These came off of an RGB Desko keyboard. the green shifts are dye sub, but the Control and Alt keys are surprisingly double shot keycaps. The blue ones are a little faded.
Worthy for the banner?
Cherry Double Shot Ctrl and Alt-lores-1.jpg (175.64 KiB) Viewed 45039 times
the original shot has the keycaps on the left side, so there isn't a lot of room to crop the caps to the right. I will need to retake the picture. Here is a crop to the banner size. Also posted on the banner thread:
Looks like the blues were very similar, from the underside of it but maybe a slight bit different as abs and pbt colors never seem to be 100%. Very nice find though, had no idea they ever even made them like that officially too bad the shifts weren't doubleshots too.
litster wrote:These came off of an RGB Desko keyboard. the green shifts are dye sub, but the Control and Alt keys are surprisingly double shot keycaps. The blue ones are a little faded.
Translation:
Dragon Bro, how are you? Long time no talk.
These RGB keycaps came from a Desko keybaord. They should be dye sub. But unexpectedly this Desko keyboard's red control and blue alt keys are double shot. The green shift keycaps are still dye sub.
The red and blue keycaps' colors has faded. So the colors you see in the picture is not reliable.
