Dampening the HHKB spacebar?
decayl
07 Dec 2016, 14:43
Hi,
I own the hhkb pro 2, and i have the pbt spacebars from the massdrop groupbuy. the problem is that the spacebar makes a plastic on plastic sound when pressed. I think the tiny round landing pads are not enough so maybe I can replace them.
Does anyone have experience with custom landing pads for the hhkb? which materials? where to buy?
Thank you.
Hking0036
07 Dec 2016, 14:46
I don't know about the hhkb in particular but if it's the bottom out noise that bothers you a thin foam pad at the bottom is supposed to help reduce the sound, since the caps aren't hitting plastic at the bottom.
Menuhin
07 Dec 2016, 17:37
It shouldn't be too noisy. Have you lost your space bar spring?
If the spring is there, perhaps swapping it to a heavier spring? A HHKB replacement spring is at around 80g to bottom out.
face
07 Dec 2016, 19:03
My pbt spacebars were soundy too. Thought it was my personal HHKB since I own the BT version. Try a thin foam pad as Hking suggested, should solve the problem. (I was to lazy to try that.)
