Group Buy 4 Sphericals Tenkeyless
bitcrusher
06 Nov 2011, 22:18
Hello, I am making a group buy for Spherical key-caps for cherry switches, it is currently included in the Group Buy 4 hosted by 7bit.
my screen name at geekhack is slueth
http://geekhack.org/showthread.php?2373 ... ts-Keycaps
The Space Cadet theme is the winner so go order your spherical :d !
The blue layout is an emulation of the space cadet by a geekhacker. Pics of space cadet by webwit.
Space Cadet
layout pictures
Sample of what a spherical key looks like that was made by Signature plastic
Sphericals
SPH/TERMINAL..................6
SPH/STANDARD..................3
SPH/TENKLESS.................12
SPH/TKL.......................5
SPH/MODIFIER.................12
SPH/FUNCTION.................11
SPH/NUMERIC...................7
SPH/POS.......................7
SPH/AWESOMEFUN................3
SPH/VIM.......................1
SPH/SPACE....................14
SPH/SPACELEO..................2
SPH/SPACEOLD..................3
SPH/SPACETIPRO...............10
SPH/BLANKPOS..................9
Quota met. My work here is done! Feel free to keep the orders coming though.
Minskleip
06 Nov 2011, 22:33
Yes! This will be a huge success :)
06 Nov 2011, 22:59
Thanks for the extra promotion and for supporting this!
I hope you like the current version in the blue/grey scheme!
bitcrusher
06 Nov 2011, 23:04
oh my gawd that is sex... is that layout for the phantom?
06 Nov 2011, 23:12
bitcrusher wrote:oh my gawd that is sex... is that layout for the phantom?
Yes, but I'm not 100% sure if I will keep it that way.
Please notice the 1.5 units space bar.
ripster
07 Nov 2011, 04:37
But the best keys are the RUBOUT, GREEK and HAND CURSOR keys! And the funky APL like symbols!
07 Nov 2011, 08:45
ripster wrote:But the best keys are the RUBOUT, GREEK and HAND CURSOR keys! And the funky APL like symbols!
No kidding, I'm working on them ...
bitcrusher
08 Nov 2011, 21:07
bump with winner of color scheme poll and updated link to order instructions
richie
08 Nov 2011, 22:02
will this work on a KBC poker keyboard?
and is geekhack been blocked for anyone else?
Gilgam
08 Nov 2011, 22:21
Yes but the space bar ....
Yes Geekhack is reported as an evil website.
They must have checked my spendings on keyboards :-)
08 Nov 2011, 22:33
Gilgam wrote:Yes but the space bar ....
Poker uses either of Leopold, Filco or Cherry.
It is in the space bar wiki which is superior to the shitty, blocked, malware contaminated GeekWreck wiki!
:ugeek:
Gilgam
08 Nov 2011, 22:38
Thanks
By the way most of the space bars i bought in GB3 do not fit my g80-1000 or g80-1800 keyboards. I must have made some mistakes while ordering them.
Space Bars are important !!
PS : i don't get the daily email on my GB4 purchases is this normal (it miss me...).
Danke
08 Nov 2011, 22:42
Gilgam wrote:Thanks
Danke
SPACENEWBLACK |Space (6 u;114;38,57) | 2.00| 1| 1| 2.00
SPACENEWGREY |Space (6 u;114;38,57) | 2.00| 3| 3| 6.00
SPACENEWORANGE |Space (6 u;114;38,57) | 2.00| 2| 2| 4.00
SPACEBLACK |Space (6.25 u;118;Filco/Cherry) | 2.00| 2| 2| 4.00
SPACEGREY |Space (6.25 u;118;Filco/Cherry) | 2.00| 2| 2| 4.00
SPACEORANGE |Space (6.25 u;118;Filco/Cherry) | 2.00| 2| 2| 4.00
SPACEPOSGREY |Space (7 u;133;57,42.8) | 2.00| 2| 2| 4.00
Indeed!
You should have taken a couple of SPACEOLD!
ps: maybe I set up something over the week-end...
Gilgam
08 Nov 2011, 22:50
7bit wrote:
Gilgam wrote:Thanks
Danke
Indeed!
Gottverdammt !!
Do you still have some stocks ?
(sorry guys private conversation :-) )
08 Nov 2011, 23:15
Gilgam wrote:Gottverdammt !!
Wie viel brauchst Du?
Gilgam
09 Nov 2011, 09:11
zwei grau und zwei schwarz für g80-1800 unnd g80-1000/3000 ?
(this is my best Deutsch i was fired from the deutsch course years ago ;-) )
09 Nov 2011, 09:20
Gilgam wrote:zwei grau und zwei schwarz für g80-1800 unnd g80-1000/3000 ?
Werd' mal nachsehen ...
(they should have fired your teacher!)
ps: Don't ask about my French abilities ...
edit:
Found a GE grey one ...
blainchen
09 Nov 2011, 09:54
If this kit would have a 7U spacebar for G80-3000, 1U super keys and a num block and everything needed for a plain ANSI Layout for G80-3000 I would directly order 2 or 3.
EDIT: Added attachement
Would be for a project I'm currently working on.
And it should have some extra keys for the upper row (Like volume up, down and mute)
09 Nov 2011, 11:06
blainchen wrote:If this kit would have a 7U spacebar for G80-3000, 1U super keys and a num block and everything needed for a plain ANSI Layout for G80-3000 I would directly order 2 or 3.
Get the following:
SPH/STANDARD 3
I'm not sure if we can do the 7 units space bar. It kond of depends on how many keys we sell in total.
You can get a 7 units DCS space bar instead and hope for Round 5 ...
blainchen
09 Nov 2011, 11:40
Does the color of the DCS space bar matches the SPH kit?
Is the function and the modifier kit also possible for SPH?
Most importantly I need old 1.5U Alt and Ctrl and 1U super keys.
09 Nov 2011, 12:17
blainchen wrote:Does the color of the DCS space bar matches the SPH kit?
FUNCTION
NUMERIC
POS
^^^ these will all happen!
MODIFIER: maybe I will change some things here ...
I will offer a DCS 7 units spacebar with matchin colors.
blainchen
09 Nov 2011, 12:24
FUNCTION
NUMERIC
POS
Will the modifier set be done? If yes, await my order ;)
09 Nov 2011, 12:35
Yes, it will but I think I will clean it up a bit.
It surely contains some keys no one will ever need and some keys are too few.
