IBM M4-1/spacesaver II cables
Jimi14
25 Jan 2017, 20:21
Found myself an m4-1 some time ago, but it came without cables.
An SDL from an model m seems to work fine for the keyboard, but what do i need to get the trackpoint working as well? connect the mini din or rj45 it also has?
need
26 Jan 2017, 00:48
Yes I think you need to use a split cable
micrex22
26 Jan 2017, 03:11
http://www.pckeyboard.com/page/product/1398094
I'm guessing those would work assuming IBM kept the same pinout
Jimi14
26 Jan 2017, 15:15
ok, thanks.
ohaimark
Kingpin
26 Jan 2017, 15:27
Yep, I think they're multiplexed.
