Topre Cluster Tester, Round 2 : Worldwide!
This is where the older threads are stored for the try before you buy ( sinklist ) items
Mrinterface
14 Jun 2012, 21:45
START OF WORLDWIDE TOPRE TESTER TOUR
Managed by : scope2k
Subscription starts : 22-1-2013
Subscription ends : 22-2-2013
If you want to participate, PM scope2k your name and address, he will manage it from there.
NOTE : the sinklist manager will guide the process for you, he will tell you what to do and what he needs from you.
The Topre testers consists of :
1. Normal Mrinterface TopreTester
2. A special TopreTester , a Topre key without the spring ( which is only used for the electrical function )
A SurpriseBag will be shipped with the sinklist item. If you like something that's inside, you are allowed to swap it for something equal in value, preferably more so the total value of the bag increases. The contents of the bag are for the sinklist manager so he can be rewarded for his efforts.
THIS IS A TEMPORARY THREAD. A NEW ONE WILL BE MADE BY THE SINKLIST MANAGER!
The following info is old. This topre cluster is lost in the mail. A new one has been made.
After some tough work and many lessons learned , I finally put together 4 topre keys in a cluster :
This was a bitch to align and therefore it was not a very tidy job, but the result was pretty OK. It gives you a very decent Topre keyfeel. I did not put the spring of one keyswitch in, so you can get a chance to feel the topre without the spring so you know how much of the keyfeel is being generated by pure rubber :-)
These are 55g switches.
As of today 14-6-2012, I will take participants for this try before you buy item.
It will be sent out 25 June 2012 to the first one on the list.
This list is a worldwide list, so its not restricted. I will shuffle the list before I send this one out so the amount of bordercrossings is minimal ( so there is no FIFO! )
ROUND 1 Participants ROUND CLOSED :
Ascaii ( Germany )
Fossala( UK ) ( REMOVED )
Trax ( Belgium )
Nathanscribe ( UK )
Hoggy ( UK )
TheDuke ( Germany )
RC-1140 ( REMOVED )
Kaen ( UK )
mhinsch( UK )
dfxdx ( UK )
cowabunga( Germany )
carter ( Germany )
usopia( Germany )
zeeko ( Germany )
Igro ( Sweden )
Rafen ( USA ) ( REMOVED )
postlapsaetia ( USA )
koralatov ( UK )
Zehkul( Germany )
Djuzuh( France )( REMOVED )
Trent ( USA ) ( Tipo33 )
ROUND 1 Participants Sorted List:
Ascaii ( Germany ). 25-6-2012 : ONROUTE
TheDuke ( Germany )
carter ( Germany )( REMOVED )
usopia( Germany )
zeeko ( Germany )
Zehkul( Germany )
Trax ( Belgium )
Nathanscribe ( UK ) RECEIVED
Hoggy ( UK ) RECEIVED
Kaen ( UK ) RECEIVED
mhinsch( UK ) RECEIVED
dfxdx ( UK ) REMOVED ON REQUEST
koralatov ( UK )
Igro ( Sweden ) Removed on request
postlapsaetia ( USA ) Removed on request
Trent ( USA ) ( Tipo33 )Removed on request
ROUND 2 , WORLDWIDE PARTICIPANTS LIST :
oyecomova ( USA )
rafen(USA)
igro
15 Jun 2012, 02:03
Sign me up :)
Sweden
Rafen
15 Jun 2012, 03:18
Sign me up
U.S.A.
postlapsaetia
15 Jun 2012, 03:28
I'd like in!
USA
nathanscribe
15 Jun 2012, 11:31
Good to see this come round. Of course, if I like them, it's going to cost me a lot more than a little postage...
cactux
15 Jun 2012, 11:52
Charlie_Brown_MX
15 Jun 2012, 12:36
Add me to the list too, please.
Mrinterface
15 Jun 2012, 19:39
cactux wrote:How hard do you think is to make keychains from spare Topre switches?
To make a keychain you'd have to attach the keychain bit to one of the screws. So, not hard....
trax
20 Jun 2012, 19:18
What version is this? 45g?
Mrinterface
20 Jun 2012, 19:24
55g. Updated OP with this knowledge.
trax
20 Jun 2012, 21:34
I'm in then :D
Never tried those and I think Ill like them more.
RC-1140
20 Jun 2012, 21:52
Probably you can take me off the list, as I have now enlisted in the Realforce Euro Tour.
Mrinterface
20 Jun 2012, 22:39
RC-1140 wrote:Probably you can take me off the list, as I have now enlisted in the Realforce Euro Tour.
Fixed that.....
Zehkul
22 Jun 2012, 23:37
Topre! Just the wrong time of the year. Anyway, I’m in!
Djuzuh
23 Jun 2012, 00:07
I'd like to try them !
France. But If possible I'd like either a french or a german guy to send it to, as I'm 10km from the german border away. I can just go on the other side to send it off.
Mrinterface
24 Jun 2012, 12:20
@zehkul : location?
Djuzuh
24 Jun 2012, 12:20
Zekhul comes from germany.
Mrinterface
24 Jun 2012, 12:22
Yeps, I just found that out.... He's on the other list as well :-)
Trent
24 Jun 2012, 23:20
Count me in! (USA) I can also show tipo33 since we live an hour away from each other
Mrinterface
25 Jun 2012, 18:09
First round CLOSED.
It's off!
First one on the list : ASCAII!
postlapsaetia
26 Jun 2012, 03:51
This started faster than I though it would. Hell yeah.
Ascaii
The Beard
29 Jun 2012, 17:49
Hi there! received the cluster today, sending it out Monday again.
I had a spare KBC box and some foam left over, so I made a fitted box for the cluster. Should travel a lot safer now. I will take some pics later.
MrInterface, please let me know who number 2 is and where to send it. Fossala or Trax?
igro
29 Jun 2012, 18:00
Ascaii wrote:Hi there! received the cluster today, sending it out Monday again.
Should it not be TheDuke (following the sorted list)
Mrinterface
29 Jun 2012, 20:22
Yes , follow the sorted list. I'll make it more clear....
Ascaii
The Beard
02 Jul 2012, 13:18
theDuke pmed for address.
I recommend removing the cluster from the box for testing, as the bubble foil is not a suitable surface for testing.
TheDuke
02 Jul 2012, 14:22
Sorry for the delay but I forgot this topic. PM send to Ascaii :)
postlapsaetia
08 Jul 2012, 02:40
Any updates?
Mrinterface
09 Jul 2012, 13:41
Yes, any updates?
oyecomova
09 Jul 2012, 17:03
Sign me up, please. Wash DC, USA.
Thanks_!
Mrinterface
09 Jul 2012, 17:09
Welcome. Added.
Return to “Sinklist Archive”
