How much smaller will they get?
elecplus
21 May 2017, 09:17
The top one is a Cherry POS keyboard.
2nd one is BTC-5100C.
3rd one is a tiny NOVA USB keyboard, about the same width as an octave on a standard piano.
darkholypl
21 May 2017, 12:29
Like this.
zslane
21 May 2017, 18:28
That's not a keyboard, that's just a fancy switch tester. ;)
Phenix
-p
21 May 2017, 18:53
zslane wrote:That's not a keyboard, that's just a fancy switch tester. ;)
and even un-usable for us strange Germans..
rsbseb
-Horned Rabbit-
21 May 2017, 19:15
But it would fit into your vest pocket nicely.
I think it could be used effectively for mood lighting
Stabilized
21 May 2017, 20:30
zslane wrote: That's not a keyboard, that's just a fancy switch tester. ;)
When I saw the thread topic that was the first keyboard that came to mind. I am a huge fan of 60% keyboards, but I keep a 65% in reserve if I need to do some text editing and need those arrow keys/nav keys. I don't think I could survive with basic punctuation on a function layer :?
Phenix
-p
21 May 2017, 22:01
that small board is called Gherkin btw.
@Stabilized
I use 90% my function-layer-arrows on asdf on my ergoDox, and just sometimes the normal arrow cluster on the right half bottom line..
paecific.jr
22 May 2017, 16:38
This isn't a mechanical keyboard, but it could be.
codemonkeymike
22 May 2017, 22:32
How bout the Twiddler, not mechanical but I think its as small as they get. http://twiddler.tekgear.com/
hoggy
23 May 2017, 14:18
Any smaller than the frogpad, you'll end up with something like the gkos.
http://www.gkos.net/gkos-net-index.html
Mechboards
23 May 2017, 15:48
hoggy wrote: Any smaller than the frogpad, you'll end up with something like the gkos.
I really want to learn this!
