HyperMicro / Deadline: 2015-03-17 / -32767 days to go! :o
04 Jan 2015, 22:04
Prototype version 0.1
I will order a 2nd prototype series.
:ugeek:
You can also preorder controllers and diodes:
Order-ID      | Price |  Pcs|Description
HYPER/MICRO/P1| 20 EUR|    1|Prototype PCB (5x12)
TEENSY20      | 22 EUR|    1|Teensy 2.0 controller <--- you need this for the HyperMicro!
TEENSY31      | 28 EUR|    1|Teensy 3.1 controller
TEENSYPP      | 32 EUR|    1|Teensy++ 2.0 controller
DIODE10       |  1 EUR|   10|1N4148 diodes (10)
DIODE100      |  3 EUR|  100|1N4148 diodes (100) <--- you need about these many for 2 HyperMicro-s!
DIODE150      |  4 EUR|  150|1N4148 diodes (150)
DIODE500      |  8 EUR|  500|1N4148 diodes (500)
DIODE1K       | 12 EUR| 1000|1N4148 diodes (1k)
DIODE2K       | 23 EUR| 2000|1N4148 diodes (2k)
DIODE5K       | 55 EUR| 5000|1N4148 diodes (5k)
DIODE10K      |105 EUR|10000|1N4148 diodes (10k)
STAB200       |  2 EUR|    1|Cherry plate mount stab 2-2.75u
STAB203       |  5 EUR|    3|Cherry plate mount stab ISO-TKL
STAB204       |  6 EUR|    4|Cherry plate mount stab ANSI-TKL
STAB206       |  8 EUR|    6|Cherry plate mount stab ISO-102
STAB207       |  9 EUR|    7|Cherry plate mount stab ANSI-101
STAB400       |  2 EUR|    1|Cherry plate mount stab 4u
STAB625       |  2 EUR|    1|Cherry plate mount stab 6.25u
STAB700       |  2 EUR|    1|Cherry plate mount stab 7u
Order-ID             |Price |Description
HYPER/MICRO/7BIT     |10 EUR|normal_plate
HYPER/MICRO/ANSI100  |10 EUR|normal_plate
HYPER/MICRO/ANSI400  |10 EUR|normal_plate
HYPER/MICRO/ANSI400M |10 EUR|normal_plate
HYPER/MICRO/ANSI625  |10 EUR|normal_plate
HYPER/MICRO/ANSI700  |10 EUR|normal_plate
HYPER/MICRO/SYM100   |10 EUR|normal_plate
HYPER/MICRO/SYM400   |10 EUR|normal_plate
HYPER/MICRO/SYM700   |10 EUR|normal_plate
HYPER/MICRO/7BITH    |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/ANSI100H |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/ANSI400H |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/ANSI400MH|10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/ANSI625H |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/ANSI700H |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/SYM100H  |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/SYM400H  |10 EUR|plate_with_trackpoint-hole
HYPER/MICRO/SYM700H  |10 EUR|plate_with_trackpoint-hole
:o
All Hyper keyboards for CherryMX switches have the mount holes for PCB-mount switches!
:o
Submitting an order works the usual way,
by pm-ing user CherryMX
HYPER/MICRO/P1
STAB700
TEENSY20
MXCLEAR/NW 45
MXGREY/NW
DIODE100
ypur e-mail address
ADDRESS
your shipping address
with name
street,
town and
country
:roll:
Shipping is 4 EUR, no matter how many PCBs, switches, or key caps you order!
:cool:
quochung1989
Vintage Cherry Collector
06 Jan 2015, 02:33
Where do I study more about Hypermicro?
06 Jan 2015, 09:10
quochung1989
06 Jan 2015, 13:30
06 Jan 2015, 18:56
7bit, how many version 0.1 prototypes are left? What has changed in the 0.2 prototype?
06 Jan 2015, 19:49
0.1 is the one I will order, 0.2 will never exist because I'm fully confident that everything will be OK in version 0.1!
:ugeek:
The differences are:
- corrected switch logic for the mouse-buttons (was alsways closed, unless pressed)
- corrected holes for case (or backplate) mounting (0.0 works OK for most layouts,
- except for those with traditional staggering)
- cosmetic changes (those green fields don't look well in version 0.0)
:o
06 Jan 2015, 19:59
Ah, I thought that the current prototypes were 0.1 already! Great. Will you offer the other parts (mouse buttons, etc) too?
How about the trackpoint? Can I use my own, like one from the IBM Space Saver rubber dome boards?
teuf
06 Jan 2015, 19:59
Do you have a rough estimate for the teensy/diode availability?
06 Jan 2015, 20:14
The trackpoint must fit through the hole, which is a bit less than 7mm in diameter.
I still don't have a cheap source for the buttons.
I will order controllers and other stuff in 2-3 weeks, depending on how many orders I get for the PCBs etc.
06 Jan 2015, 20:18
Interesting. Thanks for the info.
06 Jan 2015, 20:49
Did you measure the trackpoint yet?
I have 5.334mm if a mount plate is used and 7.112mm with only the PCB. If I make the hole wider, the G and H switches will lose stability.
09 Jan 2015, 18:08
I've made it wider!
:o
Now, you all can send in your orders.
:evilgeek:
09 Jan 2015, 18:15
I will get on that tonight. :maverick:
Halvar
09 Jan 2015, 18:57
On my PCB it says "Prototype - Version 0.0 - 2014-08-27" as on the photo above. This still means it's a v0.1 board, right?
09 Jan 2015, 18:59
Yes.
I don't have a photo of the version 0.1 yet.
:roll:
10 Jan 2015, 13:13
scottc wrote: I will get on that tonight. :maverick:
I couldn't find my loose trackpoint last night, so today I will look for my second IBM Space Saver and try to remove the trackpoint from that one.
10 Jan 2015, 13:29
You don't need to!
I already know the dimension!
10 Jan 2015, 14:24
Oh, great! Will it fit? :)
10 Jan 2015, 14:44
The edges of the trackpoint are at most 4mm and the diameter is less than 4*sqrt(2)==5.65685424949238019520mm
The diamenter of the hole in the plate is 6mm.
I've tried with my thinkpad and found out that the trackpoint is not really moving, so this should be fine.
10 Jan 2015, 15:04
Excellent. That's good info. Can't wait to try it.
11 Jan 2015, 14:07
Plates are now available:
HYPER/MICRO/7BIT      |normal plate
HYPER/MICRO/7BITH     |plate with trackpoint-hole
HYPER/MICRO/ANSI100   |normal plate
HYPER/MICRO/ANSI100H  |plate with trackpoint-hole
HYPER/MICRO/ANSI400   |normal plate
HYPER/MICRO/ANSI400H  |plate with trackpoint-hole
HYPER/MICRO/ANSI400M  |normal plate
HYPER/MICRO/ANSI400MH |plate with trackpoint-hole
HYPER/MICRO/ANSI625   |normal plate
HYPER/MICRO/ANSI625H  |plate with trackpoint-hole
HYPER/MICRO/ANSI700   |normal plate
HYPER/MICRO/ANSI700H  |plate with trackpoint-hole
HYPER/MICRO/SYM100    |normal plate
HYPER/MICRO/SYM100H   |plate with trackpoint-hole
HYPER/MICRO/SYM400    |normal plate
HYPER/MICRO/SYM400H   |plate with trackpoint-hole
HYPER/MICRO/SYM700    |normal plate
HYPER/MICRO/SYM700H   |plate with trackpoint-hole
:cry:
Price: 10 EUR each.
:roll:
-[°_°]-
11 Jan 2015, 14:17
10 each?! what material?
11 Jan 2015, 14:30
Aluminium?
HYPER/MICRO/7BITH
HYPER/MICRO/7BIT
HYPER/MICRO/SYM100H
HYPER/MICRO/SYM100
HYPER/MICRO/SYM400H
HYPER/MICRO/SYM400
HYPER/MICRO/SYM700H
HYPER/MICRO/SYM700
HYPER/MICRO/ANSI100
HYPER/MICRO/ANSI625
HYPER/MICRO/ANSI700
-[°_°]-
11 Jan 2015, 15:27
wow pretty cheap, maybe because they are super small. where do you get them at the end?
11 Jan 2015, 15:35
Can you provide images for the different layout types that correspond to the plates? I'm going to have to arrange another bank transfer :o
11 Jan 2015, 17:10
Test:
:roll:
Which looks better:
With or without black framelines?
11 Jan 2015, 17:18
With them, definitely.
12 Jan 2015, 23:28
What is the ETA for HYPER/MICRO/P1? :shock:
13 Jan 2015, 00:04
I've currently got only 2 orders, so I guess it will take a little bit more time ...
13 Jan 2015, 00:15
:( Are there any first-gen prototypes left for me to take instead?
