MarkPharaoh wrote:Are Greys the only thing that you're going to restock in the near future?
Cherry MX and Matias switches
- TheQsanity
- Main keyboard: Atm: Das S Ult
- Main mouse: Atm: Razer Lachesies
- Favorite switch: Atm: Brn or Blu. Wanting to try Grn Wht and Clears
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
All non-NW variants (plate mountable) are available.MarkPharaoh wrote:Are Greys the only thing that you're going to restock in the near future?
If there is demand for NW switches, the only thing I can do is to remove the limits and order as soon as I got the money from you.
Please notice that you only need the NW variant if you have a PCB without switches! If you just want to turn an MX-black board into MX-red or want ergo clears, you can open the switches and swap in whatever you like. No desoldering is needed if switches are PCB-mounted!
- TheQsanity
Hmm, good point. That should save money too.7bit wrote:All non-NW variants (plate mountable) are available.MarkPharaoh wrote:Are Greys the only thing that you're going to restock in the near future?
Maybe later I could learn to make my own board. Could Membrane PBC be used for Cherry mx switches? Or the Cherry MY PBC. Either that or find a cheap Cherry board.
- Vierax
- Main keyboard: Tipro MID KM128 Bépo layout
- Main mouse: Kensington Orbit Trackball
- Favorite switch: MX Clear / MX Grey (under thumbs)
When you say membrane PCB, you mean the plastic matrix used instead of PCB ?TheQsanity wrote: Hmm, good point. That should save money too.
If it's what I think, plastic and soldering are not really good friends : plastic will melt.
BTW : Welcome back 7bit
- blighty
- Main keyboard: LZ ergo (mx silent red)
- Main mouse: Logitech G Pro
- Favorite switch: Cherry MX Silent Red
- DT Pro Member: 0037
Payment from HzFaq has been received and marked as shipped for Paypal purposes (to keep them from locking up the PP account). Invoices may or may not reflect the payments yet. Keep checking this thread for the actual ship date(s). This only includes payments to me via Paypal. Note that the address on your Paypal emails is not necessarily the address 7bit will ship your switches to, he ships to the address on your invoice.
- Main keyboard: Poker, Blue
- Main mouse: SteelSeries Sensei RAW
- Favorite switch: Topre, 55g
Ah, okay, thank you for the clarification. After reading your OP I thought that I needed the NW switches for my Poker. I will probably be making an order in the near future, thank you7bit wrote:All non-NW variants (plate mountable) are available.MarkPharaoh wrote:Are Greys the only thing that you're going to restock in the near future?
- TheQsanity
I mean a PBC from a membrane board. But do Cherry MY switches have the same mounting holes as a Cherry MX?Vierax wrote:When you say membrane PCB, you mean the plastic matrix used instead of PCB ?TheQsanity wrote: Hmm, good point. That should save money too.
- 7bit
You can only mount them to a PCB which has been made for Cherry MX switches.TheQsanity wrote:
In most cases you need/can use the plate-mount versions of the switches.
- Vierax
I don't think so, but please do a research on the cherry website to compare switches specs instead of asking. All the informations are easily found with a simple search engine request.TheQsanity wrote: I mean a PBC from a membrane board. But do Cherry MY switches have the same mounting holes as a Cherry MX?
- blighty
Payment from Ichigo87 has been received and marked as shipped for Paypal purposes (to keep them from locking up the PP account). Invoices may or may not reflect the payments yet. Keep checking this thread for the actual ship date(s). This only includes payments to me via Paypal. Note that the address on your Paypal emails is not necessarily the address 7bit will ship your switches to, he ships to the address on your invoice.
NOTE: Ichigo87 (I didn't think I'd see 187 outside of gangster rap or police band radios), you paid in Euros, and paypal converted it to USD after PP fees were deducted in Euros. You may or may not be over/underpaid.
- TheQsanity
Can't find any information on the Cherry MY. Plenty about the Cherry MX.Vierax wrote:I don't think so, but please do a research on the cherry website to compare switches specs instead of asking. All the informations are easily found with a simple search engine request.TheQsanity wrote: I mean a PBC from a membrane board. But do Cherry MY switches have the same mounting holes as a Cherry MX?
- blighty
Pic is MY membrane with backing plate, with 2 mx and 2 my switches for a wee bit of comparison.TheQsanity wrote:Can't find any information on the Cherry MY. Plenty about the Cherry MX.Vierax wrote:I don't think so, but please do a research on the cherry website to compare switches specs instead of asking. All the informations are easily found with a simple search engine request.TheQsanity wrote: I mean a PBC from a membrane board. But do Cherry MY switches have the same mounting holes as a Cherry MX?
- mx with my on my membrane
- P1000384.JPG (64.53 KiB) Viewed 8012 times
- TheQsanity
Thanks! To me the mounting pins look to be different different. Can you confirm?
- blighty
MY boards only have Pcb on the controller. My caps snap into the metal plate, with the membrane sandwiched in between the leaf spring on the bottom of the switch and the plate. MX are no go....
Edit: what The_Ed said.
- TheQsanity
Ah thanks guys!
- Main keyboard: Rosewill RK-9000RE
- Main mouse: Razer Mamba, Logitech MX Revolution
- Favorite switch: Cherry MX Red/Brown
What's the usual transit time for packages from Germany to the USA 7bit? Just want to double check that order CherryMX 0068 got shipped before your 2 week trip cause its been about 3 weeks now.
- 7bit
They where marked as shipped before I went off, so I guess they got lost.Soulpyre wrote:What's the usual transit time for packages from Germany to the USA 7bit? Just want to double check that order CherryMX 0068 got shipped before your 2 week trip cause its been about 3 weeks now.
I ship again in a few days...
- Main keyboard: Realforce 88UB
- Main mouse: Logitech MX1100
I sent a PM to CherryMX with an order half an hour ago, but forgot to include my e-mailaddress. I immediately edited the message though and added it, but I haven't heard anything since then. Is this normal, or did I mess up the bot?
- blighty
Payment from aizen (welcome to DT) has been received and marked as shipped for Paypal purposes (to keep them from locking up the PP account). Invoices may or may not reflect the payments yet. Keep checking this thread for the actual ship date(s). This only includes payments to me via Paypal. Note that the address on your Paypal emails is not necessarily the address 7bit will ship your switches to, he ships to the address on your invoice.
Should be fine. It's not an instantaneous process.perost wrote:I sent a PM to CherryMX with an order half an hour ago, but forgot to include my e-mailaddress. I immediately edited the message though and added it, but I haven't heard anything since then. Is this normal, or did I mess up the bot?
- Main keyboard: KBC Poker
- Main mouse: Logitech MX518
Is there any way to confirm that mine has been shipped? I don't know if you shipped before or after you left. I just want to make sure you didn't forget about me
MX 0069 justin one
MX 0069 justin one
- Main keyboard: SS 7G
- Main mouse: Mx518
- Favorite switch: maybe blues
So im new to all this: would i have to order a cherry box if i wanted switches?
and what exactly are these cherry locks for, i mean ive read the article in the wiki for it but i cannot figure out where it might be used.
- Favorite switch: Green
you don't have to order a box, it is just a geeky thing to have if you keep a stockpile of switches.bounce wrote:So im new to all this: would i have to order a cherry box if i wanted switches?
you use the locks a key that you want to act as a toggle, e.g, if you had one on a Shift key, shift would stay activated until you pressed it again to unlock it. back in the olden days, caps lock switches were like this.
