Can pcb mounted cherry stabilizers be used without a pcb on a plate? (as with the switches?). For some reason plate mounted cherry stabilizers are uncommon, so I was wondering if the pcb mounted could serve both purposes.
Thanks
Difference between pcb and plate mounted cherry stabilizers
- derzemel
- Main keyboard: FC660C, SSK, TX-1800 Nixie
- Favorite switch: Alps SKCL/SKCM tactile
no. You need the plate mount variant.
here is a shop that has them: https://mechboards.co.uk/shop/all/cherry-stabilisers/
you can also find them on older plate mount keyboards (WYSE, Cherry G80-9009)
- Main mouse: Mouseless (occasionally trackpoint)
- Mechboards
- Main keyboard: Ducky Mini V1
- Main mouse: Wheel Mouse Optical
- Favorite switch: MX Brown
PCB mounted stabs can be used with or without a plate. PCB stabs cannot be used without a PCB, they don't attached to the plate at all.
