gianni
27 Aug 2017, 09:23
How much would you pay for this 70cm * 70cm plexiglass sign?
04680227300682 (1).jpg (29.2 KiB) Viewed 9220 times
hypkx
Chasing the Dream
27 Aug 2017, 10:18
Idk, but very cool, reminds me of that 1meter+ Nixdorf stickers on German eBay once, sadly I forgot bidding (or something else).
manna
27 Aug 2017, 19:09
Hi, how much should I ask for a double-shot G80-1800 HAD keycaps set? I've got them less then two months ago, from a NIB keyboard.
The Einfg keycap is slighty damaged in the top left corner, but beside that they're in excellent shape.
Here's a couple pictures (the spacebar is the one on the bottom, 7u wide):
http://imgur.com/a/MzQ9z
Thanks.
Thumper
knock knock
30 Aug 2017, 10:58
Quite unsure, as i didnt saw this combination.
Whitefox R1 (with signature) fitted with Linear Zealios (lubed, stickered). The Case has 0 scratches or dents or defects and comes with the original box + cable + all other stuff.
AdrianMan
01 Sep 2017, 12:56
Hello !
How much do you think an IBM Typewriter 6715 would worth?
Good condition, working.
It's like the one in this post :
photos-f62/ibm-6715-typewriter-t14358.html
Thanks !
hypkx
Chasing the Dream
01 Sep 2017, 13:22
I got the one linked in your post (my post) from ebay for under 20€ (shipped), but I think maybe 20€-30€?
AdrianMan
01 Sep 2017, 13:46
hypkx wrote: I got the one linked in your post (my post) from ebay for under 20€ (shipped), but I think maybe 20€-30€?
Ok, thanks a lot :D
AdrianMan
05 Sep 2017, 08:37
How about some Topre compatible SA profile Keycaps hebrew + side printed querty?
https://photos.app.goo.gl/IclRdAbducR061ml2
derzemel
05 Sep 2017, 11:18
AdrianMan wrote: How about some Topre compatible SA profile Keycaps hebrew + side printed querty?
Are you sure those are compatible?
Topre keycaps stems have 2 slots (just looked at one of mine)
AdrianMan
05 Sep 2017, 11:58
They should work, yes. I think the slots are for the plastic to bend and go in the switch circle...
Check this post out :
https://geekhack.org/index.php?topic=57366.0
Nullwert
06 Sep 2017, 21:36
I have an HHKB Pro 2 in Black, that was opened twice (i installed Hypersphere silencing rings and removed them again) but is otherwise rarely used (maybe a total time of one week). The layout is not for me… I'm not sure what a good price would be, can someone help out?
Thanks!
chip chop
06 Sep 2017, 23:06
A boxed white HHKB Pro 2 Type S in good condition sold on ebay UK a few days ago for £156.
07 Sep 2017, 09:46
chip chop wrote: A boxed white HHKB Pro 2 Type S in good condition sold on ebay UK a few days ago for £156.
That would be 170 Euros at the moment, I'd say if his HHKB Pro 2 was used little it should easily go for over 200 Euros.
Nullwert
07 Sep 2017, 22:20
Thanks! Then i will try that :)
maxrunner
08 Sep 2017, 17:26
HI! how much is worth the g80-5000 or the mx5000 ISO PT these days, ive been out of the keyboard scene for quite a while.
Myoth
08 Sep 2017, 18:03
maxrunner wrote: HI! how much is worth the g80-5000 or the mx5000 ISO PT these days, ive been out of the keyboard scene for quite a while.
usually around 600€
maxrunner
08 Sep 2017, 18:31
usually around 600€
Really? Anyone really got to that number here?
quochung1989
Vintage Cherry Collector
08 Sep 2017, 18:53
maxrunner wrote:
usually around 600€
I saw one on ebay: http://www.ebay.com/itm/cherry-ergoplus ... 2510870608
hansichen
08 Sep 2017, 20:00
600€ for a used iso one is way overpriced. There is one on geekhack in nearly nib for 500€ which hasn't sold in a while. Pricing is definetly below it, but that depends on the condition too.
Myoth
08 Sep 2017, 20:46
that's why I basically said "around" it can be 600€ upwards, or downwards ;)
Cyber Junkie
09 Sep 2017, 09:32
Hello all.
I would like to ask about two Cherry keyboards I have.
One is G80-3000HSMLS with Yu layout. It has got PS/2
connector. Keyboard is not yellow at all in real life
(as it looks in first picture because of the flash).
G80-1
G80-1
g80-2
g80-2
g80-3
g80-3
Another on is G81-3000SAY which should have Yu layout
but it isn't (are keys maybe changed?). It has got DIN
connector and little AT/PC switch on the keyboard.
Thanks in advance!
Myoth
09 Sep 2017, 17:44
Cyber Junkie wrote: Hello all.
Thanks in advance!
The first keyboard should have Doubleshots, it has MX Blues I think and is winkey, it would go for pretty expensive if it was ANSI or even just ISO-UK, this layout is pretty much useless to a lot of people but you can maybe get around $130 for it.
For the second, SA in the code means PBT Dye-Sub so you can expect around $120 for it I'm guessing. The keyboard iw orth nothing, you'd just sell the keycaps of this one.
My estimations are always talkable and I am no god, please tell me if I'm wrong, I'll learn and price check much more precisely if you do :)
davkol
09 Sep 2017, 18:21
derp
Myoth
09 Sep 2017, 19:36
true but at the same time I've seen a ANSI one just like it, winkey and it didn't go for $200 (or € ? can't remember)
gianni
13 Sep 2017, 11:30
Sincerely I don't see the point in buying old cherry keyboards... It's not like the case of a model f in comparison to a model m... Vintage doubleshot should be identical to the modern ones, don't they?
subcat
13 Sep 2017, 11:54
gianni wrote: Sincerely I don't see the point in buying old cherry keyboards... It's not like the case of a model f in comparison to a model m... Vintage doubleshot should be identical to the modern ones, don't they?
Often, it's a matter of price. An old Cherry HAD keyboard can be HAD ( ;) ) on eBay in Germany for far less than purchasing GMK Classic Beige or whatever it's called. Additionally, for sets like Triumph Adler there is a noticeable difference in coloring between the modern GMK visualisation and the original Cherry keycaps.
gogusrl
13 Sep 2017, 13:02
And there's stuff like this which I don't see GMK making anytime soon
13 Sep 2017, 13:25
Serious question: WHO would make keycaps with lettering in four colors? (I want black, red, green and blue for thee multipad I'll one day get to make).
davkol
13 Sep 2017, 13:34
derp
Keybug
14 Sep 2017, 10:29
What's the market value of a working Bondwell Pro 8T laptop (ALPS SKCL cream) from a keyboard collector's point of view? Or are they just too rare to have an established value? Thanks!
Return to “Marketplace Help”
