Double-Shot Cylindricals for ALPS CM
- 7bit
- Favorite switch: MX Lock
- DT Pro Member: 0001
This poll is about cylindrical key caps for ALPS switches!
In this group buy, Standard kits should be available as a complete kit or in parts, containing:
- 1 unit keys for 10-key less boards,
- numpad keys,
- function keys,
- modifiers,
- return keys (m, J, L),
- space bars
In addition, there will be at least the following national layouts available:
AT, DE, DK, ES, FI, FR, IT, NO, SE, SI, Colemak, Dvorak, Mac, Win, ...
If you don't find your dream color, please suggest what you would like ...
- numpad keys,
- function keys,
- modifiers,
- space bars
- escom_focus_3001_101.jpg (248.46 KiB) Viewed 6932 times
Swede
- Main keyboard: KBC Poker
- Main mouse: Mionix Naos
- Favorite switch: Cherry Red
Thinking of changing layout on the Ortek i've bought, It's german ISO which is identical to SE layout exept 3 keys.
And I have another Alps board with worn and ugly keys, this is an original SE layout.
Will not change layout on the Poker, why would I when it's dual layer and ANSI?
- 7bit
Yes, they will be available in the same group buy.Swede wrote:I'm interested in some white keys with red text.
Is this groupbuy included in the cherry buys?
Edit: make that two, one tenkeyless, one normal, SE layout
If you don't stop spamming you will get no Roller Mouse![1]runeazn wrote:what's that switch for?
same switch like on the VorteX?
chaning layout?
These key caps are for ALPS switches!
[1] You won't get it anyway, because it is mine already!
Pylon
- Main keyboard: Dell Latitude E6410
- Main mouse: IBM MO28UOL and E6410's Trackstick
- Favorite switch: White Alps and Scissors
How are you going to deal with stabilizers? That might be an issue on the extended keys because most Alps boards probably use different ways to attach them.
Pylon
Also you need to deal with a number of different Return/Backspace/Backslash configurations...
Standard ANSI (AT101/W, Leading Edge, AEK/II, Filco Zero, ABS M1, Matias Tactile Pro, etc.)
Large L-shaped Enter + Large backspace + small backslash next to right shift (Omnikey, FK-2001, several other Taiwanese Alps, others)
Large L-shaped Enter + Small backspace + small backslash (ASK-6600, Chicony KB-5181, and others)
Bottom row is also an issue. You need 1.5x Alt and Ctrl, possibly backslash and * (present on a number of Alps boards on bottom row), and 1.33x Ctrl, Alt, and win for AT101W and the other Windows boards. As for AEK/AEKIIs, you need 1.5x on Ctrl and Option, and 1.33x Alt.
- 7bit
Bump!
Because Round 3 stuff starts to ship in a few days, I want to bring this up again.
Round 4 will start immediately after the majority of Round 3 key caps have shipped, which will be at end of June.
Please post you ideas of what you would like to have here, or set up your own thread.
tjweir
- Main keyboard: 75% with Vintage MX Blacks
- Main mouse: Logitech something
- Favorite switch: Vintage MX Blacks
A picture of what? A Filco Zero?7bit wrote:I did not find a picture. Can you please post one?tjweir wrote:My Zero would love a set on non-boring cylindrical caps.
Mine is just like this - http://www.flickr.com/photos/takkphotos/4863186616/
