Costar CSK-7102 (Alps-like switches) — any good?
stratokaster
24 Mar 2015, 19:19
I found this keyboard on a local auction site. It appears to have some unbranded Alps-like switches. Are those any good? Is it worth buying for ~$12? Can't find much information about it.
Update. Found this thread on Geekhack: https://geekhack.org/index.php?topic=22255.5
Doesn't look encouraging...
24 Mar 2015, 20:45
If the caps are indeed alps compatible it may be worth it for that depends on how yellow they are
Jimi14
24 Mar 2015, 23:55
Hm, those switches look like they could be related to the KPT/TEC family (http://deskthority.net/wiki/KPT_switch ) or 'square alps' which i seen some people call them.
Never seen any in black before though so i could be wrong.
Edit, after checking around a little more i think i found them: they are known as Alps.tw Type OD1 (http://deskthority.net/wiki/Alps.tw_Type_OD1 )
jacobolus
25 Mar 2015, 02:41
If you don’t want it, I’m trying to put together a massive switch tester with every Alps-mount switch I can get my hands on. I’d be happy to buy the board or a handful of loose switches.
stratokaster
25 Mar 2015, 06:06
jacobolus wrote: If you don’t want it, I’m trying to put together a massive switch tester with every Alps-mount switch I can get my hands on. I’d be happy to buy the board or a handful of loose switches.
The keyboard is described as being "mostly in working order but with some keys very stiff." I will contact the seller today.
Mal-2
25 Mar 2015, 08:27
stratokaster wrote: The keyboard is described as being "mostly in working order but with some keys very stiff." I will contact the seller today.
I bet if you were willing to do a TKL conversion, you could salvage enough switches from the tenkey area to replace all the bad ones elsewhere.
mougrim
01 Apr 2015, 13:09
Hmm, found it too today, but if you want it, I won't be betting on it. Besides, I wanted to get it for caps - they seems to be with pad-printed Cyrillic letters, but still they're nice.
Кстати, все равно дороговато. Я недавно купил клавиатуру с Alps-подобными переключателями всего за 70. Но там пробел треснут, и наклейки на светодиоды нету. Хоть и работает.
