[Vendor] kbdhub.com - Keyboard Parts Store - Newest Leeku PCBs (support ISO)
I just finished assembling my pcb but i have a small problem.
Two keys don't register (it's not the switches themselves and the diodes work), and the layout of the Numpad section is messed up.
Have any of you tried your PCB's yet? Did they work?
I think I found a firmware update on kbdlab but I'm not shure how to proceed. Could you talk me through the update Azhdar?
elRetto
Unread post28 Jan 2016, 17:43
X
elRetto
Main keyboard: 87UW/ssk
Main mouse: slimblade
DT Pro Member: 0107
derzemel
Unread post28 Jan 2016, 17:51
X
derzemel
Main keyboard: FC660C, SSK, TX-1800 Nixie
Main mouse: Mionix Naos 7000
Favorite switch: Alps SKCL/SKCM tactile
DT Pro Member: -
I feel completely inept. That was the page I'd already found. I put it through google translate, felt confident and tried it. Now when I plug in the keyboard windows 10 says that the USB device is unrecognized. You can switch them between USB and PS2 as far as I know. How do you do that?
elRetto
Unread post28 Jan 2016, 18:04
X
elRetto
DT Pro Member: 0107
on the older Leeku 1800 to connect to PS2 you keep the P pressed down when connecting the board to the PS2 port.
To connect to USB you keep U pressed down.
If the above does not work, try connecting it another computer, eventually to Linux.
If none of the above works, then it means that the PCB's bootloader may have been corrupted (i had the same issue with my older model)
In this case the solution is a bit more complicated because you will need an AVR Programmer to rewrite the bootloader.
If you do not know someone who can help, then I think @flabbergast has experience with this.
I have an electronics knowledgeable friend who had a home-made AVR programmer and he helped me with mine when I received the "USB device is unrecognized" error because I did not really know what to do (and I still don't :lol:):
derzemel
Unread post28 Jan 2016, 18:52
X
derzemel
DT Pro Member: -
thanks for the help. I'l take a closer look next week after my exams. sounds like a piece of work ;)
elRetto
Unread post28 Jan 2016, 19:36
X
elRetto
DT Pro Member: 0107
Got mine too, many thanks!
Madhias
BS TORPE
Unread post03 Feb 2016, 20:51
X
Madhias
BS TORPE
Main keyboard: SSK
Main mouse: Logitech G500
Favorite switch: Topre and Buckelings
DT Pro Member: 0064
Got mine as well a while ago. Anyone got the cad files for a 1800 plate ?
gogusrl
Unread post12 Feb 2016, 12:28
X
gogusrl
Main keyboard: Cherry G80-1851
Main mouse: Logitech G9x
Favorite switch: linear stuff
DT Pro Member: -
Thanks to inlikeflynn from GeekHack I got my hands on the DWG files for 1800 plates.
If anyone needs them, gimme a shout (and don't forget to credit inlikeflynn).
gogusrl
Unread post14 Feb 2016, 15:25
X
gogusrl
DT Pro Member: -
So did everyone receive it alright? my trackings never updated.
Azhdar
Unread post26 Feb 2016, 16:59
X
Azhdar
Main keyboard: LZ-SQ
Main mouse: RAT 5
Favorite switch: Gaterons linear
DT Pro Member: -
As I wrote above I got mine! I have one problem though, that the Numpad ENTER switch does not work. I have already exchanged the switch, but I don't know how I could make a 'bridge' to another switch with a cable? If you know what I want to do... Maybe someone can help?
Madhias
BS TORPE
Unread post26 Feb 2016, 20:59
X
Madhias
BS TORPE
Main keyboard: SSK
DT Pro Member: 0064
check the diode, the diode for B on my pcb is not soldered on one side. easily fixable when I finally get to building it.
gogusrl
Unread post26 Feb 2016, 21:03
X
gogusrl
DT Pro Member: -
From what I saw it should be soldered, or at least it looks like the other ones! Also: I need a multimeter sometimes (as Compgeke told me on IRC right now)! But everything else works, and I am pleased with the result so far.
Madhias
BS TORPE
Unread post26 Feb 2016, 21:07
X
Madhias
BS TORPE
Main keyboard: SSK
DT Pro Member: 0064
this thread needs more pics. did you buy the plate as well ? what case are you using ?
gogusrl
Unread post26 Feb 2016, 21:17
X
gogusrl
DT Pro Member: -
I did not buy the plate! I am going to post some pictures, as soon as I am ready!
I am using a *NIB* Cherry G81-1800 HAD case, and use PCB mounted MX Reds, but I changed the springs, which was not really needed, but I thought I should do something fancy, so I put 55g SPRiT springs into the MX Reds. The space bar is way to heavy now, with a 100g spring!
Madhias
BS TORPE
Unread post26 Feb 2016, 21:19
X
Madhias
BS TORPE
Main keyboard: SSK
DT Pro Member: 0064
I wanted to buy one of these for the case but I was to late : http://www.ebay.de/itm/Cherry-G81-1800L ... 7675.l2557
gogusrl
Unread post26 Feb 2016, 21:26
X
gogusrl
DT Pro Member: -
With the aim of finding one 1800 case that I really liked, I've bought no less than three. The first one was a rather worn 1800HAD. Thought it wouldn't bother me. It did. Next was a Raptor K1. Thought NIB and black would mean that the case was solved. And it was, until those cheapo 1800HAMGB were posted in the great/interesting finds thread the other day. Now I just need to find the time to de-solder, tune and solder switches.
But yeah, Azhdar, as I stated on the previous page, I got the PCB :)
Khers
Unread post26 Feb 2016, 22:08
X
Khers
Main keyboard: HHKB Pro 2
Main mouse: Logitech G900
Favorite switch: Buckling Springs | Topre | Nixdorf Black
DT Pro Member: 0087
Where can we buy the Leeku 3000 PCBs now?
BigTinz
Unread post14 Apr 2016, 22:30
X
BigTinz
Main keyboard: Ducky Legend
Main mouse: Corsair Vengeance M65
Favorite switch: Blue
DT Pro Member: -
I finally got around to soldering the RGB LEDs onto mine, and they don't seem to work. They worked the first time I soldered them, but when I plugged it again they didn't light up.
Tried messing around in the software (JigOn) and still no LEDs.
Wondering if anyone has any experience with this or would know what the problem would be.
Stabilized
Unread post13 May 2016, 09:30
X
Stabilized
DT Pro Member: -
I'm looking for a plate to use with this PCB & a G81-1800 case. Let me know if anyone has some files so I can make one with a laser cutter! :)
equalunique
Unread post22 Feb 2018, 17:52
X
equalunique
Main keyboard: Atreus
Main mouse: Kensington Orbit
Favorite switch: Outemu Ice Click
DT Pro Member: -
gogusrl wrote:Thanks to inlikeflynn from GeekHack I got my hands on the DWG files for 1800 plates.
Hi there,
Do you still have the files for the 1800 plates?
Kind regards,
Max
Skickat från min SHIELD Tablet K1 via Tapatalk
maxpower
Unread post27 Feb 2018, 19:25
X
maxpower
Main keyboard: Ducky Premier
Main mouse: Mionix Naus 3200
Favorite switch: Greens
DT Pro Member: -
Yup. I'll look for them and post them here.
gogusrl
Unread post27 Feb 2018, 21:51
X
gogusrl
DT Pro Member: -
gogusrl
Unread post01 Mar 2018, 13:07
X
gogusrl
DT Pro Member: -
wow, opening links leads to adware. real nice
mike52787
Alps Aficionado
Unread post01 Mar 2018, 18:27
X
mike52787
Alps Aficionado
Main keyboard: I cant decide
Main mouse: Zowie EC1-A
Favorite switch: Vintage MX Black
DT Pro Member: 0166
wut ?
gogusrl
Unread post01 Mar 2018, 19:36
X
gogusrl
DT Pro Member: -
gogusrl wrote:wut ?
Not yours haha, I mean the ones in the op
mike52787
Alps Aficionado
Unread post02 Mar 2018, 02:28
X
mike52787
Alps Aficionado
DT Pro Member: 0166
The OP vanished in thin air after having personal issues few months after setting a shop if recall There were orders that were not being full filled and in the end I don't know if all of those got settled or not.
kokokoy
Unread post02 Mar 2018, 03:31
X
kokokoy
Main keyboard: KIRA EXS
Main mouse: Logitech G304
Favorite switch: Green Alps, Vintage Black
DT Pro Member: 0145
oh, your comment came right after I posted the links and it scared me a bit :)
gogusrl
Unread post02 Mar 2018, 06:15
X
gogusrl
DT Pro Member: -
Thank you very much!
maxpower
Unread post03 Mar 2018, 09:16
X
maxpower
DT Pro Member: -
Previous
Who is online
Users browsing this forum: mind_prepared and 31 guests
