FS: PS/2 or ADB to USB R3scan® converters
Wingklip
17 May 2019, 15:31
Hi all,
I'm selling some soarer/hasu compatible converters that I had designed and improved after two years in development and production. I've finally completed the first run, so orders can be placed now!
The price is $25 USD FLAT including global untracked insured shipping.
https://docs.google.com/forms/d/1gVTN3z ... KA-Tg1juU/
Photos below. The case is a magnetic snap fit, which means you can resolder the connections and reprogram it at will. Also drop damage resistant. Screw mountable.
1KOHM resistor is already soldered for the pullup, so feel free to use long cables.
INSTRUCTIONS******
Instructions for Assembly: (or a simple case of square block in the square hole)
1. Remove any tape, wrapping, or cardboard from the package carefully, DO NOT pierce the cardboard on the flat sides. Using a pen is recommended over sharp objects such as knives
2. Seperate the case from the pro micro and port. They are mounted in a shipping configuration to satisfy the thickness limitations.
3. Plug the PS2 or ADB port into the corresponding half with the holes in the case matching, using sufficient force to ensure a snug fit. This is hereby known as the BOTTOM SHELL. Place the pro micro flat with the microUSB port face facing towards the user onto the BOTTOM SHELL. Press fit lightly into the case. ALL CONNECTORS WILL CLEAR THE CASE UNLESS PLACED IMPROPERLY OR ON THE WRONG HALF SHELL. If you fail this after reading, please reconsider your life :)
4. Make sure the wires are tucked into the center of the pro micro and then press down the TOP SHELL. Ensure there is no gap, and that all ports clear the TOP SHELL. The shell case will only be openable should sufficient pulling force be exerted upon the shells.
If the end user breaks a component during assembly they shall be responsible for the purchase of the corresponding part as per the price below (incl postage):
Pro Micro w/resistor and Pins presoldered: $10
Case w/Magnets: $10
Connector ADB/PS2: $5
All items are inclusive of shipping and in USD. Only available to the owners of a R3scan converter
Engicoder
17 May 2019, 16:02
These look nice and compact. Good job on the case. Good luck!
Wingklip
17 May 2019, 17:56
Engicoder wrote: 17 May 2019, 16:02 These look nice and compact. Good job on the case. Good luck!
Thanks, spent hours trying to make it look perfect
Wingklip
19 May 2019, 05:31
Price has been dropped to $25USD each for the first batch of 50 :)
Wingklip
25 May 2019, 08:27
All paid orders have been sent out. Special thanks to all of the first four purchasers of this converter!
the_ambyguous
07 Jun 2019, 21:21
aw man, no idea if this is still available but just submitted a request for one ps2
Wingklip
08 Jun 2019, 03:14
Still available, but you'll probably have to wait a week or so more than usual as I'm currently doing uni as well :)
Wingklip
16 Jul 2019, 08:08
To all purchasers of my converter! Results are in, shipping may take up to 7 weeks to arrive as letters are quite unreliable, but are the only option I have to make these at this price. General time I've seen is from 1-7 weeks it seems
If you don't get it after then feel free to hit me up to discuss resends or refunds etc
daguil68367
12 Dec 2020, 06:32
Could these also be programmed to convert XT to USB?
quaker
12 Dec 2020, 09:45
Alright, now this is amazing! Both performance and value-wise :D
Sturmtiger001
14 Dec 2020, 22:14
These look absolutely amazing, I hope you expand and continue on these with another, fantastic value as well.
Return to “For sale”
