Free keycap set for 1500th post (ended)
05 Feb 2011, 15:40
Win one of these keycap sets!
The poster of the 1500th post wins a Topre keycap WASD/ESC set or an IBM RGB set (winner's choice). Shipped worldwide.
No flooding please!
You can check the number of posts at the bottom on the frontpage under Statistics.
EDIT: This contest has ended. Congrats bugfix!
05 Feb 2011, 15:48
I will take the IBM key caps!
Thanks!
05 Feb 2011, 15:50
Now you only have to write 608 posts before someone else notices!
05 Feb 2011, 15:52
I hope my auto-post-script will be ready in time:-)
keyboardlover
05 Feb 2011, 16:14
Time for some EPIC trolling... ;)
bugfix
05 Feb 2011, 16:17
I should get one because I was your first real user ;)
Ascaii
The Beard
05 Feb 2011, 16:19
bugfix wrote:I should get one because I was your first real user ;)
pah^^
heres to my new model m keyset!
Minskleip
05 Feb 2011, 16:23
Bra tiltak!
Who made the IBM set? Does the CTRL/ALT keys fit on the Customizer?
bugfix
05 Feb 2011, 16:28
Minskleip wrote:? Does the CTRL/ALT keys fit on the Customizer?
CTRL and SHIFT will fit, ALT will not.
05 Feb 2011, 16:29
Unicomp made them.
bugfix
05 Feb 2011, 16:30
Woops I thought they were the ones you posted earlier...
Minskleip
05 Feb 2011, 16:30
Ah, thanks. Good reason for whoever gets the set to get a Model M or 101 Customizer then :D
05 Feb 2011, 16:38
bugfix wrote:Woops I thought they were the ones you posted earlier...
They are.
bugfix
05 Feb 2011, 16:39
webwit wrote:They are.
So they don't fit a 105 Customizer?
05 Feb 2011, 16:41
I'm afraid they still don't fit ;)
sixty
Gasbag Guru
05 Feb 2011, 17:18
spam moar!
bugfix
05 Feb 2011, 17:19
You bet.
sixty
Gasbag Guru
05 Feb 2011, 17:24
What happens if we win, btw? :o
05 Feb 2011, 17:25
Wasn't that the whole idea?
05 Feb 2011, 17:48
They'll be not yours, anyway. They fit my 1989 model M perfectly, so it is clear that I will get them!
sixty
Gasbag Guru
05 Feb 2011, 17:50
freekeycaps.pl? 8-)
cheaters will receive coal instead.
Minskleip
05 Feb 2011, 19:16
On the subject of polish: keycap nipple piercings 8-)
How can one cheat if not camping the 1500th post?
sixty
Gasbag Guru
05 Feb 2011, 19:32
Minskleip wrote:On the subject of polish: keycap nipple piercings 8-)
have a script running that camps it for you :P
7bit has like half of his geekhack activity running on auto-pilot. i don't trust this man!
05 Feb 2011, 19:35
Show us a picture of your keycap nipple piercings and become an instant winner of this contest.
Minskleip
05 Feb 2011, 19:57
Out to find some powertools ...
I'm fascinated with 7bit's Geekhack automation
sixty
Gasbag Guru
05 Feb 2011, 19:59
Minskleip wrote:Out to find some powertools ...
Its really cool. Especially if you are subscribed to the voting newsletter. His script even emails you a copy of the results every 12 hours or something. I think he parses the "new pm" notification emails and runs the script based on that.
Minskleip
05 Feb 2011, 20:08
Yeah I know, I get his emails every day. Does he use curl or something and then discard all the irrelevant html? Or mayhe he use one of the modules on Cpan to create a stateful "web fetcher" and ditto..
Ah yes the notification emails. Then it's quite easy if he is using his own mail server. Just setup a pipe in .forward to his script.
sixty
Gasbag Guru
05 Feb 2011, 20:10
Maybe he will arrive here soon to tell us how it works if we spam some animated gifs.
05 Feb 2011, 20:18
function fetch_remote_page($url)
    $contextOptions = array(
        'http'=>array(
            'method'=>"GET",
            'header'=>"Accept-language: en\r\n" .
                "Cookie: bbuserid=<yourid>; bbpassword=<your hashed password, see your cookie>\r\n"
    $context = stream_context_create($contextOptions);
    return file_get_contents($url, FALSE, $context);
..then preg_match the hell out of what you receive
ynih
05 Feb 2011, 21:19
Only 600 more spam posts to go! woot
Locked
Return to “News”
