         |R2U100 |WFK (White)|RAS (Red)  |\"U
HONEY/INTER/RED         |R2U100 |WFK (White)|RAS (Red)  |\swedA
HONEY/INTER/RED         |R2U100 |WFK (White)|RAS (Red)  |\wedge,\dieresis,\sim
HONEY/INTER/RED         |R2U100 |WFK (White)|RAS (Red)  |\ast,\plus,\tilde
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\doublequote,2,\at
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\doublequote,2,\powertwo
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\#,3,\pound
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\S,3,\powerthree
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\textcurrency,4,\$
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\&,6
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\slash,7,\opencur
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\openparen,8,\openbra
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\closeparen,9,\closebra
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\equal,0,\closecur
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\onehalf,\sect
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\sect,\onehalf
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\sect,\vert
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\circ,\wedge
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |?,\plus,\backslash
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |?,\ss,\backslash
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\backprime,\prime
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\backprime,\vert,\prime
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\backprime,\backslash,\prime
HONEY/INTER/RED         |R1U100 |WFK (White)|RAS (Red)  |\prime,\#
HONEY/INTER/BLACK       |R4U100 |WFK (White)|NN (Black) |\gt,\lt
HONEY/INTER/BLACK       |R4U100 |WFK (White)|NN (Black) |Y
HONEY/INTER/BLACK       |R4U100 |WFK (White)|NN (Black) |\semicolon,\comma
HONEY/INTER/BLACK       |R4U100 |WFK (White)|NN (Black) |\colon,\period
HONEY/INTER/BLACK       |R4U100 |WFK (White)|NN (Black) |\longunderscore,\minus
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\"O
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\"A
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\O
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\AE
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\ast,\quote
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\prime,\#
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\c{c},\`o
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |o,\`a
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\sect,\`u
HONEY/INTER/BLACK       |R3U100 |WFK (White)|NN (Black) |\wedge,\tilde
HONEY/INTER/BLACK       |R2U100 |WFK (White)|NN (Black) |\"U
HONEY/INTER/BLACK       |R2U100 |WFK (White)|NN (Black) |\swedA
HONEY/INTER/BLACK       |R2U100 |WFK (White)|NN (Black) |\wedge,\dieresis
HONEY/INTER/BLACK       |R2U100 |WFK (White)|NN (Black) |\'e,\`e
HONEY/INTER/BLACK       |R2U100 |WFK (White)|NN (Black) |\ast,\plus
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\doublequote,2
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\#,3
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\textcurrency,4
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\&,6
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\slash,7
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\openparen,8
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\closeparen,9
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\equal,0
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\backprime,\prime
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\backprime,\backslash
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\backprime,\vert
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\pound,3
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\S,3
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |?,\ss
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |?,\plus
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |?,\textquotesingle
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\circ,\wedge
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\onehalf,\sect
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\sect,\onehalf
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\sect,\vert
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\wedge,\`i
HONEY/INTER/BLACK       |R1U100 |WFK (White)|NN (Black) |\prime,\hash
HONEY/INTERFACE         |R3U100 |WFK (White)|NN (Black) |\"O
HONEY/INTERFACE         |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/INTERFACE         |R3U100 |WFK (White)|RAS (Red)  |\"O
HONEY/INTERFACE         |R2U100 |WFK (White)|NN (Black) |\wedge,\dieresis
HONEY/INTERFACE         |R2U100 |NN (Black) |WFK (White)|\dieresis,\wedge
HONEY/INTERFACE         |R1U100 |WFK (White)|NN (Black) |\circ,\wedge
HONEY/INTERFACE         |R1U100 |NN (Black) |WFK (White)|\circ,\wedge
HONEY/INTERFACE         |R1U100 |WFK (White)|RAS (Red)  |\circ,\wedge
HONEY/INTERFACE         |R1U100 |WFK (White)|GPA (Gray) |\circ,\wedge
HONEY/DE                |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\vert
HONEY/DE                |R4U100 |NN (Black) |WFK (White)|Y
HONEY/DE                |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/DE                |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/DE                |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/DE                |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/DE                |R3U100 |NN (Black) |WFK (White)|\"A
HONEY/DE                |R3U100 |NN (Black) |WFK (White)|\prime,\#
HONEY/DE                |R2U100 |NN (Black) |WFK (White)|\"U
HONEY/DE                |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\tilde
HONEY/DE                |R1U100 |WFK (White)|GPA (Gray) |\circ,\wedge
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\circ,\wedge
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\powertwo
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\S,3,\powerthree
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|?,\ss,\backslash
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\backprime,\prime
HONEY/DE                |R1U100 |NN (Black) |WFK (White)|\prime,\#
HONEY/DK                |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\backslash
HONEY/DK                |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/DK                |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/DK                |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/DK                |R3U100 |NN (Black) |WFK (White)|\AE
HONEY/DK                |R3U100 |NN (Black) |WFK (White)|\O
HONEY/DK                |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/DK                |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/DK                |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/DK                |R1U100 |WFK (White)|GPA (Gray) |\sect,\onehalf
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\sect,\onehalf
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|?,\plus
HONEY/DK                |R1U100 |NN (Black) |WFK (White)|\backprime,\vert,\prime
HONEY/NO                |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/NO                |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/NO                |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/NO                |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/NO                |R3U100 |NN (Black) |WFK (White)|\AE
HONEY/NO                |R3U100 |NN (Black) |WFK (White)|\O
HONEY/NO                |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/NO                |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/NO                |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/NO                |R1U100 |WFK (White)|GPA (Gray) |\sect,\vert
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\sect,\vert
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|?,\plus
HONEY/NO                |R1U100 |NN (Black) |WFK (White)|\backprime,\backslash,\prime
HONEY/SE                |R4U100 |NN (Black) |WFK (White)|\gt,\lt,\vert
HONEY/SE                |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/SE                |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/SE                |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/SE                |R3U100 |NN (Black) |WFK (White)|\"O
HONEY/SE                |R3U100 |NN (Black) |WFK (White)|\"A
HONEY/SE                |R3U100 |NN (Black) |WFK (White)|\ast,\quote
HONEY/SE                |R2U100 |NN (Black) |WFK (White)|\swedA
HONEY/SE                |R2U100 |NN (Black) |WFK (White)|\wedge,\dieresis,\sim
HONEY/SE                |R1U100 |WFK (White)|GPA (Gray) |\onehalf,\sect
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\onehalf,\sect
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\doublequote,2,\at
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\#,3,\pound
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\textcurrency,4,\$
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\slash,7,\opencur
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\openparen,8,\openbra
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\closeparen,9,\closebra
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\equal,0,\closecur
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|?,\plus,\backslash
HONEY/SE                |R1U100 |NN (Black) |WFK (White)|\backprime,\prime
HONEY/IT                |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/IT                |R4U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/IT                |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/IT                |R4U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/IT                |R3U100 |NN (Black) |WFK (White)|\c{c},\`o,\at
HONEY/IT                |R3U100 |NN (Black) |WFK (White)|o,\`a,\#
HONEY/IT                |R3U100 |NN (Black) |WFK (White)|\sect,\`u
HONEY/IT                |R2U100 |NN (Black) |WFK (White)|\'e,\`e,\openbra
HONEY/IT                |R2U100 |NN (Black) |WFK (White)|\ast,\plus,\closebra
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\&,6
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\slash,7
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\openparen,8
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\closeparen,9
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\equal,0
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|?,\textquotesingle
HONEY/IT                |R1U100 |NN (Black) |WFK (White)|\wedge,\`i
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|W
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|X
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|C
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|V
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|B
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|N
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|?,\comma
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|\period,\semicolon
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|\slash,\colon
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|\sect,!
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|\mu,\ast
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|Q
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|S
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|D
HONEY/FRALPHA           |R3U100D|NN (Black) |WFK (White)|F
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|G
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|H
HONEY/FRALPHA           |R3U100D|NN (Black) |WFK (White)|J
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|K
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|L
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|M
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|\%,\`U
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|\mu,\ast
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|F
HONEY/FRALPHA           |R3U100 |NN (Black) |WFK (White)|J
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|A
HONEY/FRALPHA           |R4U100 |NN (Black) |WFK (White)|Z
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|E
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|R
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|T
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|Y
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|U
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|I
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|O
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|P
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|\dieresis,\wedge
HONEY/FRALPHA           |R2U100 |NN (Black) |WFK (White)|\pounds,\$,\textcurrency
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|\ph,\powertwo
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|1,\&
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|2,\'e,\tilde
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|3,\doublequote,\hash
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|4,\quote,\opencur
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|5,\openparen,\openbra
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|6,\minus,\splitvert
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|7,\`e,\backprime
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|8,\underscore,\backslash
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|9,\ccedile,\wedge
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|0,\gravea,\at
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|\circ,\closeparen,\closebra
HONEY/FRALPHA           |R1U100 |NN (Black) |WFK (White)|\plus,\equal,\closecur
HONEY/UK                |R4U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/UK                |R3U100 |NN (Black) |WFK (White)|\at,\quote
HONEY/UK                |R3U100 |NN (Black) |WFK (White)|\tilde,\#
HONEY/UK                |R1U100 |NN (Black) |WFK (White)|\neg,\backprime,\splitvert
HONEY/UK                |R1U100 |NN (Black) |WFK (White)|\doublequote,2
HONEY/UK                |R1U100 |NN (Black) |WFK (White)|\pound,3
HONEY/UK/BLACK          |R4U100 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/UK/BLACK          |R3U100 |WFK (White)|NN (Black) |\at,\quote
HONEY/UK/BLACK          |R3U100 |WFK (White)|NN (Black) |\tilde,\#
HONEY/UK/BLACK          |R1U100 |WFK (White)|NN (Black) |\neg,\backprime,\splitvert
HONEY/UK/BLACK          |R1U100 |WFK (White)|NN (Black) |\doublequote,2
HONEY/UK/BLACK          |R1U100 |WFK (White)|NN (Black) |\pound,3
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|\^E
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|\`A
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|Y
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|X
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|\colon,\period
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|K
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|?,\prime
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|Q
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|G
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|H
HONEY/BEPOALPHA         |R4U100 |NN (Black) |WFK (White)|F
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|A
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|U
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|I
HONEY/BEPOALPHA         |R3U100D|NN (Black) |WFK (White)|E
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|\semicolon,\comma
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|C
HONEY/BEPOALPHA         |R3U100D|NN (Black) |WFK (White)|T
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|S
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|R
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|N
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|M
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|\Ccedile
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|E
HONEY/BEPOALPHA         |R3U100 |NN (Black) |WFK (White)|T
HONEY/BEPOALPHA         |R2U150 |NN (Black) |WFK (White)|\bepoccedile,\ph
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|B
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|\'E
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|P
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|O
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|\`E
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|!,\wedge
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|V
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|D
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|L
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|J
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|Z
HONEY/BEPOALPHA         |R2U100 |NN (Black) |WFK (White)|W
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|\hash,\$
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|1,\doublequote
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|2,\ll
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|3,\gg
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|4,\openparen
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|5,\closeparen
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|6,\at
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|7,\plus
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|8,\minus
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|9,\slash
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|0,\ast
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|\circ,\equal
HONEY/BEPOALPHA         |R1U100 |NN (Black) |WFK (White)|\backprime,\mod
HONEY/COLEMAK           |R4U100 |NN (Black) |WFK (White)|K
HONEY/COLEMAK           |R3U100 |NN (Black) |WFK (White)|R
HONEY/COLEMAK           |R3U100D|NN (Black) |WFK (White)|T
HONEY/COLEMAK           |R3U100D|NN (Black) |WFK (White)|N
HONEY/COLEMAK           |R3U100 |NN (Black) |WFK (White)|E
HONEY/COLEMAK           |R3U100 |NN (Black) |WFK (White)|I
HONEY/COLEMAK           |R3U100 |NN (Black) |WFK (White)|O
HONEY/COLEMAK           |R3U100 |NN (Black) |WFK (White)|T
HONEY/COLEMAK           |R3U100 |NN (Black) |WFK (White)|N
HONEY/COLEMAK           |R2U100 |NN (Black) |WFK (White)|F
HONEY/COLEMAK           |R2U100 |NN (Black) |WFK (White)|G
HONEY/COLEMAK           |R2U100 |NN (Black) |WFK (White)|J
HONEY/COLEMAK           |R2U100 |NN (Black) |WFK (White)|L
HONEY/COLEMAK           |R2U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/DVORAK            |R4U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/DVORAK            |R4U100 |NN (Black) |WFK (White)|Q
HONEY/DVORAK            |R4U100 |NN (Black) |WFK (White)|J
HONEY/DVORAK            |R4U100 |NN (Black) |WFK (White)|K
HONEY/DVORAK            |R4U100 |NN (Black) |WFK (White)|W
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|O
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|E
HONEY/DVORAK            |R3U100D|NN (Black) |WFK (White)|U
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|I
HONEY/DVORAK            |R3U100D|NN (Black) |WFK (White)|H
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|T
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|N
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|U
HONEY/DVORAK            |R3U100 |NN (Black) |WFK (White)|H
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|F
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|G
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|C
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|L
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|?,\slash
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/DVORAK            |R2U100 |NN (Black) |WFK (White)|\at,\quote
HONEY/DVORAK            |R1U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/DVORAK            |R1U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/COLRAK            |R4U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/COLRAK            |R4U100 |NN (Black) |WFK (White)|Q
HONEY/COLRAK            |R4U100 |NN (Black) |WFK (White)|J
HONEY/COLRAK            |R4U100 |NN (Black) |WFK (White)|K
HONEY/COLRAK            |R4U100 |NN (Black) |WFK (White)|W
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|R
HONEY/COLRAK            |R3U100D|NN (Black) |WFK (White)|T
HONEY/COLRAK            |R3U100D|NN (Black) |WFK (White)|N
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|O
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|E
HONEY/COLRAK            |R3U100D|NN (Black) |WFK (White)|U
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|I
HONEY/COLRAK            |R3U100D|NN (Black) |WFK (White)|H
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|T
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|N
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|\longunderscore,\minus
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|U
HONEY/COLRAK            |R3U100 |NN (Black) |WFK (White)|H
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|\doublequote,\prime
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|\lt,\comma
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|\gt,\period
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|F
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|G
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|C
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|J
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|L
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|?,\slash
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|\plus,\equal
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|\at,\quote
HONEY/COLRAK            |R2U100 |NN (Black) |WFK (White)|\colon,\semicolon
HONEY/COLRAK            |R1U100 |NN (Black) |WFK (White)|\opencur,\openbra
HONEY/COLRAK            |R1U100 |NN (Black) |WFK (White)|\closecur,\closebra
HONEY/7BIT              |R3U100 |NN (Black) |WFK (White)|?,\slash
HONEY/7BIT              |R3U100 |NN (Black) |WFK (White)|\backprime,\semicolon
HONEY/7BIT              |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/7BIT              |R2U100 |WFK (White)|GPA (Gray) |\opencur
HONEY/7BIT              |R2U100 |WFK (White)|GPA (Gray) |\closecur
HONEY/7BIT              |R1U100 |NN (Black) |WFK (White)|\pm,\doublequote
HONEY/7BIT              |R1U100 |NN (Black) |WFK (White)|\tilde,\colon
HONEY/7BIT              |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/7BIT              |R1U100 |NN (Black) |WFK (White)|\lt,\openparen
HONEY/7BIT              |R1U100 |NN (Black) |WFK (White)|\gt,\closeparen
HONEY/7BIT              |R1U100 |WFK (White)|GPA (Gray) |\openparen
HONEY/7BIT              |R1U100 |WFK (White)|GPA (Gray) |\closeparen
HONEY/ISO               |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/ISO               |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/ISO               |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/ISO               |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/ISO/RED           |R3U125 |WFK (White)|RAS (Red)  |ALT\ \ GR
HONEY/ISO/RED           |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/ISO/RED           |R2UJRET|WFK (White)|RAS (Red)  |RETURN
HONEY/ISO/RED           |R3U150 |WFK (White)|RAS (Red)  |ALT\ \ GRAPH
HONEY/ISO/BLACK         |R3U125 |WFK (White)|NN (Black) |ALT\ \ GR
HONEY/ISO/BLACK         |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/ISO/BLACK         |R2UJRET|WFK (White)|NN (Black) |RETURN
HONEY/ISO/BLACK         |R3U150 |WFK (White)|NN (Black) |ALT\ \ GRAPH
HONEY/MODIFIER          |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER          |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIER          |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER          |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIER          |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER          |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER          |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MODIFIER          |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER          |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODIFIER          |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/MODIFIER          |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER          |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/MODIFIER          |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/MODIFIER          |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODIFIER          |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/MODIFIER          |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIER          |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/MODIFIER          |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIER          |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/MODIFIER          |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MODIFIEREXTRA     |R3U175 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA     |R3U175 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODIFIEREXTRA     |R3U175 |WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODIFIEREXTRA     |R3U175 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODIFIEREXTRA     |R3U175S|WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA     |R3U175S|WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIEREXTRA     |R3U175S|WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |TOP
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |FRONT
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |SHIFT\ \ LOCK
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/MODIFIEREXTRA     |R3U150 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |TAB
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/MODIFIEREXTRA     |R3U125 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |FUN
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |CMD
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |OPT
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |WIN
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |MENU
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |SHIFT,LOCK
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |MODE,LOCK
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |ALT,LOCK
HONEY/MODIFIEREXTRA     |R3U100 |WFK (White)|GPA (Gray) |TTY,LOCK
HONEY/FUN125            |R3U125 |WFK (White)|GPA (Gray) |FUN
HONEY/FUN125/RED        |R3U125 |WFK (White)|RAS (Red)  |FUN
HONEY/FUN125/BLACK      |R3U125 |WFK (White)|NN (Black) |FUN
HONEY/WINDOWS125        |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/WINDOWS125        |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/WINDOWS125/RED    |R3U125 |WFK (White)|RAS (Red)  |WIN
HONEY/WINDOWS125/RED    |R3U125 |WFK (White)|RAS (Red)  |MENU
HONEY/WINDOWS125/BLACK  |R3U125 |WFK (White)|NN (Black) |WIN
HONEY/WINDOWS125/BLACK  |R3U125 |WFK (White)|NN (Black) |MENU
HONEY/WINDOWS150        |R3U150 |WFK (White)|GPA (Gray) |WIN
HONEY/WINDOWS150        |R3U150 |WFK (White)|GPA (Gray) |MENU
HONEY/APPLE125          |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/APPLE125          |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/APPLE125/RED      |R3U125 |WFK (White)|RAS (Red)  |OPTION
HONEY/APPLE125/RED      |R3U125 |WFK (White)|RAS (Red)  |COMMAND
HONEY/APPLE125/BLACK    |R3U125 |WFK (White)|NN (Black) |OPTION
HONEY/APPLE125/BLACK    |R3U125 |WFK (White)|NN (Black) |COMMAND
HONEY/APPLE150          |R3U150 |WFK (White)|GPA (Gray) |OPTION
HONEY/APPLE150          |R3U150 |WFK (White)|GPA (Gray) |COMMAND
HONEY/MOD100            |R3U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/MOD100            |R3U100 |WFK (White)|GPA (Gray) |META
HONEY/MOD100            |R3U100 |WFK (White)|GPA (Gray) |SUPER
HONEY/MOD100            |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MOD100            |R1U100 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/MOD100            |R1U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |SUPER
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |META
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |FN
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |WIN
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |MENU
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |OPTION
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |COMMAND
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |ALT
HONEY/MOD125            |R3U125 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |SUPER
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |ALT
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |ALT\ \ GRAPH
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD150            |R2U150 |WFK (White)|GPA (Gray) |TAB
HONEY/MOD150            |R2U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MOD150            |R3U150 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |CONTROL
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |SUPER
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |META
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |ALT
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |ALT\ \ GRAPH
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |FUNCTION
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |SHIFT
HONEY/MOD150/RED        |R2U150 |WFK (White)|RAS (Red)  |TAB
HONEY/MOD150/RED        |R2U150 |WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/MOD150/RED        |R3U150 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |CONTROL
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |SUPER
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |META
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |ALT
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |ALT\ \ GRAPH
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |FUNCTION
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |SHIFT
HONEY/MOD150/BLACK      |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/MOD150/BLACK      |R2U150 |WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/MOD150/BLACK      |R3U150 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/MOD175            |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD175            |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/MOD175            |R3U175 |WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD175            |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MOD175            |R3U175S|WFK (White)|GPA (Gray) |CONTROL
HONEY/MOD200            |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD200            |R3U225 |WFK (White)|GPA (Gray) |RETURN
HONEY/MOD200            |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MOD200            |R1U200H|WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MOD200            |R3U275 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |FUN
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |CMD
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |OPT
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |ALT\ \ GR
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |WIN
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |MENU
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |SHIFT,LOCK
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |MODE,LOCK
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |ALT,LOCK
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |TTY,LOCK
HONEY/MODEXTRA100       |R3U100 |WFK (White)|GPA (Gray) |FN
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |TAB
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |ENTER
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/MODEXTRA125       |R3U125 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |TOP
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |FRONT
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |META
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |SYMBOL
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |MODE
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |SHIFT\ \ LOCK
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |DELETE
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |RETURN
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |LINE
HONEY/MODEXTRA150       |R3U150 |WFK (White)|GPA (Gray) |PAGE
HONEY/MODEXTRA150       |R2U150 |WFK (White)|GPA (Gray) |CUT
HONEY/MODEXTRA150       |R2U150 |WFK (White)|GPA (Gray) |CLEAR
HONEY/MODEXTRA150       |R2U150 |WFK (White)|GPA (Gray) |DELETE
HONEY/MODEXTRA150       |R1U150 |WFK (White)|GPA (Gray) |ESCAPE
HONEY/MODEXTRA150       |R1U150 |WFK (White)|GPA (Gray) |COMPOSE
HONEY/MODEXTRA150       |R1U150 |WFK (White)|GPA (Gray) |UNDO
HONEY/MODEXTRA150       |R1U150 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODEXTRA150/R4    |R4U150 |WFK (White)|GPA (Gray) |FRONT
HONEY/MODEXTRA150/R4    |R4U150 |WFK (White)|GPA (Gray) |GREEK
HONEY/MODEXTRA150/R4    |R4U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/MODEXTRA150/R4    |R4U150 |WFK (White)|GPA (Gray) |SYMBOL
HONEY/MODEXTRA175       |R3U175 |WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA175       |R3U175 |WFK (White)|GPA (Gray) |BACK\ \ SPACE
HONEY/MODEXTRA175       |R3U175 |WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODEXTRA175       |R3U175 |WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODEXTRA175       |R3U175S|WFK (White)|GPA (Gray) |HYPER
HONEY/MODEXTRA175       |R3U175S|WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/MODEXTRA175       |R3U175S|WFK (White)|GPA (Gray) |RUB\ \ OUT
HONEY/MODEXTRA175       |R3U175S|WFK (White)|GPA (Gray) |FUNCTION
HONEY/MODSYM100         |R4U100 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM100         |R3U100 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM100         |R3U100 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM100         |R3U100 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM100         |R3U100 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM100         |R2U100 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM100         |R2U100 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM100         |R2U100 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM100         |R2U100 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM125         |R3U125 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM125         |R3U125 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM125         |R3U125 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM125         |R3U125 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM150         |R4U150 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM150         |R3U150 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM150         |R3U150 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM150         |R3U150 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM150         |R3U150 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM150         |R2U150 |WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM150         |R2U150 |WFK (White)|GPA (Gray) |\square
HONEY/MODSYM150         |R2U150 |WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM150         |R2U150 |WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM200POS      |R2U200P|WFK (White)|GPA (Gray) |\circle
HONEY/MODSYM200POS      |R2U200P|WFK (White)|GPA (Gray) |\square
HONEY/MODSYM200POS      |R2U200P|WFK (White)|GPA (Gray) |\triangle
HONEY/MODSYM200POS      |R2U200P|WFK (White)|GPA (Gray) |\diamond
HONEY/MODSYM100/BLACK   |R3U100 |WFK (White)|NN (Black) |\circle
HONEY/MODSYM100/BLACK   |R3U100 |WFK (White)|NN (Black) |\square
HONEY/MODSYM100/BLACK   |R3U100 |WFK (White)|NN (Black) |\triangle
HONEY/MODSYM100/BLACK   |R3U100 |WFK (White)|NN (Black) |\diamond
HONEY/MODSYM100/BLACK   |R2U100 |WFK (White)|NN (Black) |\circle
HONEY/MODSYM100/BLACK   |R2U100 |WFK (White)|NN (Black) |\square
HONEY/MODSYM100/BLACK   |R2U100 |WFK (White)|NN (Black) |\triangle
HONEY/MODSYM100/BLACK   |R2U100 |WFK (White)|NN (Black) |\diamond
HONEY/MODSYM125/BLACK   |R3U125 |WFK (White)|NN (Black) |\circle
HONEY/MODSYM125/BLACK   |R3U125 |WFK (White)|NN (Black) |\square
HONEY/MODSYM125/BLACK   |R3U125 |WFK (White)|NN (Black) |\triangle
HONEY/MODSYM125/BLACK   |R3U125 |WFK (White)|NN (Black) |\diamond
HONEY/WASD/RED          |R3U100 |WFK (White)|RAS (Red)  |A
HONEY/WASD/RED          |R3U100 |WFK (White)|RAS (Red)  |S
HONEY/WASD/RED          |R3U100 |WFK (White)|RAS (Red)  |D
HONEY/WASD/RED          |R2U100 |WFK (White)|RAS (Red)  |W
HONEY/CURSORBASE        |R2U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/CURSORBASE        |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/CURSORBASE        |R2U100 |WFK (White)|GPA (Gray) |PAGE,DOWN
HONEY/CURSORBASE        |R1U100 |WFK (White)|GPA (Gray) |INSERT
HONEY/CURSORBASE        |R1U100 |WFK (White)|GPA (Gray) |HOME
HONEY/CURSORBASE        |R1U100 |WFK (White)|GPA (Gray) |PAGE,UP
HONEY/CURSORBASE        |R1U100 |WFK (White)|GPA (Gray) |PRINT
HONEY/CURSORBASE        |R1U100 |WFK (White)|GPA (Gray) |SCROLL,LOCK
HONEY/CURSORBASE        |R1U100 |WFK (White)|GPA (Gray) |PAUSE
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |\leftarrow
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |\downarrow
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |\rightarrow
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSORS           |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSORS           |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSORS           |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSORS           |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSORS           |R3U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSORS           |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSORS           |R2U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSORS           |R2U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSORS           |R2U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSORS           |R2U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R24        |R2U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R24        |R2U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R24        |R2U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R24        |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R24        |R4U100 |WFK (White)|GPA (Gray) |\rightarrow
HONEY/CURSOR/R24        |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R24        |R4U100 |WFK (White)|GPA (Gray) |\leftarrow
HONEY/CURSOR/R3         |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R3         |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R3         |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R3         |R3U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R3         |R3U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R34        |R3U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R34        |R3U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R34        |R3U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R34        |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R34        |R3U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R34        |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |LEFT
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |DOWN
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |RIGHT
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |UP
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |\leftarrow
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |\downarrow
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |\rightarrow
HONEY/CURSOR/R4         |R4U100 |WFK (White)|GPA (Gray) |\uparrow
HONEY/CURSORBASE/WHITE  |R2U100 |NN (Black) |WFK (White)|DELETE
HONEY/CURSORBASE/WHITE  |R2U100 |NN (Black) |WFK (White)|END
HONEY/CURSORBASE/WHITE  |R2U100 |NN (Black) |WFK (White)|PAGE,DOWN
HONEY/CURSORBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|INSERT
HONEY/CURSORBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|HOME
HONEY/CURSORBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|PAGE,UP
HONEY/CURSORBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|PRINT
HONEY/CURSORBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|SCROLL,LOCK
HONEY/CURSORBASE/WHITE  |R1U100 |NN (Black) |WFK (White)|PAUSE
HONEY/CURSORBASE/RED    |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/CURSORBASE/RED    |R2U100 |WFK (White)|RAS (Red)  |END
HONEY/CURSORBASE/RED    |R2U100 |WFK (White)|RAS (Red)  |PAGE,DOWN
HONEY/CURSORBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |INSERT
HONEY/CURSORBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |HOME
HONEY/CURSORBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PAGE,UP
HONEY/CURSORBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PRINT
HONEY/CURSORBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |SCROLL,LOCK
HONEY/CURSORBASE/RED    |R1U100 |WFK (White)|RAS (Red)  |PAUSE
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |\leftarrow
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |\downarrow
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |\rightarrow
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSORS/RED       |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSORS/RED       |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSORS/RED       |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSORS/RED       |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSORS/RED       |R3U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSORS/RED       |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSORS/RED       |R2U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSORS/RED       |R2U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSORS/RED       |R2U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSORS/RED       |R2U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R24/RED    |R2U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R24/RED    |R2U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R24/RED    |R2U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R24/RED    |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R24/RED    |R4U100 |WFK (White)|RAS (Red)  |\rightarrow
HONEY/CURSOR/R24/RED    |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R24/RED    |R4U100 |WFK (White)|RAS (Red)  |\leftarrow
HONEY/CURSOR/R3/RED     |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R3/RED     |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R3/RED     |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R3/RED     |R3U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R3/RED     |R3U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R34/RED    |R3U100 |WFK (White)|RAS (Red)  |LEFT
HONEY/CURSOR/R34/RED    |R3U100 |WFK (White)|RAS (Red)  |DOWN
HONEY/CURSOR/R34/RED    |R3U100 |WFK (White)|RAS (Red)  |RIGHT
HONEY/CURSOR/R34/RED    |R4U100 |WFK (White)|RAS (Red)  |UP
HONEY/CURSOR/R34/RED    |R3U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSOR/R34/RED    |R4U100 |WFK (White)|RAS (Red)  |\uparrow
HONEY/CURSORBASE/BLACK  |R2U100 |WFK (White)|NN (Black) |DELETE
HONEY/CURSORBASE/BLACK  |R2U100 |WFK (White)|NN (Black) |END
HONEY/CURSORBASE/BLACK  |R2U100 |WFK (White)|NN (Black) |PAGE,DOWN
HONEY/CURSORBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |INSERT
HONEY/CURSORBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |HOME
HONEY/CURSORBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PAGE,UP
HONEY/CURSORBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PRINT
HONEY/CURSORBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |SCROLL,LOCK
HONEY/CURSORBASE/BLACK  |R1U100 |WFK (White)|NN (Black) |PAUSE
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |\leftarrow
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |\downarrow
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |\rightarrow
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSORS/BLACK     |R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSORS/BLACK     |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSORS/BLACK     |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSORS/BLACK     |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSORS/BLACK     |R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSORS/BLACK     |R3U100 |WFK (White)|NN (Black) |UP
HONEY/CURSORS/BLACK     |R2U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSORS/BLACK     |R2U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSORS/BLACK     |R2U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSORS/BLACK     |R2U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R3/BLACK   |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R3/BLACK   |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R3/BLACK   |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R3/BLACK   |R3U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R3/BLACK   |R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R34/BLACK  |R3U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R34/BLACK  |R3U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R34/BLACK  |R3U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R34/BLACK  |R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R34/BLACK  |R3U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R34/BLACK  |R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |LEFT
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |DOWN
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |RIGHT
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |UP
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |\leftarrow
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |\downarrow
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |\rightarrow
HONEY/CURSOR/R4/BLACK   |R4U100 |WFK (White)|NN (Black) |\uparrow
HONEY/CURSYM100         |R2U100 |WFK (White)|GPA (Gray) |\triangleright
HONEY/CURSYM100         |R4U100 |WFK (White)|GPA (Gray) |\triangleright
HONEY/CURSYM100         |R3U100 |WFK (White)|GPA (Gray) |\triangle
HONEY/CURSYM100/RED     |R2U100 |WFK (White)|RAS (Red)  |\triangleright
HONEY/CURSYM100/RED     |R4U100 |WFK (White)|RAS (Red)  |\triangleright
HONEY/CURSYM100/RED     |R3U100 |WFK (White)|RAS (Red)  |\triangle
HONEY/CURSYM100/BLACK   |R2U100 |WFK (White)|NN (Black) |\triangleright
HONEY/CURSYM100/BLACK   |R4U100 |WFK (White)|NN (Black) |\triangleright
HONEY/CURSYM100/BLACK   |R3U100 |WFK (White)|NN (Black) |\triangle
HONEY/CURSYM100/R3      |R3U100 |WFK (White)|GPA (Gray) |\triangleupright
HONEY/CURSYM100/R3      |R3U100D|WFK (White)|GPA (Gray) |\circle
HONEY/CURSYM100/R3/RED  |R3U100 |WFK (White)|RAS (Red)  |\triangleupright
HONEY/CURSYM100/R3/RED  |R3U100D|WFK (White)|RAS (Red)  |\circle
HONEY/CURSYM100/R3/BLACK|R3U100 |WFK (White)|NN (Black) |\triangleupright
HONEY/CURSYM100/R3/BLACK|R3U100D|WFK (White)|NN (Black) |\circle
HONEY/CURSYM125         |R3U125 |WFK (White)|GPA (Gray) |\triangleright
HONEY/CURSYM125/RED     |R3U125 |WFK (White)|RAS (Red)  |\triangleright
HONEY/CURSYM125/BLACK   |R3U125 |WFK (White)|NN (Black) |\triangleright
HONEY/NUMPAD            |R3U200H|NN (Black) |WFK (White)|0
HONEY/NUMPAD            |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/NUMPAD            |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMPAD            |R3U100 |NN (Black) |WFK (White)|0
HONEY/NUMPAD            |R3U100 |NN (Black) |WFK (White)|00
HONEY/NUMPAD            |R4U100 |NN (Black) |WFK (White)|1
HONEY/NUMPAD            |R4U100 |NN (Black) |WFK (White)|2
HONEY/NUMPAD            |R4U100 |NN (Black) |WFK (White)|3
HONEY/NUMPAD            |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMPAD            |R3U100 |NN (Black) |WFK (White)|4
HONEY/NUMPAD            |R3U100D|NN (Black) |WFK (White)|5
HONEY/NUMPAD            |R3U100 |NN (Black) |WFK (White)|6
HONEY/NUMPAD            |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMPAD            |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMPAD            |R3U100 |NN (Black) |WFK (White)|5
HONEY/NUMPAD            |R2U100 |NN (Black) |WFK (White)|7
HONEY/NUMPAD            |R2U100 |NN (Black) |WFK (White)|8
HONEY/NUMPAD            |R2U100 |NN (Black) |WFK (White)|9
HONEY/NUMPAD            |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMPAD            |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMPAD            |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/NUMPAD            |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMPAD            |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMPAD            |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMPAD/GREY       |R3U200H|WFK (White)|GPA (Gray) |0
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |\cdot
HONEY/NUMPAD/GREY       |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |0
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |00
HONEY/NUMPAD/GREY       |R4U100 |WFK (White)|GPA (Gray) |1
HONEY/NUMPAD/GREY       |R4U100 |WFK (White)|GPA (Gray) |2
HONEY/NUMPAD/GREY       |R4U100 |WFK (White)|GPA (Gray) |3
HONEY/NUMPAD/GREY       |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |4
HONEY/NUMPAD/GREY       |R3U100D|WFK (White)|GPA (Gray) |5
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |6
HONEY/NUMPAD/GREY       |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMPAD/GREY       |R3U100 |WFK (White)|GPA (Gray) |5
HONEY/NUMPAD/GREY       |R2U100 |WFK (White)|GPA (Gray) |7
HONEY/NUMPAD/GREY       |R2U100 |WFK (White)|GPA (Gray) |8
HONEY/NUMPAD/GREY       |R2U100 |WFK (White)|GPA (Gray) |9
HONEY/NUMPAD/GREY       |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMPAD/GREY       |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMPAD/GREY       |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/NUMPAD/GREY       |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMPAD/GREY       |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMPAD/GREY       |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMPAD/WHITE      |R3U200H|NN (Black) |WFK (White)|0
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/NUMPAD/WHITE      |R3U200V|NN (Black) |WFK (White)|ENTER
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|0
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|00
HONEY/NUMPAD/WHITE      |R4U100 |NN (Black) |WFK (White)|1
HONEY/NUMPAD/WHITE      |R4U100 |NN (Black) |WFK (White)|2
HONEY/NUMPAD/WHITE      |R4U100 |NN (Black) |WFK (White)|3
HONEY/NUMPAD/WHITE      |R4U100 |NN (Black) |WFK (White)|\equal
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|4
HONEY/NUMPAD/WHITE      |R3U100D|NN (Black) |WFK (White)|5
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|6
HONEY/NUMPAD/WHITE      |R3U200V|NN (Black) |WFK (White)|\fontkey{\plus}
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|\&
HONEY/NUMPAD/WHITE      |R3U100 |NN (Black) |WFK (White)|5
HONEY/NUMPAD/WHITE      |R2U100 |NN (Black) |WFK (White)|7
HONEY/NUMPAD/WHITE      |R2U100 |NN (Black) |WFK (White)|8
HONEY/NUMPAD/WHITE      |R2U100 |NN (Black) |WFK (White)|9
HONEY/NUMPAD/WHITE      |R2U100 |NN (Black) |WFK (White)|\plus
HONEY/NUMPAD/WHITE      |R1U100 |NN (Black) |WFK (White)|NUM,LOCK
HONEY/NUMPAD/WHITE      |R1U100 |NN (Black) |WFK (White)|\slash
HONEY/NUMPAD/WHITE      |R1U100 |NN (Black) |WFK (White)|\sixast
HONEY/NUMPAD/WHITE      |R1U100 |NN (Black) |WFK (White)|\minus
HONEY/NUMPAD/WHITE      |R1U100 |NN (Black) |WFK (White)|\tilde
HONEY/NUMPAD/RED        |R3U200H|WFK (White)|RAS (Red)  |0
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |\cdot
HONEY/NUMPAD/RED        |R3U200V|WFK (White)|RAS (Red)  |ENTER
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |0
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |00
HONEY/NUMPAD/RED        |R4U100 |WFK (White)|RAS (Red)  |1
HONEY/NUMPAD/RED        |R4U100 |WFK (White)|RAS (Red)  |2
HONEY/NUMPAD/RED        |R4U100 |WFK (White)|RAS (Red)  |3
HONEY/NUMPAD/RED        |R4U100 |WFK (White)|RAS (Red)  |\equal
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |4
HONEY/NUMPAD/RED        |R3U100D|WFK (White)|RAS (Red)  |5
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |6
HONEY/NUMPAD/RED        |R3U200V|WFK (White)|RAS (Red)  |\fontkey{\plus}
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |\&
HONEY/NUMPAD/RED        |R3U100 |WFK (White)|RAS (Red)  |5
HONEY/NUMPAD/RED        |R2U100 |WFK (White)|RAS (Red)  |7
HONEY/NUMPAD/RED        |R2U100 |WFK (White)|RAS (Red)  |8
HONEY/NUMPAD/RED        |R2U100 |WFK (White)|RAS (Red)  |9
HONEY/NUMPAD/RED        |R2U100 |WFK (White)|RAS (Red)  |\plus
HONEY/NUMPAD/RED        |R1U100 |WFK (White)|RAS (Red)  |NUM,LOCK
HONEY/NUMPAD/RED        |R1U100 |WFK (White)|RAS (Red)  |\slash
HONEY/NUMPAD/RED        |R1U100 |WFK (White)|RAS (Red)  |\sixast
HONEY/NUMPAD/RED        |R1U100 |WFK (White)|RAS (Red)  |\minus
HONEY/NUMPAD/RED        |R1U100 |WFK (White)|RAS (Red)  |\tilde
HONEY/NUMPAD/BLACK      |R3U200H|WFK (White)|NN (Black) |0
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |\cdot
HONEY/NUMPAD/BLACK      |R3U200V|WFK (White)|NN (Black) |ENTER
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |0
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |00
HONEY/NUMPAD/BLACK      |R4U100 |WFK (White)|NN (Black) |1
HONEY/NUMPAD/BLACK      |R4U100 |WFK (White)|NN (Black) |2
HONEY/NUMPAD/BLACK      |R4U100 |WFK (White)|NN (Black) |3
HONEY/NUMPAD/BLACK      |R4U100 |WFK (White)|NN (Black) |\equal
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |4
HONEY/NUMPAD/BLACK      |R3U100D|WFK (White)|NN (Black) |5
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |6
HONEY/NUMPAD/BLACK      |R3U200V|WFK (White)|NN (Black) |\fontkey{\plus}
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |\&
HONEY/NUMPAD/BLACK      |R3U100 |WFK (White)|NN (Black) |5
HONEY/NUMPAD/BLACK      |R2U100 |WFK (White)|NN (Black) |7
HONEY/NUMPAD/BLACK      |R2U100 |WFK (White)|NN (Black) |8
HONEY/NUMPAD/BLACK      |R2U100 |WFK (White)|NN (Black) |9
HONEY/NUMPAD/BLACK      |R2U100 |WFK (White)|NN (Black) |\plus
HONEY/NUMPAD/BLACK      |R1U100 |WFK (White)|NN (Black) |NUM,LOCK
HONEY/NUMPAD/BLACK      |R1U100 |WFK (White)|NN (Black) |\slash
HONEY/NUMPAD/BLACK      |R1U100 |WFK (White)|NN (Black) |\sixast
HONEY/NUMPAD/BLACK      |R1U100 |WFK (White)|NN (Black) |\minus
HONEY/NUMPAD/BLACK      |R1U100 |WFK (White)|NN (Black) |\tilde
HONEY/NUMNUM/GREY       |R3U200H|WFK (White)|GPA (Gray) |0
HONEY/NUMNUM/GREY       |R3U100 |WFK (White)|GPA (Gray) |\cdot
HONEY/NUMNUM/GREY       |R3U100 |WFK (White)|GPA (Gray) |0
HONEY/NUMNUM/GREY       |R3U100 |WFK (White)|GPA (Gray) |00
HONEY/NUMNUM/GREY       |R4U100 |WFK (White)|GPA (Gray) |1
HONEY/NUMNUM/GREY       |R4U100 |WFK (White)|GPA (Gray) |2
HONEY/NUMNUM/GREY       |R4U100 |WFK (White)|GPA (Gray) |3
HONEY/NUMNUM/GREY       |R3U100 |WFK (White)|GPA (Gray) |4
HONEY/NUMNUM/GREY       |R3U100D|WFK (White)|GPA (Gray) |5
HONEY/NUMNUM/GREY       |R3U100 |WFK (White)|GPA (Gray) |6
HONEY/NUMNUM/GREY       |R3U100 |WFK (White)|GPA (Gray) |5
HONEY/NUMNUM/GREY       |R2U100 |WFK (White)|GPA (Gray) |7
HONEY/NUMNUM/GREY       |R2U100 |WFK (White)|GPA (Gray) |8
HONEY/NUMNUM/GREY       |R2U100 |WFK (White)|GPA (Gray) |9
HONEY/NUMNUM/WHITE      |R3U200H|NN (Black) |WFK (White)|0
HONEY/NUMNUM/WHITE      |R3U100 |NN (Black) |WFK (White)|\cdot
HONEY/NUMNUM/WHITE      |R3U100 |NN (Black) |WFK (White)|0
HONEY/NUMNUM/WHITE      |R3U100 |NN (Black) |WFK (White)|00
HONEY/NUMNUM/WHITE      |R4U100 |NN (Black) |WFK (White)|1
HONEY/NUMNUM/WHITE      |R4U100 |NN (Black) |WFK (White)|2
HONEY/NUMNUM/WHITE      |R4U100 |NN (Black) |WFK (White)|3
HONEY/NUMNUM/WHITE      |R3U100 |NN (Black) |WFK (White)|4
HONEY/NUMNUM/WHITE      |R3U100D|NN (Black) |WFK (White)|5
HONEY/NUMNUM/WHITE      |R3U100 |NN (Black) |WFK (White)|6
HONEY/NUMNUM/WHITE      |R3U100 |NN (Black) |WFK (White)|5
HONEY/NUMNUM/WHITE      |R2U100 |NN (Black) |WFK (White)|7
HONEY/NUMNUM/WHITE      |R2U100 |NN (Black) |WFK (White)|8
HONEY/NUMNUM/WHITE      |R2U100 |NN (Black) |WFK (White)|9
HONEY/NUMNUM/BLACK      |R3U200H|WFK (White)|NN (Black) |0
HONEY/NUMNUM/BLACK      |R3U100 |WFK (White)|NN (Black) |\cdot
HONEY/NUMNUM/BLACK      |R3U100 |WFK (White)|NN (Black) |0
HONEY/NUMNUM/BLACK      |R3U100 |WFK (White)|NN (Black) |00
HONEY/NUMNUM/BLACK      |R4U100 |WFK (White)|NN (Black) |1
HONEY/NUMNUM/BLACK      |R4U100 |WFK (White)|NN (Black) |2
HONEY/NUMNUM/BLACK      |R4U100 |WFK (White)|NN (Black) |3
HONEY/NUMNUM/BLACK      |R3U100 |WFK (White)|NN (Black) |4
HONEY/NUMNUM/BLACK      |R3U100D|WFK (White)|NN (Black) |5
HONEY/NUMNUM/BLACK      |R3U100 |WFK (White)|NN (Black) |6
HONEY/NUMNUM/BLACK      |R3U100 |WFK (White)|NN (Black) |5
HONEY/NUMNUM/BLACK      |R2U100 |WFK (White)|NN (Black) |7
HONEY/NUMNUM/BLACK      |R2U100 |WFK (White)|NN (Black) |8
HONEY/NUMNUM/BLACK      |R2U100 |WFK (White)|NN (Black) |9
HONEY/NUMOP/GREY        |R3U200V|WFK (White)|GPA (Gray) |ENTER
HONEY/NUMOP/GREY        |R4U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMOP/GREY        |R3U200V|WFK (White)|GPA (Gray) |\fontkey{\plus}
HONEY/NUMOP/GREY        |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMOP/GREY        |R2U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMOP/GREY        |R1U100 |WFK (White)|GPA (Gray) |NUM,LOCK
HONEY/NUMOP/GREY        |R1U100 |WFK (White)|GPA (Gray) |\slash
HONEY/NUMOP/GREY        |R1U100 |WFK (White)|GPA (Gray) |\sixast
HONEY/NUMOP/GREY        |R1U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMOP/GREY        |R1U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMOP/WHITE       |R3U200V|NN (Black) |WFK (White)|ENTER
HONEY/NUMOP/WHITE       |R4U100 |NN (Black) |WFK (White)|\equal
HONEY/NUMOP/WHITE       |R3U200V|NN (Black) |WFK (White)|\fontkey{\plus}
HONEY/NUMOP/WHITE       |R3U100 |NN (Black) |WFK (White)|\&
HONEY/NUMOP/WHITE       |R2U100 |NN (Black) |WFK (White)|\plus
HONEY/NUMOP/WHITE       |R1U100 |NN (Black) |WFK (White)|NUM,LOCK
HONEY/NUMOP/WHITE       |R1U100 |NN (Black) |WFK (White)|\slash
HONEY/NUMOP/WHITE       |R1U100 |NN (Black) |WFK (White)|\sixast
HONEY/NUMOP/WHITE       |R1U100 |NN (Black) |WFK (White)|\minus
HONEY/NUMOP/WHITE       |R1U100 |NN (Black) |WFK (White)|\tilde
HONEY/NUMOP/RED         |R3U200V|WFK (White)|RAS (Red)  |ENTER
HONEY/NUMOP/RED         |R4U100 |WFK (White)|RAS (Red)  |\equal
HONEY/NUMOP/RED         |R3U200V|WFK (White)|RAS (Red)  |\fontkey{\plus}
HONEY/NUMOP/RED         |R3U100 |WFK (White)|RAS (Red)  |\&
HONEY/NUMOP/RED         |R2U100 |WFK (White)|RAS (Red)  |\plus
HONEY/NUMOP/RED         |R1U100 |WFK (White)|RAS (Red)  |NUM,LOCK
HONEY/NUMOP/RED         |R1U100 |WFK (White)|RAS (Red)  |\slash
HONEY/NUMOP/RED         |R1U100 |WFK (White)|RAS (Red)  |\sixast
HONEY/NUMOP/RED         |R1U100 |WFK (White)|RAS (Red)  |\minus
HONEY/NUMOP/RED         |R1U100 |WFK (White)|RAS (Red)  |\tilde
HONEY/NUMOP/BLACK       |R3U200V|WFK (White)|NN (Black) |ENTER
HONEY/NUMOP/BLACK       |R4U100 |WFK (White)|NN (Black) |\equal
HONEY/NUMOP/BLACK       |R3U200V|WFK (White)|NN (Black) |\fontkey{\plus}
HONEY/NUMOP/BLACK       |R3U100 |WFK (White)|NN (Black) |\&
HONEY/NUMOP/BLACK       |R2U100 |WFK (White)|NN (Black) |\plus
HONEY/NUMOP/BLACK       |R1U100 |WFK (White)|NN (Black) |NUM,LOCK
HONEY/NUMOP/BLACK       |R1U100 |WFK (White)|NN (Black) |\slash
HONEY/NUMOP/BLACK       |R1U100 |WFK (White)|NN (Black) |\sixast
HONEY/NUMOP/BLACK       |R1U100 |WFK (White)|NN (Black) |\minus
HONEY/NUMOP/BLACK       |R1U100 |WFK (White)|NN (Black) |\tilde
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\tilde
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\eightast
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\%
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\wedge
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\&
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\minus
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\equal
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\plus
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\lt
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\openparen
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\opencur
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\openbra
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\vert
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\backslash
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\backprime
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\backprime\backprime
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\prime\prime
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\slash
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\underscore
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |?
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |!
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\at
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\#
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\pound
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\euro
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\yen
HONEY/NUMERIC7/GREY     |R3U100 |WFK (White)|GPA (Gray) |\$
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\tilde
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\eightast
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\%
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\wedge
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\&
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\minus
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\equal
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\plus
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\lt
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\openparen
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\opencur
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\openbra
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\vert
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\backslash
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\backprime
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\backprime\backprime
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\prime\prime
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\slash
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\underscore
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|?
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|!
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\at
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\#
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\pound
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\euro
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\yen
HONEY/NUMERIC7/WHITE    |R3U100 |NN (Black) |WFK (White)|\$
HONEY/NUMROW/WHITE      |R4U100 |NN (Black) |WFK (White)|\lt
HONEY/NUMROW/WHITE      |R4U100 |NN (Black) |WFK (White)|\gt
HONEY/NUMROW/WHITE      |R4U100 |NN (Black) |WFK (White)|?
HONEY/NUMROW/WHITE      |R3U100 |NN (Black) |WFK (White)|\colon
HONEY/NUMROW/WHITE      |R3U100 |NN (Black) |WFK (White)|\doublequote
HONEY/NUMROW/WHITE      |R2U100 |NN (Black) |WFK (White)|\openbra
HONEY/NUMROW/WHITE      |R2U100 |NN (Black) |WFK (White)|\closebra
HONEY/NUMROW/WHITE      |R2U150 |NN (Black) |WFK (White)|\fontkey{\backslash}
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|\tilde
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|\backprime
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|\minus
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|\plus
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|\equal
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|1
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|2
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|3
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|4
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|5
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|6
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|7
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|8
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|9
HONEY/NUMROW/WHITE      |R1U100 |NN (Black) |WFK (White)|0
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |CONTROL
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |SUPER
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |ALT
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |WIN
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |MENU
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |COMMAND
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |OPTION
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK      |R3U125 |WFK (White)|NN (Black) |RETURN
HONEY/FUNMOD/BLACK      |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK      |R3U225 |WFK (White)|NN (Black) |RETURN
HONEY/FUNMOD/BLACK      |R3U275 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK      |R3U175 |WFK (White)|NN (Black) |CAPS\ \ LOCK
HONEY/FUNMOD/BLACK      |R3U175S|WFK (White)|NN (Black) |CAPS,LOCK
HONEY/FUNMOD/BLACK      |R3U175 |WFK (White)|NN (Black) |CONTROL
HONEY/FUNMOD/BLACK      |R3U175S|WFK (White)|NN (Black) |CONTROL
HONEY/FUNMOD/BLACK      |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/FUNMOD/BLACK      |R2U150 |WFK (White)|NN (Black) |TAB
HONEY/FUNMOD/BLACK      |R2U150 |WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/FUNMOD/BLACK      |R3U100 |WFK (White)|NN (Black) |FUN
HONEY/FUNMOD/BLACK      |R1U200H|WFK (White)|NN (Black) |BACK\ \ SPACE
HONEY/FUNMOD/BLACK      |R1U200H|WFK (White)|NN (Black) |ESCAPE
HONEY/FUNMOD/BLACK      |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/FUNMOD/BLACK      |R1U100 |WFK (White)|NN (Black) |BACK,SPACE
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |COPY
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |RELOAD
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |CALC
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |COMP
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |TERM
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |MAIL
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |WEB
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |VOLUME,UP
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |VOLUME,DOWN
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |OPEN
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |ZOOM,IN
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |ZOOM,OUT
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |PLAY
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |REWIND
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |FORWD
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |PREV
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |EJECT
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |MUTE
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |RECORD
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |FF
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |RESET
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |LAYER 2
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |DEBUG
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |CLEAN
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |BUILD
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |ANY,KEY
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |STOP,RUN
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |7 BIT,MODE
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |PANIC
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |HELP
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |DT
HONEY/FUNCTION/R1       |R1U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |MARK
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |UNDO
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |PASTE
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |CUT
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |TAB
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |BTAB
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |BS
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |BACK,SPACE
HONEY/FUNCTION/R2       |R2U100 |WFK (White)|GPA (Gray) |BACK,TAB
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |ZOOM,IN
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |ZOOM,OUT
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |VOLUME,UP
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |VOLUME,DOWN
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |MUTE
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |PLAY
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |REWIND
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |FORWD
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |PREV
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |RELOAD
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |SAVE
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |EJECT
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |RECORD
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |CALC
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |COMP
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |MAIL
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |TERM
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |LAYER 2
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |DEBUG
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |CLEAN
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |BUILD
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |FIRE
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |PANIC
HONEY/FUNCTION/R3       |R3U100 |WFK (White)|GPA (Gray) |ANY,KEY
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |CTRL
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |ALT
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |RETURN
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |PAGE
HONEY/FUNCTION/R4       |R4U100 |WFK (White)|GPA (Gray) |FN
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |ALPS
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |BEL
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |HONEY
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |FAIL
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |ROLL
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |\parbox[c]{0.5ex}{\mbox{!\hspace{-0.75ex}?}}
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |ABORT
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |ANY
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |ATTN
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |BREAK
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |DUCK
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |HALT
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |POWER
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |RAND
HONEY/FUNCTION2         |R3U100 |WFK (White)|GPA (Gray) |TEST
HONEY/FUNCTION2         |R1U100 |WFK (White)|GPA (Gray) |F0
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |ALT,LOCK
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |TTY,LOCK
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |MODE,LOCK
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |PAGE
HONEY/FUNCTION7A        |R4U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |ALT
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |HYPER
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |HOME
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |EOF
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |PRIOR
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |NEXT
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |REVERT
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |RESET
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |MARK
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |SELECT
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |RETURN
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |LINE
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |PAGE
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |STOP
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |RUN
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |HELP
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |FIND
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |UNDO
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |REPEAT
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |DELETE
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |DEBUG
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |OPEN
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |CLOSE
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |LOCK
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |WRITE,BUFFER
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |LOAD,BUFFER
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |CLOSE,BUFFER
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |SHIFT,LOCK
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |SHIFT,WORD
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |COM-,POSE
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |OVER-,STRIKE
HONEY/FUNCTION7A        |R3U100 |WFK (White)|GPA (Gray) |7BIT,MODE
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |MARK
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |UNDO
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |CUT
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |PASTE
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |TAB
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION7A        |R2U100 |WFK (White)|GPA (Gray) |END
HONEY/FUNCTION7A        |R1U100 |WFK (White)|GPA (Gray) |WRITE
HONEY/FUNCTION7A        |R1U100 |WFK (White)|GPA (Gray) |BEGIN
HONEY/FUNCTION7A        |R1U100 |WFK (White)|GPA (Gray) |WRITE,BUFFER
HONEY/FUNCTION7A        |R1U100 |WFK (White)|GPA (Gray) |LOAD,BUFFER
HONEY/FUNCTION7A        |R1U100 |WFK (White)|GPA (Gray) |CLOSE,BUFFER
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |RETURN
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |RUN
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |7 BIT,MODE
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |FIRE
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |STOP,RUN
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |ANY,KEY
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |PANIC
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |TURBO
HONEY/FUNCTION/RED      |R3U100 |WFK (White)|RAS (Red)  |DT
HONEY/FUNCTION/RED      |R3U175 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/RED      |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/FUNCTION/RED      |R3U225 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/RED      |R2U150 |WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/FUNCTION/RED      |R2U150 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/RED      |R1U200H|WFK (White)|RAS (Red)  |BACK\ \ SPACE
HONEY/FUNCTION/RED      |R2U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/FUNCTION/RED      |R2U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/FUNCTION/RED      |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/FUNCTION/RED      |R1U100 |WFK (White)|RAS (Red)  |BACK,SPACE
HONEY/FUNCTION/RED      |R1U100 |WFK (White)|RAS (Red)  |DELETE
HONEY/FUNCTION/RED      |R1U100 |WFK (White)|RAS (Red)  |EJECT
HONEY/FUNCTION/RED      |R1U150 |WFK (White)|RAS (Red)  |CLEAR,RESET
HONEY/FUNCTION/RED      |R1U150 |WFK (White)|RAS (Red)  |TRANSMIT
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |RECORD
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |WEB
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |STOP,RUN
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |FIRM,WARE
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |\mu
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |MAIL
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |TERM
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |CALC
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |COMP
HONEY/FUNCTION/R1/RED   |R1U100 |WFK (White)|RAS (Red)  |POWER
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/F1TOF12           |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F11
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F12
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F9
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F10
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F7
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F8
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F5
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F6
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F3
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F4
HONEY/F1TOF12/R3        |R3U100 |WFK (White)|GPA (Gray) |F2
HONEY/F1TOF12/H7        |R3U100 |WFK (White)|GPA (Gray) |F11
HONEY/F1TOF12/H7        |R3U100 |WFK (White)|GPA (Gray) |F12
HONEY/F1TOF12/H7        |R4U100 |WFK (White)|GPA (Gray) |F9
HONEY/F1TOF12/H7        |R4U100 |WFK (White)|GPA (Gray) |F10
HONEY/F1TOF12/H7        |R3U100 |WFK (White)|GPA (Gray) |F7
HONEY/F1TOF12/H7        |R3U100 |WFK (White)|GPA (Gray) |F8
HONEY/F1TOF12/H7        |R2U100 |WFK (White)|GPA (Gray) |F5
HONEY/F1TOF12/H7        |R2U100 |WFK (White)|GPA (Gray) |F6
HONEY/F1TOF12/H7        |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/F1TOF12/H7        |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/F1TOF12/H7        |R3U100 |WFK (White)|GPA (Gray) |F2
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F1
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F2
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F3
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F4
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F5
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F6
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F7
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F8
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F9
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F10
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F11
HONEY/F1TOF12/WHITE     |R1U100 |NN (Black) |WFK (White)|F12
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F1
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F2
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F3
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F4
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F5
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F6
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F7
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F8
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F9
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F10
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F11
HONEY/F1TOF12/RED       |R1U100 |WFK (White)|RAS (Red)  |F12
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F1
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F2
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F3
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F4
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F5
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F6
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F7
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F8
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F9
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F10
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F11
HONEY/F1TOF12/BLACK     |R1U100 |WFK (White)|NN (Black) |F12
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F13
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F14
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F15
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F16
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F17
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F18
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F19
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F20
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F21
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F22
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F23
HONEY/F13TOF24          |R1U100 |WFK (White)|GPA (Gray) |F24
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F13
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F14
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F15
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F16
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F17
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F18
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F19
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F20
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F21
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F22
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F23
HONEY/F13TOF24/WHITE    |R1U100 |NN (Black) |WFK (White)|F24
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F1
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F2
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F3
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F4
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F5
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F6
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F7
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F8
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F9
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F10
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F11
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F12
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F13
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F14
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F15
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F16
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F17
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F18
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F19
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F20
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F21
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F22
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F23
HONEY/F1TOF24           |R1U100 |WFK (White)|GPA (Gray) |F24
HONEY/POS               |R3U200P|WFK (White)|GPA (Gray) |ESCAPE
HONEY/POS               |R3U200P|WFK (White)|GPA (Gray) |COMPLETE
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |SUSPEND
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |BUFFERS
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |REPEAT
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |TRANSMIT
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |STATUS
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |LOCAL
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |NETWORK
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |SYSTEM
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |REFRESH
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |\square
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |\circle
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |\triangle
HONEY/POS               |R2U200P|WFK (White)|GPA (Gray) |\diamond
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |CALL
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |RESET
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |OVER,STRIKE
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |ABORT
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |BREAK
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |RESUME
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |CLEAR,INPUT
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |CLEAR,SCREEN
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |HOLD,OUTPUT
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |STOP,OUTPUT
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |HELP
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |MACRO
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |TERMINAL
HONEY/POS               |R1U200P|WFK (White)|GPA (Gray) |QUOTE
HONEY/JRET              |R2UJRET|WFK (White)|GPA (Gray) |RETURN
HONEY/JRET/WHITE        |R2UJRET|NN (Black) |WFK (White)|RETURN
HONEY/JRET/RED          |R2UJRET|WFK (White)|RAS (Red)  |RETURN
HONEY/JRET/BLACK        |R2UJRET|WFK (White)|NN (Black) |RETURN
HONEY/CAPS175           |R3U175 |WFK (White)|GPA (Gray) |CAPS\ \ LOCK
HONEY/CAPS175S          |R3U175S|WFK (White)|GPA (Gray) |CAPS,LOCK
HONEY/CAPS175/RED       |R3U175 |WFK (White)|RAS (Red)  |CAPS\ \ LOCK
HONEY/CAPS175S/RED      |R3U175S|WFK (White)|RAS (Red)  |CAPS,LOCK
HONEY/CAPS175S/BLACK    |R3U175S|WFK (White)|NN (Black) |CAPS,LOCK
HONEY/RETURN175         |R3U175 |WFK (White)|GPA (Gray) |RETURN
HONEY/RETURN225/RED     |R3U225 |WFK (White)|RAS (Red)  |RETURN
HONEY/SHIFT100          |R3U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT125          |R3U125 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT150          |R3U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT175          |R3U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT200          |R3U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT225          |R3U225 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT100/R4       |R4U100 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT150/R4       |R4U150 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT175/R4       |R4U175 |WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT200/R4       |R4U200H|WFK (White)|GPA (Gray) |SHIFT
HONEY/SHIFT100/RED      |R3U100 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT125/RED      |R3U125 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT150/RED      |R3U150 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT175/RED      |R3U175 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT200/RED      |R3U200H|WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT225/RED      |R3U225 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT100/R4/RED   |R4U100 |WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT200/R4/RED   |R4U200H|WFK (White)|RAS (Red)  |SHIFT
HONEY/SHIFT100/BLACK    |R3U100 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT125/BLACK    |R3U125 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT150/BLACK    |R3U150 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT175/BLACK    |R3U175 |WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT200/BLACK    |R3U200H|WFK (White)|NN (Black) |SHIFT
HONEY/SHIFT225/BLACK    |R3U225 |WFK (White)|NN (Black) |SHIFT
HONEY/COMMA             |R3U100 |NN (Black) |WFK (White)|\ccomma
HONEY/COMMA/GREY        |R3U100 |WFK (White)|GPA (Gray) |\ccomma
HONEY/GTLT              |R4U100 |NN (Black) |WFK (White)|\gt,\lt
HONEY/GTLT/RED          |R4U100 |WFK (White)|RAS (Red)  |\gt,\lt
HONEY/FJ                |R3U100 |NN (Black) |WFK (White)|F
HONEY/FJ                |R3U100 |NN (Black) |WFK (White)|J
HONEY/FJ/GREY           |R3U100 |WFK (White)|GPA (Gray) |F
HONEY/FJ/GREY           |R3U100 |WFK (White)|GPA (Gray) |J
HONEY/FJ/RED            |R3U100 |WFK (White)|RAS (Red)  |F
HONEY/FJ/RED            |R3U100 |WFK (White)|RAS (Red)  |J
HONEY/FJ/BLACK          |R3U100 |WFK (White)|NN (Black) |F
HONEY/FJ/BLACK          |R3U100 |WFK (White)|NN (Black) |J
HONEY/GHB/GREY          |R4U100 |WFK (White)|GPA (Gray) |B
HONEY/GHB/GREY          |R3U100 |WFK (White)|GPA (Gray) |G
HONEY/GHB/GREY          |R3U100 |WFK (White)|GPA (Gray) |H
HONEY/GHB/WHITE         |R4U100 |NN (Black) |WFK (White)|B
HONEY/GHB/WHITE         |R3U100 |NN (Black) |WFK (White)|G
HONEY/GHB/WHITE         |R3U100 |NN (Black) |WFK (White)|H
HONEY/GHB/RED           |R4U100 |WFK (White)|RAS (Red)  |B
HONEY/GHB/RED           |R3U100 |WFK (White)|RAS (Red)  |G
HONEY/GHB/RED           |R3U100 |WFK (White)|RAS (Red)  |H
HONEY/GHB/BLACK         |R4U100 |WFK (White)|NN (Black) |B
HONEY/GHB/BLACK         |R3U100 |WFK (White)|NN (Black) |G
HONEY/GHB/BLACK         |R3U100 |WFK (White)|NN (Black) |H
HONEY/TILDEBPRIME/GREY  |R1U100 |WFK (White)|GPA (Gray) |\tilde,\backprime
HONEY/TILDEBPRIME/RED   |R1U100 |WFK (White)|RAS (Red)  |\tilde,\backprime
HONEY/TILDEBPRIME/BLACK |R1U100 |WFK (White)|NN (Black) |\tilde,\backprime
HONEY/VERTBSL/R1        |R1U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R2        |R2U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R3        |R3U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R4        |R4U100 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL/R1/RED    |R1U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL/R3/RED    |R3U100 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL150        |R2U150 |NN (Black) |WFK (White)|\vert,\backslash
HONEY/VERTBSL150/GREY   |R2U150 |WFK (White)|GPA (Gray) |\vert,\backslash
HONEY/VERTBSL150/RED    |R2U150 |WFK (White)|RAS (Red)  |\vert,\backslash
HONEY/VERTBSL150/BLACK  |R2U150 |WFK (White)|NN (Black) |\vert,\backslash
HONEY/ASTQUOTE150       |R2U150 |NN (Black) |WFK (White)|\ast,\quote
HONEY/REDESCAPE/R1      |R1U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/REDESCAPE/R2      |R2U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/REDESCAPE/R3      |R3U100 |WFK (White)|RAS (Red)  |ESCAPE
HONEY/BLACKESCAPE/R1    |R1U100 |WFK (White)|NN (Black) |ESCAPE
HONEY/SPACE100          |R3U100 |NN (Black) |WFK (White)|SPACE
HONEY/SPACE100/GREY     |R3U100 |WFK (White)|GPA (Gray) |SPACE
HONEY/SPACE100/BLACK    |R3U100 |WFK (White)|NN (Black) |SPACE
HONEY/SPACE150          |R3U150 |NN (Black) |WFK (White)|SPACE
HONEY/SPACE150/GREY     |R3U150 |WFK (White)|GPA (Gray) |SPACE
HONEY/SPACE150/RED      |R3U150 |WFK (White)|RAS (Red)  |SPACE
HONEY/SPACE150/BLACK    |R3U150 |WFK (White)|NN (Black) |SPACE
HONEY/DT/GREY           |R1U100 |WFK (White)|GPA (Gray) |\DTgrey
HONEY/DT/GREY           |R3U100 |WFK (White)|GPA (Gray) |\DTgrey
HONEY/DT/WHITE          |R1U100 |NN (Black) |WFK (White)|\DTwhite
HONEY/DT/WHITE          |R3U100 |NN (Black) |WFK (White)|\DTwhite
HONEY/DT/RED            |R1U100 |WFK (White)|RAS (Red)  |\DTred
HONEY/DT/RED            |R3U100 |WFK (White)|RAS (Red)  |\DTred
HONEY/DT/BLACK          |R1U100 |WFK (White)|NN (Black) |\DTblack
HONEY/DT/BLACK          |R3U100 |WFK (White)|NN (Black) |\DTblack
HONEY/HELVETICA         |R1U100 |WFK (White)|RAS (Red)  |\helvetica
HONEY/HELVETICA         |R3U100 |WFK (White)|RAS (Red)  |\helvetica
HONEY/HELVETICA125      |R3U125 |WFK (White)|RAS (Red)  |\helvetica
HONEY/HELVETICA150      |R3U150 |WFK (White)|RAS (Red)  |\helvetica
HONEY/ERGOKEY/R1        |R1U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGOKEY/R1        |R1U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ERGOKEY/R3        |R3U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGOKEY/R3        |R3U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ERGOKEYS          |R3U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGOKEYS          |R3U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/ERGOKEYS          |R1U100 |WFK (White)|RAS (Red)  |ERGO,DOX
HONEY/ERGOKEYS          |R1U100 |WFK (White)|RAS (Red)  |\reflectbox{ERGO},\reflectbox{DOX}
HONEY/KBDRUNNER         |R1U100 |WFK (White)|GPA (Gray) |\kbdrunner
HONEY/KBDRUNNER/WHITE   |R2U100 |NN (Black) |WFK (White)|\kbdrunner
HONEY/KBDRUNNER/RED     |R1U100 |WFK (White)|RAS (Red)  |\kbdrunner
HONEY/KBDRUNNER/RED/R2  |R2U100 |WFK (White)|RAS (Red)  |\kbdrunner
HONEY/KBDRUNNER/RED/R3  |R3U100 |WFK (White)|RAS (Red)  |\kbdrunner
HONEY/KBDRUNNER/BLACK   |R1U100 |WFK (White)|NN (Black) |\kbdrunner
HONEY/LOTUSESC          |R1U100 |WFK (White)|GPA (Gray) |\lotus
HONEY/LOTUSESC/RED      |R1U100 |WFK (White)|RAS (Red)  |\lotus
HONEY/LOTUSESC/BLACK    |R1U100 |WFK (White)|NN (Black) |\lotus
HONEY/LOTUS100          |R3U100 |WFK (White)|GPA (Gray) |\lotus
HONEY/LOTUS125          |R3U125 |WFK (White)|GPA (Gray) |\lotus
HONEY/LOTUS150          |R3U150 |WFK (White)|GPA (Gray) |\lotus
HONEY/LOTUS175          |R3U175 |WFK (White)|GPA (Gray) |\lotus
HONEY/LOTUS175S         |R3U175S|WFK (White)|GPA (Gray) |\lotus
HONEY/LOTUS100/RED      |R3U100 |WFK (White)|RAS (Red)  |\lotus
HONEY/LOTUS125/RED      |R3U125 |WFK (White)|RAS (Red)  |\lotus
HONEY/LOTUS175S/RED     |R3U175S|WFK (White)|RAS (Red)  |\lotus
HONEY/LOTUS100/BLACK    |R3U100 |WFK (White)|NN (Black) |\lotus
HONEY/LOTUS125/BLACK    |R3U125 |WFK (White)|NN (Black) |\lotus
HONEY/LOTUS175S/BLACK   |R3U175S|WFK (White)|NN (Black) |\lotus
:shock:
15 Feb 2014, 14:20
Hooray! Updating now.
My original file is a 3 meg Numbers spreadsheet. And that's for 3 differently sorted tables, the .pdf was only one. Numbers handles it as easy as day.
That said, trying to share it by iCloud is a big hairy mess. Unsurprisingly!
Screen Shot 2014-02-15 at 01.25.05 pm.png (163.78 KiB) Viewed 5400 times
Flintfish
16 Feb 2014, 08:01
Order sent! The pm is however in the outbox and not in sent messages. :? Do I have to do anything else or should I just wait a while for a reply?
Muirium wrote: Those guys are crazy thick, crazy tall, and crazy heavy. All in a good way!
Yes! Very good work on this set. Very usable colors and nice attention to detail. Finally i can have proper return/enter keys on windows 8-) Swedish doubleshots don't exactly grow on trees either...
I did however notice one thing when i was doublechecking my order. The swedish number 5 key should really be
Not sure if that's true for other european languages as well and it's not marked on my current keyboard either so it's probably a fairly new addition (does work just fine though). That would also get the Euro sign on the keyboard (wife might like that...) without messing up the E key and put the common currencys on 3,4,5.
Aleksander
16 Feb 2014, 09:16
In Norway the € is on AltGr+E, making the £$€ signs grouped together and still pretty logically laid out (on a qwerty layout)
16 Feb 2014, 09:19
Like us in Scotland, you guys should really drop the £. Who's typing that in the Eurozone these days?
Vierax
16 Feb 2014, 09:28
IMHO, adding the AltGr layer is a bad thing on centered legends as SA family, adding third labels on some keys makes a weird sensation due to heterogeneous set. That's why BEPO set doesn't contain AltGr layer, as in Colemak set (yes there is an AltGr layer in Colemak but it's hidden :D )
Yeah Muirium, it's time for Scotland to be indy and entering the Eurozone ;)
Flintfish
16 Feb 2014, 09:54
Vierax wrote:IMHO, adding the AltGr layer is a bad thing on centered legends as SA family, adding third labels on some keys makes a weird sensation due to heterogeneous set.
Yea. I see the point (and € on 5 is a hardly a big deal...) but the swedish numbers row is fairly third labled already (only 1, (5) and 6 are spared an AltGr function in the HONEY/SE keyset. I leave it up to the rest of you. Doesn't seem fair to push for unimportant changes two weeks before order deadline and causing controversy. :oops:
As for Scotland their always welcome - just bring the whisky...
Laser
emacs -nw
16 Feb 2014, 20:07
Tentative question, and pls forgive my newbiness and lack of thread perusal - what would be the cheapest way (if at all possible) to make a complete keycap set for a QPad MK-50, in UK layout?
I.e. something like this:
It has those dreaded iOne modifiers type - bottom row sizes: 1.5 1 1.5 6 1.5 1 1 1.5
Flintfish
16 Feb 2014, 22:21
Laser wrote:Tentative question, and pls forgive my newbiness and lack of thread perusal - what would be the cheapest way (if at all possible) to make a complete keycap set for a QPad MK-50, in UK layout?
I apologized for being a noob my self a few posts back, by here goes my 5 cents worth of wisdom :-)
There are no 6 unit space bars (the closest i 6.25) and since these keycaps are high profile (taller then regular caps) it will probably be wierd if you keep the old space bar. If someone more knowledgeable then me knows where to get a high profile space bar that fits, the layout can be done using grey modifiers I think.
Laser
emacs -nw
16 Feb 2014, 22:39
I see, thanks for the answer! I figure i'd need at least a HONEY/STANDARD125 + HONEY/MODIFIER + HONEY/ISO = 85$ + $51 +$8 = 144$, and a non-existent spacebar. Ok, so iOne keyboards are a no-go (our european market is full of these keyboards)
Vierax
17 Feb 2014, 03:36
Maybe you can try to find an SA 6unit space bar directly in Signature Plastics webshop, if the mold already exists. They surely have it in DCS but it will be as weird as your actual bar.
17 Feb 2014, 11:17
Yeah, that 6.0 space bar is the killer. It's available in DSA, and you'll have a cheaper time with Matt3o's beige PBT dye sub set (still in planning) or his colourful Macross set, running here:
http://deskthority.net/marketplace-f11/ ... t7402.html
DSA is spherical, like Round 5, but short and flat.
As for this GB, a slightly cheaper route is: HONEY/STANDARDISO/BASE $95 + HONEY/ALPHAUK $35 which spares you duplicate alphas, and gives you more mod choices for use on different keyboards. But still no spacebar.
rindorbrot
17 Feb 2014, 11:29
But even the dsa 6u spacebar will not fit the iOne boards because of the stem positions.
You'd have to mod it to the correct places.
So I'd buy a couple of spares to try first...
Laser
emacs -nw
17 Feb 2014, 11:42
Thanks for all this information. I'll probably skip such a solution and keep things simple. I already ordered a Round 5 set for my ANSI TKL, so no problem :) . But it's interesting that default keycaps sets for these keyboards are not popular in Europe (i know they are of not so good a reputation, but they are also cheaper or - the only ones available in local shops - e.g. Razer, Roccat, Tesoro, Steelseries).
17 Feb 2014, 11:44
The cheaper the keyboard, the more people will have it. But the more expensive the keyboard, the more owners will be willing to spend on upmarket caps.
Laser
emacs -nw
17 Feb 2014, 11:49
Muirium wrote:The cheaper the keyboard, the more people will have it. But the more expensive the keyboard, the more owners will be willing to spend on upmarket caps.
I see - they should sell these keyboards in some part of the world where the keycaps matter more, and the keyboards themselves, less, in this case. :)
seferphier
17 Feb 2014, 15:24
Hm. What is the difference between the row? Row 1,2,3,4
Madhias
BS TORPE
17 Feb 2014, 15:36
Don't know if you search for this seen here before, maybe it helps; this would be the SA profile:
17 Feb 2014, 15:55
Exactly. Or this, in real life:
There's a lot of difference across the rows. Row 1 in particular is awesome. But spot the mods in the foreground down next to space, they're all row 3. (Some will be better this round, my caps are Round 4 SPH.)
snoopy
17 Feb 2014, 16:13
Muirium wrote:Exactly. Or this, in real life:
is that your board? do you have more pics of it?
:lol: :lol: :lol: ;)
17 Feb 2014, 16:18
It's so dark here in these storms lately I have to look at my pictures to remember what it looks like…
Matteo's just kicking off the 2014 build season. So you'll have all-new stuff of mine to see (far too often) in a while! Yay.
Madhias
BS TORPE
17 Feb 2014, 18:59
Because of the row differences i add right more "spare" keys in different sizes, to have enough munition for future projects (different Lotus keys, Keyboardrunners, Helveticas, etc.). I hope this group buy ends soon! Please!
snoopy wrote:is that your board? do you have more pics of it?
It's like a proud father who always shows his children pictures :D
17 Feb 2014, 19:25
Kits of the day:
HONEY/STANDARD/WHITE
price: $179
HONEY/TENKLESS/WHITE
price: $149
HONEY/TKL/WHITE
price: $86
HONEY/TKL/BASE/BLACK
price: $36
HONEY/TKL/BASE/WHITE
price: $49
HONEY/ALPHA/RED
price: $39
:o
We still need more orders for white stuff, but because of the high volume of other keys, I've decided to definitely keep them in the group buy.
:cool:
Some prices went down:
old HONEY/JRET/WHITE        |  1|  9 USD|J-Return key (white)
new HONEY/JRET/WHITE        |  1|  6 USD|J-Return key (white)
old HONEY/NUMPAD/WHITE      | 24| 29 USD|Numpad white kit
new HONEY/NUMPAD/WHITE      | 24| 27 USD|Numpad white kit
old HONEY/STANDARD/WHITE    |157|189 USD|Standard white kit
new HONEY/STANDARD/WHITE    |157|179 USD|Standard white kit
old HONEY/STD/BASE/WHITE    |103|159 USD|Standard base white kit
new HONEY/STD/BASE/WHITE    |103|139 USD|Standard base white kit
old HONEY/STDISO/BASE/WHITE |102|159 USD|Standard ISO base white kit
new HONEY/STDISO/BASE/WHITE |102|139 USD|Standard ISO base white kit
old HONEY/TKL/WHITE         | 86| 89 USD|TKL white kit
new HONEY/TKL/WHITE         | 86| 86 USD|TKL white kit
:shock:
17 Feb 2014, 20:47
We made it!!!
17 Feb 2014, 20:48
Now, you can order more.
:evilgeek:
ray4jc
17 Feb 2014, 21:54
So the invoice always say pay within 7 days but what happens if we don't :P
