Hi all,
Does anyone know of keyboards with non-removable keycaps? Something that kids wouldn't be able to mess with. I know there are vandal-proof keyboards but they seem to be quite pricey, £180+, mainly because they're also weather proof and industrial. Also it doesn't need to be mechanical.
Thanks for any info,
Chris
Keyboard with permanent keycaps
- cookie
- Main keyboard: HHKB Pro 2
- Main mouse: MX Master
- Favorite switch: Topre
Never heared of such a keyboard.
Concidering how hard it is to remove a keycap with bare hands, a drop of superglue should do the trick!
If you want to be on the safe side, I'd use two component epoxy glue.
You could buy a dell at102w (verry cheap), Alps keycaps are pure horror to remove, they naturally fit verry tight but with a drop of glue into the slider hole, it should be impossible to remove. They are also build like a tank and have a backplate, it should be impossible for a kid to rip out the caps.
- DT Pro Member: 0167
i would say glue on an alps would be the way to go you would pull the slider out of the switch before you could remove the cap , alps are hard enough to get off on there own.
- bhtooefr
- Main keyboard: TEX Shinobi
- Main mouse: TrackPoint IV
- DT Pro Member: 0056
Glue the switch case together, if you're doing Alps.
Don't ask me how I know this. OK, if you must... I once had a Alps switch where the keycap stayed in the slider so tightly that the slider pulled the case apart before it released the keycap.
That said, if I were gluing things... Plate mount Cherry MX. Much less risk of glue getting inside, much more surface area for the keycap to glue to.
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
Poor Alps keyboard … if you have an Alps keyboard that you're going to tip glue into, do it a favour and give it to one of us instead.
Kids who are going to be that destructive are best off left with some rubbish rubber dome anyway.
Edit: I know! NMB dome with slider. Glue those.
- Daniel Beardsmore
Be careful — I don't know that pine black Alps was as bad.
