[CANCELED] Wooden Filco MJ2 TKL Case
- Main mouse: Mickey
Woohoo! I had a feeling this would show up here! Sorry about the rollback at GH nuking your last post. Glad you seem to have kept a copy.
- Icarium
- Main mouse: opened my eyes
Very nice. Would this fit the Phantom?
For everybody else you might be wondering, the Filco MJ2 TKL costs 95 GBP ~= 120 EUR at the Keyboard Company.
- guilleguillaume
- Main keyboard: Kmac Mini
- Main mouse: Razer Abyssus 2014
- Favorite switch: Topre
Fantastic! Thanks for opening the thread here. Geekhack is so unstable.
Ebony wood is quite expensive but it looks so good...
Walnut needs at least 4 orders to happen then?
- guilleguillaume
Went back from work so now I have time to post
Those close up pictures from space between wood and keycaps show that your work is fantastic and very detailed.
I show my interest in Ebony wood because it looks too awesome to pass on it. Sanctuary set would look impressive on it
- Game Theory
- Mr. Despair
- Main keyboard: Majestouch Convertible 2 or Beam Spring 5251
- Main mouse: Logitech G900
- Favorite switch: MX Blue in terms of MX
- DT Pro Member: 0008
I really like the olive too.
- Main keyboard: Filco TKL Black
- Main mouse: Logitech G700
It looks SO amazing! Unfortunately I don't know that I can be your fourth member. Not just for now anyway, I simply don't have the resources.guilleguillaume wrote:Went back from work so now I have time to post![]()
- gothic860
- Main mouse: Razer Mamba 2012
If you like it dark i can also offer you something like:
http://www.google.com/search?hl=de&cp=7 ... 4QSGqPWRCQ
Its fumed oak. About +30€ per case.
The link doesn't work for me, just sends me to the German Google homepage.gothic860 wrote:If you like it dark i can also offer you something like:
http://www.google.de/search?hl=de&cp...Ho_U4QSzlITOCQ
Its fumigated oak. About +30€ per case.
- guilleguillaume
Can I ask you to make a proper render like you did with the other types of wood?gothic860 wrote:If you like it dark i can also offer you something like:
Those renders are really useful to see what the final product would look having in mind that it's natural wood and final result may change a bit.
The price makes it more affordable and looks quite similar. I like the idea because it would be easier to reach 4 users if it looks like macassar ebony but it's cheaper.
While I said that can't afford it, I simply mean right this instant. I'd be able to afford it a while from now; I just don't want to over commit myself and end up not having enough money when it comes time to pay. Depending on when this runs I may very well be able to afford it.guilleguillaume wrote: Can I ask you to make a proper render like you did with the other types of wood?![]()
- Main mouse: G700
- Favorite switch: Brown
I Have a few questions:
What would Teak (Das Teak) cost?
How about Brass Torx screws ( das Messing)?
Modification: Mini-USB connector build into the case?
Oil/stain (öl/die Beize) finish?
Do you do full size Filco? (with num-pad)
I write here a I think others will be interested.
- gothic860
Hey,What would Teak (Das Teak) cost?
Teak: I think we have a little stock here. I will update the list with the renders, prices and so on later today and add the Teak (no minimum orders required!). Price should about the same as Olive = +50€
Brass Torx screws are possible but we don't have a stock here so -> we need some more interests (or +€)
Mini USB connector: Not possible for me. You can make your own stuff with the cable and i can mill a hole for it, but nothing more. For a normal adapter there isn't enough space.
Oil/stain finish isn't possible -> see READ FIRST (keycaps scratching).
No full size Filcos at the moment.
- gothic860
With fumed oak there are no minimum orders required! I will update add the renders later today.The price makes it more affordable and looks quite similar. I like the idea because it would be easier to reach 4 users if it looks like macassar ebony but it's cheaper.
- Main mouse: G700
Thank you for the prompt response.
Let us know when you do full Size Filco please.
I really find it difficult to understand that if some one sends you their keyboard; you can solder the USB cable but can not solder a mini USB connector. It Sounds to me, to be exactly the same work. Which is really sad for us, especially considering the high price. Are you sure we could not convince you
- gothic860
Im no soldering pro. It worked well for me, but if you want a connector just do it on your own. If you don't like the price don't buy it
(its a fair price for that work, trust me. If you order this from a normal joiner you have to pay much more.)
- Main mouse: G700
Sorry, I assumed that soldering was "easy" for you, since you offer a build service. I do not yet own a good Soldering Iron, so I was hoping there might of been a way to convince you to do it for me. Guess I would have to do it my self
Well it would be a good learning experience for me
I know it is a lot of work and didn't mean to belittle your efforts. High price referred to that fact that the case is almost twice the price of the Keyboard not that it is high for the amount off work. I hope I have not made offense.
- gothic860
Im a joiner and no electrician :p. So solder a USB-cable is no problem but I'm sure someone else here knows more about it then me.Sorry, I assumed that soldering was "easy" for you, since you offer a build service.
- Maarten
- Main keyboard: Mr Unbreakeyble
- Main mouse: Kova+
- Favorite switch: any MX
First of all, some great products you have here! One just has to love that combination of modern-day technology combined with purdy wood!gothic860 wrote:Im no soldering pro. It worked well for me, but if you want a connector just do it on your own. If you don't like the price don't buy it(its a fair price for that work, trust me. If you order this from a normal joiner you have to pay much more.)
If you'd like a partner in crime for EU-based assembly (including soldering and mounting type-B or mini-USB receptacles to your cases) please let me know, maybe we can work something out!
