Some stuff I found
Ascaii
The Beard
09 May 2011, 16:17
First off...heavy metal:
it opens!
hmmm what switches could it be?
white alps under an Alps branded protective membrane...interesting^^.
Sadly, the membrane does reduce the crisp tactile feel of the white alps considerably.
thoughts:
This is a tank. First thought: I can beat someone to death with it. After googling, it turns out I actually could. This sucker is designed to withstand 3G in use and up to 20G in storage position. The case is made from a cool aluminium alloy titled 6063-T6.
Thank you wikipedia:
Chemical composition
The alloy composition of 6063 is: [1]
Silicon minimum 0.2%, maximum 0.6% by weight
Iron no minimum, maximum 0.35%
Copper no minimum, maximum 0.10%
Manganese no minimum, maximum 0.10%
Magnesium minimum 0.45%, maximum 0.9%
Chromium no minimum, maximum 0.10%
Zinc no minimum, maximum 0.10%
Titanium no minimum, maximum 0.10%
Other elements no more than 0.05% each, 0.15% total
Remainder Aluminium
woot, titanium keyboard. Now i need the titanium caps to go with this board.
Second find:
GSE KPT-84
keyboard cover <3
and the switch:
thoughts on it...this board is louder then my 1987 Model M. Love the clicky keys, though I don't like the way the spacebar feels. Not sure if I will keep this one, might throw this one on the market.
Magna224
09 May 2011, 17:01
Wow, those are sweet! Where did you happen to find them?
nathanscribe
09 May 2011, 17:10
Nice! Makes my Toughbook look like Playmobil.
09 May 2011, 17:28
Ascaii wrote:..
Image..
Great find!
Interesting to see that there exits a spill-proof mechanical keyboard.
Is it just keyboard and monitor or is it a complete computer?
ps: I hope you made sure no one stood underneth your window .... not that it slips down and ... :shock:
Ascaii
The Beard
09 May 2011, 17:48
it would be a full computer, but I only have the case, flatscreen-monitor, and keyboard. Ive been daydreaming about modding it a little and building a mitx rig into this this... but that would be a good bit in the future, way too busy at the moment.
Swede
09 May 2011, 19:13
Funky layout on the GSE, how do the switches feel?
I wonder where that computer was designed to be placed, looks like it's made to military specs?
Ascaii
The Beard
09 May 2011, 20:02
Swede wrote:Funky layout on the GSE, how do the switches feel?
yep milspec of course. "rugged portable workstation"
switches feel great, tactile bump and click like a model m. Actuates a little tiny bit higher if im feeling this right. Only beef I have with this board is that the space bar tends to stick if hit off center. maybe some lube in the stabilizer will help.
JBert
09 May 2011, 22:58
What happened to the computer? The case seems large enough to fit one in...
Ascaii
The Beard
09 May 2011, 23:02
JBert wrote:What happened to the computer? The case seems large enough to fit one in...
good question. previous owner only had the case as it is.
i tend to believe the original owner had no interest in civilians snopping through the hard drives XD
runeazn
09 May 2011, 23:18
nice multitool :)
SOG?
09 May 2011, 23:26
Ascaii wrote:The case is made from a high tech aluminium alloy titled 6063-T6.
That is actually a common aluminium alloy for machining. Not really exotic. A great material, though. I have done several trinkets in it, by hand, as I haven't had access to fancy machines.
Brian8bit
09 May 2011, 23:33
You know now that you've got it, you're going to have to find somewhere that'll let you take the computer onto a G-Force centrifuge so you can see if it (or you) can work at 3G+
10 May 2011, 00:00
The first one is one of those boxes astronauts carry with them into the ship. I always thought their lunch was inside these.
Pylon
10 May 2011, 00:10
What switch is that on the KPT?
ripster
10 May 2011, 02:32
KPTs.
Hah, I keed.
I think they were a clone labeled precursor to Alps Simplified 2s (XMs) but Ascaii would have to open up to confirm.
SPROING!
Ascaii
The Beard
10 May 2011, 07:22
ripster wrote:KPTs.
Hah, I keed.
SPROING!
XD
I know myself well enough to know I wont be opening the switches up...I weould lose half of it in an instant. By the way does anyone have 1 cherry clear spring they could send me? I took apart a clear switch and sproooooooooing, it was gone. :(
So...buy my keyboard and check yourself ;)
Ascaii
The Beard
12 May 2011, 11:56
update:
Marquardt MiniErgo
On a side note...I need to sell some boards, my place is starting to look like sixty's place.
xbb
12 May 2011, 12:00
very nice one :) how does it feel?
Ascaii
The Beard
12 May 2011, 12:14
xbb wrote:very nice one :) how does it feel?
Considering I've been using BS and blues for the past few weeks I miss the tactility a lot. The ergonomic positioning of the hands is nice and I think I could get used to it if i force myself to. Fact is im simply too lazy to do that^^. They feel close to cherry blacks.
xbb
12 May 2011, 12:30
possible to replace them with cherrys? Should take a look at the PCB :D
sixty
Gasbag Guru
12 May 2011, 16:27
Marquardt switches sadly do not age very well. For some reason they seem to be very open (hah- literally) to dust introducing the switch case. The ones on mine make nasty noises by now.
daedalus
Buckler Of Springs
15 May 2011, 13:30
How feasible would it be to replace them with Cherry switches?
