[IC] n3rdpad (was: MX-Keypad)
aaron
03 May 2016, 12:39
Hi there!
A friend of mine designed this awesome board as a successor to my attempt (https://aaron-fischer.net/pzx). It can be programmed with the TMK firmware and used as a additional keypad for all sorts of things.
Are there some interest in a GB (PCB only)?
I think I can do it for 10 EUR for the PCB + Shipping (which i don't know how much at the moment).
b4d_tR1p
03 May 2016, 12:42
very nice work mate
gogusrl
03 May 2016, 14:05
sign me up.
03 May 2016, 14:24
I might be up for one too
shreebles
Finally 60%
03 May 2016, 15:05
Looks really good. Interested.
Alkhar
03 May 2016, 15:55
up for one
Dra
03 May 2016, 17:40
PCB only so no controller whatsoever soldered on? Or am I understanding this wrong? :)
Anyway probably interested if I don't have to solder the controller on myself
shreebles
Finally 60%
03 May 2016, 18:01
True, I only just saw that. There are solder pads for an Atmel controller there, but if he says PCB only it's probably not soldered yet...?
Dra
03 May 2016, 18:10
exactly why i'm asking, I'm not confident enough with my iron to solder a controller :lol:
aaron
03 May 2016, 20:11
Just the PCB without the components and without soldering it on the PCB.
If there is any interest, I can calculate the cost for the components. for a small number I can solder the stuff on by hand.
The PCB can be used with or without the Controller. The complete keyboard matrix can also accessed from the pin header at the right to use it with other controllers like an Arduino or a RaspberryPi.
gogusrl
03 May 2016, 20:19
A arduino pro micro socket would be awesome for this.
shreebles
Finally 60%
03 May 2016, 20:40
Wow, that's a really cool idea with the headers. Personally I have soldered a bit but never something as small as a controller. How does one do that? Solder paste?
aaron
03 May 2016, 20:50
shreebles wrote: Wow, that's a really cool idea with the headers. Personally I have soldered a bit but never something as small as a controller. How does one do that? Solder paste?
With a normal soldering iron an some practice. the trick is to use a lot of flux :)
https://www.youtube.com/watch?v=FO9CHjdqBr8
Another way is to reflow it in a cheap pizza oven or on a camping heat plate.
The idea to add additional headers for a Arduino Nano is a great idea. I'll check if there is enough space to squeeze it in.
Dra
03 May 2016, 21:07
aaron wrote: Just the PCB without the components and without soldering it on the PCB.
Aaand now I'm interested. Are there any plans to host a GB for a case as well?
aaron
03 May 2016, 21:16
Dra wrote: Aaand now I'm interested. Are there any plans to host a GB for a case as well?
Not at this time. I have a 3D-Printer. maybe can print some case in ABS or PLA. But It would not be as pretty as a CNC carved case.
aaron
03 May 2016, 21:17
It is a tight fit for a Arduino Nano, but it is possible :)
With some solder pad switches the PCB can do 3 different "modes"
* Arduino Nano hooked at the bottom
* Soldered ATmega32U4 in place
* Pin header at the bottom/top for external use (you can hook up your door bell :evilgeek:)
TalkingTree
03 May 2016, 21:34
I'd buy one.
Redmaus
Gotta start somewhere
04 May 2016, 06:05
Would it be possible to make the PCB alps and MX compatible like the Duck Eagle PCB? If so I would buy one.
mohitgarg
04 May 2016, 08:42
Redmaus wrote: Would it be possible to make the PCB alps and MX compatible like the Duck Eagle PCB? If so I would buy one.
From a technical standpoint, it shouldn't be a problem at all, I don't see any conflicts in the alps switch positions.
shreebles
Finally 60%
04 May 2016, 08:48
Thanks, I'll take a look when I get home (at work atm).
Pizza oven is a neat idea. I have an old mini oven and no use for it anymore now that I moved in together with my girl.
Also, that way I don't have to put electronics in our "real" oven and can avoid some trouble with her. :mrgreen:
aaron
05 May 2016, 11:02
Sure, here is the Alps AND MX compatible board. :lol:
I also added some through hole components for the Arduino part, so the soldering will be easier in the arduino-configuration.
Alkhar
05 May 2016, 14:31
Hope all the new fonctionality dont drive the price high.
gogusrl
05 May 2016, 14:49
So in this new version I can buy a 4$ arduino pro micro, stick it in there, get some diodes / switches and I'm good to go ?
chuckdee
05 May 2016, 18:08
I'd be interested if the soldering was included.
Prelim
05 May 2016, 18:24
does anyone know about numpad compatible cases for it?
Alkhar
05 May 2016, 21:19
Can we have the lenght / widht of the pcb ?
"I think I can do it for 10 EUR for the PCB + Shipping."
Does that change with all the modification ? At what point of price are we ?
aaron
05 May 2016, 22:53
The price is still the same. the dimensions are 5.20x3.40 inches (132.11x86.39 mm)
I've modified the PCB a little, arrange some stuff and add some labels.
You can hook up a Arduino Nano. I can add one to the order for 4 EUR.
Remember: This project is still Work in Progress. the PCB is never tested before, a friend of mine and I will inspect the whole PCB several times to find (hopefully) all the bugs. But there is a risk that there s a minor bug which need to be fixed by hand.
Soldering jobs: Maybe ... I am not sure about that if I want to spend several days soldering SMD components or build a small "assembly line" :) Manufacturing the PCB with a PickAndPlace Machine + Reflow is expensive .... :/
xtr0n
06 May 2016, 03:05
I'm interested although I'd need some hints on how to get from PCB -> working numpad. I've put together an Infinity ErgoDox kit before, but this looks like it requires a bit more know-how.
brundlefly
25 May 2016, 13:01
I could see using two of these as like a split Planck keyboard. Do you see any issues doing something like that?
aaron
02 Jun 2016, 00:25
@brundlefly: Sure, with a little bit of software tweaking and some wires, this is possible.
