keyboard boxes
xbb
09 May 2011, 01:38
I'm looking for keyboard boxes, any advices?
We have rajapack here in italy but does not have any box with interesting size.
rajapack.de and .nl have the good sizes but does not ship around europe.
Know any alternatives?
sixty
Gasbag Guru
09 May 2011, 22:17
I had been looking too for a longer while. Sadly there are no alternatives to the rajapack ones. Why do they not ship to you, though? I once contacted them before they had the Keyboard ones on their German site and they were more than willing to ship them to me from the Netherlands.
09 May 2011, 22:26
I've been heating the house last winter with all the paper spam rajapack has sent me.
Nice boxes though.
xbb
09 May 2011, 22:33
ahhhhhhhhhh I want it!! :(
.nl said me they ship only to BENELUX
.de just germany
xbb
09 May 2011, 23:03
Anyway for anyone interested you can order those boxes from every rajapack site except Spain, Italy and UK. Code is BOR50.
xbb
10 May 2011, 11:20
Ehm I've sent some mails around. France is able to ship somehow around... but minimum order price is... 350€! I just want some boxes... damn :(
mintberryminuscrunch
03 Jun 2011, 22:18
anyone willing to organize a MO?
03 Jun 2011, 22:30
No minimum order limit here, but if you order for less than € 250 you pay € 15 shipping. Above that no shipping costs. The problem with sending these around unfolded is that they are bulky.
xbb
03 Jun 2011, 23:18
I managed to buy them from rajapack italy (they ordered from france rajapack for me).
The bad thing is that the courier damaged them, there were actually holes on both side of the package so about 10 boxes became useless! (I ordered 40)
MO I dont know... It's not so easy to repackage them well unless you have the tools to do that.
03 Jun 2011, 23:34
Heh, I had the same thing..about 10 damaged.
spolia_optima
06 Jun 2011, 19:41
I never skimp on archival boxes.Spending an extra 25 cents per box and you are left with storage that will seriously last.
I go through a local box recycler. They're a bit more pricey, but I gotta support the local economy when possible.
Half-Saint
28 Jun 2011, 08:19
Webwit, can you give us the inside measurements of the boxes you got from Rajapack? Thanks.
28 Jun 2011, 22:28
52cm x 25,5cm x 7,8cm.
Half-Saint
29 Jun 2011, 08:41
I can't seem to find a box with such dimensions on Rajapack UK :(
02 Jul 2011, 00:20
Half-Saint wrote:I can't seem to find a box with such dimensions on Rajapack UK :(
http://www.rajapack.de/produkte/postver ... igibox.htm
Just search for BOR50
mobile
xbb
02 Jul 2011, 01:11
they haven't them in UK and others will not ship to there.
Only .fr can but they have a high minimum order price.
What you can try to do is ask UK to order from FR for you. I was able to do that with .it
02 Jul 2011, 22:02
xbb wrote:they haven't them in UK and others will not ship to there.
This is confusing! :?
Why don't we organise a group buy from the least expensive site and then distribute the boxes ourselves?
webwit wrote:52cm x 25,5cm x 7,8cm.
Edit: Don't they've got boxes for G80-2100 & friends?
xbb
02 Jul 2011, 22:19
My G80-2100 fits inside :)
Group buy is difficult unless someone is able to repackage them, they are big and they can be damaged easily.
I could not find any other source (online) here in italy.
02 Jul 2011, 23:02
xbb wrote:My G80-2100 fits inside :)
Its' so simple: First we've got to find a box manufactuer which makes boxes into which the keyboard boxes fit.
I know it would fit tight, but it won't fit including the original box. Also, the IBM 122 key terminal keyboards won't fit, same for so many other keyboards of that calibre...
xbb
02 Jul 2011, 23:08
Yes the G80-2100 fits tight.
Rajapack makes also custom sizes but they require a big minimum quantity.
02 Jul 2011, 23:15
I think your best bet is a local or near box supplier/maker. I remember when I searched for boxes, there were various near me, also for small quantities.
03 Jul 2011, 07:08
The seller of these:
http://cgi.ebay.de/ws/eBayISAPI.dll?Vie ... 0491788920
unfortunately excludes shipping to inter alia Italy.
The original G80-2100 box fits nearly exactly into them, leaving just enough room for a kind of inside lining made out of hard material, which would be necessary at least in the corners because the cardboard used for the box is quite thin.
Half-Saint
05 Jul 2011, 22:55
I wanted to order custom made boxes locally. Size is exactly the same as the boxes that Unicomp uses to ship keyboards.
Unfortunately I'd have to order 50+ boxes to get a price of about 3euro per box...
05 Jul 2011, 23:11
Cardboard boxes are like keycaps. In small series they are expensive, in large series very cheap.
20 Oct 2011, 11:12
Moar boxes!
xbb
20 Oct 2011, 11:50
any broken?
20 Oct 2011, 12:00
Much better packaging and handling this time.
ripster
21 Oct 2011, 01:17
Why don't they use their own products?
21 Oct 2011, 01:42
Box fetish FTW.
ripster
21 Oct 2011, 05:57
Tell those Keyboard Company people to get a better sticker printer!
Elitekeyboards did it better!
Return to “Off-topic”
