Phantom Custom Keyboard Group Buy (CLOSED)
Djuzuh
14 Sep 2012, 10:46
dirge wrote:Shit! where do I get costar stabilisers?!!
WASD.
dirge
14 Sep 2012, 10:58
Thanks for confirming for me :) got a load of stuff from them on its way.
Gilgam
14 Sep 2012, 11:02
mintberryminuscrunch wrote:
Gilgam wrote: It will be a fine keyboard in 2014 :mrgreen:
Have you decided which layout you'll use?
Not yet
i would give a try to the 7 bit layout , no stabilizers and a dedicated set of keycaps :ugeek:
But i hope the change won't be too hard.
I should have bought two PCB :-)
dirge
14 Sep 2012, 11:31
Gilgam wrote: I should have bought two PCB :-)
I bought two, should have bought more...
telge
14 Sep 2012, 14:14
Recieved phantom stuff in sweden now!
Just wondering, is there any page with pictures on the attached teensy on the phantom, could use for reference when soldering. Not to experienced so if anyone has the time it would be very helpful.
Thanks for a nice group buy!
dirge
14 Sep 2012, 15:39
In the wiki litster pit a guide up
14 Sep 2012, 15:49
It is getting time to read through the Phantom Instruction_guide very carefully.
BTW, I found that the PCB and plate with switches on it fits into an old Key Tronic KT800 case.. but there is a lot lof space around the key groups, so it does not look right. Nah, well.
ped
14 Sep 2012, 15:56
I got my switches today, too bad that's all I got.
14 Sep 2012, 16:06
ped wrote:I got my switches today, too bad that's all I got.
The Phantom is following ...
Tarkoon
14 Sep 2012, 16:43
Was my packet one of the last ones? Still received nothing... :cry:
14 Sep 2012, 17:28
Tarkoon wrote:Was my packet one of the last ones? Still received nothing... :cry:
I'm afraid so.
:o
Gilgam
14 Sep 2012, 18:07
Germany to Germany longest way ever :-)
I did get my switches weeks ago 8-)
By the way, i have some pics of Lister CAD about a case for the Phantom.
I have th pic but no mention of the size.
Does Lister or anyone have a precise scale of that drawing ?
I'll try to go and see my neighbour for a metal case (they make form steel to titanium ...).
Thanks
Phantom Case Layer 1 Top.png (19.29 KiB) Viewed 6287 times
14 Sep 2012, 20:42
Me, too lol
Let me know if you have no use for the phansi plate :-)
dirge
14 Sep 2012, 21:05
I would have if the wyse plate had been the same size:(
If I could switch for an ISO I'd be happy too. But I think it may be a Dvorak boards when the geekhack dyesubs come in.
Gilgam
15 Sep 2012, 10:12
mintberryminuscrunch wrote: Me, too lol
I think i's a ISO one, but it must be the same...
Half-Saint
15 Sep 2012, 11:00
Hmm weren't there some assembly instructions including how much time is needed? :)
bpiphany
15 Sep 2012, 11:17
15 Sep 2012, 19:57
Gilgam wrote:Does Lister or anyone have a precise scale of that drawing ?
I suspect that the dots are precisely one centimetre apart. Why don't you ask Litster for the DXF file? ;)
15 Sep 2012, 21:03
Oh, yes it is.. I overlooked that :(
Swede
16 Sep 2012, 20:14
Still not gotten mine, hoping it's on it's way :)
Guess I get it sometime next week :)
16 Sep 2012, 20:35
Got mine. Probably got here earlier, was away for a few days. Great work guys!
16 Sep 2012, 22:17
Hmm. I found that a mounted switch can not be opened if the switch position has stabilisers...
A little bit of filing fixed that. It does affect the use of the Costar stabiliser mounts that I got in the kit. I dunno about Cherry stabilisers, though, 'cause I haven't got any to try with.
I am pointing where I filed down the tab. There is still a tab on the right side. The tabs on the bottom are not in the way.
gimpster
16 Sep 2012, 22:35
Findecanor wrote:Hmm. I found that a mounted switch can not be opened if the switch position has stabilisers. A little bit of filing fixed that, and it does not affect the use of the Costar stabiliser mounts that I got in the kit. I dunno about Cherry stabilisers, though, 'cause I haven't got any to try with.
I was doing an ergo clear mod on one of my Phantoms yesterday and had the same problem with Cherry stabilizers. In fact, it was basically impossible to get the top of the switch off with the stabilizers installed, so I just desoldered the switches to do the mod instead of risking damaging the switch housing trying to pry them open while installed.
bpiphany
16 Sep 2012, 23:22
Yeah, I deliberatelty left the Cheery stabilizer cutouts like that, not to compromise their functionality.
17 Sep 2012, 14:03
I thought as much. I am sure that it was mentioned months ago, but I could not remember the details or find it when I searched for it.
There are also small barbs inside the switch holes in the plate from the manufacturing. Not a problem if you only intend to mount the switches exactly once, but they could mar the switches if you (like me last night) use the plate as a stand for lubing.
BTW, there are QR codes etched into the circuit board, all covered by black solder mask... Very hard to read. Want to disclose what they are for? ;)
bpiphany
17 Sep 2012, 14:33
Findecanor wrote:BTW, there are QR codes etched into the circuit board, all covered by black solder mask... Very hard to read. Want to disclose what they are for? ;)
Nope ;D
damorgue
17 Sep 2012, 14:39
bpiphany wrote: Nope ;D
You are just a hoopy frood, aren't ya? :P
This keyboard will soar in the sky, much like a brick doesn't.
17 Sep 2012, 14:48
Swede wrote:Still not gotten mine, hoping it's on it's way :)
You need to decide if you want the G80-2100 or just the key caps.
All remaining orders are packed and will ship today, along with some CherryMX orders.
17 Sep 2012, 15:12
bpiphany wrote:Nope ;D
Challenge accepted!
17 Sep 2012, 20:10
I sell 2 Phantom PCBs with 7BIT-layout and Teensy.
Prices:
Phantom PCB: 40 EUR
7BIT mountplate: 20 EUR
TEENSY: 15 EUR
Exchange rate is 1 EUR = $1.3 .
