I had an idea of building my own Full Size ALP SKCM Blue mechanical keyboard using a Matias Tactile Pro PCB and custom full size keyboard case. I wonder if someone have same idea as me.
I had look at Nathan Kim's LZ CLS keyboard with ALP blue which give me a possible to make one with ALP SKCM Switches.
(I don't like 64% layout as I prefer a Ginormous size keyboard. )
Matias Tactile Pro + ALP SKCM + Custom case
- cineraphael
- Main keyboard: 1992 IBM Model M
- Main mouse: Apple Pro Mouse
- Favorite switch: ALP SKCM BLUE
- XMIT
- [ XMIT ]
- DT Pro Member: 0093
Alps mods are pretty common. One thing to note is that newer boards use RoHS solder that doesn't melt or flow as easily, so, you'll have a heck of a time desoldering the old switches. But this should work just fine.
- cineraphael
- Menuhin
- Main keyboard: HHKB PD-KB400BN lubed, has Hasu Bt Controller
- Main mouse: How to make scroll ring of Expert Mouse smoother?
- Favorite switch: Gateron ink lubed
Leeku 1800 PCB
Leeku 3000 PCB
Not that I know where to get them now, perhaps some Korean connection?
Leeku 3000 PCB
- Sup
- Main keyboard: Filco Zero/AEK II
- Main mouse: Final Mouse Ultralight black
- Favorite switch: Gateron Red/Gateron Yellow/SKCL Yellow/SKCL green
- cineraphael
Those can only fit a Cherry G80 Case is it?
- Myoth
- Main keyboard: IDB60
- Main mouse: EC1-A
- Favorite switch: Cap BS
pls ;_; it's Alps like Cherry, not CHERRY
- cineraphael
Well, I guess alp deserve all cap because they are the best mechanical switch in the world. I cannot believe gamer have to use a Cherry MX and Rubber dome like Logitech G15 or any early gaming keyboard for gaming when Alp are much better.
