GMK / Cherry doubleshot modifier packs (complete?)
05 Jun 2013, 12:32
The windows and menu keys where printed.
The Shift keys have the arrow placed the same as on your keys.
Return with long arrow:
Here the J-ret:
Cherry legends are more consistent than SP ones, but still they have their inconsistencies. If the key caps should go with original Cherry keys, I don't think these little issues are a problem. Maybe with the exception of the one wrong Shift.
IvanIvanovich
05 Jun 2013, 13:55
I've never seen JA 1800 though maybe it exists. I have only seen 3 JA models 3600, 11802, and some 8000 series model. I've wanted to get my hands on any JIS G80 for awhile now but they are very hard to find it seems.
IvanIvanovich
05 Jun 2013, 22:33
Those with orders of only Esc keys, your orders have been shipped. You should have received any relevant tracking info via paypal/email.
IvanIvanovich
14 Jun 2013, 21:56
Replacement keys are on the way. I should have them by Monday and will probably have everything packed up and start sending on Wednesday.
Bullveyr
14 Jun 2013, 22:27
Gilgam
15 Jun 2013, 09:37
7bit wrote: Return with long arrow:
Any group buy for that key ? :mrgreen:
Broadmonkey
Fancy Rank
15 Jun 2013, 10:56
IvanIvanovich wrote:Replacement keys are on the way. I should have them by Monday and will probably have everything packed up and start sending on Wednesday.
w00t w00t! I am really looking forward to this, I am especially getting more and more hyped about the CMYK set :D
IvanIvanovich
18 Jun 2013, 00:22
I'm busy packing them all up and will start mailing out through the week.
Jmneuv
18 Jun 2013, 00:44
Sweet - everything perfect now?
IvanIvanovich
18 Jun 2013, 01:07
Yes, we now have uniform arrow alignment on the 2.25 shift, and uniform left aligned Ctrl. :)
IvanIvanovich
19 Jun 2013, 00:08
Updated OP with available leftovers.
19 Jun 2013, 07:55
IvanIvanovich wrote:Updated OP with available leftovers.
I'll take those 5 red on white Esc caps.
gotbadger
19 Jun 2013, 13:02
will take a CMYK set if theres one left
IvanIvanovich
19 Jun 2013, 14:37
Sorry all out of CMYKs.
IvanIvanovich
21 Jun 2013, 16:37
There are still some purple 32key sets and single keys available. Almost half done with shipments.
damorgue
21 Jun 2013, 16:46
Is there a reason as to why we didn't try their windowed caps? If I remember correctly, they carry them. Or was it just to keep this GB less complex? Just wondering if they are possible for GBs.
Acanthophis
21 Jun 2013, 16:54
Yeah, what about dem windowed stepped caps locks?
BimboBB
21 Jun 2013, 16:57
As far as I remember they are not in because windowed caps just coming with pad printed legends....and pad printed is meh.
damorgue
21 Jun 2013, 17:49
For the record, did Cherry have double shot windowed caps? Are those molds just lost or am I mistaken about that?
Jmneuv
21 Jun 2013, 17:56
i think cherry never did triple shot
BimboBB
21 Jun 2013, 18:00
I am not sure. Some say that the window on double shots is just a triple shot. I have one such key, but for me it looks like a doubleshot with a manually drilled hole and window placed in. But maybe there are other real windowed tripleshots existing.
Maybe in future when PBT doubleshot process is advanced enough, you could have dyesubbed pbt caps being doubleshoted with a window. :)
Broadmonkey
Fancy Rank
21 Jun 2013, 19:47
Why have windowed key caps, when we can have clear legends? :twisted:
21 Jun 2013, 19:57
YES!
IvanIvanovich
21 Jun 2013, 20:00
Yes, I agree with this clear legends is better, but if many people want some BLANK windowed keys I don't have a problem with this.
Only doublehot + windowed keys I have seen were all 1x only.
I have some PBT dyesubbed windowed caps locks... doubleshot from old TA with I guess Polycarb.. One set is tan, has amber color window and I think it was made that way not yellowed as the inside is the same color. Other one is grey PBT with clear.
Jmneuv
21 Jun 2013, 21:55
clear.. look at it, just look at it
Acanthophis
21 Jun 2013, 22:02
Actually, I'm not convinced that enough light from the LED will shine through the legends.
We need a photo of the keycap mounted on a switch with LED.
Jmneuv
21 Jun 2013, 23:07
here's a pic from GH which i think gives an idea of doubleshottered backlight:
http://geekhack.org/index.php?topic=426 ... #msg861878
personally i'm looking at it as a normal daylight cap, it's about that subtle 'difference' the clear legend makes (and of course about showing off the ds goodness);
Broadmonkey
Fancy Rank
21 Jun 2013, 23:08
It depends on whether your switch is turned 180 or not, but it is a valid concern, I don't think it will optimal with non-rotated switches, but I still think it will work to some degree as the clear-layer inside the cap will help spread the light to the legend. Personally I don't really care as I really like the look without it even being lit.
We could maybe do a "gamer-set" that contained W, A, S, D and ESC with clear legends.
IvanIvanovich
22 Jun 2013, 01:12
Yes it would depend if the led was on the top, or upside down switch for best result with closest to legend. Some people are really interested in making full sets, but I also agree a smaller pack to test how well it really is may be a smarter move.
I was thinking to do maybe just the lock keys, caps, num, scroll and see how it was, but WASD set could be a good idea too, maybe even do C and D row cursors for lulz.
On the other hand we see how it is on SP keys, and we know Cherry/GMK keys are not as bleedy with light since they are 3x as thick... It would probably be just fine.
damorgue
22 Jun 2013, 03:15
I for one never quite liked back lit key caps with translucent legends because the support flanges on the inside are always visible.That is why I like windowed caps, as they usually have a smaller and more homogenous lighting. Is it possible to have it matte or semi-opaque to scatter the light more?
