How many KBs are connected at once?
ShivaYash
30 Apr 2018, 15:39
This is totally normal, right? Image
HiPro under the monitor
FC660M mit Cherry MX Greens
IBM Model M SSK
HHKBPro2 BT
The SSK is my daily driver but sometimes change is good.
And yes the desk needs to be tidied.
Wodan
ISO Advocate
30 Apr 2018, 16:08
You can also just connect a Mad Catz S.T.R.I.K.E. 7 and it will technically register as FIVE keyboards :)
This is a much nicer lineup though ;)
jbondeson
30 Apr 2018, 16:27
It's totally normal and don't let anyone tell you otherwise! :lol:
When testing firmware I've overloaded my USB controller by hooking up two WhiteFoxen, a K-Type, an Erogodox Infinity and an IC60 :-?
30 Apr 2018, 19:18
Too bad that Apple does not understand that it is normal. Four USB ports is minimum for a desktop, not maximum.
chuckdee
30 Apr 2018, 19:27
I use 3 (four if you count my g13) so looks totally normal to me.
ShivaYash
01 May 2018, 08:47
Thanks for the replies. Would love to see some photos.
Return to “Off-topic”
