Which box switch?
pingmaster
19 Mar 2019, 04:26
I'm kinda lost on which box switch I should get. I know I like MX blue & brown weighting, I find SKBM grey to be a bit on the heavier side but still pretty nice...so probably 55cN to 60cN. I was thinking either white, jade or pink box switches. Which do you think I should start with...well I should probably get a switch tester to begin with but I'd like to get a bit of a clue first.
whiffysole
20 Mar 2019, 16:34
I'd recommend the White switches as they'd probably be the most familiar coming from MX blues
HC514
20 Mar 2019, 20:35
Box Whites are significantly lighter than MX Blue. Have a look at measurements of them:
Box White
MX Blue
whiffysole
20 Mar 2019, 21:10
My bad then, didn't realize they were so light
Telstar
22 Mar 2019, 03:12
Try these: pale blue, jades, pink. Whites are too light.
samuelcable
22 Mar 2019, 03:16
Id recommend pinks
amd9
22 Mar 2019, 18:16
Noble yellows are also quite good - feel a little more tactile than pink (which I would also recommend) to me, and a little lighter.
