Best board candidates for switches donor (Cherry MX)
cactux
30 Sep 2011, 13:36
JBert
30 Sep 2011, 13:42
Probably Cherry keyboards, as they are PCB mounted and are thus easy to pop open if you have a tool fit for the job. Reds are hard to find on a Cherry keyboard though.
cactux
30 Sep 2011, 13:48
Clickey
05 Oct 2011, 13:57
How much did it cost you for 87 red switches from china?
Pylon
06 Oct 2011, 18:25
If you do Cherry donor boards there's several G80s with blacks and browns. Just take a brown spring and a black stem and you've got a red switch.
itlnstln
06 Oct 2011, 18:28
For what it seems cactux is doing, I would just buy new switches. If you need 3 sets, desoldering from donor 'boards would be tedious to say the least. That, and I assume he is getting new switches (vs. used ones in donor 'boards).
ripster
06 Oct 2011, 18:47
I got some nifty ones from Singapore and Squarebox. Not sure if he has Cherry MX Clear.
FOR SCIENCE!
Somebody actually asked me what each switch weighs.
cactux
06 Oct 2011, 23:50
