New to Deskthority, need help
- Main keyboard: Razer Blackwidow W/Cherry Mx blue
- Main mouse: Logitech M720 Triathlon
- Favorite switch: White Alps
Hello everybody,
I'm not sure if this is the rigth place to ask, please feel free to tell me so. I'm new to Deskthority.
I have always been a fan of old keyboards, but where I live there is not much of a chance to see one.
Yet a few years ago, I was passing over an old bazaar store when I noticed a really old keyboard (I'll upload photos for you to see).
When I felt the clickly switches, I knew I just had to buy it!
It's an NTC Model KB-6251EA. Very heavy as it has a metal plate on top of the circuit board and it says "Zeos performance". It has white alps switches.
Unfortunatelly, it does not work. Or rather, it is glitchy. It registers "p" repeatedly as well as other numbers depending on what I press. So I left it for years in the closet untill I finaly decided today to do something about it.
I took it to an electronics expert and he told me after analysing it that it was the CPU chip (or whatever it is called).
The CPU reads as follows;
"Intel P8749H
L2041120
21V Program
Intel (m) (c) 1980"
It has 40 pins and it was quite easy to slot off the board.
I've checked on ebay and there are a few "Intel P8749H" for sale. They are all 40 pins and look exactly like the chip on the keyboard.
But what worries me is that the second line (starting with L) is always diferent. By L line I mean;
"Intel P8749H
LXXXXXXXX
21V Program
Intel (m) (c) 1980"
I'm no electronics expert. I would like anyone who knows about these things to please help me. I was just wondering whether that "L" number is just a serial number. That is, if I was to buy such a chip would it work?
Please check the images. Sorry if I waffle on, and I hope I am not too confusing. I would really apreciate your help and advice.
Kind regards,
Crimsonpizza
"Intel P8749H
L2041120
21V Program
Intel (m) (c) 1980"
"Intel P8749H
LXXXXXXXX
21V Program
Intel (m) (c) 1980"
Kind regards,
Crimsonpizza
I highly doubt that'll work.
The chips are programable so only if you have flashed matchable firmware it could be saved with the original like controller, seems that's impossible to get the original firmware. But apparently there're other ways to make it to hook up to modern pc.
I'm definitely no expert tho, just my very personal understanding. Glad to see others chip in.
Thanks for your advice!
Sounds like we would have to find another option, if there is one.
- DT Pro Member: 0190
Could just be that your "P" switch is permanently on, so you could desolder that and if the "p" stops being output, the rest of it might work as well. It's fairly unusual for ICs to be bad, though you might look for bad capacitors though if there are any.
That's what I thought too! But sometimes it registers other characters from the start. And besides, the electronics expert told me all the switches work fine as well capacitors and resistors and what have you. Thanks a lot anyway!
But he could be wrong I suppose. But I would not know where to start checking.
Hi Hausen,
Great idea! The switch reads, "80206/8088". I'm not sure which one of these numbers represents AT or XT but I've tried both.
"8088" produces those weird repetive signals I've mentioned before, however, whenever I click caps lock, num lock, and screen lock the respective LEDs light up on the board. By they way, the setting was originally "8088" when I bought it.
"80206" produces no response at all, and when I click all the caps, num, scrn lk nothing lights up. It's as if the keyboard is completely dead on that setting.
I forgot to say that I bought this cheap USB converter, since I don't have a PS2 port on my laptop (I'll upload an image). I've tried this converter with other ps2 keyboards to make sure IT was not the problem and it works fine.
Wondering maybe it does not work with THIS particular keyboard?
I'm going to take this keyboard to another electonics expert to get a second oppinion and will let you all know.
Thanks anyway for your help!
Crimsonpizza
Crimsonpizza
- an_achronism
- Main keyboard: IBM 5150 Personal Computer keyboard (1981)
- Main mouse: Gigabyte GM-M6880X
- Favorite switch: Capacitive buckling spring (IBM F models)
The 8088 and 80206 are the Intel processors used in the original IBM Personal Computer (which used the protocol now often referred to as "XT", scancode set 1) and the later IBM PC AT (set 2) respectively. I have this one two of my keyboards as well; it's just a protocol switch. The one you most likely want is 80206 unless you're using it with a really really old PC.Crimsonpizza wrote: 20 Jun 2021, 01:31 Great idea! The switch reads, "80206/8088". I'm not sure which one of these numbers represents AT or XT but I've tried both.
Thanks for that! The currect setting is "8088". I'm sure the other setting (80206) gave me no response whatsoever. I'll check it again tho and let you a'll know.
- ifohancroft
- Main keyboard: ErgoDox w/ SA Carbon on Box Jades
- Main mouse: Razer Viper Ultimate
- Favorite switch: Beamspring
Take whatever I say with a grain of salt and someone please correct me if I'm wrong, but:
According to the wiki, an AT keyboard (the 80206 setting on your switch) should work with a PS/2 host with just a passive adapter, which you already seem to have.
Then the PS/2 can be converted to USB with a converter. The PS/2 to USB adapter you have, may be just an adapter, instead of an active converter, hence the reason why it's not working.
You can try to get an active PS/2 to USB converter and try it that way on the 80206 setting, or you can just get an XT AT to USB Soarer's converter from orihalcon over at eBay: https://www.ebay.com/itm/302711725609
It allows remapping and what not.
With the converter I linked, the keyboard should in theory work regardless of the switch's position. If it doesn't work properly with Soarer's converter or the keyboard keeps spamming a key, then for sure there is something wrong in the keyboard somewhere.
Sorry guys for the long wait, I have been very busy with other stuff.
With regards to the 80206/8088 switch.
As you know it was in "8088". I switched it to "80206" and... it sort of responded. I had notepad open and in it I got "111111..." but when I clicked backspace, and it actually deleted the 1's. Then I typed "h" and it gave me repeating "hhhhhhh....." then I typed "o" and got repeated "ooooo...." then I typed something else and... nothing, it stopped responding.
Then, I tried connecting and disconnecting the keyboard several times, clicking buttons here and there but I never got the same response. Rather, the computer went crazy every time. Opening windows and highlighting random icons in desktop. So I restarted the laptop.
Cheers!
Crimsonpizza
Cheers!
Crimsonpizza
Hi ifohancroft,
It might be an idea to get another converter. The problem is getting one here in Mexico, it's a bit of a hassle, not to mention expensive. At $40 US ($800 pesos) it seems more trouble than the keyboard's worth (I bougth it for 80 pesos by the way).
Just to give you an idea. 2 weeks ago I bought a refurbished Corsair K95 Vengeance (Cherry MX reds), for $500 pesos. So far, it works like a charm.
I'll have to check the local market tho, I might be lucky to find a soarer converter.
Thank you for your help, I really appreciate all the input.
I'll keep you all posted of any eventualities.
Cheers!
Crimsonpizza
Cheers!
Crimsonpizza
- Polecat
Sounds like the controller is working, or trying to. Looking at the closeup photo it's disturbing to me how dirty the PC board is. It's possible that all the crud around the components is causing erratic behavior. Seems like a good cleaning might be in order.
Hi Polecat,
True, it's pretty dirty. I was planning to do it after I got the keyboard working. But it may be the reason why it's not working. Won’t hurt to give it a clean, eh? I guess it’s time to whip these out!
Cheers!
Cheers!
- Polecat
Uh, the solution (pun intended) for this does not come in a spray can.
edit: I'm serious about this, you probably don't want any spray cleaner getting inside the switches, and certainly not the crud that gets washed off the PC board along with the cleaner. The right way is to unsolder the switches, separate the plate and PC board to get access to the whole thing, and carefully clean everything before reassembling. Yes, it's a lot more work, but that's the right way to do it.
- maxmalkav
- dye hard
Just contributing to this with my (limited) experience.ifohancroft wrote: 05 Jul 2021, 17:00
I have a couple of those same PS/2 to USB adapters, they are active and they are quite solid for the price. I have used them in plenty of Dell, Model M and other vintage boards, it's my favourite cheap kb adapter.
Unless Crimsonpizza has been very unlucky getting a defective one, that adapter should not be the problem.
- ifohancroft
Thank you! I thought active (to be read as adapters that actually do protocol conversion) PS/2 to USB adapters cost minimum like $20-30.maxmalkav wrote: 18 Jul 2021, 12:38Just contributing to this with my (limited) experience.ifohancroft wrote: 05 Jul 2021, 17:00
Hi Polecat, I have been busy and have not had time to see this thread much less to look at the keyboard. Thanks a lot for the advice. But that is a lot of work! I wonder when will I have the time and pacience to do this. But when I do I will post the images.Polecat wrote: 18 Jul 2021, 05:19 Uh, the solution (pun intended) for this does not come in a spray can.
Crimsonpizza
Hi maxmalkav,maxmalkav wrote: 18 Jul 2021, 12:38Just contributing to this with my (limited) experience.ifohancroft wrote: 05 Jul 2021, 17:00
I agree with you. I actually tired the adapter on another PS2 keyboard someone lent me to check if it was the adapter at fault, it worked just fine. So unless it is being problematic specifically with the Zeos Keyboard, I think the daopater is not the problem.
Thank you all for your advice, I really apreciate it!
Cheers
Hi everybody,
It's been a while but I thought I'd let you know how this will end. I decided to just remove the switches, might come in handy in the future. The coiled cable was good and thick, I cleaned it and currently unsing it on my model m. I'll throw away the rest of the board. Not sure if there is anything else I can salvage.
I'd like to you thank you all for your good suggestions and you being disposed to help me out.
Keep safe! And maybe in the future I'll come bothering you again.
Cheers!
Cheers!
Here's the epilouge.
- IMG20220816152151.jpg (2.47 MiB) Viewed 33125 times
