just another foot pedal (button board)
CeeSA
11 Mar 2021, 14:52
a foot pedal build for a friend again.
4 arcade buttons with Teensy++ 2.0 running Soarer's Controller firmware
before gluing.jpg (1.07 MiB) Viewed 17250 times
back 2.jpg (491.73 KiB) Viewed 17250 times
back 1.jpg (701.84 KiB) Viewed 17250 times
No painting, using felt instead. Non slippery and warming ;)
11 Mar 2021, 16:02
What’s it for?
The Teensy++ has me thinking this must be something with a huge config file, which needs that board’s larger RAM. I mean, they’re pricey compared to regular Teensy 2. But maybe you just had one lying around. ;)
CeeSA
11 Mar 2021, 16:32
Always for gaming.
You are right, just reachable for me.
Rayndalf
16 Mar 2021, 08:01
Is this for leaning in a game like Rainbow 6 Siege? I love to see the overlap between what were one tools created for accessibility and "DIY high performance" gaming. I purchased a footpedal from a retired piece of medical equipment, but I haven't gotten around to making it useful.
I mostly play CSGO or RTS games now, so I don't need additional buttons like I used to, but this is a really practical way to use cheap off the shelf parts and still get the spacing right.
CeeSA
16 Mar 2021, 21:47
I use it in HLL for
crouch, lie down , ping, sprint
for example. My friend uses it for "ping".
Real pedals are bad for digital actions. Slow and analog.
