well other than providing a converter, how an IBM model m terminal keyboard 1392595 can be used today on a normal computer?
i know there are no LEDs, but generally what do i have to do in order to make it usable ??
can i use immediately on a modern PC (after providing a converter) ??
Terminal IBM Model M Usability ?? 1392595
- fohat
- Elder Messenger
- DT Pro Member: 0158
My experience using Soarer's method has been immediate plug-and-play with no additional drama.
Re-mapping keys is also relatively easy if you want or need that.
- Techno Trousers
- 100,000,000 actuations
- Main keyboard: IBM Model F-122
- Main mouse: Mionix Naos
- Favorite switch: Capacitive Buckling Spring (Model F)
- DT Pro Member: 0159
Your absolute plug-and-play simple method would be to reach out to Orihalcon and buy one of his Soarers converter cables. He has versions to fit any of the IBM terminal cable connectors. Just connect it between the end of your keyboard's existing cable and your computer.
to be specific, i am talking about 1392595
