Interesting Lexmark Model M
Half-Saint
05 Oct 2011, 11:19
Recently I picked up an interesting Lexmark Model M from 1994. No Lexmark label on top cover, just an empty square. Made in USA yet the layout is ISO, one-piece key caps. It also has drainage channels and holes. What's interesting to me is that the case has a hole for the SDL connector but the controller PCB doesn't feature one. The PS/2 cable is connected to a very small 4-pin connector.
Interestingly, LEDs do not light up although Caps Lock, Num Lock and Scroll Lock register fine. Used a Blue Cube to connect it to my laptop.
05 Oct 2011, 11:48
Maybe it's a construction of two Model Ms? The case is older than the insides?
daedalus
Buckler Of Springs
05 Oct 2011, 12:38
Before the 42H1292 style Model Ms, fixed cable Model Ms had the same case as the SDL cable keyboards, there was just a piece of plastic on the cable that covered the hole. If yours is missing that piece, then maybe the original cable was damaged and replaced by a third party.
Which ISO layout was it? It wouldn't be uncommon to see Canadian French and Latin American Spanish keyboards that were made in the US.
cactux
05 Oct 2011, 13:06
Half-Saint
05 Oct 2011, 17:14
daedalus wrote:Before the 42H1292 style Model Ms, fixed cable Model Ms had the same case as the SDL cable keyboards, there was just a piece of plastic on the cable that covered the hole. If yours is missing that piece, then maybe the original cable was damaged and replaced by a third party.
Indeed, the keyboard has the small piece of plastic covering the hole.
Mine is Yugoslav ISO layout which is funny because all the other YU ISO boards I have were Made in UK.
Half-Saint
06 Oct 2011, 13:30
Any idea why the LEDs don't work?
Half-Saint
17 Oct 2011, 13:57
Bump.
acfrazier
Mad Scientist
17 Oct 2011, 17:10
Half-Saint wrote:Any idea why the LEDs don't work?
Could be many reasons, but it's difficult to tell without opening it.
In order of likelihood:
Severed/missing connection internally
There aren't any LEDs inside
Burned out LEDs (as in, they had been turned on for more than 50000 hours or about 5.7 years)
Half-Saint
21 Oct 2011, 19:25
Well, connections appear to be intact, LEDs are there. Haven't tested the LEDs individually but I doubt that all three would burn out.
Half-Saint
02 Dec 2011, 14:06
Still no idea to why the LEDs don't work. The board otherwise works fine.
