My experimental setup ~dual widescreens in portrait mode
Superfluous
17 May 2011, 11:02
I assume this is on topic on this forum...
I got some new monitor arms that support rotating the screens, and it looks completely ridiculous :lol: Check it out:
Those are 21" screens @ 1050 x 1680, and you could make the case that rotated like this they're just too high. I'm fiddling with the height to see if it can be made to work. For now, I especially like the layout for code work (horizontally split emacs screen) and it actually makes some sense to have browsers / documents in this layout too.
Other interesting factoids: I'm running Debian with the i3 window manager on Xorg/nouveau where you can change the rotation on the fly using something like "xrandr --output 'name of display' --rotate left".
Gilgam
17 May 2011, 13:06
Looks odd but maybe useful
you're running debian on a i CPU and it does support double screen and rotating ...
Very nice
By the way what is your trackball ?
Superfluous
17 May 2011, 14:33
The trackball is a Kensington Expert Mouse 4. It's OK, not great, but it's extremely hard to find a great trackball.
What did you mean by "i CPU"?
Gilgam
17 May 2011, 15:09
i3 cpu
must have forgot to type strong enough the 3
I just have one screen on may steup but i plan to add another one, it's an ubuntu/debian double boot machine and double screen support is a ust have ;-)
Superfluous
17 May 2011, 15:27
I'm not using an i3 CPU; it's a Core2 Duo. i3 in my post is the name of a window manager. IMO one of the best tiling window managers out there.
Gilgam
17 May 2011, 17:05
i3 a WM, i knew openbox, WMFS, even openstep but that one i didn't...
I'll try it thanks for the advice
HaaTa
Master Kiibohd Hunter
17 May 2011, 17:44
Nice setup. I've been using it at work since mid-January. I'd prefer 3, but I'll bug IT later for that.
I use Awesome WM with Arch Linux in general (this pic was taken right before I wiped IT's version of Windows 7).
Along with my Desko with modified Zenith cupped double-shot keycaps and my CST L-Trac (3200 DPI).
I use the R600 drivers for the opensource ati driver.
ripster
17 May 2011, 17:52
This works. Porn in the center. Browsing in the right.
U3011 and ancient FP2001
Gilgam
17 May 2011, 19:38
ripster wrote:This works. Porn in the center. Browsing in the right.
And Windows in the bottom ;-)
ripster
17 May 2011, 20:01
No, that's my Realforce 87U on the bottom.
keyboardlover
17 May 2011, 20:04
The fact that you watch porn with that desktop background disturbs me.
ripster
17 May 2011, 20:11
How about this one?
Furries in the center. Panda-r posts on the right. Naked woman poster above the monitor. Who KNOWS what's going on underneath.
NewGuy
18 May 2011, 21:58
I'd definitely recommend selling the pair for a single 30" 2560x1600 monitor if you can. You don't have the issues associated with multi-monitor setups, the subpixels are properly oriented, so things look better. Only then, once you need more space than that, would I go multi-monitor. (and either do what Ripster has done, or get a second 30")
Rotlaus
19 May 2011, 13:16
NewGuy wrote:I'd definitely recommend selling the pair for a single 30" 2560x1600 monitor if you can.
1x30" costs > 1000€, 2x22" >220€. I see there a problem for the financially challenged.
CeeSA
21 May 2011, 17:18
@Superfluous - why so high?
neckbreacking setup ;)
Superfluous
24 May 2011, 07:55
It's a standing setup, and in my experience, I like the monitors a little higher compared to the desk top when standing. Though I did move the monitors down a little after I took that picture.
igro
28 May 2011, 19:45
Superfluous wrote:I assume this is on topic on this forum...
Framfab was iconic for the legendary IT bubble :)
Jim66
01 Jun 2011, 01:46
HaaTa wrote:Image
Love the wallpaper, did you make it yourself?
01 Jun 2011, 01:54
guilleguillaume
01 Jun 2011, 12:29
¿Webwit is this your setup? Looks super cool. :ugeek:
01 Jun 2011, 13:15
Multiple
02 Jun 2011, 03:44
Here's another one
Jim66
04 Jun 2011, 15:40
Multiple wrote:Here's another one
Mmmm, uTron..
