Need a translator for TaoBao (picture attached...)
hKing
23 Apr 2016, 19:08
Hello there,
I made a fancy picture for my question... :mrgreen:
Thanks in advance!
geekmie
23 Apr 2016, 19:11
Which color do you want? Better post the link. I can select and show you.
hKing
23 Apr 2016, 19:12
https://world.taobao.com/item/520956524 ... .18.WEmISh
Thanks for your help! Maybe I take every color available - I am planning my next build at the moment...
geekmie
24 Apr 2016, 01:05
hKing wrote:https://world.taobao.com/item/520956524 ... .18.WEmISh
I checked the link. Not sure which is 7 which is L. No detail description on that. I asked seller about it. Hopefully we can get an answer when he wakes up.
You can easily Google translate color texts I guess :P
faycheung
24 Apr 2016, 03:04
I'm guessing L is bigass and 7 is ISO (because 7-shaped?)
hKing
24 Apr 2016, 09:42
@ faycheung: Thanks! So the "L" is for Bigass and the "7" is Iso.
How do you manage to translate this into "ISO" and "Bigass" ?
faycheung
24 Apr 2016, 12:28
It was a guess, as I said under the pic. Bigass is a mirrored L, and ISO kinda looks like a '7'. TBH the Chinese mechanical keyboard enthusiasts aren't very good at naming or identifying things.
y11971alex
17 May 2016, 08:39
小回車 generally is ANSI return. 大回車 may mean ISO or AT. This seller has some pretty unconventional jargon going on.
