Great/Interesting Finds
09 May 2015, 15:12
XMIT wrote:
andrewjoy wrote: industrial grey 107! with blue nav cluster hmmmm
Heh, I'm planning on painting mine industrial gray as well when it floats to the top of my project stack. Keyboard sales first.
If I ever got an actual metal keyboard I would not even consider covering the metal with paint!
09 May 2015, 15:33
But what ifit were already painted, with it's original colour in good shape? My beamsprings and Kishsaver are in that category. I'd prefer them bare, but I'm not a vandal.
—Typed incompetently from my iPad
pyrelink
09 May 2015, 19:11
The paint on my F107 was pretty dreadful. I left it with its paint for a while, but as I am in the process of stripping the paint, I think I even like the bare unfinished metal better then the chipped, dirty, and uneven paint it had. If the paint was in good condition though, I would have probably kept it.
Redmaus
Gotta start somewhere
09 May 2015, 20:01
I would get mine powdercoated like dorkvaders: https://www.flickr.com/photos/dork_vade ... 9093257174
derzemel
12 May 2015, 09:47
DMD 1000 Computer with an interesting keyboard in Italy (350E):
http://www.kijiji.it/annunci/computer-e ... e/79886357
[ XMIT ]
12 May 2015, 12:06
pyrelink what are you using to remove the paint on your F107? I would use aircraft stripper.
12 May 2015, 13:27
If depends how good the paint is in the flesh, if its not that nice i will just get the industrial grey sprayed over the existing paint so that it retains the texture
[ XMIT ]
12 May 2015, 15:14
I definitely think powder coat is the way to go. I believe these were originally powder coated.
Touch_It
12 May 2015, 22:25
Redmaus wrote: I would get mine powdercoated like dorkvaders: https://www.flickr.com/photos/dork_vade ... 9093257174
Yep, I need that. SO pretty.
Touch_It
12 May 2015, 22:25
[ XMIT ]
12 May 2015, 22:36
Touch_It avatar pool thermometer, available at your local Home Depot.
Anticube
13 May 2015, 10:47
derzemel wrote: DMD 1000 Computer with an interesting keyboard in Italy (350E):
I was going to consider it, but there's something strange. The computer switch on but he says operating system doesn't start so it's a pity not to have the complete system working. And keyboard is capacitive, I'm not sure if this would necessarily be a synonym of quality.
On the other hand if the only keyboard would cost much less that would be nice to find out.
ramnes
ПБТ НАВСЕГДА
13 May 2015, 11:05
[ XMIT ]
13 May 2015, 20:24
kbdfr wrote:
XMIT wrote: […] One is missing many of the clear relegendable key caps :-( […]
Do you mean the whole caps or just the transparent covers? If the former, which? If the latter, how many?
After all you've been and still are doing for others here on DT, It's time your needs are cared for :mrgreen:
I just got a very nice package from Berlin! Thank you kbdfr! :D Let me buy you a beer sometime.
It took 37 covers to replace the missing ones. I have two extra now!
Redmaus
13 May 2015, 21:23
Is that black square a trackpad or something? Looks nice but the ISO enter is making me sick.
gogusrl
13 May 2015, 21:58
What are you talking about ? You get the best of both worlds. I love that layout (got the BoW version with browns).
edit : yes, that's a trackpad.
Redmaus
14 May 2015, 02:16
Whoa check this out! : http://www.ebay.com/itm/IBM-Model-F-Cli ... 2350d9329b
Those keys are very interesting and looks like this one was made pretty early for a F122, April of 1984.
Too bad its priced high up there.
gogusrl, the reason I don't like ISO is unlike ANSI which has the enter close to the finger so you can reach it, ISO literally has it BEND AROUND the area you actually hit enter and move the part you need to be lower farther up for some reason.
Plus, instead of nice looking horizontal bars all around, you get an ugly oversized enter keys that ruins the symmetry.
Nuum
14 May 2015, 06:31
Redmaus wrote: [...]
That's just a matter of taste/habit, there is not THE spot where everyone is trying to hit Enter and then missing it on ISO Enter.
14 May 2015, 06:49
Redmaus wrote: […] Plus, instead of nice looking horizontal bars all around, you get an ugly oversized enter keys that ruins the symmetry.
Did you say "an ugly oversized […] key that ruins the symmetry"?
Some three and a half years ago:
kbdfr wrote: […] Other arguments against ANSI: […], and the most important argument in my eyes: the silly shape of the key above the Enter key, which is bigger not because its use justifies it, but just because there is room to fill.
I always wonder how people can spend such a lot on keyboards because of their "awesome" looks without objecting to such a design abomination :o
14 May 2015, 11:01
One of the several reasons it's Backspace on my keyboards. Perfectly visually balanced against Tab, and far preferable to backslash getting such a prized place.
The real problem is staggering, though. Poor ISO with its malformed Return key. Better than Big Ass Enter, but what isn't?
14 May 2015, 11:10
i use it as escape on my beamspring :).
On IBM boards you could split backspace and use them for whatever and then use |\ ( ansi) as backspace as you do.
I like the physical layout of ansi, for a long time i hated it but i used it and found that the longer mods are just so nice on the fingers (less strain) sure the @ is in a bloody stupid place that there is no £ symbol or euro symbol. Also whats with calling # the pound symbol US people ? i don't get it its a hash sign, its been called that for years way before twitter, is a hashtag called a poundtag in the US ?
It could be worse you could have a totally useless § key or have <> on the same key like AZERTY does grrrrr.
IMO the best key layout is the unix layout with caps lock moved back to where it should be and control next to A, but with ISO assignments for symbols.
gogusrl
14 May 2015, 11:18
I've had mostly ISO keyboards with US locale so I'm used with that enter but I have no need for 2 backslash so I want a big left shift.
photekq
Cherry Picker
14 May 2015, 11:39
You're forgetting the one true layout.
14 May 2015, 11:40
oh yeah and a split + on the numbered you have to have that!
GuilleAcoustic
14 May 2015, 12:09
photekq wrote: You're forgetting the one true layout.
Nice, but I'd love the ~` key to be next to the " ' one for easy composed accentuated characters (should be easy with an ISO enter). Then move the |\ in place of the ~` and throw a double size backspace.
derzemel
14 May 2015, 13:03
Oh... that Cherry is an work of art!
ramnes
ПБТ НАВСЕГДА
14 May 2015, 14:24
14 May 2015, 14:49
andrewjoy wrote: […] a totally useless § key […]
Here again usages differ, I use characters like # rarely and \ next to never,
but in legal texts I often have do deal with there are quite a lot of §
and all the uppercase headers and subheaders would be just a pain to type without CapsLock.
14 May 2015, 14:53
I still wonder how many years I have been content with only those 24 programmable keys :mrgreen:
14 May 2015, 14:57
Big Ass. Ugh. Why not merge other keys together and be even more supremely stupid? At least on a Model F, where it came from, I can split the key myself!
As usual, Kbdfr, combos are how I handle things. Option+6 on OS X. There is no one true layout. So long as there are different languages and uses.
Return to “Other external”
