Round 4 / packing (99.8%) / shipping (99.7%)
Acanthophis
23 Jul 2013, 04:34
Why do you take pics with a tripod but leave the flash on?
sidunare
23 Jul 2013, 04:59
Because I just suck that bad.
23 Jul 2013, 09:18
My three keys arrived yesterday. Thanks!
grik
23 Jul 2013, 11:39
Mine arrived yesterday, i cant beleive 2 years waiting...more than that actually. Its worth it :)
Board = Filco
Order = ROUND3/STANDARDPT
+ ROUND3/PT
- Left Shift is short, should be wider, too small and it notices a gap
- Return key is missing, nowhere to be found
- Key between return and backspace is too short, as its different from my country layout i guess that was the problem.
Is there anything that you can do about this 7bit?
Please Please Please :)
pics of the problems
fotografia 3.JPG (119.13 KiB) Viewed 6467 times
fotografia 2.JPG (122.41 KiB) Viewed 6467 times
Apart from 3 problems, all is pefect.
Thanks 7bit
23 Jul 2013, 12:25
Those 3 problems are no 3 problems. At least not to me.
:o
- The 1.75 units Shift is for keyboards which require it on the right hand side.
- The J-shape Return should be part of the STANARDPT kit, but not the m-shape (2.25 units) because it is an ISO kit.
- I'm not sure there even existed a 1.5 units key for PT layout.
+ The only wrong key I can see is the << >> key which is in GX not GE. Didn't I add the correctly colored replacements?
grik
23 Jul 2013, 12:40
I will search for the correct color of «» when i get home.
Can you get me an ISO Return button for my filco? I didnt know that. For the left shift should i have it on the package too or can you send me a correct one too?
Is it possible to order a ^~ 1.5 for my set? This Filco as the wrong layout for PT set thats why its confusing.
m just a noob trying to have a super cool Standart set to remmember his old days of computing :)
Thanks again 7bit
Danke
Obrigado
JBert
23 Jul 2013, 13:18
Why would you need a 1.5 ^~ key?
According to http://en.wikipedia.org/wiki/File:KB_Portuguese.svg you should put it on the left of your return key...
EDIT: Or wait, are you trying to convert an ANSI keybaord to ISO just by replacing the caps? Because that rarely works well...
grik
23 Jul 2013, 14:36
Thanksf or the reply,
i just want the best alternative for that ~^ key on my Filco, maybe it cant be ordered :(. You can see that there is a big difference in size on that spot.
Also Im double checking when i get home the left Shift and the «» correct color.
Thanks for the replys, im noob and for that reason i was waiting for the package to see what iv done wrong.
Acanthophis
23 Jul 2013, 14:50
I think the main problem is that he is trying to put a ISO-PT keycap set on a US-ANSI keyboard.
Due to their layout differences certain keycaps won't fit properly.
Buffo
24 Jul 2013, 01:21
will there be an extra thread for selling the leftovers? Or do i just have to do another order in the known form and will be telled, which keys i can have and wgich not?
24 Jul 2013, 09:37
sidunare wrote:...
the spherical space bar dosent fit my leopold, anyone have suggestions? ...
There are 2 incompatible types of Leopolds, one fits, the other does not.
:cry:
24 Jul 2013, 14:12
Please report errors in received kits
(missing keys, wrong legends, row, color)
to 7bit_R4 in the following way:
MISSING
ROUND3/TERMINAL:
J-shape RETURN missing
<> one too many
CAPS LOCK key has upside down legend
RETRO/STANDARD:
* of numpad is missing.
Hint: MISSING is a keyword which makes sure the following text is written to a file which lists you missing keys!
You get a message with the registered list of missing keys. If not, the submission had failed!
Please, also provide photos, but do not attach these
to the message, because my script does not read the
attachments!
Just add links to the photos.
[/b]
:o
kps
24 Jul 2013, 16:21
7bit wrote:Please, also provide photos, but do not attach these
attachments!
Here is a photo of my missing keys:
24 Jul 2013, 17:00
Great to see you don't have any missing keys!
:evilgeek:
kps
24 Jul 2013, 17:11
7bit wrote:Great to see you don't have any missing keys!
If I had them, they wouldn't be missing.
sidunare
24 Jul 2013, 17:28
7bit wrote:
sidunare wrote:...
:cry:
Is there a SPH space bar that does fit? Any suggestions?
24 Jul 2013, 18:55
We had to pay $3500 per space bar mold.
:cool:
Just run another spherical group buy. Please don't forget to order molds for the 2.25 units and 2.75 units keys as well ...
:shock:
sidunare
24 Jul 2013, 19:05
7bit wrote:We had to pay $3500 per space bar mold.
:cool:
:shock:
Oh well, guess its time for my Dremel and plastic Weld.
Thanks for putting this all together 7bit, I appreciate it.
24 Jul 2013, 20:44
BTW, I shipped all orders now, except for one which I should ship later ...
Next: Cherry MX stuff and missing keys ...
Buffo
24 Jul 2013, 22:02
ok, and leftovers come afterwards?
gbohn
25 Jul 2013, 05:09
My keys arrived today. Thanks!
Now to check them out :)
Revan
25 Jul 2013, 12:03
This was my pn:
Missing
Noir/StandardDE
, of numpad is missing
Phantomesc is missing
But i didn`t got a message with a list so i think i did something wrong?
Is there also another keyword for too much delivered caps?
25 Jul 2013, 13:13
Now, you got one.
If you got too many keys, just say so in the same message. Might be helpful for me to know where to get an extra key if I don't have any reserve left.
BTW: There was never a komma key for DE layout-numpads.
pederlol
25 Jul 2013, 13:39
All caps are just perfect, thanks!
1 thing: Am I the only one having a hard time seeing the text on the retro keys in daylight?
25 Jul 2013, 13:45
Yes. I suggest you consult an eye specialist!
:shock:
Revan
25 Jul 2013, 13:48
7bit wrote: BTW: There was never a komma key for DE layout-numpads.
I just saw it in the wiki, seems i overlooked it somehow.
hottrout
26 Jul 2013, 15:04
pederlol wrote:All caps are just perfect, thanks!
NO, everything is perfect apart from one small point which is the caps are unreadible. :x
Revan
26 Jul 2013, 16:11
Has someone a red esc key too much that i could buy? I forgot that i was too late when i placed my order for a phantom esc key.
JSchool
26 Jul 2013, 23:44
* Languishes while waiting for keys *
sirtetris
28 Jul 2013, 01:27
Got all my stuff. :) Thanks a lot! ;3
