Romer-g's breaking easily
boxboxbox
07 Mar 2021, 22:23
Has anyone else found it quite problematic to open up any of the Romer-g switches?
It's a bit of a hassle and I don't really know how to do it without completely destroying the bottom housing's clips.
[ XMIT ]
08 Mar 2021, 00:44
You should desolder them first.
micmil
08 Mar 2021, 00:57
You desolder all of them from the PCB, remove them from any mounting plate, then it's trivial to open them up without smashing them to bits.
If you can't be bothered to do that you're going to have a bad time. And smashed switches.
boxboxbox
08 Mar 2021, 12:40
I see, so even though they were designed with the intent of pulling the top housing without desoldering, they still break...
Thanks for the info!
[ XMIT ]
08 Mar 2021, 14:50
I have no reason to believe these were designed to be delidded in place.
micmil
08 Mar 2021, 18:44
boxboxbox wrote: 08 Mar 2021, 12:40 I see, so even though they were designed with the intent of pulling the top housing without desoldering, they still break...
Umm... no. Very extremely no. I'm not sure where you got that information but it's not correct.
wiki/Omron_B3K_series
The blue one illustrates rather well why this is the case. The clips that hold the switch to the plate are part of the top housing. Above the clip that holds the switch on the plate is an indentation where the lower housing clips in. If you compress the clips to remove the switch from the plate, it just holds the lower housing tighter. If you spread the clips it grips the plate tighter.
In other words, there's no way to remove the housing in situ. You'll have to desolder.
boxboxbox
24 Mar 2021, 00:35
micmil wrote: 08 Mar 2021, 18:44
Ah alright, noted!
