- JP!
- DT Pro Member: 0194
A local contact of mine found this neat looking IBM Model M with some very interesting keycaps, many of them relegendable. Any idea of what this might be worth / a decent price to pay for this?
- JP!
- Phenix
- -p
- Main keyboard: F122, soarer´d|Novatouch-s
- Main mouse: Roccat Kone Pure|Rollermouse
- Favorite switch: BS F|Topre-s
does your estimate apply to my posted fk-555 as well? (cf. pic above)seebart wrote:If it does have SKCM blue Alps at least 350 probably more though.
- Chyros
- Gnohio
- Main keyboard: Tada68 w/ 65g Zealios
- Main mouse: Logitech G502
- Favorite switch: T:Zealios 65g C:Cap. Buckling Spring L:Green Alps
I would say its in good condition. Nothing is yellowed (not even the space bar), there arent any major visible scratches or marks on it, the cable is still coiled all the switches work and its been mildly cleaned. How much do you think the caps would be worth then?
- fohat
- Elder Messenger
- DT Pro Member: 0158
You should verify that they are the PBT variant, using the acetone test or some other. I have bought old-logo Dell 101s with ABS caps.
But, if they are not yellowed, even the spacebar, that is pretty nice. Spacebar yellowing differently from the other caps is an indicator of PBT caps.
- taylorswiftttttt
removed
- Gnohio
The FCC ID says GYIAT101-102.taylorswiftttttt wrote:If the label on the back says something like "GYUSM" its ABS caps
- Gnohio
I also have a pretty good condition Focus FK-9000. Has the multi coloured doubleshot caps and everything but it has some four tab white alps clone for switches :\ It does have genuine yellow alps for the lock light appropriate keys though. Its also missing the D cap, but on the bright side the calculator on it is fully functional and all of the display spaces work perfectly. Do you think it would even be worth selling as a whole board or do you think I should just scrap it for the caps and sell those? Keeping it one piece is tempting because the calculator actually works but then it has those alps clones
In either case, how much do you think it is appropriate to ask for it if I were to sell it?
- Main keyboard: IBM Model M
How much would a Microsoft Natural Keyboard 1.0 (1995) be worth?
more images here: http://imgur.com/gallery/v4YTb
- taylorswiftttttt
removed
Thanks, with this answer I can live. Typing for test on the natural compared to a buckling spring keyboard felt like there is something wrong with it, but it helped me to learn 10 finger typing a lot back then.davkol wrote: On one hand, it's in original box. On the other hand, the keycaps look heavily yellowed and worn.
I sold my OG MS Natural to a guy who collected them. Got about €10 for it. And that was NIB. But I was glad someone at least enjoyed it. The early generations of MS Natural weren't all that bad, only had a tad bit stiffer domes, which is why I sold mine in the end.
- Chyros
Found two MS naturals NIB a while ago at the recycling centre. Didn't even bother to take them home, let alone sell them. The boxes were pretty good though, I kept them; they're nice and deep so they fit big keyboards!
Hello, how much can I ask for 85 simplified white Alps switches? By the way, there's a key cap stem stuck in one of the sliders.
Thanks.-
- Main keyboard: Whitefox
- Main mouse: Razor
- Favorite switch: Black
Hi all
Can anyone be so kind, to give me a price check on my whitefox keyboard ? Its a very nice keyboard, but sadly i just couldnt get use to the gateron clear switches on it ( guess i should have tryed them first, before i bought it with those switches ) And its time to sell it. Instead of just letting it collect dust
It has a tiny scratch by one of the feet, other then that its in mint condition. Not used very much
Not really sure about the price, since it did cost a pretty penny, because of the damn import taxes to Denmark !!
Le me know, if you want more pictures
- IMG_20170725_183910.jpg (2.33 MiB) Viewed 8606 times
- IMG_20170725_183903.jpg (2.2 MiB) Viewed 8606 times
- IMG_20170725_183624.jpg (2.6 MiB) Viewed 8606 times
- IMG_20170725_183621.jpg (2.7 MiB) Viewed 8606 times
- Main keyboard: Masterkeys Pro S
- Main mouse: Razer Deathadder
- Favorite switch: CherryMX brown
Here's my 1988 Model M. Any idea how much it would be worth? Label is intact and the cable looks almost new.
http://imgur.com/gallery/t4zfE
- JP!
Whats is the part number? A pic of the label on the back would be nice to see. Looks in nice shape. Did you put any work into it like a bolt mod?morph wrote: Here's my 1988 Model M. Any idea how much it would be worth? Label is intact and the cable looks almost new.
Hi, Here's a pic of the label and also the cable: http://imgur.com/a/5ISPaJP! wrote:Whats is the part number? A pic of the label on the back would be nice to see. Looks in nice shape. Did you put any work into it like a bolt mod?morph wrote: Here's my 1988 Model M. Any idea how much it would be worth? Label is intact and the cable looks almost new.
There's no bolt mod, it's completely stock.
- Myoth
- Main keyboard: IDB60
- Main mouse: EC1-A
- Favorite switch: Cap BS
What layout is this, looks interesting...morph wrote: Here's my 1988 Model M. Any idea how much it would be worth? Label is intact and the cable looks almost new.
It's an old Dutch layout.Myoth wrote:What layout is this, looks interesting...morph wrote: Here's my 1988 Model M. Any idea how much it would be worth? Label is intact and the cable looks almost new.
- Wingklip
- Main keyboard: IBM 3178 Model F C2
- Main mouse: G502 Logitech Proteus core
- Favorite switch: Beam/plate spring
- Main mouse: g502
- Favorite switch: Brown ALPS
Probably a little less than what it goes for, minus shipping/import fees. If I were you I'd just solder on other switches or just swap with heavier springs if it's the weight that you don't like.Grogak wrote: Hi all
- 2ter
- Main keyboard: olympia carrera or m from 87, apple M0118 (office)
- Main mouse: wheel mouse optical
- Favorite switch: clicky
G80-3000SFD?
