Cherry 5000 trilogy
01 Apr 2012, 15:26
Behold the Cherry 5000 trilogy. See also the IBM Model M15 trilogy. This one won't last long, as one of these boards is currently up for auction. A good time for a photo opportunity.
Boards:
Cherry G80-5000HAMUS (newest, with Window keys, weight: 1138g)
Cherry G80-5000HAAUS with G80-5700HAAUS numpad (weight: 1152g)
Cherry V80-5000HAD (prototype serial 000001, weight: 1784g)
Cherry G80-5000HAMUS:
Cherry G80-5000HAAUS:
Cherry V80-5000HAD:
Cherry G80-5000HAAUS vs Cherry V80-5000HAD. 1152g vs 1784g in weight and 4.1cm vs 5.1cm in height!
cactux
01 Apr 2012, 15:39
yab8433408
01 Apr 2012, 16:37
4 :?:
01 Apr 2012, 16:52
HAU? Appears to be the same as the HAAUS.
yab8433408
02 Apr 2012, 05:49
webwit wrote:HAU? Appears to be the same as the HAAUS.
Taeyoung
02 Apr 2012, 11:40
Wow, they are great. :)
I really want one of them. :(
02 Apr 2012, 13:58
@yab8433408
8433408, what a coincidence, my lucky number!
Anyway, interesting, the stock art seems to be much more like the V80-5000. There's also the slant underneath the bottom row leading to the wrist rest that is much steeper. Could mean nothing. Could be just stock art. But maybe there's a version made with older molds after the V80-5000 and before the G80-HAAUS.
yab8433408
02 Apr 2012, 14:44
webwit wrote:@yab8433408
yab8433408
8433408,什么是巧合,我的幸运数字!
总之,有趣的,股票的艺术似乎是非常相似的V80-5000。还有导致更陡的腕托下方的底部行的倾斜度。可能意味着什么。可能只是库存的艺术。但也许是年龄较大的模具后的V80-5000和之前的G80-HAAUS版本。
坦白说 谷歌翻译的意识 我没看懂
02 Apr 2012, 15:08
^ G80 vs V80. The photo in the stock art also seems the have a steeper slant here. Also, the part labeled 3 seems weird. None of my 5000s have knobs/holes that slide into each other. And where is the connecting cable? The flat plastic piece that swivels at the bottom of the keyboard looks weird too. It's straight and not partly circular like the others. I wonder if it could slide together properly. And I wonder if this version really exists or only in stock art.
