Wrong input with Leeku 1800 pcb
manna
09 Jun 2017, 23:44
Hello.
I recently soldered all the switches on my Leeku 1800 pcb, and when I press two of them, specifically those needed for the ISO layout, I'm getting the wrong input.
If I press the key on the right of the left shift ( \ on ISO UK) I get a 0, and if I press the switch above the right shift ( / on ISO UK) i get numpad 4.
I tried to flash an updated firmware but it didn't solve the problem.
Hope someone can help, thanks.
Delirious
10 Jun 2017, 06:33
Leeku's default keymap layout is weird, you need to download Jigon and remap your keys to the desire layout. That's all. 2 out of 3 leeku pcb's I got so far have the spacebar mapped to fn before.
manna
10 Jun 2017, 14:39
Yep, it worked. Thanks!
